D'où vient le 127.0.0.1 ?
Wolfen38
Message par Wolfen38 »
J'ai un script dzvent pour changer le nom d'un widget :
-- Icon changer
local ICON_RAIN = 116
local ICON_SUN = 117
return {
    logging = {
	level = domoticz.LOG_DEBUG, -- Select one of LOG_DEBUG, LOG_INFO, LOG_ERROR, LOG_FORCE to override system log level
	on = {
        devices = {404},
    execute = function(dz, item)
    local pluiej = dz.variables('Pluie-jour').value
    print('start icon ' .. pluiej)
	if item.level == 10 then
	    item.setIcon(ICON_RAIN)
		item.rename('Aujourdhui - pluie : '..pluiej..'mm')
		item.switchSelector(10).silent()
 elseif item.level == 20 then
        item.setIcon(ICON_SUN)
		item.rename('Aujourdhui - soleil')
        item.switchSelector(20).silent()
Quand il se lance, j'ai ca dans les log :
2020-11-05 12:00:01.154 Status: dzVents: Info: Handling events for: "Aujourdhui - soleil", value: "Soleil"
2020-11-05 12:00:01.155 Status: dzVents: Info: ------ Start external script: icone-pluie-jour.lua: Device: "Aujourdhui - soleil (Virtualsensor)", Index: 404
2020-11-05 12:00:01.156 Status: dzVents: start icon 0.0
2020-11-05 12:00:01.156 Status: dzVents: Debug: OpenURL: url = http://127.0.0.1:8080/json.htm?type=setused&used=true&name=Aujourdhui+-+soleil&description=&idx=404&switchtype=18&customimage=117
2020-11-05 12:00:01.156 Status: dzVents: Debug: OpenURL: method = GET
2020-11-05 12:00:01.156 Status: dzVents: Debug: OpenURL: post data = nil
2020-11-05 12:00:01.156 Status: dzVents: Debug: OpenURL: headers = nil
2020-11-05 12:00:01.156 Status: dzVents: Debug: OpenURL: callback = nil
2020-11-05 12:00:01.156 Status: dzVents: Debug: OpenURL: url = http://127.0.0.1:8080/json.htm?type=command&param=renamedevice&idx=404&name=Aujourdhui+-+soleil
2020-11-05 12:00:01.156 Status: dzVents: Debug: Constructed timed-command: Set Level 20
2020-11-05 12:00:01.156 Status: dzVents: Debug: Constructed timed-command: Set Level 20 NOTRIGGER
2020-11-05 12:00:01.158 Status: dzVents: Info: ------ Finished icone-pluie-jour.lua
Et je ne comprends pas d'où vient l'ip 127.0.0.1:8080 ?
Parce ce que je veux mettre en place un second rasp qui aura le port 8181, donc je ne sais pas où modifier et quoi pour cet ip....
Merci.
Re: D'où vient le 127.0.0.1 ?
Les logs que tu vois sont en mode débug : tu vois tout ce que fait DomoticZ.
Et je pense que la ligne de code item.rename('Aujourdhui - pluie : '..pluiej..'mm') se traduit par une action via l'API JSON http://127.0.0.1:8080/json.htm?type=com ... i+-+soleil
Le 127.0.0.1 est l'IP propre du serveur (en gros il s'appelle lui-même). Ça peut aussi être localhost. Et concernant le port, il doit récupérer l'info des paramètres de DomoticZ.
Réduit ton niveau de débogage : tu vas te poser trop de questions ;)
Wolfen38
Mardi pour cette réponse détaillée.
Et comment je réduis le niveau de debug?
denis_brasseur
Message par denis_brasseur »
logging = {
Wolfen38
ok, je mets juste le log error pour etre juste alerté en cas de probleme ?
Log erreur ne te donnera que les erreurs. Si tu as mis des prints dans tes scripts, ils ne seront pas dans les logs.
Je pense que le niveau le plus adéquat est LOG_INFO.
Wolfen38
ok merci
