[Résolu] Ma zigate ne répond plus
calouis
Message par calouis »
Je viens de passer ma zigate usb en ZiGate_v3.1d, puis j'ai mis à jour le plugin dans sa dernière version stable 4.11214:
2020-12-02 12:41:20.481 Status: Domoticz V4.11214 (c)2012-2019 GizMoCuz
2020-12-02 12:41:20.481 Status: Build Hash: e7672936b, Date: 2019-08-19 10:51:32
2020-12-02 12:41:20.482 Status: Startup Path: /home/pi/domoticz/
2020-12-02 12:41:20.597 Status: PluginSystem: Started, Python version '3.5.3'.
2020-12-02 12:41:20.622 Status: WebServer(HTTP) started on address: :: with port 8282
2020-12-02 12:41:20.637 Status: WebServer(SSL) started on address: :: with port 443
2020-12-02 12:41:20.684 Status: RxQueue: queue worker started...
2020-12-02 12:41:20.684 Status: TCPServer: shared server started...
2020-12-02 12:41:22.684 Status: YeeLight Worker started...
2020-12-02 12:41:22.685 Status: XiaomiGateway (ID=7): Delaying worker startup...
2020-12-02 12:41:27.685 Status: XiaomiGateway (ID=7): Selected as main Gateway
2020-12-02 12:41:27.686 Status: XiaomiGateway (ID=7): Worker started...
2020-12-02 12:41:27.686 Status: Netatmo: Worker started...
2020-12-02 12:41:27.686 Status: XiaomiGateway (ID=7): Using 192.168.1.12 for local IP address.
2020-12-02 12:41:27.686 Status: RFXCOM: Worker started...
2020-12-02 12:41:27.686 Status: (ZG) Started.
2020-12-02 12:41:27.687 Status: (PiMoniteur) Started.
2020-12-02 12:41:27.688 Status: Pinger: Worker started...
2020-12-02 12:41:27.689 Status: EventSystem: reset all events...
2020-12-02 12:41:27.717 Status: EventSystem: reset all device statuses...
2020-12-02 12:41:27.765 Status: XiaomiGateway: RGB Gateway Detected
2020-12-02 12:41:28.032 Status: PluginSystem: Entering work loop.
2020-12-02 12:41:28.187 Status: OpenZWave: using config in: /home/pi/domoticz/Config/
2020-12-02 12:41:28.225 Status: OpenZWave: Starting...
2020-12-02 12:41:28.225 Status: OpenZWave: Version: 1.6-808-gbb0a4bf7-dirty
2020-12-02 12:41:28.521 Status: (ZG) Entering work loop.
2020-12-02 12:41:28.521 Status: (ZG) Initialized version 4.11, author 'zaraki673 pipiche38'
2020-12-02 12:41:28.648 Status: (PiMoniteur) Entering work loop.
2020-12-02 12:41:28.648 Status: (PiMoniteur) Initialized version 3.1, author 'Xorfor'
2020-12-02 12:41:28.662 Status: (ZG) Zigate plugin stable-4.11.011 started
2020-12-02 12:41:28.662 Status: (ZG) Debug: 0
2020-12-02 12:41:28.662 Status: (ZG) load PluginConf
2020-12-02 12:41:28.664 Status: (ZG) filename set to /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/PluginConf-17.json
2020-12-02 12:41:28.664 Status: (ZG) pluginHome set to /home/pi/domoticz/plugins/Domoticz-Zigate/
2020-12-02 12:41:28.664 Status: (ZG) pluginData set to /home/pi/domoticz/plugins/Domoticz-Zigate/Data/
2020-12-02 12:41:28.664 Status: (ZG) pluginWWW set to /home/pi/domoticz/plugins/Domoticz-Zigate/www/
2020-12-02 12:41:28.664 Status: (ZG) pluginOTAFirmware set to /home/pi/domoticz/plugins/Domoticz-Zigate/OTAFirmware/
2020-12-02 12:41:28.664 Status: (ZG) pluginReports set to /home/pi/domoticz/plugins/Domoticz-Zigate/Reports/
2020-12-02 12:41:28.664 Status: (ZG) pluginLogs set to /home/pi/domoticz/plugins/Domoticz-Zigate/Logs/
2020-12-02 12:41:28.664 Status: (ZG) pluginConfig set to /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/
2020-12-02 12:41:28.664 Status: (ZG) homedirectory set to /home/pi/domoticz/plugins/Domoticz-Zigate/
2020-12-02 12:41:28.665 Status: (ZG) port set to 8282
2020-12-02 12:41:28.665 Status: (ZG) channel set to 11
2020-12-02 12:41:28.665 Status: (ZG) Switching Heartbeat to 5 s interval
2020-12-02 12:41:28.665 Status: (ZG) Python Version - 3.5.3 (default, Sep 27 2018, 17:25:39)
2020-12-02 12:41:28.665 [GCC 6.3.0 20170516]
2020-12-02 12:41:28.665 Status: (ZG) DomoticzVersion: 4.11214
2020-12-02 12:41:28.665 Status: (ZG) DomoticzHash: e7672936b
2020-12-02 12:41:28.665 Status: (ZG) DomoticzBuildTime: 2019-08-19 10:51:32
2020-12-02 12:41:28.665 Status: (ZG) Opening DomoticzDB in raw
2020-12-02 12:41:28.689 Status: RFXCOM: Using serial port: /dev/ttyUSB-RFXComXL
2020-12-02 12:41:28.713 Status: (ZG) Plugin Database: DeviceList-17.txt
2020-12-02 12:41:28.722 Status: (ZG) DeviceConf loaded
2020-12-02 12:41:28.789 Status: (ZG) load ListOfDevice
2020-12-02 12:41:29.227 Status: (ZG) Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigate/Data/DeviceList-17.txt
2020-12-02 12:41:29.272 Status: (ZG) Transport mode: USB
2020-12-02 12:41:29.272 Status: (ZG) ==> Transport Mode: auto
2020-12-02 12:41:29.276 Status: (ZG) Connection Name: Zigate, Transport: Serial, Address: /dev/ttyUSB-Zigate
2020-12-02 12:41:29.276 Status: (ZG) Connection open: Name: 'ZiGate', Transport: 'Serial', Protocol: 'None', Address: '/dev/ttyUSB-Zigate', Port: '', Baud: 115200, Connected: False, Parent: 'None'
Résultat plus d'accés au Dashboard (cache vidé) et aucun dispositif zigate ne répond 5interrupteur, PIR...)!!
Est-ce du au fait que je suis sur Raspberry Pi3 Stretch + Domoticz V4.11214 ?
Si Pipiche pouvait me venir en aide ?
_ Raspberry Pi3 Stretch + Domoticz V4.11214
_ dzVents Version: 2.4.28
_ Python 3.5.3
_ usbZwave
_ RFX433XL USB Version: Pro XL1/1035
_ GW Xiaomi
_ station meteo Oregon & Netatmo
_ LMS
_ Yeelight
_ Tradfri
_ Zigate plugin 4.11.012 + Version : 031d
Re: Ma zigate ne répond plus
Les logs s’arrêtent là ? même au bout d'1 minutes rien de plus ?
as-tu vérifié que la ZiGate est toujours sur le même port /dev/ttyUSB-Zigate (qui semble etre codé en dur).
calouis
oui la zigate est branchée sur même port
2020-12-02 14:27:34.078 Status: (ZG) Started.
2020-12-02 14:27:34.882 Status: (ZG) Entering work loop.
2020-12-02 14:27:34.883 Status: (ZG) Initialized version 4.11, author 'zaraki673 pipiche38'
2020-12-02 14:27:35.028 (ZG) Device ID: '2169'
2020-12-02 14:27:35.028 (ZG) Device Name: 'ZG - KIA Conso'
2020-12-02 14:27:35.029 (ZG) Device nValue: 4
2020-12-02 14:27:35.029 (ZG) Device sValue: '4.514'
2020-12-02 14:27:35.029 (ZG) Device LastLevel: 0
2020-12-02 14:27:35.029 (ZG) Device Options: {}
2020-12-02 14:27:35.029 (ZG) Device: 50 - ID: 2170, Name: 'ZG - KIA Cumul', nValue: 0, sValue: '4.51;851.4'
2020-12-02 14:27:35.029 (ZG) Device ID: '2170'
2020-12-02 14:27:35.029 (ZG) Device Name: 'ZG - KIA Cumul'
2020-12-02 14:27:35.029 (ZG) Device nValue: 0
2020-12-02 14:27:35.029 (ZG) Device sValue: '4.51;851.4'
2020-12-02 14:27:35.029 (ZG) Device Options: {'EnergyMeterMode': '1'}
2020-12-02 14:27:35.029 (ZG) Device: 51 - ID: 2171, Name: 'ZG - 220FR - 2 KIA', nValue: 1, sValue: 'On'
2020-12-02 14:27:35.029 (ZG) Device ID: '2171'
2020-12-02 14:27:35.029 (ZG) Device Name: 'ZG - 220FR - 2 KIA'
2020-12-02 14:27:35.029 (ZG) Device nValue: 1
2020-12-02 14:27:35.029 (ZG) Device sValue: 'On'
2020-12-02 14:27:35.029 (ZG) Device: 52 - ID: 2730, Name: 'ZG - Portail', nValue: 0, sValue: 'Closed'
2020-12-02 14:27:35.029 (ZG) Device ID: '2730'
2020-12-02 14:27:35.029 (ZG) Device Name: 'ZG - Portail'
2020-12-02 14:27:35.029 (ZG) Device sValue: 'Closed'
2020-12-02 14:27:35.029 (ZG) Device: 53 - ID: 2781, Name: 'ZG - Volet Baie', nValue: 0, sValue: '0'
2020-12-02 14:27:35.029 (ZG) Device ID: '2781'
2020-12-02 14:27:35.029 (ZG) Device Name: 'ZG - Volet Baie'
2020-12-02 14:27:35.029 (ZG) Device sValue: '0'
2020-12-02 14:27:35.029 (ZG) Device LastLevel: 100
2020-12-02 14:27:35.029 (ZG) Device: 54 - ID: 2783, Name: 'ZG - Contact Volet', nValue: 0, sValue: 'Closed'
2020-12-02 14:27:35.029 (ZG) Device ID: '2783'
2020-12-02 14:27:35.029 (ZG) Device Name: 'ZG - Contact Volet'
2020-12-02 14:27:35.030 (ZG) Device: 55 - ID: 2784, Name: 'ZG - Contact Baie', nValue: 0, sValue: 'Closed'
2020-12-02 14:27:35.030 (ZG) Device ID: '2784'
2020-12-02 14:27:35.030 (ZG) Device Name: 'ZG - Contact Baie'
2020-12-02 14:27:35.030 (ZG) Device nValue: 0
2020-12-02 14:27:35.030 (ZG) Device sValue: 'Closed'
2020-12-02 14:27:35.030 (ZG) Device LastLevel: 0
2020-12-02 14:27:35.030 (ZG) Device Options: {}
2020-12-02 14:27:35.030 (ZG) DomoticzVersion: 4.11214
2020-12-02 14:27:35.019 Status: (ZG) Zigate plugin stable-4.11.011 started
2020-12-02 14:27:35.019 Status: (ZG) Debug: 2
2020-12-02 14:27:35.030 Status: (ZG) load PluginConf
2020-12-02 14:27:35.032 Status: (ZG) port set to 8282
2020-12-02 14:27:35.032 Status: (ZG) channel set to 11
2020-12-02 14:27:35.032 Status: (ZG) filename set to /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/PluginConf-17.json
2020-12-02 14:27:35.032 Status: (ZG) homedirectory set to /home/pi/domoticz/plugins/Domoticz-Zigate/
2020-12-02 14:27:35.032 Status: (ZG) pluginLogs set to /home/pi/domoticz/plugins/Domoticz-Zigate/Logs/
2020-12-02 14:27:35.032 Status: (ZG) pluginOTAFirmware set to /home/pi/domoticz/plugins/Domoticz-Zigate/OTAFirmware/
2020-12-02 14:27:35.032 Status: (ZG) pluginReports set to /home/pi/domoticz/plugins/Domoticz-Zigate/Reports/
2020-12-02 14:27:35.032 Status: (ZG) pluginHome set to /home/pi/domoticz/plugins/Domoticz-Zigate/
2020-12-02 14:27:35.032 Status: (ZG) pluginConfig set to /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/
2020-12-02 14:27:35.032 Status: (ZG) pluginData set to /home/pi/domoticz/plugins/Domoticz-Zigate/Data/
2020-12-02 14:27:35.032 Status: (ZG) pluginWWW set to /home/pi/domoticz/plugins/Domoticz-Zigate/www/
2020-12-02 14:27:35.032 Status: (ZG) Switching Heartbeat to 5 s interval
2020-12-02 14:27:35.032 Status: (ZG) Python Version - 3.5.3 (default, Sep 27 2018, 17:25:39)
2020-12-02 14:27:35.033 Status: (ZG) DomoticzVersion: 4.11214
2020-12-02 14:27:35.033 Status: (ZG) DomoticzHash: e7672936b
2020-12-02 14:27:35.033 Status: (ZG) DomoticzBuildTime: 2019-08-19 10:51:32
2020-12-02 14:27:35.033 Status: (ZG) Opening DomoticzDB in raw
2020-12-02 14:27:35.081 Status: (ZG) Plugin Database: DeviceList-17.txt
2020-12-02 14:27:35.089 Status: (ZG) DeviceConf loaded
2020-12-02 14:27:35.153 Status: (ZG) load ListOfDevice
2020-12-02 14:27:35.572 Status: (ZG) Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigate/Data/DeviceList-17.txt
2020-12-02 14:27:35.616 Status: (ZG) Transport mode: USB
2020-12-02 14:27:35.616 Status: (ZG) ==> Transport Mode: auto
2020-12-02 14:27:35.621 Status: (ZG) Connection Name: Zigate, Transport: Serial, Address: /dev/ttyUSB-Zigate
2020-12-02 14:27:35.621 Status: (ZG) Connection open: Name: 'ZiGate', Transport: 'Serial', Protocol: 'None', Address: '/dev/ttyUSB-Zigate', Port: '', Baud: 115200, Connected: False, Parent: 'None'
si je clique sur widget "evier" :
2020-12-02 14:28:42.266 (ZG) UpdateDevice - (ZG - GU10 - 01 - Evier) 1:On
2020-12-02 14:28:42.223 Status: User: Admin initiated a switch command (1104/ZG - GU10 - 01 - Evier/On)
2020-12-02 14:28:59.591 (ZG) UpdateDevice - (ZG - GU10 - 01 - Evier) 0:Off
2020-12-02 14:28:59.556 Status: User: Admin initiated a switch command (1104/ZG - GU10 - 01 - Evier/Off)
pas de réaction de l'ampoule !
_ Python 3.5.3
_ usbZwave
_ GW Xiaomi
_ LMS
_ Yeelight
_ Tradfri
Donnes tous les logs Zigate pas des extraits. C'est le contexte qui est intéressant.
peux-tu faire la commande:
dmesg | grep tty
ls -l /dev/serial/*
calouis
pipiche a écrit : 02 déc. 2020, 14:39 Donnes tous les logs Zigate pas des extraits. C'est le contexte qui est intéressant.
dmesg | grep tty
pi@Pi3_Domo:~ $ dmesg | grep tty
[    0.000000] Kernel command line: 8250.nr_uarts=0 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=33e99940-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[    0.000808] console [tty1] enabled
[    0.825332] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
[    6.785987] cdc_acm 1-1.1.3.4:1.0: ttyACM0: USB ACM device
[    6.807169] usb 1-1.3: pl2303 converter now attached to ttyUSB0
[    6.832585] usb 1-1.1.3.3: FTDI USB Serial Device converter now attached to ttyUSB1
ls -l /dev/serial/*
_ Python 3.5.3
_ usbZwave
_ GW Xiaomi
_ LMS
_ Yeelight
_ Tradfri
calouis
dmesg | grep tty
ls -l /dev/serial/*
pi@Pi3_Domo:~ $ ls -l /dev/serial/*
/dev/serial/by-id:
total 0
lrwxrwxrwx 1 root root 13 déc  2 14:21 usb-0658_0200-if00 -> ../../ttyACM0
lrwxrwxrwx 1 root root 13 déc  2 14:21 usb-Prolific_Technology_Inc._USB-Serial_Controller-if00-port0 -> ../../ttyUSB0
lrwxrwxrwx 1 root root 13 déc  2 14:21 usb-RFXCOM_RFXtrx433XL_DO2ZYL2E-if00-port0 -> ../../ttyUSB1
/dev/serial/by-path:
total 0
lrwxrwxrwx 1 root root 13 déc  2 14:21 platform-3f980000.usb-usb-0:1.1.3.3:1.0-port0 -> ../../ttyUSB1
lrwxrwxrwx 1 root root 13 déc  2 14:21 platform-3f980000.usb-usb-0:1.1.3.4:1.0 -> ../../ttyACM0
lrwxrwxrwx 1 root root 13 déc  2 14:21 platform-3f980000.usb-usb-0:1.3:1.0-port0 -> ../../ttyUSB0
_ Python 3.5.3
_ usbZwave
_ GW Xiaomi
_ LMS
_ Yeelight
_ Tradfri
calouis
reboot :
2020-12-02 14:45:30.410 Sunrise: 08:34:00 SunSet: 16:53:00
2020-12-02 14:45:30.410 Day length: 08:19:00 Sun at south: 12:43:00
2020-12-02 14:45:30.410 Civil twilight start: 07:56:00 Civil twilight end: 17:30:00
2020-12-02 14:45:30.410 Nautical twilight start: 07:15:00 Nautical twilight end: 18:12:00
2020-12-02 14:45:30.410 Astronomical twilight start: 06:36:00 Astronomical twilight end: 18:51:00
2020-12-02 14:45:30.700 Active notification Subsystems: pushover (1/13)
2020-12-02 14:45:30.784 Starting shared server on: :::6144
2020-12-02 14:45:30.301 Status: Domoticz V4.11214 (c)2012-2019 GizMoCuz
2020-12-02 14:45:30.301 Status: Build Hash: e7672936b, Date: 2019-08-19 10:51:32
2020-12-02 14:45:30.301 Status: Startup Path: /home/pi/domoticz/
2020-12-02 14:45:30.683 Status: PluginSystem: Started, Python version '3.5.3'.
2020-12-02 14:45:30.738 Status: WebServer(HTTP) started on address: :: with port 8282
2020-12-02 14:45:30.746 Status: WebServer(SSL) started on address: :: with port 443
2020-12-02 14:45:30.785 Status: TCPServer: shared server started...
2020-12-02 14:45:30.785 Status: RxQueue: queue worker started...
2020-12-02 14:45:32.787 Status: YeeLight Worker started...
2020-12-02 14:45:32.787 Status: XiaomiGateway (ID=7): Delaying worker startup...
2020-12-02 14:45:37.787 Status: XiaomiGateway (ID=7): Selected as main Gateway
2020-12-02 14:45:37.788 Status: XiaomiGateway (ID=7): Worker started...
2020-12-02 14:45:37.788 Status: Netatmo: Worker started...
2020-12-02 14:45:37.788 Status: (ZG) Started.
2020-12-02 14:45:37.788 Status: XiaomiGateway (ID=7): Using 192.168.1.12 for local IP address.
2020-12-02 14:45:37.788 Status: (PiMoniteur) Started.
2020-12-02 14:45:37.789 Status: RFXCOM: Worker started...
2020-12-02 14:45:37.789 Status: Pinger: Worker started...
2020-12-02 14:45:37.790 Status: EventSystem: reset all events...
2020-12-02 14:45:37.821 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/Solardata.lua
2020-12-02 14:45:37.822 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/global_data.lua
2020-12-02 14:45:37.822 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/Yeelight Scene Selector.lua
2020-12-02 14:45:37.822 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/Rideau_Garage_Axroll.lua
2020-12-02 14:45:37.822 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/Check_dead_devices.lua
2020-12-02 14:45:37.822 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/PIR_Cadre_Etage.lua
2020-12-02 14:45:37.823 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/PIR_Cadre_Salon_Nuit.lua
2020-12-02 14:45:37.823 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/Bouton_Carre_Switch.lua
2020-12-02 14:45:37.823 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/PIR_Cadre_SdB.lua
2020-12-02 14:45:37.823 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/CO2_ruban.lua
2020-12-02 14:45:37.823 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/Bouton_Rond_miBox.lua
2020-12-02 14:45:37.824 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/PIR_Evier.lua
2020-12-02 14:45:37.824 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/PIR_mi_box.lua
2020-12-02 14:45:37.824 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/Dummy_Soir_salon.lua
2020-12-02 14:45:37.824 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/Dummy_tv_cine.lua
2020-12-02 14:45:37.824 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/Dummy_cuisine_eclairage.lua
2020-12-02 14:45:37.825 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/Xiaomi_gw.lua
2020-12-02 14:45:37.825 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/Dummy_Salon_Blanc.lua
2020-12-02 14:45:37.825 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/PIR_Salon.lua
2020-12-02 14:45:37.825 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/Beaufort.lua
2020-12-02 14:45:37.826 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/xiaomiMP3.lua
2020-12-02 14:45:37.826 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/Fin2Cycle.lua
2020-12-02 14:45:37.826 Status: EventSystem: reset all device statuses...
2020-12-02 14:45:37.840 Status: XiaomiGateway: RGB Gateway Detected
2020-12-02 14:45:37.926 Status: PluginSystem: Entering work loop.
2020-12-02 14:45:38.851 (ZG) Device Options: {}
2020-12-02 14:45:38.851 (ZG) Device: 49 - ID: 2169, Name: 'ZG - KIA Conso', nValue: 4, sValue: '4.514'
2020-12-02 14:45:38.851 (ZG) Device ID: '2169'
2020-12-02 14:45:38.851 (ZG) Device Name: 'ZG - KIA Conso'
2020-12-02 14:45:38.851 (ZG) Device nValue: 4
2020-12-02 14:45:38.851 (ZG) Device sValue: '4.514'
2020-12-02 14:45:38.851 (ZG) Device LastLevel: 0
2020-12-02 14:45:38.851 (ZG) Device: 50 - ID: 2170, Name: 'ZG - KIA Cumul', nValue: 0, sValue: '4.51;851.4'
2020-12-02 14:45:38.851 (ZG) Device ID: '2170'
2020-12-02 14:45:38.851 (ZG) Device Name: 'ZG - KIA Cumul'
2020-12-02 14:45:38.851 (ZG) Device nValue: 0
2020-12-02 14:45:38.851 (ZG) Device sValue: '4.51;851.4'
2020-12-02 14:45:38.851 (ZG) Device Options: {'EnergyMeterMode': '1'}
2020-12-02 14:45:38.851 (ZG) Device: 51 - ID: 2171, Name: 'ZG - 220FR - 2 KIA', nValue: 1, sValue: 'On'
2020-12-02 14:45:38.851 (ZG) Device ID: '2171'
2020-12-02 14:45:38.851 (ZG) Device Name: 'ZG - 220FR - 2 KIA'
2020-12-02 14:45:38.851 (ZG) Device nValue: 1
2020-12-02 14:45:38.851 (ZG) Device sValue: 'On'
2020-12-02 14:45:38.852 (ZG) Device Options: {}
2020-12-02 14:45:38.852 (ZG) Device: 52 - ID: 2730, Name: 'ZG - Portail', nValue: 0, sValue: 'Closed'
2020-12-02 14:45:38.852 (ZG) Device ID: '2730'
2020-12-02 14:45:38.852 (ZG) Device Name: 'ZG - Portail'
2020-12-02 14:45:38.852 (ZG) Device nValue: 0
2020-12-02 14:45:38.852 (ZG) Device sValue: 'Closed'
2020-12-02 14:45:38.852 (ZG) Device LastLevel: 0
2020-12-02 14:45:38.852 (ZG) Device: 53 - ID: 2781, Name: 'ZG - Volet Baie', nValue: 0, sValue: '0'
2020-12-02 14:45:38.852 (ZG) Device ID: '2781'
2020-12-02 14:45:38.852 (ZG) Device Name: 'ZG - Volet Baie'
2020-12-02 14:45:38.852 (ZG) Device sValue: '0'
2020-12-02 14:45:38.852 (ZG) Device LastLevel: 100
2020-12-02 14:45:38.852 (ZG) Device: 54 - ID: 2783, Name: 'ZG - Contact Volet', nValue: 0, sValue: 'Closed'
2020-12-02 14:45:38.852 (ZG) Device ID: '2783'
2020-12-02 14:45:38.852 (ZG) Device Name: 'ZG - Contact Volet'
2020-12-02 14:45:38.852 (ZG) Device: 55 - ID: 2784, Name: 'ZG - Contact Baie', nValue: 0, sValue: 'Closed'
2020-12-02 14:45:38.852 (ZG) Device ID: '2784'
2020-12-02 14:45:38.852 (ZG) Device Name: 'ZG - Contact Baie'
2020-12-02 14:45:38.852 (ZG) DomoticzVersion: 4.11214
2020-12-02 14:45:38.288 Status: OpenZWave: using config in: /home/pi/domoticz/Config/
2020-12-02 14:45:38.344 Status: OpenZWave: Starting...
2020-12-02 14:45:38.344 Status: OpenZWave: Version: 1.6-808-gbb0a4bf7-dirty
2020-12-02 14:45:38.621 Status: (ZG) Entering work loop.
2020-12-02 14:45:38.622 Status: (ZG) Initialized version 4.11, author 'zaraki673 pipiche38'
2020-12-02 14:45:38.750 Status: (PiMoniteur) Entering work loop.
2020-12-02 14:45:38.751 Status: (PiMoniteur) Initialized version 3.1, author 'Xorfor'
2020-12-02 14:45:38.792 Status: RFXCOM: Using serial port: /dev/ttyUSB-RFXComXL
2020-12-02 14:45:38.815 Status: Python EventSystem: Initalizing event module.
2020-12-02 14:45:38.816 Status: EventSystem: Queue thread started...
2020-12-02 14:45:38.817 Status: EventSystem: Started
2020-12-02 14:45:38.841 Status: (ZG) Zigate plugin stable-4.11.011 started
2020-12-02 14:45:38.841 Status: (ZG) Debug: 2
2020-12-02 14:45:38.852 Status: (ZG) load PluginConf
2020-12-02 14:45:38.857 Status: (ZG) port set to 8282
2020-12-02 14:45:38.857 Status: (ZG) channel set to 11
2020-12-02 14:45:38.857 Status: (ZG) pluginConfig set to /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/
2020-12-02 14:45:38.857 Status: (ZG) pluginReports set to /home/pi/domoticz/plugins/Domoticz-Zigate/Reports/
2020-12-02 14:45:38.857 Status: (ZG) pluginData set to /home/pi/domoticz/plugins/Domoticz-Zigate/Data/
2020-12-02 14:45:38.857 Status: (ZG) pluginWWW set to /home/pi/domoticz/plugins/Domoticz-Zigate/www/
2020-12-02 14:45:38.857 Status: (ZG) pluginOTAFirmware set to /home/pi/domoticz/plugins/Domoticz-Zigate/OTAFirmware/
2020-12-02 14:45:38.857 Status: (ZG) homedirectory set to /home/pi/domoticz/plugins/Domoticz-Zigate/
2020-12-02 14:45:38.857 Status: (ZG) pluginHome set to /home/pi/domoticz/plugins/Domoticz-Zigate/
2020-12-02 14:45:38.857 Status: (ZG) pluginLogs set to /home/pi/domoticz/plugins/Domoticz-Zigate/Logs/
2020-12-02 14:45:38.857 Status: (ZG) filename set to /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/PluginConf-17.json
2020-12-02 14:45:38.857 Status: (ZG) Switching Heartbeat to 5 s interval
2020-12-02 14:45:38.857 Status: (ZG) Python Version - 3.5.3 (default, Sep 27 2018, 17:25:39)
2020-12-02 14:45:38.857 [GCC 6.3.0 20170516]
2020-12-02 14:45:38.857 Status: (ZG) DomoticzVersion: 4.11214
2020-12-02 14:45:38.857 Status: (ZG) DomoticzHash: e7672936b
2020-12-02 14:45:38.857 Status: (ZG) DomoticzBuildTime: 2019-08-19 10:51:32
2020-12-02 14:45:38.858 Status: (ZG) Opening DomoticzDB in raw
2020-12-02 14:45:38.955 Status: (ZG) Plugin Database: DeviceList-17.txt
2020-12-02 14:45:38.968 Status: (ZG) DeviceConf loaded
2020-12-02 14:45:39.444
2020-12-02 14:45:39.444 subtype = Interface Response
2020-12-02 14:45:39.444 Sequence nbr = 2
2020-12-02 14:45:39.444 response on cmnd = Get Status
2020-12-02 14:45:39.444 Transceiver type = 433.92MHz
2020-12-02 14:45:39.444 Firmware version = 1035
2020-12-02 14:45:39.444 Firmware type = Pro XL1
2020-12-02 14:45:39.444 Noise Level: 95
2020-12-02 14:45:39.444 Hardware version = 3.0
2020-12-02 14:45:39.444 Undec off
2020-12-02 14:45:39.444 X10 enabled
2020-12-02 14:45:39.444 ARC enabled
2020-12-02 14:45:39.444 AC enabled
2020-12-02 14:45:39.444 HomeEasy EU disabled
2020-12-02 14:45:39.444 Meiantech/Atlantic disabled
2020-12-02 14:45:39.444 Oregon Scientific enabled
2020-12-02 14:45:39.444 ATI/Cartelectronic disabled
2020-12-02 14:45:39.444 Visonic disabled
2020-12-02 14:45:39.444 Mertik disabled
2020-12-02 14:45:39.444 AD disabled
2020-12-02 14:45:39.444 Hideki disabled
2020-12-02 14:45:39.444 La Crosse enabled
2020-12-02 14:45:39.444 Legrand disabled
2020-12-02 14:45:39.444 MSG4Reserved5 disabled
2020-12-02 14:45:39.444 BlindsT0 disabled
2020-12-02 14:45:39.444 BlindsT1 disabled
2020-12-02 14:45:39.444 AE disabled
2020-12-02 14:45:39.444 RUBiCSON disabled
2020-12-02 14:45:39.444 FineOffset disabled
2020-12-02 14:45:39.444 Lighting4 disabled
2020-12-02 14:45:39.444 Conrad RSL disabled
2020-12-02 14:45:39.444 ByronSX disabled
2020-12-02 14:45:39.444 IMAGINTRONIX disabled
2020-12-02 14:45:39.444 KEELOQ disabled
2020-12-02 14:45:39.444 Home Confort disabled
2020-12-02 14:45:39.802 (PiMoniteur) Debug logging mask set to: NONE
2020-12-02 14:45:39.271 Status: (ZG) load ListOfDevice
2020-12-02 14:45:39.444 Status: RFXCOM: Async Disabled
2020-12-02 14:45:39.746 Status: (ZG) Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigate/Data/DeviceList-17.txt
2020-12-02 14:45:39.792 Status: (ZG) Transport mode: USB
2020-12-02 14:45:39.792 Status: (ZG) ==> Transport Mode: auto
2020-12-02 14:45:39.796 Status: (ZG) Connection Name: Zigate, Transport: Serial, Address: /dev/ttyUSB-Zigate
2020-12-02 14:45:39.796 Status: (ZG) Connection open: Name: 'ZiGate', Transport: 'Serial', Protocol: 'None', Address: '/dev/ttyUSB-Zigate', Port: '', Baud: 115200, Connected: False, Parent: 'None'
2020-12-02 14:45:40.758 Status: OpenZWave: User Alert - Manufacturer_specific.xml out of Date
2020-12-02 14:45:40.758 Status: OpenZWave: Received unhandled notification type (30) from HomeID: 0, NodeID: 0 (0x00)
2020-12-02 14:45:40.758 Status: OpenZWave: ManufacturerSpecificDB Ready
2020-12-02 14:45:41.044 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1, Index: 0
2020-12-02 14:45:41.044 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: METER, Label: Electric - kWh, Instance: 1, Index: 0
2020-12-02 14:45:41.044 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: METER, Label: Electric - W, Instance: 1, Index: 2
2020-12-02 14:45:41.044 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: METER, Label: Electric - V, Instance: 1, Index: 4
2020-12-02 14:45:41.044 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: METER, Label: Electric - A, Instance: 1, Index: 5
2020-12-02 14:45:41.044 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: METER, Label: Exporting, Instance: 1, Index: 256
2020-12-02 14:45:41.044 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: ALARM, Label: Power Management, Instance: 1, Index: 8
2020-12-02 14:45:41.044 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: ALARM, Label: Previous Event Cleared, Instance: 1, Index: 256
2020-12-02 14:45:41.045 OpenZWave: Value_Added: Node: 5 (0x05), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1, Index: 0
2020-12-02 14:45:41.045 OpenZWave: Value_Added: Node: 5 (0x05), CommandClass: METER, Label: Electric - kWh, Instance: 1, Index: 0
2020-12-02 14:45:41.045 OpenZWave: Value_Added: Node: 5 (0x05), CommandClass: METER, Label: Electric - W, Instance: 1, Index: 2
2020-12-02 14:45:41.045 OpenZWave: Value_Added: Node: 5 (0x05), CommandClass: METER, Label: Electric - V, Instance: 1, Index: 4
2020-12-02 14:45:41.045 OpenZWave: Value_Added: Node: 5 (0x05), CommandClass: METER, Label: Electric - A, Instance: 1, Index: 5
2020-12-02 14:45:41.046 OpenZWave: Value_Added: Node: 5 (0x05), CommandClass: METER, Label: Exporting, Instance: 1, Index: 256
2020-12-02 14:45:41.046 OpenZWave: Value_Added: Node: 5 (0x05), CommandClass: ALARM, Label: Power Management, Instance: 1, Index: 8
2020-12-02 14:45:41.046 OpenZWave: Value_Added: Node: 5 (0x05), CommandClass: ALARM, Label: Previous Event Cleared, Instance: 1, Index: 256
2020-12-02 14:45:41.047 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1, Index: 0
2020-12-02 14:45:41.047 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: METER, Label: Electric - kWh, Instance: 1, Index: 0
2020-12-02 14:45:41.047 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: METER, Label: Electric - W, Instance: 1, Index: 2
2020-12-02 14:45:41.047 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: METER, Label: Electric - V, Instance: 1, Index: 4
2020-12-02 14:45:41.047 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: METER, Label: Electric - A, Instance: 1, Index: 5
2020-12-02 14:45:41.047 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: METER, Label: Exporting, Instance: 1, Index: 256
2020-12-02 14:45:41.047 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: ALARM, Label: Power Management, Instance: 1, Index: 8
2020-12-02 14:45:41.047 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: ALARM, Label: Previous Event Cleared, Instance: 1, Index: 256
2020-12-02 14:45:41.048 OpenZWave: Value_Added: Node: 7 (0x07), CommandClass: SENSOR BINARY, Label: Sensor, Instance: 1, Index: 0
2020-12-02 14:45:41.048 OpenZWave: Value_Added: Node: 7 (0x07), CommandClass: SENSOR MULTILEVEL, Label: Air Temperature, Instance: 1, Index: 1
2020-12-02 14:45:41.048 OpenZWave: Value_Added: Node: 7 (0x07), CommandClass: SENSOR MULTILEVEL, Label: Illuminance, Instance: 1, Index: 3
2020-12-02 14:45:41.048 OpenZWave: Value_Added: Node: 7 (0x07), CommandClass: SENSOR MULTILEVEL, Label: Seismic Intensity, Instance: 1, Index: 25
2020-12-02 14:45:41.048 OpenZWave: Value_Added: Node: 7 (0x07), CommandClass: SENSOR MULTILEVEL, Label: X-Axis Acceleration, Instance: 1, Index: 52
2020-12-02 14:45:41.048 OpenZWave: Value_Added: Node: 7 (0x07), CommandClass: SENSOR MULTILEVEL, Label: Y-Axis Acceleration, Instance: 1, Index: 53
2020-12-02 14:45:41.048 OpenZWave: Value_Added: Node: 7 (0x07), CommandClass: SENSOR MULTILEVEL, Label: Z-Axis Acceleration, Instance: 1, Index: 54
2020-12-02 14:45:41.049 OpenZWave: Value_Added: Node: 7 (0x07), CommandClass: ALARM, Label: Home Security, Instance: 1, Index: 7
2020-12-02 14:45:41.049 OpenZWave: Value_Added: Node: 7 (0x07), CommandClass: ALARM, Label: Previous Event Cleared, Instance: 1, Index: 256
2020-12-02 14:45:41.049 OpenZWave: Value_Added: Node: 7 (0x07), CommandClass: BATTERY, Label: Battery Level, Instance: 1, Index: 0
2020-12-02 14:45:41.050 OpenZWave: Value_Added: Node: 7 (0x07), CommandClass: SENSOR ALARM, Label: General, Instance: 1, Index: 0
2020-12-02 14:45:41.050 OpenZWave: Value_Added: Node: 8 (0x08), CommandClass: SENSOR BINARY, Label: Sensor, Instance: 1, Index: 0
2020-12-02 14:45:41.050 OpenZWave: Value_Added: Node: 8 (0x08), CommandClass: SENSOR MULTILEVEL, Label: Air Temperature, Instance: 1, Index: 1
2020-12-02 14:45:41.050 OpenZWave: Value_Added: Node: 8 (0x08), CommandClass: SENSOR MULTILEVEL, Label: Illuminance, Instance: 1, Index: 3
2020-12-02 14:45:41.050 OpenZWave: Value_Added: Node: 8 (0x08), CommandClass: SENSOR MULTILEVEL, Label: Seismic Intensity, Instance: 1, Index: 25
2020-12-02 14:45:41.050 OpenZWave: Value_Added: Node: 8 (0x08), CommandClass: SENSOR MULTILEVEL, Label: X-Axis Acceleration, Instance: 1, Index: 52
2020-12-02 14:45:41.051 OpenZWave: Value_Added: Node: 8 (0x08), CommandClass: SENSOR MULTILEVEL, Label: Y-Axis Acceleration, Instance: 1, Index: 53
2020-12-02 14:45:41.051 OpenZWave: Value_Added: Node: 8 (0x08), CommandClass: SENSOR MULTILEVEL, Label: Z-Axis Acceleration, Instance: 1, Index: 54
2020-12-02 14:45:41.051 OpenZWave: Value_Added: Node: 8 (0x08), CommandClass: ALARM, Label: Home Security, Instance: 1, Index: 7
2020-12-02 14:45:41.051 OpenZWave: Value_Added: Node: 8 (0x08), CommandClass: ALARM, Label: Previous Event Cleared, Instance: 1, Index: 256
2020-12-02 14:45:41.052 OpenZWave: Value_Added: Node: 8 (0x08), CommandClass: BATTERY, Label: Battery Level, Instance: 1, Index: 0
2020-12-02 14:45:41.052 OpenZWave: Value_Added: Node: 8 (0x08), CommandClass: SENSOR ALARM, Label: General, Instance: 1, Index: 0
2020-12-02 14:45:41.034 Status: OpenZWave: Driver Ready
2020-12-02 14:45:43.822 (Zwave) General/kWh (Lave Linge (Historique))
2020-12-02 14:45:43.958 (Zwave) Usage (Lave Linge (Conso))
2020-12-02 14:45:43.962 (Zwave) General/kWh (Lave Linge (Historique))
2020-12-02 14:45:44.081 (Opale) Temp + Humidity (Netatmo ext.)
2020-12-02 14:45:44.085 (Opale) Temp + Humidity + Baro (Netatmo int.)
2020-12-02 14:45:44.088 (Opale) Air Quality (CO2)
2020-12-02 14:45:44.091 (Opale) General/Sound Level (Sonomètre)
2020-12-02 14:45:44.119 (Zwave) General/Voltage (Ll_Voltage)
2020-12-02 14:45:44.253 (Zwave) Current (Ll_Unknown)
2020-12-02 14:45:44.316 (Zwave) General/Alarm (Ll_Alarm Type: Power Management 8 (0x08))
2020-12-02 14:45:44.320 (Zwave) Light/Switch (Ll_Power Management)
2020-12-02 14:45:44.387 (Zwave) General/Alarm (Ll_Alarm Type: Power Management 8 (0x08))
2020-12-02 14:45:44.390 (Zwave) Light/Switch (Ll_Power Management)
2020-12-02 14:45:44.564 (Zwave) General/kWh (Lave Vaisselle (Historique))
2020-12-02 14:45:44.600 (Zwave) Usage (Lave Vaisselle (Conso))
2020-12-02 14:45:44.605 (Zwave) General/kWh (Lave Vaisselle (Historique))
2020-12-02 14:45:44.634 (Zwave) General/Voltage (LV_Voltage)
2020-12-02 14:45:44.672 (Zwave) Current (LV_Unknown)
2020-12-02 14:45:44.711 (Zwave) General/Alarm (LV_Alarm Type: Power Management 8 (0x08))
2020-12-02 14:45:44.714 (Zwave) Light/Switch (LV_Power Management)
2020-12-02 14:45:44.153 Status: dzVents: Info: Handling events for: "Lave Linge (Conso)", value: "0.0"
2020-12-02 14:45:44.153 Status: dzVents: Info: FIN DE CYCLE: ------ Start internal script: Fin2Cycle: Device: "Lave Linge (Conso) (Zwave)", Index: 2070
2020-12-02 14:45:44.164 Status: dzVents: Info: FIN DE CYCLE: ------ Finished Fin2Cycle
2020-12-02 14:45:44.314 Status: OpenZWave: Alarm received (Power Management: Clear), NodeID: 2 (0x02)
2020-12-02 14:45:44.386 Status: OpenZWave: Alarm received (Power Management: Clear), NodeID: 2 (0x02)
2020-12-02 14:45:44.579 Status: dzVents: Info: Handling events for: "CO2", value: "356"
2020-12-02 14:45:44.579 Status: dzVents: Info: ------ Start internal script: CO2_ruban: Device: "CO2 (Opale)", Index: 62
2020-12-02 14:45:44.581 Status: dzVents: Info: ------ Finished CO2_ruban
2020-12-02 14:45:44.710 Status: OpenZWave: Alarm received (Power Management: Clear), NodeID: 5 (0x05)
2020-12-02 14:45:45.831 (Zwave) General/kWh (Sèche Linge (Historique))
2020-12-02 14:45:45.136 Status: dzVents: Info: Handling events for: "Lave Vaisselle (Conso)", value: "0.0"
2020-12-02 14:45:45.136 Status: dzVents: Info: FIN DE CYCLE: ------ Start internal script: Fin2Cycle: Device: "Lave Vaisselle (Conso) (Zwave)", Index: 2097
2020-12-02 14:45:45.142 Status: dzVents: Info: FIN DE CYCLE: ------ Finished Fin2Cycle
2020-12-02 14:45:46.254 (Zwave) Usage (Sèche Linge (Conso))
2020-12-02 14:45:46.287 (Zwave) General/kWh (Sèche Linge (Historique))
2020-12-02 14:45:46.653 (Zwave) General/Voltage (SL_Voltage)
2020-12-02 14:45:46.408 Status: dzVents: Info: Handling events for: "Sèche Linge (Conso)", value: "0.0"
2020-12-02 14:45:46.408 Status: dzVents: Info: FIN DE CYCLE: ------ Start internal script: Fin2Cycle: Device: "Sèche Linge (Conso) (Zwave)", Index: 2105
2020-12-02 14:45:46.414 Status: dzVents: Info: FIN DE CYCLE: ------ Finished Fin2Cycle
2020-12-02 14:45:47.060 (Zwave) Current (SL_Unknown)
2020-12-02 14:45:47.495 (Zwave) General/Alarm (SL_Alarm Type: Power Management 8 (0x08))
2020-12-02 14:45:47.498 (Zwave) Light/Switch (SL_Power Management)
2020-12-02 14:45:47.477 Status: OpenZWave: Alarm received (Power Management: Clear), NodeID: 6 (0x06)
2020-12-02 14:45:47.678 Status: OpenZWave: Awake Nodes queried
2020-12-02 14:45:50.338 (RFX433XL) Wind (Vent Jardin)
2020-12-02 14:45:50.822 Status: dzVents: Info: Handling events for: "Vent Jardin", value: "315.00;NW;22;24;0.0;-2.7"
2020-12-02 14:45:50.823 Status: dzVents: Info: Beaufort v1.00: ------ Start internal script: Beaufort: Device: "Vent Jardin (RFX433XL)", Index: 1890
2020-12-02 14:45:50.826 Status: dzVents: Info: Beaufort v1.00: ------ Finished Beaufort
2020-12-02 14:45:55.082 (RFX433XL) Temp (Ch. Lucie)
2020-12-02 14:45:55.509 (RFX433XL) Humidity (Ch. Lucie)
2020-12-02 14:46:27.894 Status: EventSystem: Script event triggered: script_time_weewx38.lua
2020-12-02 14:46:35.150 (RFX433XL) Wind (Vent Jardin)
2020-12-02 14:46:35.335 Status: dzVents: Info: Handling events for: "Vent Jardin", value: "293.00;WNW;22;14;0.0;-2.7"
2020-12-02 14:46:35.335 Status: dzVents: Info: Beaufort v1.00: ------ Start internal script: Beaufort: Device: "Vent Jardin (RFX433XL)", Index: 1890
2020-12-02 14:46:35.338 Status: dzVents: Info: Beaufort v1.00: ------ Finished Beaufort
_ Python 3.5.3
_ usbZwave
_ GW Xiaomi
_ LMS
_ Yeelight
_ Tradfri
et quid de
ls -l /dev/ttyUSB-Zigate
car a priori c'est toi qui a du créé ca ?
Peux-tu confirmer que le module USB-TTL de la Zigate est de couleur bleue ?
Vérifie les cablages entre le module Zigbee et le module USB
et re-essayes
calouis
pipiche a écrit : 02 déc. 2020, 14:51 et quid de
car a priori c'est toi qui a du créé ca ? oui et celuis depuis +sieurs années
Peux-tu confirmer que le module USB-TTL de la Zigate est de couleur bleue ? oui
et re-essayes
pi@Pi3_Domo:~ $ ls -l /dev/ttyUSB-Zigate
lrwxrwxrwx 1 root root 7 déc  2 14:45 /dev/ttyUSB-Zigate -> ttyUSB1
_ Python 3.5.3
_ usbZwave
_ GW Xiaomi
_ LMS
_ Yeelight
_ Tradfri
calouis a écrit : 02 déc. 2020, 14:53
En gros tu pointes sur ton control usb-RFXCOM qui est sur ttyUSB1 !!
Je te recommande dans Domoticz de changer le port et de mettre:
a la place de ttyUSB1
