[Résolu] Zigbee sur domoticz
audi68
Re: Zigbee sur domoticz
Message par audi68 »
oui j’ai mis ça.
Le model est ZBDongle-P
Il faut que dans les settings de Domoticz tu autorises l'access libre ( sans user/password) a localhost 127.0.0.1
Screenshot 2022-12-04 at 13.10.12.png (39.78 Kio) Consulté 1231 fois
audi68
Merci pour ton aide je viens rajouter l’accès 127.0.0.* mais toujours une erreur
2022-12-04 16:55:41.454 Status: zibgee: Checking Python modules /home/jeedom/domoticz/plugins/Domoticz-Zigbee/requirements.txt
2022-12-04 16:55:41.610 Status: zibgee: filename set to /home/jeedom/domoticz/plugins/Domoticz-Zigbee/Conf/PluginConf-09.json
2022-12-04 16:55:41.611 Status: zibgee: pluginHome set to /home/jeedom/domoticz/plugins/Domoticz-Zigbee/
2022-12-04 16:55:41.611 Status: zibgee: homedirectory set to /home/jeedom/domoticz/plugins/Domoticz-Zigbee/
2022-12-04 16:55:41.611 Status: zibgee: pluginData set to /home/jeedom/domoticz/plugins/Domoticz-Zigbee/Data/
2022-12-04 16:55:41.611 Status: zibgee: pluginConfig set to /home/jeedom/domoticz/plugins/Domoticz-Zigbee/Conf/
2022-12-04 16:55:41.611 Status: zibgee: pluginOTAFirmware set to /home/jeedom/domoticz/plugins/Domoticz-Zigbee/OTAFirmware/
2022-12-04 16:55:41.611 Status: zibgee: pluginReports set to /home/jeedom/domoticz/plugins/Domoticz-Zigbee/Reports/
2022-12-04 16:55:41.611 Status: zibgee: pluginWWW set to /home/jeedom/domoticz/plugins/Domoticz-Zigbee/www/
2022-12-04 16:55:41.611 Status: zibgee: pluginLogs set to /home/jeedom/domoticz/plugins/Domoticz-Zigbee/Logs/
2022-12-04 16:55:41.616 Status: zibgee: Please watch plugin log into /home/jeedom/domoticz/plugins/Domoticz-Zigbee/Logs//PluginZigbee_09.log
2022-12-04 16:55:41.630 Status: zibgee: Zigbee for Domoticz (z4d) plugin stable6-6.3.006 started
2022-12-04 16:55:41.640 Status: Incoming connection from: 127.0.0.1
2022-12-04 16:55:41.645 Status: zibgee: Multi instances plugin detected. Enable zigpy workaround
2022-12-04 16:55:41.666 Status: zibgee: DeviceConf loaded - 22 confs loaded
2022-12-04 16:55:41.931 Status: zibgee: DeviceConf loaded - 369 confs loaded
2022-12-04 16:55:41.931 Status: zibgee: load ListOfDevice
2022-12-04 16:55:41.933 Status: zibgee: 0 Entries loaded from /home/jeedom/domoticz/plugins/Domoticz-Zigbee/Data/DeviceList-9.txt
2022-12-04 16:55:41.940 Status: zibgee: Transport mode: ZigpyEZSP
2022-12-04 16:55:41.937 Error: zibgee: Call to function 'onStart' failed, exception details:
2022-12-04 16:55:41.942 Error: zibgee: Traceback (most recent call last):
2022-12-04 16:55:41.942 Error: zibgee: File "/home/jeedom/domoticz/plugins/Domoticz-Zigbee/plugin.py", line 1562, in onStart
2022-12-04 16:55:41.942 Error: zibgee: _plugin.onStart()
2022-12-04 16:55:41.942 Error: zibgee: File "/home/jeedom/domoticz/plugins/Domoticz-Zigbee/plugin.py", line 581, in onStart
2022-12-04 16:55:41.942 Error: zibgee: import bellows
2022-12-04 16:55:41.942 Error: zibgee: ModuleNotFoundError: No module named 'bellows'
2022-12-04 16:57:10.062 Error: zibgee: [ 90] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-12-04 16:57:20.082 Error: zibgee: [100] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-12-04 16:57:30.054 Error: zibgee: [110] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-12-04 16:57:40.074 Error: zibgee: [120] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
Il y a une erreur avec les modules.
Tu peux faire la commande sudo pip3 install -r requirements.txt dans le dossier du plugin et nous copier le résultat ici.
Ton modèle est ZBDongle-P doncTexas Instrument ==> ZNP. Pas SiliconLabs. Le SiliconLabs indiqué dans ta commande USB est, en faite, pour la partie USB et non la partie ZigBee.
audi68
je dois aller dans le dossier domoticz/plugings/Domoticz-Zigbee c'est ça?
jeedom@raspberrypi:~/domoticz/plugins $ cd Domoticz-Zigbee
jeedom@raspberrypi:~/domoticz/plugins/Domoticz-Zigbee $ sudo pip3 install -r requirements.txt
Ignoring pyserial-asyncio: markers 'platform_system == "Windows"' don't match your environment
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Requirement already satisfied: aiohttp in /usr/local/lib/python3.7/dist-packages (from -r requirements.txt (line 1)) (3.8.3)
Requirement already satisfied: aiosignal in /usr/local/lib/python3.7/dist-packages (from -r requirements.txt (line 2)) (1.3.1)
Requirement already satisfied: aiosqlite>=0.16.0 in /usr/local/lib/python3.7/dist-packages (from -r requirements.txt (line 3)) (0.17.0)
Requirement already satisfied: async-timeout in /usr/local/lib/python3.7/dist-packages (from -r requirements.txt (line 4)) (4.0.2)
Requirement already satisfied: attrs in /usr/local/lib/python3.7/dist-packages (from -r requirements.txt (line 5)) (22.1.0)
Requirement already satisfied: click in /usr/local/lib/python3.7/dist-packages (from -r requirements.txt (line 6)) (8.1.3)
Requirement already satisfied: click-log>=0.2.1 in /usr/local/lib/python3.7/dist-packages (from -r requirements.txt (line 7)) (0.4.0)
Requirement already satisfied: crccheck in /usr/local/lib/python3.7/dist-packages (from -r requirements.txt (line 8)) (1.3.0)
Requirement already satisfied: coloredlogs in /usr/local/lib/python3.7/dist-packages (from -r requirements.txt (line 9)) (15.0.1)
Requirement already satisfied: jsonschema in /usr/local/lib/python3.7/dist-packages (from -r requirements.txt (line 10)) (4.17.3)
Requirement already satisfied: frozenlist in /usr/local/lib/python3.7/dist-packages (from -r requirements.txt (line 12)) (1.3.3)
Requirement already satisfied: multidict in /usr/local/lib/python3.7/dist-packages (from -r requirements.txt (line 13)) (6.0.2)
Requirement already satisfied: pure-pcapy3 in /usr/local/lib/python3.7/dist-packages (from -r requirements.txt (line 14)) (1.0.1)
Requirement already satisfied: pyserial>=3.5 in /usr/local/lib/python3.7/dist-packages (from -r requirements.txt (line 15)) (3.5)
Requirement already satisfied: pyserial-asyncio in /usr/local/lib/python3.7/dist-packages (from -r requirements.txt (line 16)) (0.6)
Requirement already satisfied: pyusb>=1.2.1 in /usr/local/lib/python3.7/dist-packages (from -r requirements.txt (line 18)) (1.2.1)
Requirement already satisfied: typing-extensions in /usr/local/lib/python3.7/dist-packages (from -r requirements.txt (line 19)) (4.4.0)
Requirement already satisfied: voluptuous in /usr/local/lib/python3.7/dist-packages (from -r requirements.txt (line 20)) (0.13.1)
Requirement already satisfied: yarl in /usr/local/lib/python3.7/dist-packages (from -r requirements.txt (line 21)) (1.8.1)
Requirement already satisfied: cryptography in /usr/lib/python3/dist-packages (from -r requirements.txt (line 22)) (2.6.1)
Requirement already satisfied: dnspython==2.2.1 in /usr/local/lib/python3.7/dist-packages (from -r requirements.txt (line 23)) (2.2.1)
Requirement already satisfied: charset-normalizer<3.0,>=2.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->-r requirements.txt (line 1)) (2.0.9)
Requirement already satisfied: asynctest==0.13.0; python_version < "3.8" in /usr/local/lib/python3.7/dist-packages (from aiohttp->-r requirements.txt (line 1)) (0.13.0)
Requirement already satisfied: importlib-metadata; python_version < "3.8" in /usr/local/lib/python3.7/dist-packages (from click->-r requirements.txt (line 6)) (5.1.0)
Requirement already satisfied: humanfriendly>=9.1 in /usr/local/lib/python3.7/dist-packages (from coloredlogs->-r requirements.txt (line 9)) (10.0)
Requirement already satisfied: pyrsistent!=0.17.0,!=0.17.1,!=0.17.2,>=0.14.0 in /usr/local/lib/python3.7/dist-packages (from jsonschema->-r requirements.txt (line 10)) (0.19.2)
Requirement already satisfied: importlib-resources>=1.4.0; python_version < "3.9" in /usr/local/lib/python3.7/dist-packages (from jsonschema->-r requirements.txt (line 10)) (5.10.0)
Requirement already satisfied: pkgutil-resolve-name>=1.3.10; python_version < "3.9" in /usr/local/lib/python3.7/dist-packages (from jsonschema->-r requirements.txt (line 10)) (1.3.10)
Requirement already satisfied: setuptools in /usr/lib/python3/dist-packages (from pure-pcapy3->-r requirements.txt (line 14)) (40.8.0)
Requirement already satisfied: idna>=2.0 in /usr/lib/python3/dist-packages (from yarl->-r requirements.txt (line 21)) (2.6)
Requirement already satisfied: zipp>=0.5 in /usr/local/lib/python3.7/dist-packages (from importlib-metadata; python_version < "3.8"->click->-r requirements.txt (line 6)) (3.11.0)
J'ai mis en Texas instrument ca ne change rien
oui, mais si tu as mis ZNP alors mets les logs ici, car il est possible que maintenant ce soit un problème différent
audi68
ci joint les log en Texas
2022-12-04 18:54:59.718 Status: zibgee: homedirectory set to /home/jeedom/domoticz/plugins/Domoticz-Zigbee/
2022-12-04 18:54:59.718 Status: zibgee: pluginData set to /home/jeedom/domoticz/plugins/Domoticz-Zigbee/Data/
2022-12-04 18:54:59.718 Status: zibgee: pluginConfig set to /home/jeedom/domoticz/plugins/Domoticz-Zigbee/Conf/
2022-12-04 18:54:59.718 Status: zibgee: pluginOTAFirmware set to /home/jeedom/domoticz/plugins/Domoticz-Zigbee/OTAFirmware/
2022-12-04 18:54:59.718 Status: zibgee: pluginReports set to /home/jeedom/domoticz/plugins/Domoticz-Zigbee/Reports/
2022-12-04 18:54:59.718 Status: zibgee: pluginWWW set to /home/jeedom/domoticz/plugins/Domoticz-Zigbee/www/
2022-12-04 18:54:59.718 Status: zibgee: pluginLogs set to /home/jeedom/domoticz/plugins/Domoticz-Zigbee/Logs/
2022-12-04 18:54:59.722 Status: zibgee: Please watch plugin log into /home/jeedom/domoticz/plugins/Domoticz-Zigbee/Logs//PluginZigbee_08.log
2022-12-04 18:54:59.737 Status: zibgee: Zigbee for Domoticz (z4d) plugin stable6-6.3.006 started
2022-12-04 18:54:59.746 Status: Incoming connection from: 127.0.0.1
2022-12-04 18:54:59.751 Status: zibgee: Multi instances plugin detected. Enable zigpy workaround
2022-12-04 18:54:59.767 Status: zibgee: DeviceConf loaded - 22 confs loaded
2022-12-04 18:55:00.031 Status: zibgee: DeviceConf loaded - 369 confs loaded
2022-12-04 18:55:00.032 Status: zibgee: load ListOfDevice
2022-12-04 18:55:00.033 Status: zibgee: 0 Entries loaded from /home/jeedom/domoticz/plugins/Domoticz-Zigbee/Data/DeviceList-8.txt
2022-12-04 18:55:00.039 Status: zibgee: Transport mode: ZigpyZNP
2022-12-04 18:55:00.038 Error: zibgee: Call to function 'onStart' failed, exception details:
2022-12-04 18:55:00.042 Error: zibgee: Traceback (most recent call last):
2022-12-04 18:55:00.042 Error: zibgee: File "/home/jeedom/domoticz/plugins/Domoticz-Zigbee/plugin.py", line 1562, in onStart
2022-12-04 18:55:00.042 Error: zibgee: _plugin.onStart()
2022-12-04 18:55:00.042 Error: zibgee: File "/home/jeedom/domoticz/plugins/Domoticz-Zigbee/plugin.py", line 549, in onStart
2022-12-04 18:55:00.042 Error: zibgee: import zigpy
2022-12-04 18:55:00.042 Error: zibgee: ModuleNotFoundError: No module named 'zigpy'
Depuis le repertoire du plugin
git config --add submodule.recurse true
git submodule update --init --recursive
https://zigbeefordomoticz.github.io/wik ... g-on-linux
audi68
j'ai cette erreur dans putty
jeedom@raspberrypi:~ $ cd domoticz/plugins/
jeedom@raspberrypi:~/domoticz/plugins $ git config --add submodule.recurse true
fatal: pas dans un répertoire git
audi68
Je viens de suivre le tuto et il me semble que ça fonctionne plus d'erreur dans les logs sur domoticz
Par contre j'ai pas les plugins dans mesure
