Mi Smart Plug (Zigbee) Model : ZNCZ04LM
calouis
Message par calouis »
Après inclusion avec la Zigate et redémarrage Domoticz, j'ai les logs suivants :
2020-06-15 12:44:56.552 Status: (ZG) Entering work loop.
2020-06-15 12:44:56.553 Status: (ZG) Initialized version 4.9, author 'zaraki673 pipiche38'
2020-06-15 12:45:03.550 (ZG) DomoticzVersion: 4.11214
2020-06-15 12:45:03.550 Status: (ZG) Zigate plugin stable-4.9.001 started
2020-06-15 12:45:03.550 Status: (ZG) Debug: 0
2020-06-15 12:45:03.550 Status: (ZG) load PluginConf
2020-06-15 12:45:03.554 Status: (ZG) port set to 8282
2020-06-15 12:45:03.554 Status: (ZG) pluginOTAFirmware set to /home/pi/domoticz/plugins/Domoticz-Zigate/OTAFirmware/
2020-06-15 12:45:03.554 Status: (ZG) pluginData set to /home/pi/domoticz/plugins/Domoticz-Zigate/Data/
2020-06-15 12:45:03.555 Status: (ZG) homedirectory set to /home/pi/domoticz/plugins/Domoticz-Zigate/
2020-06-15 12:45:03.555 Status: (ZG) pluginHome set to /home/pi/domoticz/plugins/Domoticz-Zigate/
2020-06-15 12:45:03.555 Status: (ZG) pluginReports set to /home/pi/domoticz/plugins/Domoticz-Zigate/Reports/
2020-06-15 12:45:03.555 Status: (ZG) pluginConfig set to /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/
2020-06-15 12:45:03.555 Status: (ZG) pluginLogs set to /home/pi/domoticz/plugins/Domoticz-Zigate/Logs/
2020-06-15 12:45:03.555 Status: (ZG) pluginWWW set to /home/pi/domoticz/plugins/Domoticz-Zigate/www/
2020-06-15 12:45:03.555 Status: (ZG) filename set to /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/PluginConf-17.json
2020-06-15 12:45:03.555 Status: (ZG) channel set to 11
2020-06-15 12:45:03.555 Status: (ZG) Switching Heartbeat to 5 s interval
2020-06-15 12:45:03.556 Status: (ZG) Python Version - 3.5.3 (default, Sep 27 2018, 17:25:39)
2020-06-15 12:45:03.556 Status: (ZG) DomoticzVersion: 4.11214
2020-06-15 12:45:03.556 Status: (ZG) DomoticzHash: e7672936b
2020-06-15 12:45:03.556 Status: (ZG) DomoticzBuildTime: 2019-08-19 10:51:32
2020-06-15 12:45:03.556 Status: (ZG) Opening DomoticzDB in raw
2020-06-15 12:45:03.621 Status: (ZG) Plugin Database: DeviceList-17.txt
2020-06-15 12:45:03.636 Status: (ZG) DeviceConf loaded
2020-06-15 12:45:03.687 Status: (ZG) --> Config loaded: dict_keys(['WarningDevice', 'TRADFRI bulb E26 WS clear 950lm', 'TRADFRI bulb E14 W opch 400lm', 'Shutters central remote switch', 'Pluzzy-Door', 'lumi.remote.b286opcn01', 'LXN56-DC27LX1.1', 'Pluzzy-Plug', 'SMOK_V16', '3AFE14010402000D', 'SML001', 'lumi.sensor_magnet', 'LCT015', 'TRADFRI Signal Repeater', 'PST03A-v2.2.5', 'lumi.sensor_switch.aq2', 'ZBT-ExtendedColor', 'Telecommande-Profalux', 'ZHA-CSW', 'EH-ZB-HACT', 'RB 285 C', 'TS0302', 'Pluzzy-Motion', 'Lamp_01', 'FB56-ZCW08KU1.1', 'GL-C-008', 'TS0201', 'lumi.vibration.aq1', 'LST002', 'LCT010', 'Pluzzy-TH', 'LCT003', 'GL-C-009', 'LIGHTIFY Indoor Flex RGBW', 'lumi.ctrl_neutral1', 'EH-ZB-BMS', 'LLC010', 'TS0011', 'VoletBSO-Profalux', 'lumi.weather', 'lumi.remote.b686opcn01', 'TRADFRI bulb E27 CWS opal 600lm', 'lumi.ctrl_86plug', 'GL-C-008Z', 'lumi.sensor_cube', 'Lightify Switch Mini', 'BSO-Profalux', 'Shutter switch with neutral', 'SAL6ET1', 'TRADFRI bulb E27 WS opal 1000lm', 'LTW013', 'lumi.sensor_wleak.aq1', 'GAS_V15', '3AFE130104020015', 'lumi.sensor_switch', 'FLOALT panel WS 30x90', 'lumi.sensor_natgas', 'lumi.sensor_ht', 'TI0001', '3AFE28010402000D', 'lumi.ctrl_neutral2', 'TRADFRI onoff switch', 'RC 110', 'LCT007', 'Connected outlet', 'TRADFRI bulb E27 opal 1000lm', 'GLEDOPTO', 'Thermostat', 'TRADFRI bulb GU10 WS 400lm', 'SmokeSensor-N-3.0', 'SPZB0001', 'TS0012', 'lumi.ctrl_ln2', 'LWB006', 'GL-C-008S', 'RH3001', 'PAR16 50 TW', 'lumi.remote.b486opcn01-bulb', '902010/28', 'lumi.remote.b686opcn01-bulb', 'RWL021', 'TRADFRI Driver 30W', 'EH-ZB-VACT', 'TS0003', 'EH-ZB-RTS', 'LTA001', 'TRADFRI motion sensor', 'Mobile outlet', 'FLOALT panel WS 60x60', 'Micromodule switch', 'LCT001', 'LIGHTIFY Outdoor Flex RGBW', 'lumi.router', 'ZPLUG', 'lumi.sensor_86sw2', 'TRADFRI bulb GU10 W 400lm', 'SmokeSensor-N', 'lumi.plug', 'ZHUM', 'Dimmer switch wo neutral', 'CLA60 TW OSRAM', 'TRADFRI bulb E14 WS 470lm', '3AFE140103020000', 'lumi.remote.b486opcn01', 'SPE600', 'TS0002', 'lumi.remote.b1acn01', 'lumi.ctrl_86plug.aq1', 'TRADFRI remote control', 'DIN power consumption module', 'EH-ZB-SPD', 'TS0001', 'lumi.remote.b286opcn01-bulb', 'lumi.light.aqcn02', 'lumi.sen_ill.mgl01', 'Cable outlet', 'GL-D-003Z', 'lumi.sensor_motion.aq2', 'lumi.remote.b186acn01', 'GL-B-008Z', 'TRADFRI bulb E27 WS opal 950lm', 'lumi.sensor_cube.aqgl01', 'TRADFRI bulb E27 W opal 1000lm', 'Zigate-Router', 'TRADFRI bulb E27 WS clear 950lm', 'Plug Z3', 'EH-ZB-LMACT', 'lumi.sensor_motion', 'TRADFRI bulb E14 WS opal 600lm', 'Double gangs remote switch', 'TRADFRI bulb E27 WW clear 250lm', 'TRADFRI bulb E26 WS opal 980lm', 'GL-B-007Z', '3AFE170100510001', 'RB 248 T', 'lumi.sensor_switch.aq3', 'lumi.sensor_86sw1', '902010/22', 'TRADFRI bulb E12 WS opal 400lm', '902010/21A', 'GL-MC-001', 'Super TR', 'EH-ZB-SPD-V2', 'ZMOVE', 'lumi.ctrl_ln2.aq1', 'Remote switch', 'lumi.relay.c2acn01', 'Plug 01', 'TRADFRI bulb E27 WS opal 980lm', 'LTC001', 'SML002', 'lumi.sensor_smoke', 'lumi.sensor_magnet.aq2', '3c4e4fc81ed442efaf69353effcdfc5f', 'TRADFRI control outlet', 'LTW001', 'TRADFRI bulb E14 WS opal 400lm', 'Volet-Profalux', 'TRADFRI wireless dimmer', 'LTW004', 'TRV10RFM', 'lumi.remote.b286acn01', 'TS0013', 'GL-FL-004TZS', 'COSensor-N'])
2020-06-15 12:45:03.687 Status: (ZG) load ListOfDevice
2020-06-15 12:45:03.968 Status: (ZG) Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigate/Data/DeviceList-17.txt
2020-06-15 12:45:04.001 Status: (ZG) Transport mode: USB
2020-06-15 12:45:04.003 Status: (ZG) Connection Name: Zigate, Transport: Serial, Address: /dev/ttyUSB-Zigate
2020-06-15 12:45:04.003 Status: (ZG) Connection open: Name: 'ZiGate', Transport: 'Serial', Protocol: 'None', Address: '/dev/ttyUSB-Zigate', Port: '', Baud: 115200, Connected: False, Parent: 'None'
2020-06-15 12:45:04.013 Status: (ZG) Trigger a Topology Scan
2020-06-15 12:45:04.015 Status: (ZG) Trigger a Energy Level Scan
2020-06-15 12:45:17.023 Status: (ZG) Major Version Num: 0003
2020-06-15 12:45:17.023 Status: (ZG) Installer Version Number: 030f
2020-06-15 12:45:26.155 Status: (ZG) Zigate addresses ieee: 00158d0001b22e1f , short addr: 0000
2020-06-15 12:45:26.155 Status: (ZG) Network state UP, PANID: 465a extPANID: 0x71b9e7f76a9c3e03 Channel: 11
2020-06-15 12:45:31.041 Status: (ZG) Request Disabling Accepting new Hardware
2020-06-15 12:45:31.446 Status: (ZG) Accepting new Hardware: Disable
2020-06-15 12:45:31.548 Status: (ZG) Number of devices recently active in Zigate = 15
2020-06-15 12:45:36.058 (ZG) Switch Blue Led On
2020-06-15 12:45:36.059 Status: (ZG) Zigate set to Certification : CE
2020-06-15 12:45:36.060 Status: (ZG) Start Web Server connection
2020-06-15 12:45:36.102 Status: (ZG) Web backend for Web User Interface started on port: 9440
2020-06-15 12:45:36.102 Status: (ZG) Plugin with Zigate firmware 030f correctly initialized
2020-06-15 12:45:41.165 Status: (ZG) There is a newer plugin version available on gitHub
Seul l'interrupteur fonctionne, mais pas de remontée sur la consommation après plusieurs essais avec une bouilloire ...
J'ai en double les type USAGE et GENERAL ?
Avez-vous eu ce problème ?
_ Raspberry Pi3 Stretch + Domoticz V4.11214
_ dzVents Version: 2.4.28
_ Python 3.5.3
_ usbZwave
_ RFX433XL USB Version: Pro XL1/1035
_ GW Xiaomi
_ station meteo Oregon & Netatmo
_ LMS
_ Yeelight
_ Tradfri
_ Zigate plugin 4.11.012 + Version : 031d
Re: Mi Smart Plug (Zigbee) Model : ZNCZ04LM
Dans un premier temps peux-tu mettre en attaché ici le fichier export.json comme indiqué dans le lien wiki ci-après
https://github.com/pipiche38/Domoticz-Z ... -device.md
calouis
Comment on fait pour attacher une extension .json non prise en charge ?
_ Python 3.5.3
_ usbZwave
_ GW Xiaomi
_ LMS
_ Yeelight
_ Tradfri
calouis
Il fallait le zipper ....
export.json.zip
(13.36 Kio) Téléchargé 186 fois
_ Python 3.5.3
_ usbZwave
_ GW Xiaomi
_ LMS
_ Yeelight
_ Tradfri
Super et merci pour les infos
Effectivement cette prise n'est pas 100% supportée par le plugin.
Je viens de pousser des modifs sur la branche beta, peux-tu y passer
depuis le repertoire du plugin ( Domoticz-Zigate )
git pull
git checkout beta
git pull
relancer le plugin
Supprimer les 6 widgets créées par le précédent appairage:
Power (2153), Meter (2154), Switch(2155), Power(2156), Meter(2157), Alarm(2158)
Puis refaire l'appairage. Devrait alors etre créé 4 widgets
Plug, Power, Meter et Voltage
Regardes ce qu'il se passe, et j'aurais besoin des logs, car je ne suis pas certain que tous fonctionne.
je suis interessé par des messages de ce type:
ReadCluster - 0000/0055 Saddr: .............
Merci d'avance
calouis
Voilà les logs.
Pour info : j'ai fait le jumelage dans mon bureau, puis débrancher et rebrancher dans cuisine et test on/off : OK.
Ensuite, ajouter bouilloire électrique et au moment où j'allume la bouilloire : diode qui clignote rouge rapide !
Puissance trop forte ? LIDL 2200W...
Avec une Nespresso, ça passe avec des erreurs :
2020-06-15 16:12:22.589 (ZG) DomoticzVersion: 4.11214
2020-06-15 16:12:22.588 Status: (ZG) Zigate plugin beta-4.10.002 started
2020-06-15 16:12:22.588 Status: (ZG) Debug: 0
2020-06-15 16:12:22.589 Status: (ZG) load PluginConf
2020-06-15 16:12:22.592 Status: (ZG) channel set to 11
2020-06-15 16:12:22.592 Status: (ZG) port set to 8282
2020-06-15 16:12:22.593 Status: (ZG) homedirectory set to /home/pi/domoticz/plugins/Domoticz-Zigate/
2020-06-15 16:12:22.593 Status: (ZG) pluginLogs set to /home/pi/domoticz/plugins/Domoticz-Zigate/Logs/
2020-06-15 16:12:22.593 Status: (ZG) pluginHome set to /home/pi/domoticz/plugins/Domoticz-Zigate/
2020-06-15 16:12:22.593 Status: (ZG) pluginData set to /home/pi/domoticz/plugins/Domoticz-Zigate/Data/
2020-06-15 16:12:22.593 Status: (ZG) pluginReports set to /home/pi/domoticz/plugins/Domoticz-Zigate/Reports/
2020-06-15 16:12:22.593 Status: (ZG) pluginWWW set to /home/pi/domoticz/plugins/Domoticz-Zigate/www/
2020-06-15 16:12:22.593 Status: (ZG) pluginConfig set to /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/
2020-06-15 16:12:22.593 Status: (ZG) filename set to /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/PluginConf-17.json
2020-06-15 16:12:22.593 Status: (ZG) pluginOTAFirmware set to /home/pi/domoticz/plugins/Domoticz-Zigate/OTAFirmware/
2020-06-15 16:12:22.594 Status: (ZG) Switching Heartbeat to 5 s interval
2020-06-15 16:12:22.594 Status: (ZG) Python Version - 3.5.3 (default, Sep 27 2018, 17:25:39)
2020-06-15 16:12:22.594 Status: (ZG) DomoticzVersion: 4.11214
2020-06-15 16:12:22.594 Status: (ZG) DomoticzHash: e7672936b
2020-06-15 16:12:22.594 Status: (ZG) DomoticzBuildTime: 2019-08-19 10:51:32
2020-06-15 16:12:22.594 Status: (ZG) Opening DomoticzDB in raw
2020-06-15 16:12:22.701 Status: (ZG) Plugin Database: DeviceList-17.txt
2020-06-15 16:12:22.708 Status: (ZG) DeviceConf loaded
2020-06-15 16:12:22.757 Status: (ZG) --> Config loaded: dict_keys(['lumi.ctrl_86plug', 'Remote switch', 'FLOALT panel WS 30x90', 'lumi.sen_ill.mgl01', '3AFE170100510001', 'lumi.ctrl_86plug.aq1', 'lumi.sensor_switch.aq2', 'SPZB0001', 'LST002', 'lumi.remote.b686opcn01-bulb', 'lumi.remote.b1acn01', 'TS0002', 'TRADFRI bulb E26 WS opal 980lm', 'TRADFRI control outlet', 'Lightify Switch Mini', 'TRADFRI bulb E14 WS 470lm', 'TRADFRI bulb E27 WS clear 950lm', 'GL-FL-004TZS', 'LLC010', 'lumi.ctrl_neutral2', 'lumi.sensor_cube.aqgl01', 'lumi.sensor_motion.aq2', 'TRADFRI wireless dimmer', 'TRADFRI Driver 30W', 'EH-ZB-VACT', 'GL-C-009', 'COSensor-N', 'GL-C-008', 'GL-MC-001', '902010/22', 'Thermostat', '3AFE28010402000D', 'TRADFRI onoff switch', 'TRADFRI bulb E27 W opal 1000lm', 'ZMOVE', '902010/28', 'TRADFRI bulb GU10 WS 400lm', 'lumi.light.aqcn02', 'EH-ZB-RTS', 'Telecommande-Profalux', 'EH-ZB-SPD-V2', 'GAS_V15', 'TRADFRI bulb E27 opal 1000lm', 'GL-C-008S', 'LTA001', 'TS0302', 'lumi.sensor_magnet', 'lumi.vibration.aq1', 'Plug 01', 'Cable outlet', 'TRADFRI bulb E27 WS opal 950lm', 'Pluzzy-Door', 'LTW001', '3c4e4fc81ed442efaf69353effcdfc5f', 'Shutter switch with neutral', 'TS0011', 'lumi.sensor_switch.aq3', 'lumi.weather', 'LTW004', 'Pluzzy-Plug', 'lumi.remote.b286opcn01', 'SmokeSensor-N', 'Volet-Profalux', 'lumi.sensor_ht', 'Lamp_01', '3AFE140103020000', 'lumi.router', 'TRADFRI bulb E27 WS opal 980lm', 'lumi.sensor_86sw2', 'LWB006', 'EH-ZB-LMACT', '3AFE130104020015', 'GL-B-008Z', 'lumi.remote.b286acn01', 'GL-B-007Z', 'TS0001', 'TRV10RFM', 'FLOALT panel WS 60x60', 'LTW013', 'LIGHTIFY Outdoor Flex RGBW', '902010/21A', 'LCT001', 'TRADFRI motion sensor', 'Pluzzy-Motion', 'EH-ZB-BMS', 'Mobile outlet', 'CLA60 TW OSRAM', 'LCT003', 'RB 248 T', 'SPE600', 'ZPLUG', 'lumi.remote.b686opcn01', 'lumi.ctrl_ln2.aq1', 'TRADFRI Signal Repeater', 'lumi.relay.c2acn01', 'lumi.sensor_cube', 'RB 285 C', 'EH-ZB-SPD', 'TRADFRI bulb E14 W opch 400lm', 'lumi.sensor_86sw1', 'LXN56-DC27LX1.1', 'TRADFRI bulb E12 WS opal 400lm', 'GLEDOPTO', 'lumi.remote.b186acn01', 'lumi.remote.b486opcn01-bulb', 'TRADFRI bulb E14 WS opal 600lm', 'PAR16 50 TW', '3AFE14010402000D', 'lumi.sensor_natgas', 'ZHA-CSW', 'lumi.ctrl_ln2', 'EH-ZB-HACT', 'LCT010', 'lumi.remote.b486opcn01', 'LIGHTIFY Indoor Flex RGBW', 'Connected outlet', 'RWL021', 'GL-C-008Z', 'Double gangs remote switch', 'lumi.sensor_magnet.aq2', 'ZHUM', 'lumi.plug.mmeu01', 'VoletBSO-Profalux', 'WarningDevice', 'SML002', 'DIN power consumption module', 'LTC001', 'TRADFRI bulb E14 WS opal 400lm', 'TRADFRI bulb GU10 W 400lm', 'lumi.sensor_wleak.aq1', 'TRADFRI bulb E27 WS opal 1000lm', 'LCT007', 'SML001', 'LCT015', 'TS0201', 'TI0001', 'TRADFRI bulb E27 CWS opal 600lm', 'lumi.sensor_motion', 'TS0012', 'TRADFRI remote control', 'SMOK_V16', 'lumi.plug', 'RH3001', 'ZBT-ExtendedColor', 'TRADFRI bulb E26 WS clear 950lm', 'Dimmer switch wo neutral', 'BSO-Profalux', 'SmokeSensor-N-3.0', 'Plug Z3', 'TS0013', 'lumi.sensor_switch', 'lumi.remote.b286opcn01-bulb', 'FB56-ZCW08KU1.1', 'SAL6ET1', 'TS0003', 'Zigate-Router', 'GL-D-003Z', 'Super TR', 'lumi.ctrl_neutral1', 'RC 110', 'Shutters central remote switch', 'Micromodule switch', 'PST03A-v2.2.5', 'Pluzzy-TH', 'lumi.sensor_smoke', 'TRADFRI bulb E27 WW clear 250lm'])
2020-06-15 16:12:22.758 Status: (ZG) load ListOfDevice
2020-06-15 16:12:23.816 (ZG) UpdateDevice - (ZG - Home-cinema cumul) 0:331.37;0.0
2020-06-15 16:12:23.823 (ZG) UpdateDevice - (ZG - Conso Home-cinema) 331.37:331.37
2020-06-15 16:12:23.056 Status: (ZG) Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigate/Data/DeviceList-17.txt
2020-06-15 16:12:23.091 Status: (ZG) Transport mode: USB
2020-06-15 16:12:23.092 Status: (ZG) Connection Name: Zigate, Transport: Serial, Address: /dev/ttyUSB-Zigate
2020-06-15 16:12:23.092 Status: (ZG) Connection open: Name: 'ZiGate', Transport: 'Serial', Protocol: 'None', Address: '/dev/ttyUSB-Zigate', Port: '', Baud: 115200, Connected: False, Parent: 'None'
2020-06-15 16:12:23.103 Status: (ZG) Trigger a Topology Scan
2020-06-15 16:12:23.104 Status: (ZG) Trigger a Energy Level Scan
2020-06-15 16:12:33.818 (ZG) UpdateDevice - (ZG - Home-cinema cumul) 0:308.63;0.0
2020-06-15 16:12:33.823 (ZG) UpdateDevice - (ZG - Conso Home-cinema) 308.63:308.63
2020-06-15 16:12:33.204 Status: (ZG) Major Version Num: 0003
2020-06-15 16:12:33.204 Status: (ZG) Installer Version Number: 030f
2020-06-15 16:12:43.811 (ZG) UpdateDevice - (ZG - Home-cinema cumul) 0:270.27;0.0
2020-06-15 16:12:43.817 (ZG) UpdateDevice - (ZG - Conso Home-cinema) 270.27:270.27
2020-06-15 16:12:43.312 Status: (ZG) Zigate addresses ieee: 00158d0001b22e1f , short addr: 0000
2020-06-15 16:12:43.312 Status: (ZG) Network state UP, PANID: 465a extPANID: 0x71b9e7f76a9c3e03 Channel: 11
2020-06-15 16:12:48.189 Status: (ZG) Request Disabling Accepting new Hardware
2020-06-15 16:12:48.598 Status: (ZG) Accepting new Hardware: Disable
2020-06-15 16:12:48.702 Status: (ZG) Number of devices recently active in Zigate = 14
2020-06-15 16:12:53.166 (ZG) Switch Blue Led On
2020-06-15 16:12:53.168 Status: (ZG) Zigate set to Certification : CE
2020-06-15 16:12:53.169 Status: (ZG) Start Web Server connection
2020-06-15 16:12:53.210 Status: (ZG) Web backend for Web User Interface started on port: 9440
2020-06-15 16:12:53.210 Status: (ZG) Plugin with Zigate firmware 030f correctly initialized
2020-06-15 16:12:58.398 Status: (ZG) There is a newer Zigate Firmware version available
2020-06-15 16:15:23.841 (ZG) UpdateDevice - (ZG - Home-cinema cumul) 0:260.91;0.0
2020-06-15 16:15:23.846 (ZG) UpdateDevice - (ZG - Conso Home-cinema) 260.91:260.91
2020-06-15 16:15:37.306 (ZG) UpdateDevice - (ZG - Capteur de vibrations) 2:20
2020-06-15 16:15:39.343 (ZG) lookupForIEEE - looking for 2c0b in Neighbourgs table
2020-06-15 16:15:39.343 (ZG) lookupForIEEE found IEEE 04cf8cdf3c7b2056 for 2c0b in none known as 2133 Neighbourg table
2020-06-15 16:15:39.344 (ZG) Found IEEE for short address: 2c0b is 04cf8cdf3c7b2056
2020-06-15 16:15:39.347 (ZG) lookupForIEEE - looking for 2c0b in Neighbourgs table
2020-06-15 16:15:39.347 (ZG) lookupForIEEE found IEEE 04cf8cdf3c7b2056 for 2c0b in none known as 2133 Neighbourg table
2020-06-15 16:15:39.348 (ZG) Found IEEE for short address: 2c0b is 04cf8cdf3c7b2056
2020-06-15 16:15:42.230 (ZG) --> Adding device 2c0b in self.DevicesInPairingMode
2020-06-15 16:15:42.230 (ZG) --> ['2c0b']
2020-06-15 16:15:42.230 Status: (ZG) Device Announcement Addr: 2c0b, IEEE: 04cf8cdf3c7b2056 Join Flag: 0x99 - Unknown value received. RSSI: 117 ChangeShortID: False
2020-06-15 16:15:42.360 Status: (ZG) [-] NEW OBJECT: 2c0b Active Endpoint Response Ep: 01 RSSI: 114
2020-06-15 16:15:42.360 Status: (ZG) [-] NEW OBJECT: 2c0b Active Endpoint Response Ep: 15 RSSI: 114
2020-06-15 16:15:42.360 Status: (ZG) [-] NEW OBJECT: 2c0b Active Endpoint Response Ep: 16 RSSI: 114
2020-06-15 16:15:42.360 Status: (ZG) [-] NEW OBJECT: 2c0b Active Endpoint Response Ep: f2 RSSI: 114
2020-06-15 16:15:42.360 Status: (ZG) [-] NEW OBJECT: 2c0b Request Simple Descriptor for Ep: f2
2020-06-15 16:15:42.361 Status: (ZG) [-] NEW OBJECT: 2c0b Request Simple Descriptor for Ep: 16
2020-06-15 16:15:42.361 Status: (ZG) [-] NEW OBJECT: 2c0b Request Simple Descriptor for Ep: 15
2020-06-15 16:15:42.361 Status: (ZG) [-] NEW OBJECT: 2c0b Request Simple Descriptor for Ep: 01
2020-06-15 16:15:42.463 Status: (ZG) [-] NEW OBJECT: 2c0b Simple Descriptor Response EP: 0xf2 RSSI: 99
2020-06-15 16:15:42.463 Status: (ZG) [-] NEW OBJECT: 2c0b ProfileID a1e0
2020-06-15 16:15:42.463 Status: (ZG) [-] NEW OBJECT: 2c0b ZDeviceID 0061
2020-06-15 16:15:42.463 Status: (ZG) [-] NEW OBJECT: 2c0b Application Version 0000
2020-06-15 16:15:42.464 Status: (ZG) [-] NEW OBJECT: 2c0b Cluster IN Count: 00
2020-06-15 16:15:42.464 Status: (ZG) [-] NEW OBJECT: 2c0b Cluster OUT Count: 01
2020-06-15 16:15:42.464 Status: (ZG) [-] NEW OBJECT: 2c0b Cluster Out 1: 0021
2020-06-15 16:15:42.566 Status: (ZG) [-] NEW OBJECT: 2c0b Simple Descriptor Response EP: 0x16 RSSI: 102
2020-06-15 16:15:42.566 Status: (ZG) [-] NEW OBJECT: 2c0b ProfileID 0104
2020-06-15 16:15:42.566 Status: (ZG) [-] NEW OBJECT: 2c0b ZDeviceID 0051
2020-06-15 16:15:42.566 Status: (ZG) [-] NEW OBJECT: 2c0b Application Version 0001
2020-06-15 16:15:42.566 Status: (ZG) [-] NEW OBJECT: 2c0b Cluster IN Count: 01
2020-06-15 16:15:42.566 Status: (ZG) [-] NEW OBJECT: 2c0b Cluster In 1: 000c (Analog Input (basic))
2020-06-15 16:15:42.566 Status: (ZG) [-] NEW OBJECT: 2c0b Cluster OUT Count: 00
2020-06-15 16:15:42.673 Status: (ZG) [-] NEW OBJECT: 2c0b Simple Descriptor Response EP: 0x15 RSSI: 105
2020-06-15 16:15:42.673 Status: (ZG) [-] NEW OBJECT: 2c0b ProfileID 0104
2020-06-15 16:15:42.673 Status: (ZG) [-] NEW OBJECT: 2c0b ZDeviceID 0051
2020-06-15 16:15:42.673 Status: (ZG) [-] NEW OBJECT: 2c0b Application Version 0001
2020-06-15 16:15:42.674 Status: (ZG) [-] NEW OBJECT: 2c0b Cluster IN Count: 01
2020-06-15 16:15:42.674 Status: (ZG) [-] NEW OBJECT: 2c0b Cluster In 1: 000c (Analog Input (basic))
2020-06-15 16:15:42.674 Status: (ZG) [-] NEW OBJECT: 2c0b Cluster OUT Count: 00
2020-06-15 16:15:42.776 Status: (ZG) [-] NEW OBJECT: 2c0b Simple Descriptor Response EP: 0x01 RSSI: 99
2020-06-15 16:15:42.777 Status: (ZG) [-] NEW OBJECT: 2c0b ProfileID 0104
2020-06-15 16:15:42.777 Status: (ZG) [-] NEW OBJECT: 2c0b ZDeviceID 0051
2020-06-15 16:15:42.777 Status: (ZG) [-] NEW OBJECT: 2c0b Application Version 0001
2020-06-15 16:15:42.777 Status: (ZG) [-] NEW OBJECT: 2c0b Cluster IN Count: 07
2020-06-15 16:15:42.777 Status: (ZG) [-] NEW OBJECT: 2c0b Cluster In 1: 0000 (Basic)
2020-06-15 16:15:42.777 Status: (ZG) [-] NEW OBJECT: 2c0b Cluster In 2: 0002
2020-06-15 16:15:42.777 Status: (ZG) [-] NEW OBJECT: 2c0b Cluster In 3: 0003 (Identify)
2020-06-15 16:15:42.777 Status: (ZG) [-] NEW OBJECT: 2c0b Cluster In 4: 0004 (Groups)
2020-06-15 16:15:42.777 Status: (ZG) [-] NEW OBJECT: 2c0b Cluster In 5: 0005 (Scenes)
2020-06-15 16:15:42.777 Status: (ZG) [-] NEW OBJECT: 2c0b Cluster In 6: 0006 (On/Off)
2020-06-15 16:15:42.777 Status: (ZG) [-] NEW OBJECT: 2c0b Cluster In 7: fcc0
2020-06-15 16:15:42.777 Status: (ZG) [-] NEW OBJECT: 2c0b Cluster OUT Count: 02
2020-06-15 16:15:42.777 Status: (ZG) [-] NEW OBJECT: 2c0b Cluster Out 1: 000a (Time)
2020-06-15 16:15:42.777 Status: (ZG) [-] NEW OBJECT: 2c0b Cluster Out 2: 0019 (Over-the-Air Upgrade)
2020-06-15 16:15:43.836 (ZG) UpdateDevice - (ZG - Home-cinema cumul) 0:298.37;0.0
2020-06-15 16:15:43.841 (ZG) UpdateDevice - (ZG - Conso Home-cinema) 298.37:298.37
2020-06-15 16:15:47.374 Status: (ZG) [0] NEW OBJECT: 2c0b Request Node Descriptor
2020-06-15 16:15:48.666 (ZG) readCluster - 0006 - 2c0b/01 unknown attribute: 00f5 23 0004 022c0b00
2020-06-15 16:15:52.381 (ZG) Ep: f2 found in DeviceConf
2020-06-15 16:15:52.381 (ZG) 'Type' entry found inf DeviceConf
2020-06-15 16:15:52.382 (ZG) Ep: 16 found in DeviceConf
2020-06-15 16:15:52.382 (ZG) 'Type' entry found inf DeviceConf
2020-06-15 16:15:52.854 (ZG) UpdateDevice - (ZG - lumi.plug.mmeu01_Plug-04cf8cdf3c7b2056-01) 0:Off
2020-06-15 16:31:06.923 (ZG) UpdateDevice - (ZG - lumi.plug.mmeu01_Meter-04cf8cdf3c7b2056-15) 0:514.8;0.0
2020-06-15 16:31:06.933 (ZG) UpdateDevice - (ZG - lumi.plug.mmeu01_Power-04cf8cdf3c7b2056-15) 514.8:514.8
2020-06-15 16:31:12.545 (ZG) ReadCluster - 0000/ff01 Saddr: 4839/01 Consumption 7d9e8444
2020-06-15 16:31:12.545 Error: (ZG) 'onMessage' failed 'TypeError':'decodeFloat() takes 1 positional argument but 3 were given'.
2020-06-15 16:31:12.545 Error: (ZG) ----> Line 984 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onMessage
2020-06-15 16:31:12.545 Error: (ZG) ----> Line 519 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onMessage
2020-06-15 16:31:12.545 Error: (ZG) ----> Line 325 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Classes/Transport.py', function onMessage
2020-06-15 16:31:12.545 Error: (ZG) ----> Line 538 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Classes/Transport.py', function processFrame
2020-06-15 16:31:12.545 Error: (ZG) ----> Line 523 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function processFrame
2020-06-15 16:31:12.545 Error: (ZG) ----> Line 122 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Modules/input.py', function ZigateRead
2020-06-15 16:31:12.545 Error: (ZG) ----> Line 1773 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Modules/input.py', function Decode8102
2020-06-15 16:31:12.545 Error: (ZG) ----> Line 222 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Modules/readClusters.py', function ReadCluster
2020-06-15 16:31:12.545 Error: (ZG) ----> Line 515 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Modules/readClusters.py', function Cluster0000
2020-06-15 16:31:12.545 Error: (ZG) ----> Line 284 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Modules/lumi.py', function readXiaomiCluster
_ Python 3.5.3
_ usbZwave
_ GW Xiaomi
_ LMS
_ Yeelight
_ Tradfri
calouis
Je possède également ce type de plug en version chinoise, avec adaptateur la bouilloire a bien chauffée....
_ Python 3.5.3
_ usbZwave
_ GW Xiaomi
_ LMS
_ Yeelight
_ Tradfri
peux-tu faire un update
git pull
et simplement relancer le plugin
Dis-moi ce que ca donne
calouis
Voilà, je n'ai plus de message d'erreurs, mais l'interrupteur passe à OFF et clignote rouge rapidement avec bouilloire...
020-06-15 17:22:23.888 Status: (ZG) Stopped.
2020-06-15 17:22:36.630 Status: (ZG) Started.
2020-06-15 17:22:37.090 (ZG) DomoticzVersion: 4.11214
2020-06-15 17:22:37.076 Status: (ZG) Entering work loop.
2020-06-15 17:22:37.077 Status: (ZG) Initialized version 4.10, author 'zaraki673 pipiche38'
2020-06-15 17:22:37.090 Status: (ZG) Zigate plugin beta-4.10.002 started
2020-06-15 17:22:37.090 Status: (ZG) Debug: 0
2020-06-15 17:22:37.090 Status: (ZG) load PluginConf
2020-06-15 17:22:37.092 Status: (ZG) channel set to 11
2020-06-15 17:22:37.092 Status: (ZG) port set to 8282
2020-06-15 17:22:37.092 Status: (ZG) homedirectory set to /home/pi/domoticz/plugins/Domoticz-Zigate/
2020-06-15 17:22:37.092 Status: (ZG) pluginLogs set to /home/pi/domoticz/plugins/Domoticz-Zigate/Logs/
2020-06-15 17:22:37.092 Status: (ZG) pluginHome set to /home/pi/domoticz/plugins/Domoticz-Zigate/
2020-06-15 17:22:37.092 Status: (ZG) pluginData set to /home/pi/domoticz/plugins/Domoticz-Zigate/Data/
2020-06-15 17:22:37.092 Status: (ZG) pluginReports set to /home/pi/domoticz/plugins/Domoticz-Zigate/Reports/
2020-06-15 17:22:37.092 Status: (ZG) pluginWWW set to /home/pi/domoticz/plugins/Domoticz-Zigate/www/
2020-06-15 17:22:37.092 Status: (ZG) pluginConfig set to /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/
2020-06-15 17:22:37.092 Status: (ZG) filename set to /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/PluginConf-17.json
2020-06-15 17:22:37.092 Status: (ZG) pluginOTAFirmware set to /home/pi/domoticz/plugins/Domoticz-Zigate/OTAFirmware/
2020-06-15 17:22:37.093 Status: (ZG) Switching Heartbeat to 5 s interval
2020-06-15 17:22:37.093 Status: (ZG) Python Version - 3.5.3 (default, Sep 27 2018, 17:25:39)
2020-06-15 17:22:37.093 Status: (ZG) DomoticzVersion: 4.11214
2020-06-15 17:22:37.093 Status: (ZG) DomoticzHash: e7672936b
2020-06-15 17:22:37.093 Status: (ZG) DomoticzBuildTime: 2019-08-19 10:51:32
2020-06-15 17:22:37.093 Status: (ZG) Opening DomoticzDB in raw
2020-06-15 17:22:37.107 Status: (ZG) Plugin Database: DeviceList-17.txt
2020-06-15 17:22:37.115 Status: (ZG) DeviceConf loaded
2020-06-15 17:22:37.197 Status: (ZG) --> Config loaded: dict_keys(['lumi.ctrl_86plug', 'Remote switch', 'FLOALT panel WS 30x90', 'lumi.sen_ill.mgl01', '3AFE170100510001', 'lumi.ctrl_86plug.aq1', 'lumi.sensor_switch.aq2', 'SPZB0001', 'LST002', 'lumi.remote.b686opcn01-bulb', 'lumi.remote.b1acn01', 'TS0002', 'TRADFRI bulb E26 WS opal 980lm', 'TRADFRI control outlet', 'Lightify Switch Mini', 'TRADFRI bulb E14 WS 470lm', 'TRADFRI bulb E27 WS clear 950lm', 'GL-FL-004TZS', 'LLC010', 'lumi.ctrl_neutral2', 'lumi.sensor_cube.aqgl01', 'lumi.sensor_motion.aq2', 'TRADFRI wireless dimmer', 'TRADFRI Driver 30W', 'EH-ZB-VACT', 'GL-C-009', 'COSensor-N', 'GL-C-008', 'GL-MC-001', '902010/22', 'Thermostat', '3AFE28010402000D', 'TRADFRI onoff switch', 'TRADFRI bulb E27 W opal 1000lm', 'ZMOVE', '902010/28', 'TRADFRI bulb GU10 WS 400lm', 'lumi.light.aqcn02', 'EH-ZB-RTS', 'Telecommande-Profalux', 'EH-ZB-SPD-V2', 'GAS_V15', 'TRADFRI bulb E27 opal 1000lm', 'GL-C-008S', 'LTA001', 'TS0302', 'lumi.sensor_magnet', 'lumi.vibration.aq1', 'Plug 01', 'Cable outlet', 'TRADFRI bulb E27 WS opal 950lm', 'Pluzzy-Door', 'LTW001', '3c4e4fc81ed442efaf69353effcdfc5f', 'Shutter switch with neutral', 'TS0011', 'lumi.sensor_switch.aq3', 'lumi.weather', 'LTW004', 'Pluzzy-Plug', 'lumi.remote.b286opcn01', 'SmokeSensor-N', 'Volet-Profalux', 'lumi.sensor_ht', 'Lamp_01', '3AFE140103020000', 'lumi.router', 'TRADFRI bulb E27 WS opal 980lm', 'lumi.sensor_86sw2', 'LWB006', 'EH-ZB-LMACT', '3AFE130104020015', 'GL-B-008Z', 'lumi.remote.b286acn01', 'GL-B-007Z', 'TS0001', 'TRV10RFM', 'FLOALT panel WS 60x60', 'LTW013', 'LIGHTIFY Outdoor Flex RGBW', '902010/21A', 'LCT001', 'TRADFRI motion sensor', 'Pluzzy-Motion', 'EH-ZB-BMS', 'Mobile outlet', 'CLA60 TW OSRAM', 'LCT003', 'RB 248 T', 'SPE600', 'ZPLUG', 'lumi.remote.b686opcn01', 'lumi.ctrl_ln2.aq1', 'TRADFRI Signal Repeater', 'lumi.relay.c2acn01', 'lumi.sensor_cube', 'RB 285 C', 'EH-ZB-SPD', 'TRADFRI bulb E14 W opch 400lm', 'lumi.sensor_86sw1', 'LXN56-DC27LX1.1', 'TRADFRI bulb E12 WS opal 400lm', 'GLEDOPTO', 'lumi.remote.b186acn01', 'lumi.remote.b486opcn01-bulb', 'TRADFRI bulb E14 WS opal 600lm', 'PAR16 50 TW', '3AFE14010402000D', 'lumi.sensor_natgas', 'ZHA-CSW', 'lumi.ctrl_ln2', 'EH-ZB-HACT', 'LCT010', 'lumi.remote.b486opcn01', 'LIGHTIFY Indoor Flex RGBW', 'Connected outlet', 'RWL021', 'GL-C-008Z', 'Double gangs remote switch', 'lumi.sensor_magnet.aq2', 'ZHUM', 'lumi.plug.mmeu01', 'VoletBSO-Profalux', 'WarningDevice', 'SML002', 'DIN power consumption module', 'LTC001', 'TRADFRI bulb E14 WS opal 400lm', 'TRADFRI bulb GU10 W 400lm', 'lumi.sensor_wleak.aq1', 'TRADFRI bulb E27 WS opal 1000lm', 'LCT007', 'SML001', 'LCT015', 'TS0201', 'TI0001', 'TRADFRI bulb E27 CWS opal 600lm', 'lumi.sensor_motion', 'TS0012', 'TRADFRI remote control', 'SMOK_V16', 'lumi.plug', 'RH3001', 'ZBT-ExtendedColor', 'TRADFRI bulb E26 WS clear 950lm', 'Dimmer switch wo neutral', 'BSO-Profalux', 'SmokeSensor-N-3.0', 'Plug Z3', 'TS0013', 'lumi.sensor_switch', 'lumi.remote.b286opcn01-bulb', 'FB56-ZCW08KU1.1', 'SAL6ET1', 'TS0003', 'Zigate-Router', 'GL-D-003Z', 'Super TR', 'lumi.ctrl_neutral1', 'RC 110', 'Shutters central remote switch', 'Micromodule switch', 'PST03A-v2.2.5', 'Pluzzy-TH', 'lumi.sensor_smoke', 'TRADFRI bulb E27 WW clear 250lm'])
2020-06-15 17:22:37.197 Status: (ZG) load ListOfDevice
2020-06-15 17:22:47.221 Status: (ZG) Major Version Num: 0003
2020-06-15 17:22:47.222 Status: (ZG) Installer Version Number: 030f
2020-06-15 17:22:57.263 Status: (ZG) Zigate addresses ieee: 00158d0001b22e1f , short addr: 0000
2020-06-15 17:22:57.264 Status: (ZG) Network state UP, PANID: 465a extPANID: 0x71b9e7f76a9c3e03 Channel: 11
2020-06-15 17:23:02.115 Status: (ZG) Request Disabling Accepting new Hardware
2020-06-15 17:23:05.310 (ZG) UpdateDevice - (ZG - Home-cinema cumul) 0:317.55;0.0
2020-06-15 17:23:05.321 (ZG) UpdateDevice - (ZG - Conso Home-cinema) 317.55:317.55
2020-06-15 17:23:05.662 Status: (ZG) Accepting new Hardware: Disable
2020-06-15 17:23:05.764 Status: (ZG) Number of devices recently active in Zigate = 15
2020-06-15 17:23:09.753 (ZG) Switch Blue Led On
2020-06-15 17:23:09.755 Status: (ZG) Zigate set to Certification : CE
2020-06-15 17:23:09.756 Status: (ZG) Start Web Server connection
2020-06-15 17:23:09.796 Status: (ZG) Web backend for Web User Interface started on port: 9440
2020-06-15 17:23:09.797 Status: (ZG) Plugin with Zigate firmware 030f correctly initialized
2020-06-15 17:23:14.972 Status: (ZG) There is a newer Zigate Firmware version available
2020-06-15 17:28:16.084 (ZG) UpdateDevice - (ZG - lumi.plug.mmeu01_Meter) 0:415.8;0.0
2020-06-15 17:28:16.090 (ZG) UpdateDevice - (ZG - lumi.plug.mmeu01_Power) 415.8:415.8
2020-06-15 17:29:08.825 (ZG) UpdateDevice - (ZG - lumi.plug.mmeu01_Meter) 0:1.29;0.0
2020-06-15 17:29:08.835 (ZG) UpdateDevice - (ZG - lumi.plug.mmeu01_Power) 1.29:1.292
2020-06-15 17:29:10.034 (ZG) UpdateDevice - (ZG - lumi.plug.mmeu01_Meter) 0:445.5;0.0
2020-06-15 17:29:10.040 (ZG) UpdateDevice - (ZG - lumi.plug.mmeu01_Power) 445.5:445.5
2020-06-15 17:29:34.935 (ZG) UpdateDevice - (ZG - lumi.plug.mmeu01_Meter) 0:1291.95;0.0
2020-06-15 17:29:34.945 (ZG) UpdateDevice - (ZG - lumi.plug.mmeu01_Power) 1291.95:1291.95
2020-06-15 17:30:57.212 (ZG) UpdateDevice - (ZG - lumi.plug.mmeu01) 0:Off
2020-06-15 17:31:17.565 (ZG) UpdateDevice - (ZG - lumi.plug.mmeu01) 1:On
2020-06-15 17:31:41.955 (ZG) UpdateDevice - (ZG - lumi.plug.mmeu01_Meter) 0:2286.9;0.0
2020-06-15 17:31:41.970 (ZG) UpdateDevice - (ZG - lumi.plug.mmeu01_Power) 2286.9:2286.9
2020-06-15 17:31:58.355 (ZG) UpdateDevice - (ZG - lumi.plug.mmeu01_Meter) 0:0.0;0.0
2020-06-15 17:31:58.360 (ZG) UpdateDevice - (ZG - lumi.plug.mmeu01_Power) 0.0:0.0
2020-06-15 17:31:58.393 (ZG) UpdateDevice - (ZG - lumi.plug.mmeu01) 0:Off
_ Python 3.5.3
_ usbZwave
_ GW Xiaomi
_ LMS
_ Yeelight
_ Tradfri
calouis
1ere courbe : nespresso
2de : bouilloire
_ Python 3.5.3
_ usbZwave
_ GW Xiaomi
_ LMS
_ Yeelight
_ Tradfri
