Page 3 sur 5
Re: 2 petits soucis aprés installation du plugin
Publié : 23 mars 2022, 23:02
par taz5962
2022-03-23 22:59:39.809 Status: Domoticz V2022.1 (c)2012-2022 GizMoCuz
2022-03-23 22:59:39.809 Status: Build Hash: c9526851b, Date: 2022-01-31 09:34:32
2022-03-23 22:59:39.809 Status: Startup Path: /home/pi/domoticz/
2022-03-23 22:59:40.805 Sunrise: 06:43:00 SunSet: 19:05:00
2022-03-23 22:59:40.805 Day length: 12:22:00 Sun at south: 12:54:00
2022-03-23 22:59:40.805 Civil twilight start: 06:11:00 Civil twilight end: 19:38:00
2022-03-23 22:59:40.805 Nautical twilight start: 05:32:00 Nautical twilight end: 20:16:00
2022-03-23 22:59:40.805 Astronomical twilight start: 04:51:00 Astronomical twilight end: 20:57:00
2022-03-23 22:59:44.142 Active notification Subsystems: (0/13)
2022-03-23 22:59:44.420 Starting shared server on: :::8147
2022-03-23 22:59:44.055 Status: PluginSystem: Started, Python version '3.7.3', 3 plugin definitions loaded.
2022-03-23 22:59:44.270 Status: WebServer(HTTP) started on address: :: with port 8007
2022-03-23 22:59:44.376 Status: WebServer(SSL) started on address: :: with port 878
2022-03-23 22:59:44.420 Status: TCPServer: shared server started...
2022-03-23 22:59:44.420 Status: RxQueue: queue worker started...
2022-03-23 22:59:46.545 SonoffZigBee: Worker thread started.
2022-03-23 22:59:46.477 Status: RPI_Monitoring: System: Raspberry Pi
2022-03-23 22:59:46.512 Status: RPI_Monitoring: Hardware Monitor: Started (OStype Raspberry Pi Linux)
2022-03-23 22:59:46.544 Status: Meteo: Using specified location (Lon 3.13308, Lat 50.61829) Unable to find nearest City!
2022-03-23 22:59:46.545 Status: Meteo: Started
2022-03-23 22:59:46.545 Status: SonoffZigBee: Entering work loop.
2022-03-23 22:59:46.545 Status: SonoffZigBee: Started.
2022-03-23 22:59:46.545 Status: NotificationSystem: thread started...
2022-03-23 22:59:46.571 Status: EventSystem: reset all events...
2022-03-23 22:59:46.649 Status: EventSystem: reset all device statuses...
2022-03-23 22:59:46.773 Status: PluginSystem: 1 plugins started.
2022-03-23 22:59:46.544 Error: Meteo: Error getting http data!
2022-03-23 22:59:47.054 Status: Python EventSystem: Initializing event module.
2022-03-23 22:59:47.054 Status: EventSystem: Started
2022-03-23 22:59:47.054 Status: EventSystem: Queue thread started...
2022-03-23 22:59:48.544 RPI_Monitoring: Temp (Temperature_CPU)
2022-03-23 22:59:58.556 RPI_Monitoring: General/Custom Sensor (Arm Clock Speed)
2022-03-23 22:59:58.571 RPI_Monitoring: General/Custom Sensor (V3D Clock Speed)
2022-03-23 22:59:58.584 RPI_Monitoring: General/Custom Sensor (Core Clock Speed)
2022-03-23 22:59:59.229 Meteo: General/Text (Previsions_Meteo)
2022-03-23 22:59:59.233 Meteo: Temp + Humidity + Baro (Temperature_Humidité_Barometre)
2022-03-23 22:59:59.237 Meteo: Temp (Temperature_Ressentie)
2022-03-23 22:59:59.245 Meteo: Wind (Vent)
2022-03-23 22:59:59.250 Meteo: UV (Index_UV)
2022-03-23 22:59:59.251 Meteo: General/Visibility (Visibility)
2022-03-23 22:59:59.254 Meteo: General/Percentage (Prevision_Nuageuse)
2022-03-23 22:59:59.287 Meteo: Rain (Prevision_Precipitation)
2022-03-23 23:00:01.088 Status: Starting automatic database backup procedure...
2022-03-23 23:00:41.982 Status: SonoffZigBee: Initialized version 6.0, author 'pipiche38'
2022-03-23 23:00:42.199 SonoffZigBee: Zigbee for Domoticz plugin started!
2022-03-23 23:00:42.221 SonoffZigBee: load PluginConf
2022-03-23 23:00:42.242 SonoffZigBee: is_domoticz_db_available: Fashion: True , Major: 2022, Minor: 1
2022-03-23 23:00:42.242 SonoffZigBee: is_domoticz_db_available: True
2022-03-23 23:00:42.244 SonoffZigBee: Starting LoggingManagement thread
2022-03-23 23:00:42.244 SonoffZigBee: start_logging_thread
2022-03-23 23:00:42.245 SonoffZigBee: logging_thread - listening
2022-03-23 23:00:42.170 Status: Ending automatic database backup procedure...
2022-03-23 23:00:42.243 Status: SonoffZigBee: filename set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Conf/PluginConf-04.json
2022-03-23 23:00:42.243 Status: SonoffZigBee: pluginHome set to /home/pi/domoticz/plugins/Domoticz-Zigbee/
2022-03-23 23:00:42.243 Status: SonoffZigBee: homedirectory set to /home/pi/domoticz/plugins/Domoticz-Zigbee/
2022-03-23 23:00:42.243 Status: SonoffZigBee: pluginData set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Data/
2022-03-23 23:00:42.243 Status: SonoffZigBee: pluginConfig set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Conf/
2022-03-23 23:00:42.243 Status: SonoffZigBee: pluginOTAFirmware set to /home/pi/domoticz/plugins/Domoticz-Zigbee/OTAFirmware/
2022-03-23 23:00:42.243 Status: SonoffZigBee: pluginReports set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Reports/
2022-03-23 23:00:42.243 Status: SonoffZigBee: pluginWWW set to /home/pi/domoticz/plugins/Domoticz-Zigbee/www/
2022-03-23 23:00:42.243 Status: SonoffZigBee: pluginLogs set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Logs/
2022-03-23 23:00:42.245 Status: SonoffZigBee: Please watch plugin log into /home/pi/domoticz/plugins/Domoticz-Zigbee/Logs//PluginZigbee_04.log
2022-03-23 23:00:42.266 Status: SonoffZigBee: Log history not found, no error logged
2022-03-23 23:00:42.271 Status: SonoffZigBee: Zigate plugin beta6-6.0.124 started
2022-03-23 23:00:42.342 Status: SonoffZigBee: DeviceConf loaded - 23 confs loaded
2022-03-23 23:00:43.779 SonoffZigBee: is_domoticz_db_available: Fashion: True , Major: 2022, Minor: 1
2022-03-23 23:00:43.780 SonoffZigBee: is_domoticz_db_available: True
2022-03-23 23:00:43.782 Status: SonoffZigBee: DeviceConf loaded - 330 confs loaded
2022-03-23 23:00:43.783 Status: SonoffZigBee: load ListOfDevice
2022-03-23 23:00:43.790 Status: SonoffZigBee: Transport mode: ZigpyZNP
2022-03-23 23:00:44.324 RPI_Monitoring: General/Percentage (Usage_RAM)
2022-03-23 23:00:44.325 RPI_Monitoring: General/Custom Sensor (Process Usage)
2022-03-23 23:00:49.119 SonoffZigBee: Start Zigpy Transport on ZNP
2022-03-23 23:00:49.128 Status: SonoffZigBee: ZigpyTransport: thread_processing_and_sending Thread start.
2022-03-23 23:00:49.129 Status: SonoffZigBee: Start Web Server connection
2022-03-23 23:00:49.159 Status: SonoffZigBee: Web backend for Web User Interface started on port: 9440
2022-03-23 23:00:54.358 RPI_Monitoring: General/Percentage (Usage_HDD)
2022-03-23 23:00:54.370 RPI_Monitoring: General/Percentage (Usage_HDD_Boot)
2022-03-23 23:01:04.382 RPI_Monitoring: General/Percentage (Usage_CPU)
2022-03-23 23:01:04.414 RPI_Monitoring: General/Custom Sensor (Arm Clock Speed)
2022-03-23 23:01:04.463 RPI_Monitoring: General/Custom Sensor (V3D Clock Speed)
2022-03-23 23:01:04.483 RPI_Monitoring: General/Custom Sensor (Core Clock Speed)
Publié : 23 mars 2022, 23:05
par taz5962
cool j'ai accés a l'interface web
apparemment ca fonctionne alors ?
peu tu me dire comment mettre ces balise comme tu l'a modifier ?
Tu as coupé les logs trop tôt.
Tu n'as pas une ligne Plugin with XXXXX, firmware XXXXX correctly initialized ?
Edit : Pour les balises code, regarde les boutons au-dessus de la zone de rédaction des messages.
Le bandeau en bas de l'interface Web du plugin (webUI) est de quelle couleur ? Vert ?
Publié : 23 mars 2022, 23:18
par taz5962
je ne comprends pas pourquoi tu me dis que je coupe les logs trop tôt
je ne coupe rien les logs continues a tourner
par contre je vois pas la ligne que tu cherche
le bandeau est bien vert
2022-03-23 23:01:09.064 Status: SonoffZigBee: Accepting new Hardware: Disable (Off)
2022-03-23 23:01:21.037 Status: SonoffZigBee: Number of devices recently active in Zigate = 0
2022-03-23 23:01:21.040 Status: SonoffZigBee: Initialize Zigate Data Structure 0000 00124b0024c99757
2022-03-23 23:01:21.048 Status: SonoffZigBee: CC1352/CC2652, Z-Stack 3.30+ (znp)
2022-03-23 23:01:21.055 Status: SonoffZigBee: Updating Channel in Plugin Configuration from: 0 to: 11
2022-03-23 23:01:21.056 Status: SonoffZigBee: Installer Version Number: 1217
2022-03-23 23:01:21.063 Status: SonoffZigBee: Branch Version: ==> CC1352/CC2652, Z-Stack 3.30+ (znp) <==
2022-03-23 23:01:21.115 Status: SonoffZigBee: Zigbee Coordinator ieee: 00124b0024c99757 , short addr: 0000
2022-03-23 23:01:21.121 Status: SonoffZigBee: Network state UP, PANID: 1a62 extPANID: 0x00124b0024c99757 Channel: 11
2022-03-23 23:01:28.085 Status: SonoffZigBee: Request Disabling Accepting new Hardware
2022-03-23 23:01:28.126 Status: SonoffZigBee: Accepting new Hardware: Disable (Off)
2022-03-23 23:01:33.150 Status: SonoffZigBee: Zigate set to Certification : 1/CE -> CE
2022-03-23 23:01:33.171 Status: SonoffZigBee: Plugin with ZNP, firmware 21-1217 correctly initialized
2022-03-23 23:07:27.697 Error: SonoffZigBee: No transport, write directive to '192.168.1.10:53106' ignored.
2022-03-23 23:07:27.698 Error: SonoffZigBee: No transport, write directive to '192.168.1.10:53013' ignored.
2022-03-23 23:07:53.116 Status: SonoffZigBee: Request Accepting new Hardware for 240 seconds
2022-03-23 23:07:53.207 Status: SonoffZigBee: Accepting new Hardware: Enable (On)
2022-03-23 23:08:35.949 RPI_Monitoring: General/Percentage (Usage_CPU)
2022-03-23 23:08:35.959 RPI_Monitoring: General/Custom Sensor (Arm Clock Speed)
2022-03-23 23:08:35.987 RPI_Monitoring: General/Custom Sensor (V3D Clock Speed)
2022-03-23 23:08:36.011 RPI_Monitoring: General/Custom Sensor (Core Clock Speed)
2022-03-23 23:08:46.016 RPI_Monitoring: General/Percentage (Usage_RAM)
2022-03-23 23:08:46.020 RPI_Monitoring: General/Custom Sensor (Process Usage)
2022-03-23 23:09:04.487 SonoffZigBee: Enable Assisted pairing
2022-03-23 23:09:04.542 SonoffZigBee: Assisted Pairing: Polling: []
2022-03-23 23:09:04.542 SonoffZigBee: --> Empty queue
2022-03-23 23:09:04.490 Status: SonoffZigBee: Request Accepting new Hardware for 240 seconds
2022-03-23 23:09:06.035 RPI_Monitoring: General/Percentage (Usage_CPU)
2022-03-23 23:09:06.067 RPI_Monitoring: General/Custom Sensor (Arm Clock Speed)
2022-03-23 23:09:06.099 RPI_Monitoring: General/Custom Sensor (V3D Clock Speed)
2022-03-23 23:09:06.121 RPI_Monitoring: General/Custom Sensor (Core Clock Speed)
2022-03-23 23:09:14.816 SonoffZigBee: Assisted Pairing: Polling: []
2022-03-23 23:09:14.816 SonoffZigBee: --> Empty queue
2022-03-23 23:09:24.688 SonoffZigBee: Assisted Pairing: Polling: []
2022-03-23 23:09:24.688 SonoffZigBee: --> Empty queue
2022-03-23 23:09:26.155 RPI_Monitoring: General/Percentage (Usage_HDD)
2022-03-23 23:09:26.165 RPI_Monitoring: General/Percentage (Usage_HDD_Boot)
2022-03-23 23:09:34.813 SonoffZigBee: Assisted Pairing: Polling: []
2022-03-23 23:09:34.813 SonoffZigBee: --> Empty queue
2022-03-23 23:09:36.170 RPI_Monitoring: General/Percentage (Usage_CPU)
2022-03-23 23:09:36.201 RPI_Monitoring: General/Custom Sensor (Arm Clock Speed)
2022-03-23 23:09:36.234 RPI_Monitoring: General/Custom Sensor (V3D Clock Speed)
2022-03-23 23:09:36.256 RPI_Monitoring: General/Custom Sensor (Core Clock Speed)
2022-03-23 23:09:44.587 SonoffZigBee: Assisted Pairing: Polling: []
2022-03-23 23:09:44.587 SonoffZigBee: --> Empty queue
2022-03-23 23:09:46.279 RPI_Monitoring: Temp (Temperature_CPU)
2022-03-23 23:09:54.769 SonoffZigBee: Assisted Pairing: Polling: []
2022-03-23 23:09:54.769 SonoffZigBee: --> Empty queue
2022-03-23 23:10:02.888 SonoffZigBee: Disable Assisted pairing
2022-03-23 23:10:02.891 Status: SonoffZigBee: Request Disabling Accepting new Hardware
2022-03-23 23:10:03.013 Status: SonoffZigBee: Accepting new Hardware: Disable (Off)
2022-03-23 23:10:06.289 RPI_Monitoring: General/Percentage (Usage_CPU)
2022-03-23 23:10:06.305 RPI_Monitoring: General/Custom Sensor (Arm Clock Speed)
2022-03-23 23:10:06.327 RPI_Monitoring: General/Custom Sensor (V3D Clock Speed)
2022-03-23 23:10:06.344 RPI_Monitoring: General/Custom Sensor (Core Clock Speed)
2022-03-23 23:10:06.352 RPI_Monitoring: General/Percentage (Usage_RAM)
2022-03-23 23:10:06.356 RPI_Monitoring: General/Custom Sensor (Process Usage)
2022-03-23 23:10:35.833 Meteo: General/Text (Previsions_Meteo)
2022-03-23 23:10:35.840 Meteo: Temp + Humidity + Baro (Temperature_Humidité_Barometre)
2022-03-23 23:10:35.847 Meteo: Temp (Temperature_Ressentie)
2022-03-23 23:10:35.855 Meteo: Wind (Vent)
2022-03-23 23:10:35.862 Meteo: UV (Index_UV)
2022-03-23 23:10:35.866 Meteo: General/Visibility (Visibility)
2022-03-23 23:10:35.872 Meteo: General/Percentage (Prevision_Nuageuse)
2022-03-23 23:10:35.884 Meteo: Rain (Prevision_Precipitation)
2022-03-23 23:10:36.365 RPI_Monitoring: General/Percentage (Usage_CPU)
2022-03-23 23:10:36.392 RPI_Monitoring: General/Custom Sensor (Arm Clock Speed)
2022-03-23 23:10:36.425 RPI_Monitoring: General/Custom Sensor (V3D Clock Speed)
2022-03-23 23:10:36.450 RPI_Monitoring: General/Custom Sensor (Core Clock Speed)
2022-03-23 23:10:50.365 SonoffZigBee: Enable Assisted pairing
2022-03-23 23:10:50.421 SonoffZigBee: Assisted Pairing: Polling: []
2022-03-23 23:10:50.421 SonoffZigBee: --> Empty queue
2022-03-23 23:10:50.371 Status: SonoffZigBee: Request Accepting new Hardware for 240 seconds
2022-03-23 23:10:50.424 Status: SonoffZigBee: Accepting new Hardware: Enable (On)
2022-03-23 23:10:56.474 RPI_Monitoring: Temp (Temperature_CPU)
2022-03-23 23:11:00.395 SonoffZigBee: Assisted Pairing: Polling: []
2022-03-23 23:11:00.395 SonoffZigBee: --> Empty queue
2022-03-23 23:11:06.484 RPI_Monitoring: General/Percentage (Usage_CPU)
2022-03-23 23:11:06.505 RPI_Monitoring: General/Custom Sensor (Arm Clock Speed)
2022-03-23 23:11:06.532 RPI_Monitoring: General/Custom Sensor (V3D Clock Speed)
2022-03-23 23:11:06.552 RPI_Monitoring: General/Custom Sensor (Core Clock Speed)
2022-03-23 23:11:10.418 SonoffZigBee: Assisted Pairing: Polling: []
2022-03-23 23:11:10.418 SonoffZigBee: --> Empty queue
2022-03-23 23:11:20.441 SonoffZigBee: Assisted Pairing: Polling: []
2022-03-23 23:11:20.441 SonoffZigBee: --> Empty queue
2022-03-23 23:11:26.558 RPI_Monitoring: General/Percentage (Usage_RAM)
2022-03-23 23:11:26.562 RPI_Monitoring: General/Custom Sensor (Process Usage)
2022-03-23 23:11:30.417 SonoffZigBee: Assisted Pairing: Polling: []
2022-03-23 23:11:30.417 SonoffZigBee: --> Empty queue
2022-03-23 23:11:33.074 SonoffZigBee: Disable Assisted pairing
2022-03-23 23:11:33.078 Status: SonoffZigBee: Request Disabling Accepting new Hardware
2022-03-23 23:11:33.190 Status: SonoffZigBee: Accepting new Hardware: Disable (Off)
2022-03-23 23:11:36.575 RPI_Monitoring: General/Percentage (Usage_CPU)
2022-03-23 23:11:36.605 RPI_Monitoring: General/Custom Sensor (Arm Clock Speed)
2022-03-23 23:11:36.642 RPI_Monitoring: General/Custom Sensor (V3D Clock Speed)
2022-03-23 23:11:36.662 RPI_Monitoring: General/Custom Sensor (Core Clock Speed)
2022-03-23 23:11:53.667 Status: SonoffZigBee: Request Disabling Accepting new Hardware
2022-03-23 23:12:06.693 RPI_Monitoring: Temp (Temperature_CPU)
2022-03-23 23:12:06.704 RPI_Monitoring: General/Percentage (Usage_CPU)
2022-03-23 23:12:06.715 RPI_Monitoring: General/Custom Sensor (Arm Clock Speed)
2022-03-23 23:12:06.731 RPI_Monitoring: General/Custom Sensor (V3D Clock Speed)
2022-03-23 23:12:06.745 RPI_Monitoring: General/Custom Sensor (Core Clock Speed)
2022-03-23 23:12:16.777 RPI_Monitoring: General/Percentage (Usage_HDD)
2022-03-23 23:12:16.793 RPI_Monitoring: General/Percentage (Usage_HDD_Boot)
2022-03-23 23:12:36.782 RPI_Monitoring: General/Percentage (Usage_CPU)
2022-03-23 23:12:36.798 RPI_Monitoring: General/Custom Sensor (Arm Clock Speed)
2022-03-23 23:12:36.818 RPI_Monitoring: General/Custom Sensor (V3D Clock Speed)
2022-03-23 23:12:36.833 RPI_Monitoring: General/Custom Sensor (Core Clock Speed)
2022-03-23 23:12:46.842 RPI_Monitoring: General/Percentage (Usage_RAM)
2022-03-23 23:12:46.850 RPI_Monitoring: General/Custom Sensor (Process Usage)
2022-03-23 23:13:04.949 Status: SonoffZigBee: Request Accepting new Hardware for 240 seconds
2022-03-23 23:13:05.078 Status: SonoffZigBee: Accepting new Hardware: Enable (On)
2022-03-23 23:13:06.856 RPI_Monitoring: General/Percentage (Usage_CPU)
2022-03-23 23:13:06.882 RPI_Monitoring: General/Custom Sensor (Arm Clock Speed)
2022-03-23 23:13:06.914 RPI_Monitoring: General/Custom Sensor (V3D Clock Speed)
2022-03-23 23:13:06.939 RPI_Monitoring: General/Custom Sensor (Core Clock Speed)
2022-03-23 23:13:16.969 RPI_Monitoring: Temp (Temperature_CPU)
2022-03-23 23:13:36.985 RPI_Monitoring: General/Percentage (Usage_CPU)
2022-03-23 23:13:37.014 RPI_Monitoring: General/Custom Sensor (Arm Clock Speed)
2022-03-23 23:13:37.044 RPI_Monitoring: General/Custom Sensor (V3D Clock Speed)
2022-03-23 23:13:37.066 RPI_Monitoring: General/Custom Sensor (Core Clock Speed)
2022-03-23 23:14:07.082 RPI_Monitoring: General/Percentage (Usage_CPU)
2022-03-23 23:14:07.104 RPI_Monitoring: General/Custom Sensor (Arm Clock Speed)
2022-03-23 23:14:07.128 RPI_Monitoring: General/Custom Sensor (V3D Clock Speed)
2022-03-23 23:14:07.147 RPI_Monitoring: General/Custom Sensor (Core Clock Speed)
2022-03-23 23:14:07.157 RPI_Monitoring: General/Percentage (Usage_RAM)
2022-03-23 23:14:07.162 RPI_Monitoring: General/Custom Sensor (Process Usage)
2022-03-23 23:14:27.193 RPI_Monitoring: Temp (Temperature_CPU)
2022-03-23 23:14:37.195 RPI_Monitoring: General/Percentage (Usage_CPU)
2022-03-23 23:14:37.212 RPI_Monitoring: General/Custom Sensor (Arm Clock Speed)
2022-03-23 23:14:37.231 RPI_Monitoring: General/Custom Sensor (V3D Clock Speed)
2022-03-23 23:14:37.245 RPI_Monitoring: General/Custom Sensor (Core Clock Speed)
2022-03-23 23:15:07.267 RPI_Monitoring: General/Percentage (Usage_CPU)
2022-03-23 23:15:07.295 RPI_Monitoring: General/Custom Sensor (Arm Clock Speed)
2022-03-23 23:15:07.323 RPI_Monitoring: General/Custom Sensor (V3D Clock Speed)
2022-03-23 23:15:07.352 RPI_Monitoring: General/Custom Sensor (Core Clock Speed)
2022-03-23 23:15:07.376 RPI_Monitoring: General/Percentage (Usage_HDD)
2022-03-23 23:15:07.386 RPI_Monitoring: General/Percentage (Usage_HDD_Boot)
2022-03-23 23:15:27.378 RPI_Monitoring: General/Percentage (Usage_RAM)
2022-03-23 23:15:27.382 RPI_Monitoring: General/Custom Sensor (Process Usage)
2022-03-23 23:15:36.303 Meteo: General/Text (Previsions_Meteo)
2022-03-23 23:15:36.311 Meteo: Temp + Humidity + Baro (Temperature_Humidité_Barometre)
2022-03-23 23:15:36.318 Meteo: Temp (Temperature_Ressentie)
2022-03-23 23:15:36.325 Meteo: Wind (Vent)
2022-03-23 23:15:36.331 Meteo: UV (Index_UV)
2022-03-23 23:15:36.335 Meteo: General/Visibility (Visibility)
2022-03-23 23:15:36.342 Meteo: General/Percentage (Prevision_Nuageuse)
2022-03-23 23:15:36.353 Meteo: Rain (Prevision_Precipitation)
2022-03-23 23:15:37.417 RPI_Monitoring: Temp (Temperature_CPU)
2022-03-23 23:15:37.430 RPI_Monitoring: General/Percentage (Usage_CPU)
2022-03-23 23:15:37.445 RPI_Monitoring: General/Custom Sensor (Arm Clock Speed)
2022-03-23 23:15:37.472 RPI_Monitoring: General/Custom Sensor (V3D Clock Speed)
2022-03-23 23:15:37.493 RPI_Monitoring: General/Custom Sensor (Core Clock Speed)
2022-03-23 23:16:07.515 RPI_Monitoring: General/Percentage (Usage_CPU)
2022-03-23 23:16:07.544 RPI_Monitoring: General/Custom Sensor (Arm Clock Speed)
2022-03-23 23:16:07.574 RPI_Monitoring: General/Custom Sensor (V3D Clock Speed)
2022-03-23 23:16:07.597 RPI_Monitoring: General/Custom Sensor (Core Clock Speed)
2022-03-23 23:16:37.610 RPI_Monitoring: General/Percentage (Usage_CPU)
2022-03-23 23:16:37.630 RPI_Monitoring: General/Custom Sensor (Arm Clock Speed)
2022-03-23 23:16:37.650 RPI_Monitoring: General/Custom Sensor (V3D Clock Speed)
2022-03-23 23:16:37.664 RPI_Monitoring: General/Custom Sensor (Core Clock Speed)
2022-03-23 23:16:47.708 RPI_Monitoring: Temp (Temperature_CPU)
2022-03-23 23:16:47.722 RPI_Monitoring: General/Percentage (Usage_RAM)
2022-03-23 23:16:47.730 RPI_Monitoring: General/Custom Sensor (Process Usage)
2022-03-23 23:17:07.713 RPI_Monitoring: General/Percentage (Usage_CPU)
2022-03-23 23:17:07.729 RPI_Monitoring: General/Custom Sensor (Arm Clock Speed)
2022-03-23 23:17:07.749 RPI_Monitoring: General/Custom Sensor (V3D Clock Speed)
2022-03-23 23:17:07.764 RPI_Monitoring: General/Custom Sensor (Core Clock Speed)
2022-03-23 23:17:37.786 RPI_Monitoring: General/Percentage (Usage_CPU)
2022-03-23 23:17:37.816 RPI_Monitoring: General/Custom Sensor (Arm Clock Speed)
2022-03-23 23:17:37.843 RPI_Monitoring: General/Custom Sensor (V3D Clock Speed)
2022-03-23 23:17:37.862 RPI_Monitoring: General/Custom Sensor (Core Clock Speed)
Publié : 23 mars 2022, 23:28
Oui mais on n'avait pas les infos jusqu'à :
Au moins, pour l'installation ça semble bon.
Pour infos, tu peux régler le niveau de log par matériel : Info / Status / Erreur. Cela te permettra d'éviter d'avoir des plugins trop bavards
Tu as pu appairer des objets ?
Publié : 23 mars 2022, 23:33
par taz5962
pour le réglage tu veux certainement parler des infos envoyer par le monitoring et la météo ?
j'ai essayé d'appairer avec plusieurs capteurs, bouton mais malgré le reset ou le maintien du bouton pour certain, ils n'ont pas l'air d’être détecter
Publié : 23 mars 2022, 23:40
Oui je pensais au monitoring et à la météo qui semble beaucoup causer.
Quand tu appuis sur les boutons, le voyant de l'objet indique qu'il se met en mode appairage ? Quelques fois, ça peut prendre 20-30 secondes pour que l'assistant d'appairage affiche les infos. L'info remonte plus vite dans les logs.
Publié : 23 mars 2022, 23:44
par taz5962
oui oui la LED des boutons ou capteurs clignote bien pour dire qu'il sont passé en appairage
ce sont que des capteurs et boutons de chez sonoff
j'ai essayé avec le bouton sans fil, un détecteur de mouvement, un capteur T°/Humidité et un sensor d'ouverture de porte/fenêtre mais rien a faire je lance l’appairage sur l'interface et lance le reset sur chaque device mais l'appairage ne fait que tourner
Publié : 24 mars 2022, 09:04
par pipiche
taz5962 a écrit : 23 mars 2022, 22:47
d’où sort l'adresse IP 192.168.1.10 dans les statuts, car mon pi n'est pas du tout sur cette adresse IP
ton pi probablement pas, pas ton client (là où se trouve ton browser probablement oui)
depuis le répertoire du plugin peux-tu faire la commande
si le résultat est :
total 0
alors effectues la commande
git config --add submodule.recurse true
git submodule update --init --recursive
Peux-tu ensuite faire la commande
et copier ici le résultat
Publié : 24 mars 2022, 14:26
par taz5962
- Capture56.JPG (82.67 Kio) Consulté 1678 fois
voici le résultat de la 1ere commande, vu que le total n'est pas 0 je n'ai pas continuer les autres en attendant ton retour
