[Résolu] PB inter sans fils Legrand-Netatmo
Re: PB inter sans fils Legrand-Netatmo
Tu peux attacher un fichier
la suite
merci de ton aide et bonne soirée
2 appuis courts
2023-12-08 19:20:25,154 INFO :b'ZigateRead - MsgType: 8000, Data: 00000014008d0000, LQI: 0'
2023-12-08 19:20:25,155 INFO :b'ZigateRead - MsgType: 8014, Data: 00, LQI: 0'
2023-12-08 19:20:25,155 INFO :b'Decode8014 - Permit Join status: False'
2023-12-08 19:20:25,156 INFO :b"---> self.permitTojoin['Starttime']: 1702059625"
2023-12-08 19:20:25,156 INFO :b"---> self.permitTojoin['Duration']: 0"
2023-12-08 19:20:25,157 INFO :b'---> Current time : 1702059625'
2023-12-08 19:20:25,157 INFO :b"---> self.Ping['Permit'] (prev) : Off"
2023-12-08 19:20:25,158 INFO :b"---> self.Ping['Permit'] (new ) : Off"
2023-12-08 19:20:25,159 INFO :b'---> _to_notify : False'
2023-12-08 19:20:25,159 INFO :b'Ping - received'
2023-12-08 19:20:50,336 INFO :b'ZigateRead - MsgType: 8102, Data: 3d475e010b04050b002900020000, LQI: 48'
2023-12-08 19:20:50,338 INFO :b'Decode8102 - Attribute Reports: [475e:01] MsgSQN: 3d ClusterID: 0b04 AttributeID: 050b Status: 00 Type: 29 Size: 0002 ClusterData: >0000<'
2023-12-08 19:20:50,341 INFO :b'scan_attribute_reponse - Sqn: 3d i_sqn: None Nwkid: 475e Ep: 01 Cluster: 0b04 MsgData: 3d475e010b04050b002900020000 Type: 8102'
2023-12-08 19:20:50,343 INFO :b'scan_attribute_reponse - 8102 idx: 28 Read Attribute Response: [475e:01] ClusterID: 0b04 MsgSQN: 3d, i_sqn: None, AttributeID: 050b Status: 00 Type: 29 Size: 0002 ClusterData: >0000<'
2023-12-08 19:20:50,348 INFO :b'Decode8102 - LQI: 48 Received Cluster:0b04 Attribute: 050b Value: 0000 from (475e/01)'
2023-12-08 19:20:50,350 INFO :b'ReadCluster - 0b04 - 475e/01 AttrId: 050b AttrType: 29 Attsize: 0002 Status: 00 AttrValue: 0000'
2023-12-08 19:20:50,351 INFO :b"is_generic_zcl_cluster 0b04/050b and definition {'Enabled': True, 'Name': 'ActivePower', 'DataType': '29', 'Range': [-32768, 32768], 'Acc': 'R', 'Default': '0', 'Mandatory': False, 'EvalFunc': 'compute_electrical_measurement_conso', 'ActionList': ['check_store_value', 'upd_domo_device']}"
2023-12-08 19:20:50,352 INFO :b'Foundation Cluster - Nwkid: 475e Ep: 01 Cluster: 0b04 Attribute: 050b Type: 29 Data: 0000 Source: 8102'
2023-12-08 19:20:50,352 INFO :b'compute_attribute_value - _decoding_value: None value: 0'
2023-12-08 19:20:50,353 INFO :b"compute_attribute_value - _function: compute_electrical_measurement_conso FUNCTION_MODULE: {'compute_metering_conso': <function compute_metering_conso at 0xec0487c0>, 'compute_electrical_measurement_conso': <function compute_electrical_measurement_conso at 0xec048808>, 'current_position_lift_percent': <function CurrentPositionLiftPercentage at 0xec048850>, 'legrand_operating_time': <function legrand_operating_time at 0xec036f10>, 'konke_onoff': <function konke_onoff at 0xec036ec8>, 'chameleon_stge': <function chameleon_stge at 0xec036c88>}"
2023-12-08 19:20:50,354 INFO :b"compute_electrical_measurement_conso - 475e/01 0b04 050b 0 <class 'int'>"
2023-12-08 19:20:50,355 INFO :b'compute_electrical_measurement_conso - 475e/01 Multiplier: 1 , Divisor: 1 , raw: 0 result: 0.0'
2023-12-08 19:20:50,355 INFO :b'---> Data Action: check_store_value'
2023-12-08 19:20:50,356 INFO :b'---> Data Action: upd_domo_device'
2023-12-08 19:20:50,357 INFO :b'action_majdomodevice - 475e/01 0b04 050b Connected outlet 0.0'
2023-12-08 19:20:50,358 INFO :b' _majdomo_formater: None'
2023-12-08 19:20:50,358 INFO :b'get_device_config_param: 475e Config: disableBinaryInputCluster'
2023-12-08 19:20:50,359 INFO :b' _majdomo_cluster: None'
2023-12-08 19:20:50,360 INFO :b' _majdomo_attribute: None'
2023-12-08 19:20:50,365 INFO :b'UpdateDevice - (zigbee - Connected outlet_Power-000474000009e10d-01) 0.0:0.0'
2023-12-08 19:20:50,386 INFO :b'UpdateDevice - (zigbee - Connected outlet_Meter-000474000009e10d-01) 0:0.0;'
2023-12-08 19:20:50,391 INFO :b'ZigateRead - MsgType: 8102, Data: 3e475e01000600000010000100, LQI: 49'
2023-12-08 19:20:50,393 INFO :b'Decode8102 - Attribute Reports: [475e:01] MsgSQN: 3e ClusterID: 0006 AttributeID: 0000 Status: 00 Type: 10 Size: 0001 ClusterData: >00<'
2023-12-08 19:20:50,396 INFO :b'scan_attribute_reponse - Sqn: 3e i_sqn: None Nwkid: 475e Ep: 01 Cluster: 0006 MsgData: 3e475e01000600000010000100 Type: 8102'
2023-12-08 19:20:50,398 INFO :b'scan_attribute_reponse - 8102 idx: 26 Read Attribute Response: [475e:01] ClusterID: 0006 MsgSQN: 3e, i_sqn: None, AttributeID: 0000 Status: 00 Type: 10 Size: 0001 ClusterData: >00<'
2023-12-08 19:20:50,404 INFO :b'Decode8102 - LQI: 49 Received Cluster:0006 Attribute: 0000 Value: 00 from (475e/01)'
2023-12-08 19:20:50,406 INFO :b'ReadCluster - 0006 - 475e/01 AttrId: 0000 AttrType: 10 Attsize: 0001 Status: 00 AttrValue: 00'
2023-12-08 19:20:50,407 INFO :b"is_generic_zcl_cluster 0006/0000 and definition {'Enabled': True, 'Name': 'OnOff', 'DataType': '10', 'Acc': 'RPS', 'Default': '0', 'Mandatory': True, 'DomoClusterType': 'Switch', 'ActionList': ['check_store_value', 'upd_domo_device']}"
2023-12-08 19:20:50,408 INFO :b'Foundation Cluster - Nwkid: 475e Ep: 01 Cluster: 0006 Attribute: 0000 Type: 10 Data: 00 Source: 8102'
2023-12-08 19:20:50,408 INFO :b'compute_attribute_value - _decoding_value: None value: 00'
2023-12-08 19:20:50,409 INFO :b'---> Data Action: check_store_value'
2023-12-08 19:20:50,409 INFO :b'---> Data Action: upd_domo_device'
2023-12-08 19:20:50,410 INFO :b'action_majdomodevice - 475e/01 0006 0000 Connected outlet 00'
2023-12-08 19:20:50,411 INFO :b' _majdomo_formater: None'
2023-12-08 19:20:50,411 INFO :b'get_device_config_param: 475e Config: disableBinaryInputCluster'
2023-12-08 19:20:50,412 INFO :b' _majdomo_cluster: None'
2023-12-08 19:20:50,412 INFO :b' _majdomo_attribute: None'
2023-12-08 19:21:14,565 INFO :b'ZigateRead - MsgType: 8102, Data: 328f2e010008001100200001bd, LQI: 83'
2023-12-08 19:21:14,568 INFO :b'Decode8102 - Attribute Reports: [8f2e:01] MsgSQN: 32 ClusterID: 0008 AttributeID: 0011 Status: 00 Type: 20 Size: 0001 ClusterData: >bd<'
2023-12-08 19:21:14,571 INFO :b'scan_attribute_reponse - Sqn: 32 i_sqn: None Nwkid: 8f2e Ep: 01 Cluster: 0008 MsgData: 328f2e010008001100200001bd Type: 8102'
2023-12-08 19:21:14,571 INFO :b'scan_attribute_reponse - 8102 idx: 26 Read Attribute Response: [8f2e:01] ClusterID: 0008 MsgSQN: 32, i_sqn: None, AttributeID: 0011 Status: 00 Type: 20 Size: 0001 ClusterData: >bd<'
2023-12-08 19:21:14,572 INFO :b'Decode8102 - LQI: 83 Received Cluster:0008 Attribute: 0011 Value: bd from (8f2e/01)'
2023-12-08 19:21:14,573 INFO :b'ReadCluster - 0008 - 8f2e/01 AttrId: 0011 AttrType: 20 Attsize: 0001 Status: 00 AttrValue: bd'
2023-12-08 19:21:14,573 INFO :b'ReadCluster - ClusterID: 0008 Addr: 8f2e MsgAttrID: 0011 MsgAttType: 20 MsgAttSize: 0001 MsgClusterData: bd'
2023-12-08 19:21:14,574 INFO :b'ReadCluster - ClusterId=0008 - 8f2e/01 On Level : bd'
2023-12-08 19:21:14,616 INFO :b'ZigateRead - MsgType: 8102, Data: 338f2e01000600000010000100, LQI: 84'
2023-12-08 19:21:14,619 INFO :b'Decode8102 - Attribute Reports: [8f2e:01] MsgSQN: 33 ClusterID: 0006 AttributeID: 0000 Status: 00 Type: 10 Size: 0001 ClusterData: >00<'
2023-12-08 19:21:14,624 INFO :b'scan_attribute_reponse - Sqn: 33 i_sqn: None Nwkid: 8f2e Ep: 01 Cluster: 0006 MsgData: 338f2e01000600000010000100 Type: 8102'
2023-12-08 19:21:14,624 INFO :b'scan_attribute_reponse - 8102 idx: 26 Read Attribute Response: [8f2e:01] ClusterID: 0006 MsgSQN: 33, i_sqn: None, AttributeID: 0000 Status: 00 Type: 10 Size: 0001 ClusterData: >00<'
2023-12-08 19:21:14,625 INFO :b'Decode8102 - LQI: 84 Received Cluster:0006 Attribute: 0000 Value: 00 from (8f2e/01)'
2023-12-08 19:21:14,626 INFO :b'ReadCluster - 0006 - 8f2e/01 AttrId: 0000 AttrType: 10 Attsize: 0001 Status: 00 AttrValue: 00'
2023-12-08 19:21:14,626 INFO :b"is_generic_zcl_cluster 0006/0000 and definition {'Enabled': True, 'Name': 'OnOff', 'DataType': '10', 'Acc': 'RPS', 'Default': '0', 'Mandatory': True, 'DomoClusterType': 'Switch', 'ActionList': ['check_store_value', 'upd_domo_device']}"
2023-12-08 19:21:14,627 INFO :b'Foundation Cluster - Nwkid: 8f2e Ep: 01 Cluster: 0006 Attribute: 0000 Type: 10 Data: 00 Source: 8102'
2023-12-08 19:21:14,627 INFO :b'compute_attribute_value - _decoding_value: None value: 00'
2023-12-08 19:21:14,628 INFO :b'---> Data Action: check_store_value'
2023-12-08 19:21:14,628 INFO :b'---> Data Action: upd_domo_device'
2023-12-08 19:21:14,629 INFO :b'action_majdomodevice - 8f2e/01 0006 0000 Dimmer switch wo neutral 00'
2023-12-08 19:21:14,629 INFO :b' _majdomo_formater: None'
2023-12-08 19:21:14,630 INFO :b'get_device_config_param: 8f2e Config: disableBinaryInputCluster'
2023-12-08 19:21:14,630 INFO :b' _majdomo_cluster: None'
2023-12-08 19:21:14,631 INFO :b' _majdomo_attribute: None'
2023-12-08 19:21:16,549 INFO :b'ZigateRead - MsgType: 8102, Data: 348f2e01000800000020000100, LQI: 86'
2023-12-08 19:21:16,552 INFO :b'Decode8102 - Attribute Reports: [8f2e:01] MsgSQN: 34 ClusterID: 0008 AttributeID: 0000 Status: 00 Type: 20 Size: 0001 ClusterData: >00<'
2023-12-08 19:21:16,557 INFO :b'scan_attribute_reponse - Sqn: 34 i_sqn: None Nwkid: 8f2e Ep: 01 Cluster: 0008 MsgData: 348f2e01000800000020000100 Type: 8102'
2023-12-08 19:21:16,558 INFO :b'scan_attribute_reponse - 8102 idx: 26 Read Attribute Response: [8f2e:01] ClusterID: 0008 MsgSQN: 34, i_sqn: None, AttributeID: 0000 Status: 00 Type: 20 Size: 0001 ClusterData: >00<'
2023-12-08 19:21:16,559 INFO :b'Decode8102 - LQI: 86 Received Cluster:0008 Attribute: 0000 Value: 00 from (8f2e/01)'
2023-12-08 19:21:16,560 INFO :b'ReadCluster - 0008 - 8f2e/01 AttrId: 0000 AttrType: 20 Attsize: 0001 Status: 00 AttrValue: 00'
2023-12-08 19:21:16,560 INFO :b"is_generic_zcl_cluster 0008/0000 and definition {'Enabled': True, 'Name': 'CurrentLevel', 'DataType': '20', 'Range': ['00', 'ff'], 'Acc': 'RPS', 'Default': 'ff', 'Mandatory': True, 'DomoClusterType': 'LvlControl', 'ActionList': ['check_store_value', 'upd_domo_device']}"
2023-12-08 19:21:16,561 INFO :b'Foundation Cluster - Nwkid: 8f2e Ep: 01 Cluster: 0008 Attribute: 0000 Type: 20 Data: 00 Source: 8102'
2023-12-08 19:21:16,562 INFO :b'compute_attribute_value - _decoding_value: None value: 0'
2023-12-08 19:21:16,562 INFO :b'---> Data Action: check_store_value'
2023-12-08 19:21:16,563 INFO :b'---> Data Action: upd_domo_device'
2023-12-08 19:21:16,563 INFO :b'action_majdomodevice - 8f2e/01 0008 0000 Dimmer switch wo neutral 0'
2023-12-08 19:21:16,564 INFO :b' _majdomo_formater: None'
2023-12-08 19:21:16,565 INFO :b'get_device_config_param: 8f2e Config: disableBinaryInputCluster'
2023-12-08 19:21:16,565 INFO :b' _majdomo_cluster: None'
2023-12-08 19:21:16,566 INFO :b' _majdomo_attribute: None'
2023-12-08 19:21:26,351 INFO :b'zcl_decoders Zcl.ddr: 0 GlobalCommand: False Sqn: 01 ManufCode: 1021 Command: 09 Data: 9181c4000074040001 Payload: 05211001099181c4000074040001'
2023-12-08 19:21:26,353 INFO :b'zcl_decoders Unknown Command: 09 NwkId: 2c2f Ep: 01 Cluster: fc01 Payload: 9181c4000074040001 - GlobalCommand: False, Sqn: 01, ManufacturerCode: 1021'
2023-12-08 19:21:26,356 INFO :b'ZigateRead - MsgType: 8002, Data: 000104fc010101022c2f02000005211001099181c4000074040001, LQI: 81'
2023-12-08 19:21:26,357 INFO :b'zcl_decoders Zcl.ddr: 0 GlobalCommand: False Sqn: 01 ManufCode: 1021 Command: 09 Data: 9181c4000074040001 Payload: 05211001099181c4000074040001'
2023-12-08 19:21:26,358 INFO :b'zcl_decoders Unknown Command: 09 NwkId: 2c2f Ep: 01 Cluster: fc01 Payload: 9181c4000074040001 - GlobalCommand: False, Sqn: 01, ManufacturerCode: 1021'
2023-12-08 19:21:26,359 INFO :b'Reception Data indication, Source Address: 2c2f Destination Address: 0000 ProfilID: 0104 ClusterID: fc01 Message Payload: 05211001099181c4000074040001'
2023-12-08 19:21:26,360 INFO :b'legrandReadRawAPS - Nwkid: 2c2f Ep: 01, Cluster: fc01, dstNwkid: 0000, dstEp: 01, Payload: 05211001099181c4000074040001'
2023-12-08 19:21:26,361 INFO :b' NwkId: 2c2f/01 Cluster: fc01 Command: 09 Data: 9181c4000074040001'
2023-12-08 19:21:26,361 INFO :b'---> Decoding cmd 0x09 Ieee: 4740000c48191 leftright: 01'
2023-12-08 19:21:26,362 INFO :b'assign_group_membership_to_legrand_remote 2c2f lefright: 01'
2023-12-08 19:21:26,404 INFO :b'zcl_decoders Zcl.ddr: 1 GlobalCommand: False Sqn: 02 ManufCode: 1021 Command: 05 Data: 9181c40000740400 Payload: 15211002059181c40000740400'
2023-12-08 19:21:26,406 INFO :b'zcl_decoders Unknown Command: 05 NwkId: 2c2f Ep: 01 Cluster: fc01 Payload: 9181c40000740400 - GlobalCommand: False, Sqn: 02, ManufacturerCode: 1021'
2023-12-08 19:21:26,408 INFO :b'ZigateRead - MsgType: 8002, Data: 000104fc010101022c2f02000015211002059181c40000740400, LQI: 81'
2023-12-08 19:21:26,410 INFO :b'zcl_decoders Zcl.ddr: 1 GlobalCommand: False Sqn: 02 ManufCode: 1021 Command: 05 Data: 9181c40000740400 Payload: 15211002059181c40000740400'
2023-12-08 19:21:26,411 INFO :b'zcl_decoders Unknown Command: 05 NwkId: 2c2f Ep: 01 Cluster: fc01 Payload: 9181c40000740400 - GlobalCommand: False, Sqn: 02, ManufacturerCode: 1021'
2023-12-08 19:21:26,411 INFO :b'Reception Data indication, Source Address: 2c2f Destination Address: 0000 ProfilID: 0104 ClusterID: fc01 Message Payload: 15211002059181c40000740400'
2023-12-08 19:21:26,412 INFO :b'legrandReadRawAPS - Nwkid: 2c2f Ep: 01, Cluster: fc01, dstNwkid: 0000, dstEp: 01, Payload: 15211002059181c40000740400'
2023-12-08 19:21:26,413 INFO :b' NwkId: 2c2f/01 Cluster: fc01 Command: 05 Data: 9181c40000740400'
2023-12-08 19:21:26,560 INFO :b'zcl_decoders Zcl.ddr: 1 GlobalCommand: True Sqn: 03 ManufCode: None Command: 0a Data: 55001000 Payload: 18030a55001000'
2023-12-08 19:21:26,561 INFO :b'zcl_decoders Sqn: 3/03 ManufCode: None Command: 0a Data: 55001000 '
2023-12-08 19:21:26,563 INFO :b'buildframe_report_attribute_response - 2c2f 01 000f Data: 55001000'
2023-12-08 19:21:26,564 INFO :b'ZigateRead - MsgType: 8102, Data: 032c2f01000f00550010000100, LQI: 81'
2023-12-08 19:21:26,570 INFO :b'Decode8102 - Attribute Reports: [2c2f:01] MsgSQN: 03 ClusterID: 000f AttributeID: 0055 Status: 00 Type: 10 Size: 0001 ClusterData: >00<'
2023-12-08 19:21:26,572 INFO :b'scan_attribute_reponse - Sqn: 03 i_sqn: 13 Nwkid: 2c2f Ep: 01 Cluster: 000f MsgData: 032c2f01000f00550010000100 Type: 8102'
2023-12-08 19:21:26,572 INFO :b'scan_attribute_reponse - 8102 idx: 26 Read Attribute Response: [2c2f:01] ClusterID: 000f MsgSQN: 03, i_sqn: 13, AttributeID: 0055 Status: 00 Type: 10 Size: 0001 ClusterData: >00<'
2023-12-08 19:21:26,573 INFO :b'Decode8102 - LQI: 81 Received Cluster:000f Attribute: 0055 Value: 00 from (2c2f/01)'
2023-12-08 19:21:26,574 INFO :b'ReadCluster - 000f - 2c2f/01 AttrId: 0055 AttrType: 10 Attsize: 0001 Status: 00 AttrValue: 00'
2023-12-08 19:21:26,574 INFO :b"is_cluster_specific_config 000f/0055 and definition {'Enabled': True, 'Name': 'PresentValue', 'DataType': '10', 'UpdDomoDeviceWithCluster': '0006', 'ActionList': ['check_store_value', 'upd_domo_device']}"
2023-12-08 19:21:26,575 INFO :b'Foundation Cluster - Nwkid: 2c2f Ep: 01 Cluster: 000f Attribute: 0055 Type: 10 Data: 00 Source: 8102'
2023-12-08 19:21:26,576 INFO :b"is_cluster_specific_config 000f/0055 and definition {'Enabled': True, 'Name': 'PresentValue', 'DataType': '10', 'UpdDomoDeviceWithCluster': '0006', 'ActionList': ['check_store_value', 'upd_domo_device']}"
2023-12-08 19:21:26,577 INFO :b"is_cluster_specific_config 000f and definition {'Attributes': {'0055': {'Enabled': True, 'Name': 'PresentValue', 'DataType': '10', 'UpdDomoDeviceWithCluster': '0006', 'ActionList': ['check_store_value', 'upd_domo_device']}, 'f000': {'Enabled': True, 'Name': 'LegrandOnOff', 'DataType': '21', 'UpdDomoDeviceWithCluster': '0006', 'ActionList': ['check_store_value', 'upd_domo_device']}}}"
2023-12-08 19:21:26,577 INFO :b"is_cluster_specific_config 000f/0055 and definition {'Enabled': True, 'Name': 'PresentValue', 'DataType': '10', 'UpdDomoDeviceWithCluster': '0006', 'ActionList': ['check_store_value', 'upd_domo_device']}"
2023-12-08 19:21:26,578 INFO :b"is_cluster_specific_config 000f/0055 and definition {'Enabled': True, 'Name': 'PresentValue', 'DataType': '10', 'UpdDomoDeviceWithCluster': '0006', 'ActionList': ['check_store_value', 'upd_domo_device']}"
2023-12-08 19:21:26,579 INFO :b"is_cluster_specific_config 000f/0055 and definition {'Enabled': True, 'Name': 'PresentValue', 'DataType': '10', 'UpdDomoDeviceWithCluster': '0006', 'ActionList': ['check_store_value', 'upd_domo_device']}"
2023-12-08 19:21:26,580 INFO :b"is_cluster_specific_config 000f/0055 and definition {'Enabled': True, 'Name': 'PresentValue', 'DataType': '10', 'UpdDomoDeviceWithCluster': '0006', 'ActionList': ['check_store_value', 'upd_domo_device']}"
2023-12-08 19:21:26,581 INFO :b"is_cluster_specific_config 000f/0055 and definition {'Enabled': True, 'Name': 'PresentValue', 'DataType': '10', 'UpdDomoDeviceWithCluster': '0006', 'ActionList': ['check_store_value', 'upd_domo_device']}"
2023-12-08 19:21:26,582 INFO :b"is_cluster_specific_config 000f/0055 and definition {'Enabled': True, 'Name': 'PresentValue', 'DataType': '10', 'UpdDomoDeviceWithCluster': '0006', 'ActionList': ['check_store_value', 'upd_domo_device']}"
2023-12-08 19:21:26,583 INFO :b'compute_attribute_value - _decoding_value: None value: 00'
2023-12-08 19:21:26,583 INFO :b"is_cluster_specific_config 000f/0055 and definition {'Enabled': True, 'Name': 'PresentValue', 'DataType': '10', 'UpdDomoDeviceWithCluster': '0006', 'ActionList': ['check_store_value', 'upd_domo_device']}"
2023-12-08 19:21:26,584 INFO :b'---> Data Action: check_store_value'
2023-12-08 19:21:26,584 INFO :b'---> Data Action: upd_domo_device'
2023-12-08 19:21:26,586 INFO :b"is_cluster_specific_config 000f/0055 and definition {'Enabled': True, 'Name': 'PresentValue', 'DataType': '10', 'UpdDomoDeviceWithCluster': '0006', 'ActionList': ['check_store_value', 'upd_domo_device']}"
2023-12-08 19:21:26,587 INFO :b'action_majdomodevice - 2c2f/01 000f 0055 Remote switch 00'
2023-12-08 19:21:26,588 INFO :b"is_cluster_specific_config 000f/0055 and definition {'Enabled': True, 'Name': 'PresentValue', 'DataType': '10', 'UpdDomoDeviceWithCluster': '0006', 'ActionList': ['check_store_value', 'upd_domo_device']}"
2023-12-08 19:21:26,588 INFO :b' _majdomo_formater: None'
2023-12-08 19:21:26,589 INFO :b'get_device_config_param: 2c2f Config: disableBinaryInputCluster'
2023-12-08 19:21:26,589 INFO :b"is_cluster_specific_config 000f/0055 and definition {'Enabled': True, 'Name': 'PresentValue', 'DataType': '10', 'UpdDomoDeviceWithCluster': '0006', 'ActionList': ['check_store_value', 'upd_domo_device']}"
2023-12-08 19:21:26,590 INFO :b' _majdomo_cluster: 0006'
2023-12-08 19:21:26,591 INFO :b"is_cluster_specific_config 000f/0055 and definition {'Enabled': True, 'Name': 'PresentValue', 'DataType': '10', 'UpdDomoDeviceWithCluster': '0006', 'ActionList': ['check_store_value', 'upd_domo_device']}"
2023-12-08 19:21:26,591 INFO :b' _majdomo_attribute: None'
2023-12-08 19:21:26,594 INFO :b'UpdateDevice - (zigbee - Remote switch_LegrandSelector-0004740000c48191-01) 0:00'
2023-12-08 19:21:26,663 INFO :b'ZigateRead - MsgType: 8102, Data: 1b04cc01010200080020000164, LQI: 83'
2023-12-08 19:21:26,665 INFO :b'Decode8102 - Attribute Reports: [04cc:01] MsgSQN: 1b ClusterID: 0102 AttributeID: 0008 Status: 00 Type: 20 Size: 0001 ClusterData: >64<'
2023-12-08 19:21:26,670 INFO :b'scan_attribute_reponse - Sqn: 1b i_sqn: None Nwkid: 04cc Ep: 01 Cluster: 0102 MsgData: 1b04cc01010200080020000164 Type: 8102'
2023-12-08 19:21:26,671 INFO :b'scan_attribute_reponse - 8102 idx: 26 Read Attribute Response: [04cc:01] ClusterID: 0102 MsgSQN: 1b, i_sqn: None, AttributeID: 0008 Status: 00 Type: 20 Size: 0001 ClusterData: >64<'
2023-12-08 19:21:26,672 INFO :b'Decode8102 - LQI: 83 Received Cluster:0102 Attribute: 0008 Value: 64 from (04cc/01)'
2023-12-08 19:21:26,672 INFO :b'ReadCluster - 0102 - 04cc/01 AttrId: 0008 AttrType: 20 Attsize: 0001 Status: 00 AttrValue: 64'
2023-12-08 19:21:26,673 INFO :b"is_generic_zcl_cluster 0102/0008 and definition {'Enabled': True, 'Name': 'CurrentPositionLiftPercentage', 'DataType': '20', 'Range': [0, 100], 'Acc': 'R', 'Mandatory': False, 'DomoDeviceFormat': 'strhex', 'EvalFunc': 'current_position_lift_percent', 'ActionList': ['check_store_value', 'upd_domo_device']}"
2023-12-08 19:21:26,673 INFO :b'Foundation Cluster - Nwkid: 04cc Ep: 01 Cluster: 0102 Attribute: 0008 Type: 20 Data: 64 Source: 8102'
2023-12-08 19:21:26,674 INFO :b'compute_attribute_value - _decoding_value: None value: 100'
2023-12-08 19:21:26,674 INFO :b"compute_attribute_value - _function: current_position_lift_percent FUNCTION_MODULE: {'compute_metering_conso': <function compute_metering_conso at 0xec0487c0>, 'compute_electrical_measurement_conso': <function compute_electrical_measurement_conso at 0xec048808>, 'current_position_lift_percent': <function CurrentPositionLiftPercentage at 0xec048850>, 'legrand_operating_time': <function legrand_operating_time at 0xec036f10>, 'konke_onoff': <function konke_onoff at 0xec036ec8>, 'chameleon_stge': <function chameleon_stge at 0xec036c88>}"
2023-12-08 19:21:26,675 INFO :b'CurrentPositionLiftPercentage - 0102 - 04cc/01 - Shutter after correction value: 100'
2023-12-08 19:21:26,675 INFO :b'---> Data Action: check_store_value'
2023-12-08 19:21:26,676 INFO :b'---> Data Action: upd_domo_device'
2023-12-08 19:21:26,676 INFO :b'action_majdomodevice - 04cc/01 0102 0008 Shutter switch with neutral 100'
2023-12-08 19:21:26,677 INFO :b' _majdomo_formater: strhex'
2023-12-08 19:21:26,677 INFO :b'get_device_config_param: 04cc Config: disableBinaryInputCluster'
2023-12-08 19:21:26,678 INFO :b'get_device_config_param: 04cc Config: disableBinaryInputCluster return 0'
2023-12-08 19:21:26,678 INFO :b' _majdomo_cluster: None'
2023-12-08 19:21:26,679 INFO :b' _majdomo_attribute: None'
2023-12-08 19:21:26,765 INFO :b'ZigateRead - MsgType: 004d, Data: 2c2f0004740000c4819180, LQI: 81'
2023-12-08 19:21:26,769 INFO :b'ZigateRead - MsgType: 8011, Data: 002c2f01fc018e, LQI: 0'
2023-12-08 19:21:26,817 INFO :b'ZigateRead - MsgType: 8011, Data: 002c2f01fc018f, LQI: 0'
j'ai une piste ..
première chose, on reçoit bien l'évènement lié à l'appui bref, par contre celui-ci n'est pas le meme que avec les versions précédentes de la remote. Je pense que c'est l'implémentation toggle qu'ils ont ajouté
Et du coup il y a un bug qui fait que l'évènement n'est pas correctement interprété
Tu peux désactiver les debugs
restart du plugin, puis tu re-essayes
au cas ou, retour arriere
il faudrait que tu passes sur branche spécifiqueInput
Cluster
zclDecoder
Legrand
git pull
git checkout device/remote-legrand-toggle
sudo python3 -m pip install -r requirements --upgrade
git checkout stable7
sudo python3 -m pip install -r requirements --upgradeZigbee for Domoticz - Clef zzh-p (electrolama) 45 devices.
Aucune résultat sur la remote... hélas.
Je pense avoir fait la bonne manip
par contre l'interrupteur filaire est passé en mode 'toggle' alors qu'il fonctionnait en mode 'On-Off'
j'ai des erreurs dans Domoticz
un appui simple donne:
pi@raspberrypi:~/domoticz/plugins/Domoticz-Zigbee $ git checkout device/remotegrand-toggle
Déjà sur 'device/remote-legrand-toggle'
Votre branche est à jour avec 'origin/device/remote-legrand-toggle'.
2023-12-09 09:42:58.398 Error: zigbee: Decode8000 - PacketType: 00e0 TypeSqn: 01 sqn_app: 00 sqn_aps: 7e Status: [06]
2023-12-09 09:43:08.772 Error: zigbee: ------> Auto Update (Power 00) not found in SWITCH_SELECTORS
2023-12-09 09:43:08.947 Error: zigbee: ------> Auto Update (Meter 00) not found in SWITCH_SELECTORS
2023-12-09 09:45:21.034 Error: zigbee: ReadCluster - Error/unknow 04cc/01 Cluster: 0102 Attribute: f000 Status: 00 DataType: 20 DataSize: 0001 Data: 64
23-12-09 10:02:31,818 INFO :b"is_generic_zcl_cluster 0006/4003 and definition {'Enabled': True, 'Name': 'StartUpOnOff', 'DataType': '30', 'Acc': 'RW', 'Default': '0', 'Mandatory': False, 'ActionList': ['check_store_value']}"
2023-12-09 10:02:31,818 INFO :b'Foundation Cluster - Nwkid: 475e Ep: 01 Cluster: 0006 Attribute: 4003 Type: 30 Data: ff Source: 8100'
2023-12-09 10:02:31,819 INFO :b'compute_attribute_value - _decoding_value: None value: 255'
2023-12-09 10:02:31,819 INFO :b'---> Data Action: check_store_value'
2023-12-09 10:02:32,306 INFO :b"is_generic_zcl_cluster 0006/4003 and definition {'Enabled': True, 'Name': 'StartUpOnOff', 'DataType': '30', 'Acc': 'RW', 'Default': '0', 'Mandatory': False, 'ActionList': ['check_store_value']}"
2023-12-09 10:02:32,307 INFO :b'Foundation Cluster - Nwkid: 8f2e Ep: 01 Cluster: 0006 Attribute: 4003 Type: 30 Data: ff Source: 8100'
2023-12-09 10:02:32,308 INFO :b'compute_attribute_value - _decoding_value: None value: 255'
2023-12-09 10:02:32,308 INFO :b'---> Data Action: check_store_value'
2023-12-09 10:02:32,586 INFO :b"is_generic_zcl_cluster 0301/0011 and definition {'Enabled': True, 'Name': 'MaxLevel', 'DataType': '20', 'Range': ['00', 'ff'], 'Acc': 'RW', 'Default': 0, 'Mandatory': True, 'ActionList': ['check_store_value']}"
2023-12-09 10:02:32,587 INFO :b'Foundation Cluster - Nwkid: 8f2e Ep: 01 Cluster: 0301 Attribute: 0011 Type: 20 Data: fe Source: 8100'
2023-12-09 10:02:32,587 INFO :b'compute_attribute_value - _decoding_value: None value: 254'
2023-12-09 10:02:32,588 INFO :b'---> Data Action: check_store_value'
2023-12-09 10:02:32,875 INFO :b"is_generic_zcl_cluster 0301/0010 and definition {'Enabled': True, 'Name': 'MinLevel', 'DataType': '20', 'Range': ['00', 'ff'], 'Acc': 'RW', 'Default': 0, 'Mandatory': True, 'ActionList': ['check_store_value']}"
2023-12-09 10:02:32,875 INFO :b'Foundation Cluster - Nwkid: 8f2e Ep: 01 Cluster: 0301 Attribute: 0010 Type: 20 Data: 01 Source: 8100'
2023-12-09 10:02:32,876 INFO :b'compute_attribute_value - _decoding_value: None value: 1'
2023-12-09 10:02:32,877 INFO :b'---> Data Action: check_store_value'
2023-12-09 10:02:33,053 INFO :b"is_generic_zcl_cluster 0006/4003 and definition {'Enabled': True, 'Name': 'StartUpOnOff', 'DataType': '30', 'Acc': 'RW', 'Default': '0', 'Mandatory': False, 'ActionList': ['check_store_value']}"
2023-12-09 10:02:33,053 INFO :b'Foundation Cluster - Nwkid: 2492 Ep: 01 Cluster: 0006 Attribute: 4003 Type: 30 Data: ff Source: 8100'
2023-12-09 10:02:33,054 INFO :b'compute_attribute_value - _decoding_value: None value: 255'
2023-12-09 10:02:33,055 INFO :b'---> Data Action: check_store_value'
2023-12-09 10:02:33,341 INFO :b"is_generic_zcl_cluster 0301/0011 and definition {'Enabled': True, 'Name': 'MaxLevel', 'DataType': '20', 'Range': ['00', 'ff'], 'Acc': 'RW', 'Default': 0, 'Mandatory': True, 'ActionList': ['check_store_value']}"
2023-12-09 10:02:33,342 INFO :b'Foundation Cluster - Nwkid: 2492 Ep: 01 Cluster: 0301 Attribute: 0011 Type: 20 Data: fe Source: 8100'
2023-12-09 10:02:33,343 INFO :b'compute_attribute_value - _decoding_value: None value: 254'
2023-12-09 10:02:33,343 INFO :b'---> Data Action: check_store_value'
2023-12-09 10:02:33,564 INFO :b"is_generic_zcl_cluster 0301/0010 and definition {'Enabled': True, 'Name': 'MinLevel', 'DataType': '20', 'Range': ['00', 'ff'], 'Acc': 'RW', 'Default': 0, 'Mandatory': True, 'ActionList': ['check_store_value']}"
2023-12-09 10:02:33,565 INFO :b'Foundation Cluster - Nwkid: 2492 Ep: 01 Cluster: 0301 Attribute: 0010 Type: 20 Data: 01 Source: 8100'
2023-12-09 10:02:33,566 INFO :b'compute_attribute_value - _decoding_value: None value: 1'
2023-12-09 10:02:33,566 INFO :b'---> Data Action: check_store_value'
2023-12-09 10:02:54,160 INFO :b'zcl_decoders Unknown Command: 09 NwkId: 2c2f Ep: 01 Cluster: fc01 Payload: 9181c4000074040001 - GlobalCommand: False, Sqn: 00, ManufacturerCode: 1021'
2023-12-09 10:02:54,164 INFO :b'zcl_decoders Unknown Command: 09 NwkId: 2c2f Ep: 01 Cluster: fc01 Payload: 9181c4000074040001 - GlobalCommand: False, Sqn: 00, ManufacturerCode: 1021'
2023-12-09 10:02:54,209 INFO :b'zcl_decoders Unknown Command: 05 NwkId: 2c2f Ep: 01 Cluster: fc01 Payload: 9181c40000740400 - GlobalCommand: False, Sqn: 02, ManufacturerCode: 1021'
2023-12-09 10:02:54,211 INFO :b'zcl_decoders Unknown Command: 05 NwkId: 2c2f Ep: 01 Cluster: fc01 Payload: 9181c40000740400 - GlobalCommand: False, Sqn: 02, ManufacturerCode: 1021'
2023-12-09 10:02:54,579 INFO :b"is_cluster_specific_config 000f/f000 and definition {'Enabled': True, 'Name': 'LegrandOnOff', 'DataType': '21', 'UpdDomoDeviceWithCluster': '0006', 'UpdDomoDeviceWithAttribute': '0000', 'DomoDeviceFormat': 'str_2digits', 'ActionList': ['check_store_value', 'upd_domo_device']}"
2023-12-09 10:02:54,581 INFO :b'Foundation Cluster - Nwkid: 2c2f Ep: 01 Cluster: 000f Attribute: f000 Type: 21 Data: 0001 Source: 8102'
2023-12-09 10:02:54,582 INFO :b"is_cluster_specific_config 000f/f000 and definition {'Enabled': True, 'Name': 'LegrandOnOff', 'DataType': '21', 'UpdDomoDeviceWithCluster': '0006', 'UpdDomoDeviceWithAttribute': '0000', 'DomoDeviceFormat': 'str_2digits', 'ActionList': ['check_store_value', 'upd_domo_device']}"
2023-12-09 10:02:54,585 INFO :b"is_cluster_specific_config 000f/f000 and definition {'Enabled': True, 'Name': 'LegrandOnOff', 'DataType': '21', 'UpdDomoDeviceWithCluster': '0006', 'UpdDomoDeviceWithAttribute': '0000', 'DomoDeviceFormat': 'str_2digits', 'ActionList': ['check_store_value', 'upd_domo_device']}"
2023-12-09 10:02:54,585 INFO :b"is_cluster_specific_config 000f and definition {'Attributes': {'0055': {'Enabled': True, 'Name': 'PresentValue', 'DataType': '10', 'UpdDomoDeviceWithCluster': '0006', 'ActionList': ['check_store_value', 'upd_domo_device']}, 'f000': {'Enabled': True, 'Name': 'LegrandOnOff', 'DataType': '21', 'UpdDomoDeviceWithCluster': '0006', 'UpdDomoDeviceWithAttribute': '0000', 'DomoDeviceFormat': 'str_2digits', 'ActionList': ['check_store_value', 'upd_domo_device']}}}"
2023-12-09 10:02:54,586 INFO :b"is_cluster_specific_config 000f/f000 and definition {'Enabled': True, 'Name': 'LegrandOnOff', 'DataType': '21', 'UpdDomoDeviceWithCluster': '0006', 'UpdDomoDeviceWithAttribute': '0000', 'DomoDeviceFormat': 'str_2digits', 'ActionList': ['check_store_value', 'upd_domo_device']}"
2023-12-09 10:02:54,587 INFO :b"is_cluster_specific_config 000f/f000 and definition {'Enabled': True, 'Name': 'LegrandOnOff', 'DataType': '21', 'UpdDomoDeviceWithCluster': '0006', 'UpdDomoDeviceWithAttribute': '0000', 'DomoDeviceFormat': 'str_2digits', 'ActionList': ['check_store_value', 'upd_domo_device']}"
2023-12-09 10:02:54,588 INFO :b"is_cluster_specific_config 000f/f000 and definition {'Enabled': True, 'Name': 'LegrandOnOff', 'DataType': '21', 'UpdDomoDeviceWithCluster': '0006', 'UpdDomoDeviceWithAttribute': '0000', 'DomoDeviceFormat': 'str_2digits', 'ActionList': ['check_store_value', 'upd_domo_device']}"
2023-12-09 10:02:54,589 INFO :b"is_cluster_specific_config 000f/f000 and definition {'Enabled': True, 'Name': 'LegrandOnOff', 'DataType': '21', 'UpdDomoDeviceWithCluster': '0006', 'UpdDomoDeviceWithAttribute': '0000', 'DomoDeviceFormat': 'str_2digits', 'ActionList': ['check_store_value', 'upd_domo_device']}"
2023-12-09 10:02:54,590 INFO :b"is_cluster_specific_config 000f/f000 and definition {'Enabled': True, 'Name': 'LegrandOnOff', 'DataType': '21', 'UpdDomoDeviceWithCluster': '0006', 'UpdDomoDeviceWithAttribute': '0000', 'DomoDeviceFormat': 'str_2digits', 'ActionList': ['check_store_value', 'upd_domo_device']}"
2023-12-09 10:02:54,591 INFO :b"is_cluster_specific_config 000f/f000 and definition {'Enabled': True, 'Name': 'LegrandOnOff', 'DataType': '21', 'UpdDomoDeviceWithCluster': '0006', 'UpdDomoDeviceWithAttribute': '0000', 'DomoDeviceFormat': 'str_2digits', 'ActionList': ['check_store_value', 'upd_domo_device']}"
2023-12-09 10:02:54,593 INFO :b'compute_attribute_value - _decoding_value: None value: 1'
2023-12-09 10:02:54,598 INFO :b"is_cluster_specific_config 000f/f000 and definition {'Enabled': True, 'Name': 'LegrandOnOff', 'DataType': '21', 'UpdDomoDeviceWithCluster': '0006', 'UpdDomoDeviceWithAttribute': '0000', 'DomoDeviceFormat': 'str_2digits', 'ActionList': ['check_store_value', 'upd_domo_device']}"
2023-12-09 10:02:54,600 INFO :b'---> Data Action: check_store_value'
2023-12-09 10:02:54,600 INFO :b'---> Data Action: upd_domo_device'
2023-12-09 10:02:54,601 INFO :b"is_cluster_specific_config 000f/f000 and definition {'Enabled': True, 'Name': 'LegrandOnOff', 'DataType': '21', 'UpdDomoDeviceWithCluster': '0006', 'UpdDomoDeviceWithAttribute': '0000', 'DomoDeviceFormat': 'str_2digits', 'ActionList': ['check_store_value', 'upd_domo_device']}"
2023-12-09 10:02:54,601 INFO :b'action_majdomodevice - 2c2f/01 000f f000 Remote switch 1'
2023-12-09 10:02:54,602 INFO :b"is_cluster_specific_config 000f/f000 and definition {'Enabled': True, 'Name': 'LegrandOnOff', 'DataType': '21', 'UpdDomoDeviceWithCluster': '0006', 'UpdDomoDeviceWithAttribute': '0000', 'DomoDeviceFormat': 'str_2digits', 'ActionList': ['check_store_value', 'upd_domo_device']}"
2023-12-09 10:02:54,602 INFO :b' _majdomo_formater: str_2digits'
2023-12-09 10:02:54,603 INFO :b"is_cluster_specific_config 000f/f000 and definition {'Enabled': True, 'Name': 'LegrandOnOff', 'DataType': '21', 'UpdDomoDeviceWithCluster': '0006', 'UpdDomoDeviceWithAttribute': '0000', 'DomoDeviceFormat': 'str_2digits', 'ActionList': ['check_store_value', 'upd_domo_device']}"
2023-12-09 10:02:54,604 INFO :b' _majdomo_cluster: 0006'
2023-12-09 10:02:54,604 INFO :b"is_cluster_specific_config 000f/f000 and definition {'Enabled': True, 'Name': 'LegrandOnOff', 'DataType': '21', 'UpdDomoDeviceWithCluster': '0006', 'UpdDomoDeviceWithAttribute': '0000', 'DomoDeviceFormat': 'str_2digits', 'ActionList': ['check_store_value', 'upd_domo_device']}"
2023-12-09 10:02:54,605 INFO :b' _majdomo_attribute: 0000'
2023-12-09 10:02:54,607 ERROR : [ZiGateForwarder_2] ------> Auto Update (LegrandSelector 1) not found in SWITCH_SELECTORSHard:Raspberry Pi4 + SSD Arduino Tablette murale Archos
BRAVO !!!!
Ça marche
Un grand merci
Bon Week-End
Jihem
Ça marche
Un grand merci
Bon Week-End
Jihem
Modération
Si le sujet est terminé, merci de bien vouloir modifier le premier message de cette discussion pour indiquer [Résolu] dans le titre du sujet. Comment faire ? Voir le sujet [A lire avant de poster] Guide pour bien formuler une demande.
Ok, je met ca au propre, et je le bougerais sur une autre branche avant la release
pourrais-tu refaire un test pour vérifier que ca fonctionne toujours correctement
restart du plugin
git pull
