ZIGATE DEVICE ERREUR
jfcjfc
Message par jfcjfc »
Domoticz sur synology v2020.1 ,plugin zigate 4.11.006, firmware zigate 031d
erreur pour philips (hue Smart plug)
2020-10-15 16:17:48.311 Error: (ZIGATE) 'onHeartbeat' failed 'KeyError'.
2020-10-15 16:17:48.311 Error: (ZIGATE) ----> Line 1019 in '/usr/local/domoticz/var/plugins/Domoticz-Zigate/plugin.py', function onHeartbeat
2020-10-15 16:17:48.311 Error: (ZIGATE) ----> Line 662 in '/usr/local/domoticz/var/plugins/Domoticz-Zigate/plugin.py', function onHeartbeat
2020-10-15 16:17:48.311 Error: (ZIGATE) ----> Line 522 in '/usr/local/domoticz/var/plugins/Domoticz-Zigate/Modules/heartbeat.py', function processListOfDevices
2020-10-15 16:17:48.311 Error: (ZIGATE) ----> Line 210 in '/usr/local/domoticz/var/plugins/Domoticz-Zigate/Modules/pairingProcess.py', function processNotinDBDevices
2020-10-15 16:17:53.363 Error: (ZIGATE) 'onHeartbeat' failed 'KeyError'.
2020-10-15 16:17:53.363 Error: (ZIGATE) ----> Line 1019 in '/usr/local/domoticz/var/plugins/Domoticz-Zigate/plugin.py', function onHeartbeat
2020-10-15 16:17:53.363 Error: (ZIGATE) ----> Line 662 in '/usr/local/domoticz/var/plugins/Domoticz-Zigate/plugin.py', function onHeartbeat
2020-10-15 16:17:53.364 Error: (ZIGATE) ----> Line 522 in '/usr/local/domoticz/var/plugins/Domoticz-Zigate/Modules/heartbeat.py', function processListOfDevices
2020-10-15 16:17:53.364 Error: (ZIGATE) ----> Line 210 in '/usr/local/domoticz/var/plugins/Domoticz-Zigate/Modules/pairingProcess.py', function processNotinDBDevices
2020-10-15 16:17:58.355 Error: (ZIGATE) 'onHeartbeat' failed 'KeyError'.
2020-10-15 16:17:58.355 Error: (ZIGATE) ----> Line 1019 in '/usr/local/domoticz/var/plugins/Domoticz-Zigate/plugin.py', function onHeartbeat
2020-10-15 16:17:58.355 Error: (ZIGATE) ----> Line 662 in '/usr/local/domoticz/var/plugins/Domoticz-Zigate/plugin.py', function onHeartbeat
2020-10-15 16:17:58.355 Error: (ZIGATE) ----> Line 522 in '/usr/local/domoticz/var/plugins/Domoticz-Zigate/Modules/heartbeat.py', function processListOfDevices
2020-10-15 16:17:58.355 Error: (ZIGATE) ----> Line 210 in '/usr/local/domoticz/var/plugins/Domoticz-Zigate/Modules/pairingProcess.py', function processNotinDBDevices
2020-10-15 16:18:03.312 Error: (ZIGATE) 'onHeartbeat' failed 'KeyError'.
2020-10-15 16:18:03.313 Error: (ZIGATE) ----> Line 1019 in '/usr/local/domoticz/var/plugins/Domoticz-Zigate/plugin.py', function onHeartbeat
2020-10-15 16:18:03.313 Error: (ZIGATE) ----> Line 662 in '/usr/local/domoticz/var/plugins/Domoticz-Zigate/plugin.py', function onHeartbeat
2020-10-15 16:18:03.313 Error: (ZIGATE) ----> Line 522 in '/usr/local/domoticz/var/plugins/Domoticz-Zigate/Modules/heartbeat.py', function processListOfDevices
2020-10-15 16:18:03.313 Error: (ZIGATE) ----> Line 210 in '/usr/local/domoticz/var/plugins/Domoticz-Zigate/Modules/pairingProcess.py', function processNotinDBDevices
2020-10-15 16:18:08.320 Error: (ZIGATE) [4] NEW OBJECT: 43bb Not able to get all needed attributes on time
2020-10-15 16:18:08.320 Error: (ZIGATE) processNotinDB - not able to find response from 43bb stop process at 8043
2020-10-15 16:18:08.320 Error: (ZIGATE) processNotinDB - RIA: 5 waitForDomoDeviceCreation: False, capturePairingInfos: 0 Model: LOM002
2020-10-15 16:18:08.321 Error: (ZIGATE) processNotinDB - Collected Infos are : {'LQI': 168, 'Capability': ['Full-Function Device', 'Main Powered', 'Receiver during Idle', 'Standard security', 'NwkAddr should be allocated'], 'RIA': '5', 'ProfileID': 'a1e0', 'Max Rx': '0080', 'HW Version': '', 'ZCL Version': '', 'ReadAttributes': {'Ep': {'0b': {'0000': {'TimeStamp': 1602771463, 'iSQN': {'0005': 16, '0004': 16}, 'Attributes': {'0005': '00', '0004': '00'}, 'ZigateRequest': {}}}, 'f2': {'0000': {'TimeStamp': 1602771463, 'iSQN': {'0005': 17, '0004': 17}, 'Attributes': {}, 'ZigateRequest': {}}}}}, 'Health': 'Live', 'SQN': 'f6', 'Stamp': {'MsgType': '8011', 'Time': '2020-10-15 16:17:48', 'LastSeen': 1602771468}, 'Max Buffer Size': '52', 'Model': 'LOM002', 'DeviceType': 'FFD', 'ConsistencyCheck': 'Bad Pairing', 'LogicalType': 'Router', 'WriteAttributes': {'Ep': {'0b': {'0000': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}}}}, 'Battery': {}, 'MacCapa': '8e', 'Version': '3', 'App Version': '', 'Max Tx': '0080', 'Ep': {'0b': {'0008': {}, '1000': {}, '0019': {}, 'fc02': {}, '0000': {'0005': 'LOM002', '0004': 'Philips'}, '0003': {}, '0005': {}, '0004': {}, '0006': {}}, 'f2': {'0021': {}}}, 'RollingLQI': [165, 168, 168, 168, 168, 168], 'Last Cmds': [(16, '02', '43bb', '0100', '010b0000000000000200040005'), (17, '02', '43bb', '0100', '01f20000000000000200040005')], 'ZDeviceVersion': '0000', 'ConfigSource': '8043', 'IEEE': '0017880108e677fc', 'Stack Version': '', 'Manufacturer Name': 'Philips', 'Heartbeat': '5', 'PairingInProgress': True, 'ZDeviceName': '', 'Type': {}, 'Status': 'UNKNOW', 'ZDeviceID': '0061', 'NbEp': '2', 'Manufacturer': '100b', 'ReceiveOnIdle': 'On', 'Attributes List': {}, 'Epv2': {'0b': {'ProfileID': '0104', 'ClusterOut': {'0019': {}}, 'ZDeviceID': '010a', 'ClusterIn': {'0008': {}, '1000': {}, 'fc02': {}, '0000': {}, '0003': {}, '0005': {}, '0004': {}, '0006': {}}}, 'f2': {'ZDeviceID': '0061', 'ProfileID': 'a1e0', 'ClusterIn': {}, 'ClusterOut': {'0021': {}}}}, 'PowerSource': 'Main', 'ForceAckCommands': []}
integré dans l'affichage "http://192.168.0.1:9440/device" , 'Domoticz Widget' vide, santé live, status UNKNOW, et
... rien dans domoticz.
Merci d'avance
Ma config :
DS220+ DSM 7.1.1-42962 Update 4 / Docker / dz/dz:stable (2023.1), Python 3.9.2, / Z4D
ZBDongle-E UNK 3.10.3.0 build 297 Plugin 6.3.011 +RFXCOM
passage le 15/03/2023 de la zigate à la ZBDongle-E (Zigate+WIFI : Plugin 6.3.011 / Zigate 0321.)
Re: ZIGATE DEVICE ERREUR
Effectivement c'est pas beau. j'essaie de fixer cela d'ici ce soir, pur que vous puissiez appairer votre device.
jfcjfc
Ce qui est un peu bizarre,
C'est qu'avant le grand nettoyage à zéro après les essais (nouveau sur zigate)
Je pense qu'il y a eu un appariement correct avec on/off marchant avec domoticz de ce devise
cijoint, les nouveaux dispositifs liés y compris le domoticz Widget vide
8b77
588e81fffe6556c0
TRADFRI control outlet
ZIG_BUR_FREEBOX
ZIG_BUR_FREEBOX
FFD
RxonIdle
MainPower
90
inDB
Live
43bb
0017880108e677fc
LOM002
VIDE
VIDE
FFD
RxonIdle
MainPower
153
UNKNOW
Live
985b
680ae2fffef6fd4b
ZIG_BUR_AR
ZIG_BUR_AR
FFD
RxonIdle
MainPower
168
inDB
Live
Je suis entrain de fixer le pb. il se manifeste uniquement sur les materiels qui ne sont pas considéré comme certifiés avec le plugin.
jfcjfc a écrit : 15 oct. 2020, 16:49 Domoticz sur synology v2020.1 ,plugin zigate 4.11.006, firmware zigate 031d
Merci d'avance
Version 4.11.007 disponible.
Elle règle problème de création de device quand le modèle n'est pas référencé dans la base du plugin.
Si c'est possible je suis interessé par le fichier d'information relatif a cette prise Philips. Les informations dont j'ai besoin (et notamment je fichier export.json) sont détaillées ici.
jfcjfc
Lequel des export json dans le module outils ???? : ....
plugin infos, zgate infos, liste des widgets domoticz ...... j'en ai douze..
jfcjfc
4.11.007 installé sur synology avec domoticz, ça marche, merci
Celui-ci
Screenshot 2020-10-15 at 19.46.43.png (6.84 Kio) Consulté 3147 fois
Screenshot 2020-10-15 at 19.46.35.png (6.09 Kio) Consulté 3147 fois
et désolé pour le pb!
jfcjfc
Liste des équipements raw (json)
0 : Object {"ZDeviceName":"Zigate","LogicalType":"Coordinator","PowerSource":"Main","NwkID":"0000","Version":"3","Status":"","Neighbours":[{"Devices":[{"849b":{"_depth":1,"_lnkqty":144,"_permitjnt":"--","_IEEE":"588e81fffe6556c0","_devicetype":"Router","_rxonwhenidl":"Rx-On","_relationshp":"Child"}},{"ab98":{"_depth":0,"_lnkqty":145,"_permitjnt":"--","_IEEE":"0017880108e677fc","_devicetype":"Router","_rxonwhenidl":"Rx-On","_relationshp":"Sibling"}}],"Time":"2020-10-15 14:55:45"},{"Devices":[{"985b":{"_depth":0,"_lnkqty":159,"_permitjnt":"--","_IEEE":"680ae2fffef6fd4b","_devicetype":"Router","_rxonwhenidl":"Rx-On","_relationshp":"Sibling"}},{"8b77":{"_depth":0,"_lnkqty":137,"_permitjnt":"--","_IEEE":"588e81fffe6556c0","_devicetype":"Router","_rxonwhenidl":"Rx-On","_relationshp":"Sibling"}},{"43bb":{"_depth":0,"_lnkqty":195,"_permitjnt":"--","_IEEE":"0017880108e677fc","_devicetype":"Router","_rxonwhenidl":"Rx-On","_relationshp":"Sibling"}}],"Time":"2020-10-15 15:44:10"},{"Devices":[{"8b77":{"_depth":0,"_lnkqty":165,"_permitjnt":"--","_IEEE":"588e81fffe6556c0","_devicetype":"Router","_rxonwhenidl":"Rx-On","_relationshp":"Sibling"}},{"43bb":{"_depth":0,"_lnkqty":209,"_permitjnt":"--","_IEEE":"0017880108e677fc","_devicetype":"Router","_rxonwhenidl":"Rx-On","_relationshp":"Sibling"}},{"985b":{"_depth":0,"_lnkqty":160,"_permitjnt":"--","_IEEE":"680ae2fffef6fd4b","_devicetype":"Router","_rxonwhenidl":"Rx-On","_relationshp":"Sibling"}}],"Time":"2020-10-15 16:22:58"},{"Devices":[{"985b":{"_depth":0,"_lnkqty":164,"_permitjnt":"--","_IEEE":"680ae2fffef6fd4b","_devicetype":"Router","_rxonwhenidl":"Rx-On","_relationshp":"Sibling"}},{"2809":{"_depth":0,"_lnkqty":232,"_permitjnt":"--","_IEEE":"0017880108e677fc","_devicetype":"Router","_rxonwhenidl":"Rx-On","_relationshp":"Sibling"}},{"8b77":{"_depth":0,"_lnkqty":138,"_permitjnt":"--","_IEEE":"588e81fffe6556c0","_devicetype":"Router","_rxonwhenidl":"Rx-On","_relationshp":"Sibling"}}],"Time":"2020-10-15 19:46:35"}],"IEEE":"00158d0002bcfbfb","Health":"","ConsistencyCheck":"","Ep":{"15":{"1000":{},"0004":{},"0005":{},"0101":{},"0006":{},"0b05":{},"0702":{},"0001":{},"0400":{},"0401":{},"0402":{},"0403":{},"0000":{},"0405":{},"0406":{},"0003":{},"0500":{},"0019":{},"0008":{},"0204":{},"0201":{},"0b03":{},"0300":{}},"01":{"1000":{},"0004":{},"0005":{},"0006":{},"0b05":{},"0702":{},"0001":{},"0400":{},"0401":{},"0402":{},"0403":{},"0000":{},"0405":{},"0406":{},"0003":{},"0500":{},"0019":{},"0008":{},"0204":{},"000f":{},"0201":{},"0b03":{},"0300":{}},"0a":{"1000":{},"0004":{},"0005":{},"0101":{},"0006":{},"0b05":{},"0702":{},"0001":{},"0400":{},"0401":{},"0402":{},"0403":{},"0000":{},"0405":{},"0406":{},"0003":{},"0500":{},"0019":{},"0008":{},"0204":{},"0201":{},"0b03":{},"0300":{}},"6e":{"1000":{},"0004":{},"0005":{},"0101":{},"0006":{},"0b05":{},"0702":{},"0001":{},"0400":{},"0401":{},"0402":{},"0403":{},"0000":{},"0405":{},"0406":{},"0003":{},"0500":{},"0019":{},"0008":{},"0204":{},"0201":{},"0b03":{},"0300":{}}},"GroupMemberShip":{"0a":{}},"MapLQI":{"2809":252,"985b":255,"8b77":242},"RIA":"10"}
1 : Object {"Last Cmds":[[165,"07","985b","0100","0101000600000000040000400140024003"],[170,"07","985b","0100","0101000600000000040000400140024003"],[176,"07","985b","0100","0101000600000000040000400140024003"],[181,"07","985b","0100","0101000600000000040000400140024003"],[186,"07","985b","0100","0101000600000000040000400140024003"],[191,"07","985b","0100","0101000600000000040000400140024003"],[197,"07","985b","0100","0101000600000000040000400140024003"],[199,"02","985b","0092","010101"],[200,"07","985b","0100","0101000600000000010000"],[201,"07","985b","0100","0101000800000000010000"]],"Manufacturer":"117c","NbEp":"2","ProfileID":"a1e0","Type":"Plug","ReceiveOnIdle":"On","SWBUILD_3":"2.0.022","MapLQI":{"2809":156,"0000":164,"8b77":177},"SQN":"32","HW Version":"1","ZDeviceName":"ZIG_BUR_AR","LogicalType":"Router","Epv2":{"f2":{"ClusterOut":{},"ZDeviceID":"0061","ClusterIn":{},"ProfileID":"a1e0"},"01":{"ZDeviceID":"010a","ProfileID":"0104"}},"Battery":{},"Capability":["Full-Function Device","Main Powered","Receiver during Idle","Standard security","NwkAddr should be allocated"],"Status":"inDB","Bind":{"01":{"0019":{"Phase":"binded","Target":"0000","Status":"00","i_sqn":45,"Stamp":"15/10/2020 15:37:55"},"0006":{"Phase":"binded","Target":"0000","Status":"00","i_sqn":44,"Stamp":"15/10/2020 15:37:55"}}},"MacCapa":"8e","Manufacturer Name":"IKEA of Sweden","Ep":{"02":{"1000":{},"0021":{},"Type":""},"01":{"0004":{},"0005":{},"0006":{"4001":"0","4002":"0","4003":"255","0000":"01"},"0000":{"4000":"2.0.022","0004":"IKEA of Sweden","0005":"TRADFRI control outlet","0007":"1","0000":"3","000a":"4531373036","0002":"98","0003":"1","0001":"32"},"0003":{},"Type":"Plug","0019":{},"0008":{"0000":"fe"},"ClusterType":{"1767":"Plug"},"fc7c":{}}},"RIA":"0","App Version":"32","ZCL Version":"3","ReadAttributes":{"Ep":{"f2":{"0000":{"Attributes":{},"iSQN":{"0004":41,"0005":41},"ZigateRequest":{},"TimeStamp":"15/10/2020 15:37:52"}},"01":{"0008":{"Attributes":{"0000":"00"},"iSQN":{"0000":201},"ZigateRequest":{},"TimeStamp":"16/10/2020 00:52:22"},"0006":{"Attributes":{"4001":"00","4002":"00","4003":"00","0000":"00"},"iSQN":{"4001":197,"4002":197,"4003":197,"0000":200},"ZigateRequest":{},"TimeStamp":"16/10/2020 00:52:22"},"0000":{"Attributes":{"4000":"00","0004":"00","0005":"00","0007":"00","0000":"00","000a":"00","0002":"00","0003":"00","0001":"00"},"iSQN":{"4000":59,"0004":55,"0005":56,"0007":57,"0000":9,"000a":58,"0002":53,"0003":54,"0001":52},"ZigateRequest":{},"TimeStamp":"15/10/2020 19:41:10"}}}},"Stack Version":"98","Version":"3","Stamp":{"MsgType":"8100","LastPing":1602783670,"Time":"2020-10-16 00:52:22","LastSeen":"16/10/2020 00:52:22"},"ConsistencyCheck":"ok","Model":"TRADFRI control outlet","RollingLQI":[168,168,168,168,168,168,168,168,168,168,162],"ForceAckCommands":[],"Attributes List":{},"ConfigureReporting":{"Ep":{"01":{"0006":{"Attributes":{"0000":"00"},"iSQN":{"0000":46},"ZigateRequest":{},"TimeStamp":"15/10/2020 15:37:55"}}}},"NwkID":"985b","Neighbours":[{"Devices":[{"0000":{"_depth":0,"_lnkqty":255,"_permitjnt":"--","_IEEE":"00158d0002bcfbfb","_devicetype":"Coordinator","_rxonwhenidl":"Rx-On","_relationshp":"Parent"}},{"43bb":{"_depth":15,"_lnkqty":168,"_permitjnt":"--","_IEEE":"0017880108e677fc","_devicetype":"Router","_rxonwhenidl":"Rx-On","_relationshp":"Sibling"}},{"8b77":{"_depth":15,"_lnkqty":151,"_permitjnt":"--","_IEEE":"588e81fffe6556c0","_devicetype":"Router","_rxonwhenidl":"Rx-On","_relationshp":"Sibling"}}],"Time":"2020-10-15 15:44:10"},{"Devices":[{"0000":{"_depth":0,"_lnkqty":255,"_permitjnt":"--","_IEEE":"00158d0002bcfbfb","_devicetype":"Coordinator","_rxonwhenidl":"Rx-On","_relationshp":"Parent"}},{"8b77":{"_depth":15,"_lnkqty":145,"_permitjnt":"--","_IEEE":"588e81fffe6556c0","_devicetype":"Router","_rxonwhenidl":"Rx-On","_relationshp":"Sibling"}},{"43bb":{"_depth":15,"_lnkqty":151,"_permitjnt":"--","_IEEE":"0017880108e677fc","_devicetype":"Router","_rxonwhenidl":"Rx-On","_relationshp":"Sibling"}}],"Time":"2020-10-15 16:22:58"},{"Devices":[{"8b77":{"_depth":15,"_lnkqty":174,"_permitjnt":"--","_IEEE":"588e81fffe6556c0","_devicetype":"Router","_rxonwhenidl":"Rx-On","_relationshp":"Sibling"}},{"2809":{"_depth":15,"_lnkqty":158,"_permitjnt":"--","_IEEE":"0017880108e677fc","_devicetype":"Router","_rxonwhenidl":"Rx-On","_relationshp":"Sibling"}},{"0000":{"_depth":0,"_lnkqty":255,"_permitjnt":"--","_IEEE":"00158d0002bcfbfb","_devicetype":"Coordinator","_rxonwhenidl":"Rx-On","_relationshp":"Parent"}}],"Time":"2020-10-15 19:46:35"}],"Heartbeat":"32","PowerSource":"Main","WriteAttributes":{"Ep":{"02":{"1000":{"Attributes":{},"iSQN":{},"ZigateRequest":{},"TimeStamp":0},"0021":{"Attributes":{},"iSQN":{},"ZigateRequest":{},"TimeStamp":0}},"01":{"0004":{"Attributes":{},"iSQN":{},"ZigateRequest":{},"TimeStamp":0},"0005":{"Attributes":{},"iSQN":{},"ZigateRequest":{},"TimeStamp":0},"0006":{"Attributes":{},"iSQN":{},"ZigateRequest":{},"TimeStamp":0},"0000":{"Attributes":{},"iSQN":{},"ZigateRequest":{},"TimeStamp":0},"0003":{"Attributes":{},"iSQN":{},"ZigateRequest":{},"TimeStamp":0},"0019":{"Attributes":{},"iSQN":{},"ZigateRequest":{},"TimeStamp":0},"0008":{"Attributes":{},"iSQN":{},"ZigateRequest":{},"TimeStamp":0},"fc7c":{"Attributes":{},"iSQN":{},"ZigateRequest":{},"TimeStamp":0}}}},"ConfigSource":"DeviceConf","DeviceType":"FFD","IEEE":"680ae2fffef6fd4b","Health":"Live","LQI":162,"ZDeviceID":"0061"}
2 : Object {"Last Cmds":[[61,"02","2809","0092","010b01"],[62,"07","2809","0100","010b000600000000010000"],[63,"07","2809","0100","010b000800000000010000"],[86,"02","2809","0092","010b00"],[87,"07","2809","0100","010b000600000000010000"],[88,"07","2809","0100","010b000800000000010000"],[117,"07","2809","0100","010b000600000000014003"],[198,"02","2809","0092","010b01"],[202,"07","2809","0100","010b000600000000010000"],[203,"07","2809","0100","010b000800000000010000"]],"Manufacturer":"100b","App Version":"2","ProfileID":"a1e0","LQI":195,"WriteAttributes":{"Ep":{"0b":{"1000":{"Attributes":{},"iSQN":{},"ZigateRequest":{},"TimeStamp":0},"0004":{"Attributes":{},"iSQN":{},"ZigateRequest":{},"TimeStamp":0},"0005":{"Attributes":{},"iSQN":{},"ZigateRequest":{},"TimeStamp":0},"0006":{"Attributes":{},"iSQN":{},"ZigateRequest":{},"TimeStamp":0},"0000":{"Attributes":{},"iSQN":{},"ZigateRequest":{},"TimeStamp":0},"0003":{"Attributes":{},"iSQN":{},"ZigateRequest":{},"TimeStamp":0},"0019":{"Attributes":{},"iSQN":{},"ZigateRequest":{},"TimeStamp":0},"0008":{"Attributes":{},"iSQN":{},"ZigateRequest":{},"TimeStamp":0},"fc02":{"Attributes":{},"iSQN":{},"ZigateRequest":{},"TimeStamp":0}},"f2":{"0021":{"Attributes":{},"iSQN":{},"ZigateRequest":{},"TimeStamp":0}}}},"SWBUILD_1":"20190514","ReceiveOnIdle":"On","SWBUILD_3":"1.55.10_r29112","MapLQI":{"0000":232,"985b":158,"8b77":241},"SQN":"85","HW Version":"1","ZDeviceName":"","LogicalType":"Router","Epv2":{"0b":{"ZDeviceID":"010a","ClusterOut":{"0019":{}},"ClusterIn":{"1000":{},"0004":{},"0005":{},"0006":{},"0000":{},"0003":{},"0008":{},"fc02":{}},"ProfileID":"0104"},"f2":{"ClusterOut":{"0021":{}},"ZDeviceID":"0061","ClusterIn":{},"ProfileID":"a1e0"}},"Battery":{},"Capability":["Full-Function Device","Main Powered","Receiver during Idle","Standard security","NwkAddr should be allocated"],"ZDeviceVersion":"0000","Version":"3","Type":"Switch/LvlControl","Manufacturer Name":"Philips","MacCapa":"8e","RIA":"1","Max Buffer Size":"52","ZCL Version":"2","ReadAttributes":{"Ep":{"0b":{"0008":{"Attributes":{"0000":"00"},"iSQN":{"0000":203},"ZigateRequest":{},"TimeStamp":"16/10/2020 00:52:24"},"0006":{"Attributes":{"4003":"00","0000":"00"},"iSQN":{"4003":117,"0000":202},"ZigateRequest":{},"TimeStamp":"16/10/2020 00:52:22"},"0000":{"Attributes":{"4000":"00","0004":"00","0005":"00","0006":"00","0007":"00","0000":"00","0001":"00","0002":"00","0003":"00","000f":"86","0010":"86","000a":"00","f000":"86","0015":"86"},"iSQN":{"4000":39,"0004":31,"0005":32,"0006":33,"0007":34,"0000":27,"0001":28,"0002":29,"0003":30,"000f":36,"0010":37,"000a":35,"f000":40,"0015":38},"ZigateRequest":{},"TimeStamp":"15/10/2020 19:41:37"}},"f2":{"0000":{"Attributes":{},"iSQN":{"0004":15,"0005":15},"ZigateRequest":{},"TimeStamp":"15/10/2020 19:41:34"}}}},"RollingLQI":[195,195,195,195,195,195,195,195,195,195,195],"Bind":{"0b":{"0000":{"Stamp":"15/10/2020 19:41:35","Target":"0000","Phase":"binded","i_sqn":22,"Status":"00"},"0019":{"Stamp":"15/10/2020 19:41:35","Target":"0000","Phase":"binded","i_sqn":19,"Status":"00"},"0008":{"Stamp":"15/10/2020 19:41:35","Target":"0000","Phase":"binded","i_sqn":21,"Status":"00"},"0006":{"Stamp":"15/10/2020 19:41:35","Target":"0000","Phase":"binded","i_sqn":20,"Status":"00"}}},"Stamp":{"MsgType":"8102","LastPing":0,"Time":"2020-10-16 00:52:24","LastSeen":"16/10/2020 00:52:24"},"NwkID":"2809","Model":"LOM002","Stack Version":"1","PowerSource":"Main","ForceAckCommands":[],"Attributes List":{"Ep":{"0b":{"0004":{"0000":"18","fffd":"21"},"0005":{"0004":"18","0000":"20","0001":"20","0002":"21","0003":"10","fffd":"21"},"0006":{"4000":"10","4001":"21","4002":"21","4003":"30","0000":"10","fffd":"21"},"0000":{"4000":"42","0004":"42","0005":"42","0006":"42","0007":"30","0000":"20","0001":"20","0002":"20","0003":"20","0008":"30","0009":"30","000a":"41","000b":"42","fffd":"21"},"0003":{"0000":"21","fffd":"21"},"0008":{"4000":"20","000f":"18","0000":"20","0001":"21","fffd":"21"}}}},"Ep":{"0b":{"1000":{},"0004":{},"0005":{},"0006":{"4003":"1","0000":"01"},"0000":{"4000":"1.55.10_r29112","0004":"Philips","0005":"LOM002","0006":"20190514","0007":"1","0000":"2","0001":"2","0002":"1","0003":"1","000a":"None"},"0003":{},"ClusterType":{"1769":"LvlControl"},"0019":{},"0008":{"0000":"fe"},"fc02":{}},"f2":{"0021":{}}},"ConfigureReporting":{"Ep":{"0b":{"0006":{"Attributes":{"0000":"00"},"iSQN":{"0000":23},"ZigateRequest":{},"TimeStamp":"15/10/2020 19:41:35"},"0008":{"Attributes":{"0000":"00"},"iSQN":{"0000":24},"ZigateRequest":{},"TimeStamp":"15/10/2020 19:41:35"}}}},"ConfigSource":"8043","Neighbours":[{"Devices":[{"8b77":{"_depth":15,"_lnkqty":255,"_permitjnt":"--","_IEEE":"588e81fffe6556c0","_devicetype":"Router","_rxonwhenidl":"Rx-On","_relationshp":"Sibling"}},{"985b":{"_depth":15,"_lnkqty":156,"_permitjnt":"--","_IEEE":"680ae2fffef6fd4b","_devicetype":"Router","_rxonwhenidl":"Rx-On","_relationshp":"Sibling"}},{"0000":{"_depth":0,"_lnkqty":252,"_permitjnt":"--","_IEEE":"00158d0002bcfbfb","_devicetype":"Coordinator","_rxonwhenidl":"Rx-On","_relationshp":"Sibling"}}],"Time":"2020-10-15 19:46:35"}],"PairingInProgress":false,"Heartbeat":"32","Max Tx":"0080","Max Rx":"0080","Status":"inDB","DeviceType":"FFD","IEEE":"0017880108e677fc","Health":"Live","NbEp":"2","ZDeviceID":"0061"}
3 : Object {"Last Cmds":[[147,"07","8b77","0100","0101000600000000040000400140024003"],[153,"07","8b77","0100","0101000600000000040000400140024003"],[158,"07","8b77","0100","0101000600000000040000400140024003"],[163,"07","8b77","0100","0101000600000000040000400140024003"],[168,"07","8b77","0100","0101000600000000040000400140024003"],[174,"07","8b77","0100","0101000600000000040000400140024003"],[179,"07","8b77","0100","0101000600000000040000400140024003"],[184,"07","8b77","0100","0101000600000000040000400140024003"],[189,"07","8b77","0100","0101000600000000040000400140024003"],[195,"07","8b77","0100","0101000600000000040000400140024003"]],"Manufacturer":"117c","NbEp":"2","ProfileID":"a1e0","Type":"Plug","ReceiveOnIdle":"On","SWBUILD_3":"2.0.024","MapLQI":{"2809":255,"985b":174,"0000":138},"SQN":"2d","HW Version":"1","ZDeviceName":"ZIG_BUR_FREEBOX","LogicalType":"Router","Epv2":{"f2":{"ClusterOut":{},"ZDeviceID":"0061","ClusterIn":{},"ProfileID":"a1e0"},"01":{"ZDeviceID":"010a","ProfileID":"0104"}},"Battery":{},"Capability":["Full-Function Device","Main Powered","Receiver during Idle","Standard security","NwkAddr should be allocated"],"Status":"inDB","Bind":{"01":{"0019":{"Phase":"binded","Target":"0000","Status":"00","i_sqn":65,"Stamp":"15/10/2020 15:40:46"},"0006":{"Phase":"binded","Target":"0000","Status":"00","i_sqn":64,"Stamp":"15/10/2020 15:40:46"}}},"MacCapa":"8e","Manufacturer Name":"IKEA of Sweden","Ep":{"02":{"1000":{},"0021":{},"Type":""},"01":{"0004":{},"0005":{},"0006":{"4001":"0","4002":"0","4003":"255","0000":"00"},"0000":{"4000":"2.0.024","0004":"IKEA of Sweden","0005":"TRADFRI control outlet","0007":"1","0000":"3","0001":"32","0002":"98","0003":"1","000a":"4531373036"},"0003":{},"Type":"Plug","0019":{},"0008":{"0000":"fe"},"ClusterType":{"1765":"Plug"},"fc7c":{}}},"RIA":"0","App Version":"32","ZCL Version":"3","ReadAttributes":{"Ep":{"01":{"0008":{"Attributes":{"0000":"00"},"iSQN":{"0000":71},"ZigateRequest":{},"TimeStamp":"15/10/2020 19:43:40"},"0006":{"Attributes":{"4001":"00","4002":"00","4003":"00","0000":"00"},"iSQN":{"4001":195,"4002":195,"4003":195,"0000":195},"ZigateRequest":{},"TimeStamp":"16/10/2020 00:43:47"},"0000":{"Attributes":{"4000":"00","0004":"00","0005":"00","0007":"00","0000":"00","000a":"00","0002":"00","0003":"00","0001":"00"},"iSQN":{"4000":75,"0004":71,"0005":72,"0007":73,"0000":10,"000a":74,"0002":69,"0003":70,"0001":68},"ZigateRequest":{},"TimeStamp":"15/10/2020 19:41:10"}}}},"Stack Version":"98","Version":"3","Stamp":{"MsgType":"8100","LastPing":1602783670,"Time":"2020-10-16 00:43:47","LastSeen":"16/10/2020 00:43:47"},"ConsistencyCheck":"ok","Model":"TRADFRI control outlet","RollingLQI":[159,159,159,159,159,159,159,159,159,159,159],"ForceAckCommands":[],"Attributes List":{},"ConfigureReporting":{"Ep":{"01":{"0006":{"Attributes":{"0000":"00"},"iSQN":{"0000":66},"ZigateRequest":{},"TimeStamp":"15/10/2020 15:40:46"}}}},"NwkID":"8b77","Neighbours":[{"Devices":[{"0000":{"_depth":0,"_lnkqty":244,"_permitjnt":"--","_IEEE":"00158d0002bcfbfb","_devicetype":"Coordinator","_rxonwhenidl":"Rx-On","_relationshp":"Parent"}},{"ab98":{"_depth":15,"_lnkqty":255,"_permitjnt":"--","_IEEE":"0017880108e677fc","_devicetype":"Router","_rxonwhenidl":"Rx-On","_relationshp":"Sibling"}}],"Time":"2020-10-15 14:55:45"},{"Devices":[{"985b":{"_depth":15,"_lnkqty":164,"_permitjnt":"--","_IEEE":"680ae2fffef6fd4b","_devicetype":"Router","_rxonwhenidl":"Rx-On","_relationshp":"Sibling"}},{"0000":{"_depth":0,"_lnkqty":243,"_permitjnt":"--","_IEEE":"00158d0002bcfbfb","_devicetype":"Coordinator","_rxonwhenidl":"Rx-On","_relationshp":"Parent"}},{"43bb":{"_depth":15,"_lnkqty":168,"_permitjnt":"--","_IEEE":"0017880108e677fc","_devicetype":"Router","_rxonwhenidl":"Rx-On","_relationshp":"Sibling"}}],"Time":"2020-10-15 15:44:10"},{"Devices":[{"0000":{"_depth":0,"_lnkqty":255,"_permitjnt":"--","_IEEE":"00158d0002bcfbfb","_devicetype":"Coordinator","_rxonwhenidl":"Rx-On","_relationshp":"Parent"}},{"43bb":{"_depth":15,"_lnkqty":187,"_permitjnt":"--","_IEEE":"0017880108e677fc","_devicetype":"Router","_rxonwhenidl":"Rx-On","_relationshp":"Sibling"}},{"985b":{"_depth":15,"_lnkqty":147,"_permitjnt":"--","_IEEE":"680ae2fffef6fd4b","_devicetype":"Router","_rxonwhenidl":"Rx-On","_relationshp":"Sibling"}}],"Time":"2020-10-15 16:22:58"},{"Devices":[{"985b":{"_depth":15,"_lnkqty":177,"_permitjnt":"--","_IEEE":"680ae2fffef6fd4b","_devicetype":"Router","_rxonwhenidl":"Rx-On","_relationshp":"Sibling"}},{"2809":{"_depth":15,"_lnkqty":241,"_permitjnt":"--","_IEEE":"0017880108e677fc","_devicetype":"Router","_rxonwhenidl":"Rx-On","_relationshp":"Sibling"}},{"0000":{"_depth":0,"_lnkqty":242,"_permitjnt":"--","_IEEE":"00158d0002bcfbfb","_devicetype":"Coordinator","_rxonwhenidl":"Rx-On","_relationshp":"Parent"}}],"Time":"2020-10-15 19:46:35"}],"Heartbeat":"3732","PowerSource":"Main","WriteAttributes":{"Ep":{"02":{"1000":{"Attributes":{},"iSQN":{},"ZigateRequest":{},"TimeStamp":0},"0021":{"Attributes":{},"iSQN":{},"ZigateRequest":{},"TimeStamp":0}},"01":{"0004":{"Attributes":{},"iSQN":{},"ZigateRequest":{},"TimeStamp":0},"0005":{"Attributes":{},"iSQN":{},"ZigateRequest":{},"TimeStamp":0},"0006":{"Attributes":{},"iSQN":{},"ZigateRequest":{},"TimeStamp":0},"0000":{"Attributes":{},"iSQN":{},"ZigateRequest":{},"TimeStamp":0},"0003":{"Attributes":{},"iSQN":{},"ZigateRequest":{},"TimeStamp":0},"0019":{"Attributes":{},"iSQN":{},"ZigateRequest":{},"TimeStamp":0},"0008":{"Attributes":{},"iSQN":{},"ZigateRequest":{},"TimeStamp":0},"fc7c":{"Attributes":{},"iSQN":{},"ZigateRequest":{},"TimeStamp":0}}}},"ConfigSource":"DeviceConf","DeviceType":"FFD","IEEE":"588e81fffe6556c0","Health":"Live","LQI":159,"ZDeviceID":"0061"}
Je n'ai pas "plugin raw device (json)", j'ai 'plugin infos (json)" (1) ou "santé plugin (json)" (2), voici ci-dessous :
(1)
Address : 0.0.0.0
Author : zaraki673 pipiche38
Database : /usr/local/domoticz/var/domoticz.db
DomoticzBuildTime : 1970-01-01 01:00:00
DomoticzHash : 0
DomoticzVersion : 2020.1
FirmwareUpdate : false
FirmwareVersion : 031d
HardwareID : 11
HomeFolder : /usr/local/domoticz/var/plugins/Domoticz-Zigate/
Key : Zigate
Language : fr
Mode1 : USB
Mode2 :
Mode3 : False
Mode4 : 9440
Mode5 :
Mode6 : 30
Password :
PluginBranch : stable
PluginUpdate : false
PluginVersion : 4.11.007
Port : 9999
SerialPort : /dev/ttyUSB-Zigate
StartupFolder : /usr/local/domoticz/
TimeStamp : 16/10/2020 01:05:52
UserDataFolder : /usr/local/domoticz/var/
Username :
Version : 4.11
WebRoot :
available : 4.11.004
available-firmMajor : 0003
available-firmMinor : 031d
(2)
GroupStatus : "ready"
HealthFlag : 1
HealthTxt : "Ready"
Demande si plus ou autre, rien d'autre en " plugin ", ni en " raw "
.... et merci pour ta célérité.
Merci pour les informations, c'est parfait. Est-ce que la prise fonctionne correctement ?
Ce que je note c'est qu'au niveau de Domoticz la widget créée doit permettre de faire varier la tension (ce que je doute est possible sur ta prise)
