Impossible de réappairer un capteur
mce35
Message par mce35 »
J'ai un capteur de temp/humidité Xiaomi qui s'est déconnecté du réseau (pour une raison inconnue, ce qui arrive régulièrement sur divers capteurs), et lorsque que j'essaie de le réappairé voici ce que j'ai dans le log (alors qu'habituellement cela fonctionne):
Aug  5 00:38:15 rasp3 domoticz: (Zigate) ReadCluster - 0000 - e3dd/01 AttrId: ff01 AttrType: 42 Attsize: 001f Status: 00 AttrValue: 0121350c0421a8330521a7080624020000000064299b086521101a0a218c38
Aug  5 00:38:15 rasp3 domoticz: (Zigate) ReadCluster - 0000 ff01 Saddr: e3dd ClusterData: 0121350c0421a8330521a7080624020000000064299b086521101a0a218c38
Aug  5 00:38:15 rasp3 domoticz: (Zigate) ReadCluster - 0000/ff01 Saddr: e3dd RSSI: 167
Aug  5 00:38:15 rasp3 domoticz: (Zigate) ReadCluster - 0000/ff01 Saddr: e3dd Battery: 94 Voltage: 3125 MacCapa: 80 PowerSource: Battery
Aug  5 00:38:15 rasp3 domoticz: (Zigate) ReadCluster - 0000/ff01 Saddr: e3dd Temperature : 22.0
Aug  5 00:38:15 rasp3 domoticz: (Zigate) MajDomoDevice NwkId: e3dd Ep: 01 ClusterId: 0402 Value: 22.0 ValueType: <class 'float'> Attribute:  Color:
Aug  5 00:38:16 rasp3 domoticz: (Zigate) UpdateDevice_v2 22.0:22.0:    94:  6:False (Zigate - lumi.sensor_ht_Temp-00158d00023938b5-01)
Aug  5 00:38:16 rasp3 domoticz: (Zigate) UpdateDevice - (Zigate - lumi.sensor_ht_Temp-00158d00023938b5-01) 22.0:22.0
Aug  5 00:38:16 rasp3 domoticz: (Zigate) --->  [Unit: 34] 22.0:22.0: 94:6 False (Zigate - lumi.sensor_ht_Temp-00158d00023938b5-01)
Aug  5 00:38:16 rasp3 domoticz: (Zigate) ReadCluster - 0000/ff01 Saddr: e3dd Humidity : 66.7
Aug  5 00:38:16 rasp3 domoticz: (Zigate) MajDomoDevice NwkId: e3dd Ep: 01 ClusterId: 0405 Value: 66.7 ValueType: <class 'float'> Attribute:  Color:
Aug  5 00:38:16 rasp3 domoticz: (Zigate) UpdateDevice_v2 66.7:1:    94:  6:False (Zigate - lumi.sensor_ht_Humi-00158d00023938b5-01)
Aug  5 06:31:38 rasp3 domoticz: (Zigate) Device Health - Nwkid: e3dd,Ieee: 00158d00023938b5 , Model: lumi.sensor_ht seems to be out of the network
Aug  5 11:24:40 rasp3 domoticz: (Zigate) Decode004D V2 - Device Annoucement: NwkId: 4ad7 Ieee: 00158d00023938b5 MacCap: 80 ReJoin: 00 LQI: 00 NewDevice: False
Aug  5 11:24:40 rasp3 domoticz: (Zigate) ------------ > Existing device ShortId New: 4ad7 ShortId Old: e3dd
Aug  5 11:24:40 rasp3 domoticz: (Zigate) ------------ > Store device Rejoin Flag: 00 droping
Le dernier message du capteur était vers 00H38, puis plus rien. et quand j'essaie de le réappairer, il y a le message "Store device Rejoin Flag: 00 droping".
J'essaie également depuis hier de connecter 2 ampoules Hue mais cela ne fonctionne pas pour un problème similaire:
Aug  5 11:42:44 rasp3 domoticz: (Zigate) Decode004D V2 - Device Annoucement: NwkId: d411 Ieee: 001788010244052b MacCap: 8e ReJoin: 00 LQI: 00 NewDevice: True
Aug  5 11:42:44 rasp3 domoticz: (Zigate) ------------ > Adding Device Droping rejoin flag! d411 001788010244052b 00)
Je suis sur le firmware 031c, plugin Ziaget beta mis à jour ce matin.
Quelqu'un aurait une idée de ce qui se passe?
Merci de votre aide
MCE35
Re: Impossible de réappairer un capteur
Je ne vois rien d'anormal. Ton capteur est bien re-appairé , non ?
Il a meme mis à jour le taux d'Humidité
mce35
Message par mce35 »
Il fonctionnait à ce moment (0H38) :
Mais ensuite a 6H31 (rien sur ce capteur entre les 2) :
Et quand j'ai essayé de le réappairer a 11H24 :
Et aucune donnée du capteur, le last seen est toujours a 0H38 dans Domoticz.
Que veut dire le message "Store device Rejoin Flag: 00 droping" ?
Merci.
MCE35
mce35
Message par mce35 »
Je viens de voir que la limite de la Zigate est de (seulement) 40 devices.
Je suis à 39 (et j'ai pu supprimer des devices par le passé, mais pas récemment), est-ce que cela pourrait expliquer que je ne peux pas réappairer un device existant?
MCE35
La Zigate est prévue pour 40 devices en direct et 30 en indirect (via router).
Les routers sont les ampoules, prises, les éléments branchés sur le 220v qui peuvent participer au maillage.
Normalement tu devrais pouvoir repérer ton device. Tu ne serais pas en limite de portée ?
mce35
Message par mce35 »
En réalité j'ai 33 end devices et 6 routeurs.
Les 33 end devices ont été connectés à un moment sur la Zigate, j'ai ajouté les routeurs à postériori (sur lesquels certains capteurs se sont connectés du coup), je ne sais pas si de ce fait je peux dépasser les 40 ou pas.
Le capteur en question est à ~6m de la Zigate, en ligne directe sans obstacle (pas de mur ni autre).
Tu pourrais essayer de faire un appairage directement sur un des routers, car vraisemblablement tous le monde est appairé sur la ZiGate.
Pour cela
1/ Tu t'assures que la Zigate n'est pas en PermitToJoin (la Led de clignote pas)
2/ Via l'interface Web - Admin -> Provisionning, tu vas utiliser l'appairage à partir d'un router
Une fois activer, l'appairage est possible pendant 4 minutes . Il n'y aura que quelques messages dans les logs
Cela fonctionne bien avec les Prises et Ampoules Ikea, ainsi qu'avec le Switch Xiaomi
Screenshot 2020-08-06 at 12.55.37.png (236.43 Kio) Consulté 4944 fois
mce35
Message par mce35 »
J'ai déjà essayé de l'appairer sur un routeur (prise Ikea), mais ca n'a pas marché non plus.
Mais j'ai l'impression que les capteurs Xiaomi ont du mal à passer par des routeurs, pour certains cette méthode fonctionne bien, pour d'autre pas vraiment.
Je n'ai aucun message dans le log (à part le permit to join sur le routeur) :
Aug  6 13:25:14 rasp3 domoticz: (Zigate) Requesting router: 388c to enable Permit to join
Aug  6 13:25:14 rasp3 domoticz: (Zigate) Pairing Mode enabled
Essayes sur autre chose qu’une prise si c’est possible
Wolfen38
Message par Wolfen38 »
Tu me fais plaisir mce35, pareil que toi.
Y a quelques mois, appairer sur prise ikea passait nickel, maintenant, y se passe plus rien, log vide et pas d'appairage.
