Perte de capteur aléatoire
mce35
Message par mce35 »
De temps à autre, certains de mes capteurs ne donnent plus de signes de vies et je suis obligé de les réintégrer manuellement au réseau Zigbee. Je n'ai que des capteurs Xiaomi (sauf un routeur Ikea) (une 30aine de capteurs).
Le dernier en date :
Jun  3 19:20:05 rasp3 domoticz: (Zigate) ReadCluster - 0000 ff02 Saddr: 3f37 ClusterData: 100021bd0b21a813240300000000218800205c
Jun  3 19:20:05 rasp3 domoticz: (Zigate) ReadCluster - 0000/ff02 Saddr: 3f37 Light Level: 43027
Jun  3 20:20:44 rasp3 domoticz: (Zigate) ReadCluster - 0000 - 3f37/01 AttrId: ff02 AttrType: 42 Attsize: 0013 Status: 00 AttrValue: 100021bd0b21a813240100000000218800205d
Jun  3 20:20:44 rasp3 domoticz: (Zigate) ReadCluster - 0000 ff02 Saddr: 3f37 ClusterData: 100021bd0b21a813240100000000218800205d
Jun  3 20:20:44 rasp3 domoticz: (Zigate) ReadCluster - 0000/ff02 Saddr: 3f37 Light Level: 43027
Jun  3 21:21:24 rasp3 domoticz: (Zigate) ReadCluster - 0000 - 3f37/01 AttrId: ff02 AttrType: 42 Attsize: 0013 Status: 00 AttrValue: 100021bd0b21a813240100000000218800205e
Jun  3 21:21:24 rasp3 domoticz: (Zigate) ReadCluster - 0000 ff02 Saddr: 3f37 ClusterData: 100021bd0b21a813240100000000218800205e
Jun  3 21:21:24 rasp3 domoticz: (Zigate) ReadCluster - 0000/ff02 Saddr: 3f37 Light Level: 43027
Jun  3 22:22:04 rasp3 domoticz: (Zigate) ReadCluster - 0000 - 3f37/01 AttrId: ff02 AttrType: 42 Attsize: 0013 Status: 00 AttrValue: 100021bd0b21a813240100000000218800205e
Jun  3 22:22:04 rasp3 domoticz: (Zigate) ReadCluster - 0000 ff02 Saddr: 3f37 ClusterData: 100021bd0b21a813240100000000218800205e
Jun  3 22:22:04 rasp3 domoticz: (Zigate) ReadCluster - 0000/ff02 Saddr: 3f37 Light Level: 43027
Jun  4 03:29:27 rasp3 domoticz: (Zigate) Porte buanderie (3f37/00158d0002282f65) send a Leave indication and will be outside of the network. RSSI: 00
Jun  4 13:00:44 rasp3 domoticz: (Zigate) Device Announcement Addr: ccc0, IEEE: 00158d0002282f65 Join Flag: 0x00 - join a network through association RSSI: 0 ChangeShortID: True
Jun  4 13:00:44 rasp3 domoticz: (Zigate) NetworkID : ccc0 is replacing 3f37 and is attached to IEEE : 00158d0002282f65
Jun  4 13:00:44 rasp3 domoticz: (Zigate) Device Announcement: Porte buanderie(ccc0, 00158d0002282f65) Join Flag: 0x99 - Unknown value received. RSSI: 87 ChangeShortID: False
Jusqu'a 22H22, pas de souci, le capteur envoi bien un signe de vie toutes les heures environ. Puis plus rien, a 3H29 il y a un leave (est-ce que c'est le capteur qui a demandé explicitement ou un timeout quelque part?). Je l'ai ensuite réintégré au réseau a 13H00. Le RSSI n'est pas mauvais, le capteur n'est pas très loin de la zigate.
Je n'ai pas encore assez de recul pour savoir si certains capteurs sont plus touchés que d'autres (c'est arrivé au moins sur porte et température, les capteurs de mouvement semble ne pas avoir ce pb mais ca reste à confirmer) ni la fréquence (semble assez rare cependant, plusieurs semaines), ni si cela dépend de la qualité du lien radio (mais visiblement cela arrive même sur des capteurs proches).
Est-ce que d'autres personne sont confrontées à ce problème?
Quelle peut en être l'origine? un bug sur les capteurs Xiaomi (mais pourtant ca ne semble pas toucher tous les capteurs même du même type)? Je vais peut-être acheter un capteur d'un autre fabriquant pour comparer.
Merci pour votre aide.
MCE35
Wolfen38
Re: Perte de capteur aléatoire
Message par Wolfen38 »
Moi ça arrivait souvent quand j'avais que les Xiaomi.
Maintenant j'ai ajouté des routeurs, prise Ikea, Inter de volet Legrand, et plus de perte
mce35
Message par mce35 »
Et les capteurs Xiaomi passent par ces routeurs?
Je n'ai qu'un seul routeur Ikea et même des capteurs qui sont relativement loin de la Zigate et qui pourraient passer par le routeur ne le font pas.
Je me demandais justement si je n'allais pas acheter des prises juste pour augmenter le nombre de routeur.
Wolfen38
Tu vois sur l'image par ex Inter sdb2 est sur la prise caméra porteImage
Après tu peux forcer l'appairage sur un routeur en particulier, par ex sur l'image mon capteur porte cuisine était sur volet Emerik qui est proche du capteur port, mais loin de la zigate, donc je l'ai re appairer sur le volet salon plus proche
Je suis dans la même configuration et une Zigate, environ 20 capteurs xiaomi et des prises Ikea.
J'ai toujours un capteur de température et une sonde d’inondation qui sont toujours en indéfini. De temps en temps de capteur de température se "réveille" quelques jours. Je n'y touche pourtant pas :roll:
mce35
Message par mce35 »
J'ai ajouté quelques routeurs (ampoules Hue/Ikea et prises Ikea), mais j'avais toujours des problèmes.
Cependant, à force d'ajouter des capteurs, j'ai atteint la limite des 40 en direct sur la Zigate.
Du coup, pour associer les capteurs au routeur le plus proche (puisqu'en particulier les Xiaomi ne savent pas changer de routeur tout seul, contrairement à d'autres), j'ai fais un erase PDM de la Zigate et tout réappairer (en commençant par les routeurs.
Cela fait 15 jours et depuis je n'ai pas eu de perte de capteur, en espérant que cela dure.
MCE35
