je débute sous domoticz et je n'arrive pas à parametrer une prise connectée TP-Link HS110.
J'ai ce script dans /domoticz/scripts/python/ avec les droit d'executions :
-rwxr-xr-x 1 pi pi 3063 juil. 13 10:11 tplink-smartplug.py
#!/usr/bin/env python
# TP-Link Wi-Fi Smart Plug Protocol Client
# For use with TP-Link HS-100 or HS-110
# by Lubomir Stroetmann
# Copyright 2016 softScheck GmbH
# Licensed under the Apache License, Version 2.0 (the "License");
# you may not use this file except in compliance with the License.
# You may obtain a copy of the License at
# http://www.apache.org/licenses/LICENSE-2.0
# Unless required by applicable law or agreed to in writing, software
# distributed under the License is distributed on an "AS IS" BASIS,
# WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
# See the License for the specific language governing permissions and
# limitations under the License.
import socket
import argparse
version = 0.1
# Check if IP is valid
def validIP(ip):
try:
socket.inet_pton(socket.AF_INET, ip)
except socket.error:
parser.error("Invalid IP Address.")
return ip
# Predefined Smart Plug Commands
# For a full list of commands, consult tplink_commands.txt
commands = {'info' : '{"system":{"get_sysinfo":{}}}',
'on' : '{"system":{"set_relay_state":{"state":1}}}',
'off' : '{"system":{"set_relay_state":{"state":0}}}',
'cloudinfo': '{"cnCloud":{"get_info":{}}}',
'wlanscan' : '{"netif":{"get_scaninfo":{"refresh":0}}}',
'time' : '{"time":{"get_time":{}}}',
'schedule' : '{"schedule":{"get_rules":{}}}',
'countdown': '{"count_down":{"get_rules":{}}}',
'antitheft': '{"anti_theft":{"get_rules":{}}}',
'reboot' : '{"system":{"reboot":{"delay":1}}}',
'reset' : '{"system":{"reset":{"delay":1}}}'
# Encryption and Decryption of TP-Link Smart Home Protocol
# XOR Autokey Cipher with starting key = 171
def encrypt(string):
key = 171
result = "\0\0\0\0"
for i in string:
a = key ^ ord(i)
key = a
result += chr(a)
return result
def decrypt(string):
key = 171
result = ""
for i in string:
a = key ^ ord(i)
key = ord(i)
result += chr(a)
return result
# Parse commandline arguments
parser = argparse.ArgumentParser(description="TP-Link Wi-Fi Smart Plug Client v" + str(version))
parser.add_argument("-t", "--target", metavar="<ip>", required=True, help="Target IP Address", type=validIP)
group = parser.add_mutually_exclusive_group(required=True)
group.add_argument("-c", "--command", metavar="<command>", help="Preset command to send. Choices are: "+", ".join(commands), choices=commands)
group.add_argument("-j", "--json", metavar="<JSON string>", help="Full JSON string of command to send")
args = parser.parse_args()
# Set target IP, port and command to send
ip = args.target
port = 9999
if args.command is None:
cmd = args.json
else:
cmd = commands[args.command]
# Send command and receive reply
try:
sock_tcp = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
sock_tcp.connect((ip, port))
sock_tcp.send(encrypt(cmd))
data = sock_tcp.recv(2048)
sock_tcp.close()
print "Sent: ", cmd
print "Received: ", decrypt(data[4:])
quit("Cound not connect to host " + ip + ":" + str(port))
Je n'arrive pas à piloter la prise, alors que cela fonction bien via KASA.
Ces commandes ne retournent rien du tout :
pi@domoticz:~/domoticz/scripts/python $ python tplink-smartplug.py -t 192.168.1.32 -c on
Sent: {"system":{"set_relay_state":{"state":1}}}
Received:
pi@domoticz:~/domoticz/scripts/python $ python tplink-smartplug.py -t 192.168.1.32 -c info
Sent: {"system":{"get_sysinfo":{}}}
Received:
Pour infos mon système est bien à jour et j'ai python 3.7.3
Merci de votre aide
