demande entreaide JSON / DZVENTS
multinet
Message par multinet »
Je suis à la recherche d'une aide pour extraire en DZVENTS des données de ce retour JSON que j'obtiens de mon appel api netatmo et qui est stocké dans l'objet : item.json (certaines données anonymisée).
J'aimerais récuperer les données contenues dans les dashboard_data (de device et de chaque module). Je n'ai pas réussi à coder en dzvents cette récupération (pour ensuite valoriser mes devices).
Toute aide est la bienvenue :) merci à vous
"body": {
"devices": [
                    "_id": "*****",
                    "station_name": "*****",
                    "date_setup": 1359763200,
                    "last_setup": 1359763200,
                    "type": "NAMain",
                    "last_status_store": 1592734332,
                    "module_name": "Salon",
                    "firmware": 177,
                    "last_upgrade": 1486894899,
                    "wifi_status": 50,
                    "reachable": true,
                    "co2_calibrating": false,
                    "data_type": [
                        "Temperature",
                        "CO2",
                        "Humidity",
                        "Noise",
                        "Pressure"
                    ], // data_type
                    "place": {
                          "altitude": 36,
                          "city": "******",
                          "country": "FR",
                          "timezone": "Europe/Paris",
                          "location": [
                                      -0.00000,
                                      00.000000
                    "dashboard_data": {
                          "time_utc": 1592733109,
                          "Temperature": 23.6,
                          "CO2": 421,
                          "Humidity": 58,
                          "Noise": 45,
                          "Pressure": 1027.7,
                          "AbsolutePressure": 1023.4,
                          "min_temp": 21.5,
                          "max_temp": 23.8,
                          "date_max_temp": 1592730861,
                          "date_min_temp": 1592718251,
                          "temp_trend": "stable",
                          "pressure_trend": "up"
                      "modules": [
                                "_id": "*************",
                                "type": "NAModule1",
                                "module_name": "Jardin",
                                "last_setup": 1356994864,
                                "data_type": [
                                    "Temperature",
                                    "Humidity"
                                "battery_percent": 100,
                                "reachable": true,
                                "firmware": 50,
                                "last_message": 1592734328,
                                "last_seen": 1592734289,
                                "rf_status": 61,
                                "battery_vp": 6234,
                                "dashboard_data": {
                                    "time_utc": 1592733059,
                                    "Temperature": 23.7,
                                    "Humidity": 61,
                                    "min_temp": 15,
                                    "max_temp": 24.3,
                                    "date_max_temp": 1592730548,
                                    "date_min_temp": 1592713939,
                                    "temp_trend": "down"
                                "_id": "***********",
                                "type": "NAModule3",
                                "module_name": "Pluviomètre",
                                "last_setup": 1522256764,
                                "data_type": [
                                      "Rain"
                                "battery_percent": 53,
                                "reachable": true,
                                "firmware": 12,
                                "last_seen": 1592734321,
                                "rf_status": 86,
                                "battery_vp": 4962,
                                "dashboard_data": {
                                    "time_utc": 1592733104,
                                    "Rain": 0,
                                    "sum_rain_1": 0,
                                    "sum_rain_24": 0
                                "_id": "****************",
                                "type": "NAModule2",
                                "module_name": "Anémomètre",
                                "last_setup": 1544359768,
                                "data_type": [
                                    "Wind"
                                "battery_percent": 84,
                                "reachable": true,
                                "firmware": 25,
                                "last_seen": 1592734328,
                                "rf_status": 67,
                                "battery_vp": 5676,
                                "dashboard_data": {
                                    "WindStrength": 5,
                                    "WindAngle": 313,
                                    "GustStrength": 17,
                                    "GustAngle": 315,
                                    "max_wind_str": 38,
                                    "max_wind_angle": 313,
                                    "date_max_wind_str": 1592731900
                        ] // modules
                  } // devices
                ], // devices
  "user": {
      "mail": "**************",
      "administrative": {
          "country": "FR",
          "feel_like_algo": 0,
          "lang": "fr-FR",
          "reg_locale": "fr-FR",
          "unit": 0,
          "windunit": 0
  }, // body
  "status": "ok",
  "time_exec": 0.10169386863708496,
  "time_server": 1592734433
  } // head
Re: demande entreaide JSON / DZVENTS
Il n'y a pas beaucoup de différence entre le LUA et le DZvents pour récupérer des infos d'un Json.
Le forum est plein d'exemples. J'utilise des infos Json dans mon Tuto OpenWeatherMap (lien en signature).
La difficulté peut-être au niverau de la récupération des info avec weather = jsonValeur.current.weather[1].description (exemple). Poste nous que tu n'arrives pas à obtenir et on pourra certainement t'aiguiller.
multinet
Merci pour ta réponse
voici mon (bout de) code :
	    local msg = domoticz.time.rawTime..'\n\r'..version..'\n\r\n\r'
	    if (item.isTimer) then
	        domoticz.data.dist = 0
	    	-- Lecture des données de ma station
--print("IS TIMER")
--print("token : "..domoticz.globalData.access_token)
			domoticz.openURL({url = 'https://api.netatmo.com/api/getstationsdata',
				method = 'POST',
				callback = 'meteoNetatmo',
				postData = {
					access_token = domoticz.globalData.access_token,
					device_id = myStation,
					get_favorites = false
	-- TRAITEMENT de la réponse de NETATMO
	if (item.isHTTPResponse) then
		if (item.ok) then
			if (item.isJSON) then
				if (item.json.body.errors == nil) then
					if (item.callback == 'meteoNetatmo') then
print("INSIDE")
                        local valeur      = item.json.body.device[1]['dashboard_data']['Temperature']
print(valeur)
Dans la log j'ai bien le message 'INSIDE' qui implique que j'ai un JSON en retour de l'appel api qui est OK
en fait ce que je n'arrive pas a maitriser c'est comment adresser la valeur alors que le json a des tableaux intégrés ?
===> item.json.body.device[1]['dashboard_data']['Temperature']
doit etre sans doute adressé autrement ?
Je vais regardé tes tutos en //
merci
multinet
Rebonjour
c'est bon avec l'aide de ton tuto j'ai trouvé !
local valeur = item.json.body.devices[1].dashboard_data.Temperature
il manquait au passage le s de devices ce qui explique pourquoi je n'étais pas parvenu malgré tout mes essais a trouver.
Encore merci
Multinet
Tant mieux que tu ai pu trouver la bonne syntaxe.
Bonne continuation ;)
