Message d'erreur "KeyError' Zigate
SpaWnOL
Message par SpaWnOL »
J'ai du reinstaller mon domoticz et depuis je rencontre ces messages d'erreur avec mon zigate, à intervalle régulier (toutes les 5min)
Une idée du pourquoi? Merci
2020-12-07 21:24:02.263 Error: (Zigate) 'onMessage' failed 'KeyError'.
2020-12-07 21:24:02.263 Error: (Zigate) ----> Line 984 in '/home/pi/domoticz/plugins/Domoticz-Zigate-stable/plugin.py', function onMessage
2020-12-07 21:24:02.263 Error: (Zigate) ----> Line 519 in '/home/pi/domoticz/plugins/Domoticz-Zigate-stable/plugin.py', function onMessage
2020-12-07 21:24:02.263 Error: (Zigate) ----> Line 325 in '/home/pi/domoticz/plugins/Domoticz-Zigate-stable/Classes/Transport.py', function onMessage
2020-12-07 21:24:02.264 Error: (Zigate) ----> Line 538 in '/home/pi/domoticz/plugins/Domoticz-Zigate-stable/Classes/Transport.py', function processFrame
2020-12-07 21:24:02.264 Error: (Zigate) ----> Line 523 in '/home/pi/domoticz/plugins/Domoticz-Zigate-stable/plugin.py', function processFrame
2020-12-07 21:24:02.264 Error: (Zigate) ----> Line 122 in '/home/pi/domoticz/plugins/Domoticz-Zigate-stable/Modules/input.py', function ZigateRead
2020-12-07 21:24:02.264 Error: (Zigate) ----> Line 1773 in '/home/pi/domoticz/plugins/Domoticz-Zigate-stable/Modules/input.py', function Decode8102
2020-12-07 21:24:02.264 Error: (Zigate) ----> Line 222 in '/home/pi/domoticz/plugins/Domoticz-Zigate-stable/Modules/readClusters.py', function ReadCluster
2020-12-07 21:24:02.264 Error: (Zigate) ----> Line 796 in '/home/pi/domoticz/plugins/Domoticz-Zigate-stable/Modules/readClusters.py', function Cluster0006
2020-12-07 21:24:02.264 Error: (Zigate) ----> Line 410 in '/home/pi/domoticz/plugins/Domoticz-Zigate-stable/Modules/domoMaj.py', function MajDomoDevice
2020-12-07 21:24:02.264 Error: (Zigate) ----> Line 197 in '/home/pi/domoticz/plugins/Domoticz-Zigate-stable/Modules/domoTools.py', function UpdateDevice_v2
Re: Message d'erreur "KeyError' Zigate
Tu peux nous mettre les logs de démarrage du plugin Zigate stp.
Tu es sur quelle branche du plugin ? Quelle version ? Sur quel système ?
Tu as essayé de refaire un git pull ? Ou de forcer la mise à jour suivant les indications du wiki
Comment as tu réinstaller ton DomoticZ ? Tu as remis une sauvegarde complète ? Tu as réinstallé DomoticZ à partir de zéro et tu as importer ta base de données ? Qu'as tu fait un niveau du plugin Zigate ? Tu as remis des dossiers ?
SpaWnOL
Keros a écrit : 07 déc. 2020, 21:49 Tu peux nous mettre les logs de démarrage du plugin Zigate stp.
2020-12-07 21:49:13.141 Status: (Zigate) Entering work loop.
2020-12-07 21:49:13.142 Status: (Zigate) Initialized version 4.9, author 'zaraki673 pipiche38'
2020-12-07 21:49:13.155 Status: (Zigate) Zigate plugin stable-4.9.004 started
2020-12-07 21:49:13.155 Status: (Zigate) Debug: 4
2020-12-07 21:49:13.167 Status: (Zigate) load PluginConf
2020-12-07 21:49:13.169 Status: (Zigate) allowOTA set to 1
2020-12-07 21:49:13.169 Status: (Zigate) enableAPSFailureReporting set to 0
2020-12-07 21:49:13.169 Status: (Zigate) Certification set to FCC
2020-12-07 21:49:13.169 Status: (Zigate) CertificationCode set to 2
2020-12-07 21:49:13.169 Status: (Zigate) channel set to 11
2020-12-07 21:49:13.169 Status: (Zigate) filename set to /home/pi/domoticz/plugins/Domoticz-Zigate-stable/Conf/PluginConf-22.json
2020-12-07 21:49:13.169 Status: (Zigate) pluginHome set to /home/pi/domoticz/plugins/Domoticz-Zigate-stable/
2020-12-07 21:49:13.169 Status: (Zigate) homedirectory set to /home/pi/domoticz/plugins/Domoticz-Zigate-stable/
2020-12-07 21:49:13.169 Status: (Zigate) pluginData set to /home/pi/domoticz/plugins/Domoticz-Zigate-stable/Data/
2020-12-07 21:49:13.169 Status: (Zigate) pluginConfig set to /home/pi/domoticz/plugins/Domoticz-Zigate-stable/Conf/
2020-12-07 21:49:13.169 Status: (Zigate) pluginOTAFirmware set to /home/pi/domoticz/plugins/Domoticz-Zigate-stable/OTAFirmware/
2020-12-07 21:49:13.169 Status: (Zigate) pluginReports set to /home/pi/domoticz/plugins/Domoticz-Zigate-stable/Reports/
2020-12-07 21:49:13.169 Status: (Zigate) pluginWWW set to /home/pi/domoticz/plugins/Domoticz-Zigate-stable/www/
2020-12-07 21:49:13.169 Status: (Zigate) pluginLogs set to /home/pi/domoticz/plugins/Domoticz-Zigate-stable/Logs/
2020-12-07 21:49:13.169 Status: (Zigate) Switching Heartbeat to 5 s interval
2020-12-07 21:49:13.169 Status: (Zigate) Python Version - 3.7.3 (default, Jul 25 2020, 13:03:44)
2020-12-07 21:49:13.169 [GCC 8.3.0]
2020-12-07 21:49:13.169 Status: (Zigate) DomoticzVersion: 2020.2
2020-12-07 21:49:13.170 Status: (Zigate) DomoticzHash: b63341bc0
2020-12-07 21:49:13.170 Status: (Zigate) DomoticzBuildTime: 2020-04-26 13:47:55
2020-12-07 21:49:13.170 Status: (Zigate) Opening DomoticzDB in raw
2020-12-07 21:49:13.184 Status: (Zigate) Plugin Database: DeviceList-22.txt
2020-12-07 21:49:13.194 Status: (Zigate) DeviceConf loaded
2020-12-07 21:49:13.249 Status: (Zigate) load ListOfDevice
2020-12-07 21:49:13.378 Status: (Zigate) Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigate-stable/Data/DeviceList-22.txt
2020-12-07 21:49:13.395 Status: (Zigate) Transport mode: USB
2020-12-07 21:49:13.397 Status: (Zigate) Connection Name: Zigate, Transport: Serial, Address: /dev/serial/by-id/usb-Silicon_Labs_ZIGATE_0001-if00-port0
2020-12-07 21:49:13.397 Status: (Zigate) Connection open: Name: 'ZiGate', Transport: 'Serial', Protocol: 'None', Address: '/dev/serial/by-id/usb-Silicon_Labs_ZIGATE_0001-if00-port0', Port: '', Baud: 115200, Connected: False, Parent: 'None'
2020-12-07 21:49:13.409 Status: (Zigate) Trigger a Topology Scan
2020-12-07 21:49:13.410 Status: (Zigate) Trigger a Energy Level Scan
2020-12-07 21:49:23.287 Status: (Zigate) Major Version Num: 0003
2020-12-07 21:49:23.287 Status: (Zigate) Installer Version Number: 031c
2020-12-07 21:49:33.291 Status: (Zigate) Zigate addresses ieee: 00158d0001b22e9a , short addr: 0000
2020-12-07 21:49:33.291 Status: (Zigate) Network state UP, PANID: a515 extPANID: 0xe0dcba4c0081fd14 Channel: 11
2020-12-07 21:49:38.168 Status: (Zigate) Request Disabling Accepting new Hardware
2020-12-07 21:49:38.576 Status: (Zigate) Accepting new Hardware: Disable
2020-12-07 21:49:38.677 Status: (Zigate) Number of devices recently active in Zigate = 8
2020-12-07 21:49:43.188 (Zigate) Switch Blue Led On
2020-12-07 21:49:43.189 Status: (Zigate) Zigate set to Certification : FCC
2020-12-07 21:49:43.189 Status: (Zigate) Start Web Server connection
2020-12-07 21:49:43.225 Status: (Zigate) Web backend for Web User Interface started on port: 9440
2020-12-07 21:49:43.225 Status: (Zigate) Plugin with Zigate firmware 031c correctly initialized
2020-12-07 21:49:43.437 Status: (Zigate) TxPower Attenuation : 0 dBm
2020-12-07 21:49:48.424 Status: (Zigate) There is a newer Zigate Firmware version available
Branche stable / 3.1c / Debian10
Je n'arrive pas à faire le git pull..
~/domoticz/plugins/Domoticz-Zigate-stable $ git pull
fatal: not a git repository (or any of the parent directories): .git
J'ai format la carte SD et reinstall Domoticz.. et rechargé avec le backup.
j'ai juste copié coller le dossier du plugin Zigate dans le dossier plugins de Domoticz..
Merci pour les infos (désolé pour la liste mais c'est plus facile quand on a les infos)
Je pense que ton soucis vient de ta réinstallation du plugin où tu as juste fait un copier-coller. Il faut d'abord réinstaller le plugin via git puis remettre les dossiers. Il y a une page sur le wiki qui explique la réinstallation : https://github.com/pipiche38/Domoticz-Z ... install.md
SpaWnOL
Keros a écrit : 07 déc. 2020, 22:03 Merci pour les infos (désolé pour la liste mais c'est plus facile quand on a les infos)
C'est normal.. Je demande de l'aide donc tu es en droit de demander ce que tu veux :-)
Merci. Je test ça dès demain !!!
Merci pour la rapidité de ta réponse en tout cas !
SpaWnOL
Je viens de tester..cest good!!
Merci encore pour ta rapidité !!
Tant mieux ;)
SpaWnOL
J'ai parlé trop vite........
2020-12-08 21:57:15.707 Error: (Zigate) 'onMessage' failed 'TypeError':'not all arguments converted during string formatting'.
2020-12-08 21:57:15.707 Error: (Zigate) ----> Line 1011 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onMessage
2020-12-08 21:57:15.707 Error: (Zigate) ----> Line 517 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onMessage
2020-12-08 21:57:15.707 Error: (Zigate) ----> Line 573 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Classes/Transport.py', function on_message
2020-12-08 21:57:15.707 Error: (Zigate) ----> Line 1197 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Classes/Transport.py', function process_frame
2020-12-08 21:57:15.708 Error: (Zigate) ----> Line 523 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function processFrame
2020-12-08 21:57:15.708 Error: (Zigate) ----> Line 229 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Modules/input.py', function ZigateRead
2020-12-08 21:57:15.708 Error: (Zigate) ----> Line 2778 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Modules/input.py', function Decode8102
2020-12-08 21:57:15.708 Error: (Zigate) ----> Line 2886 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Modules/input.py', function read_report_attributes
2020-12-08 21:57:15.708 Error: (Zigate) ----> Line 209 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Modules/readClusters.py', function ReadCluster
2020-12-08 21:57:15.708 Error: (Zigate) ----> Line 806 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Modules/readClusters.py', function Cluster0006
2020-12-08 21:57:15.708 Error: (Zigate) ----> Line 449 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Modules/domoMaj.py', function MajDomoDevice
2020-12-08 21:57:15.708 Error: (Zigate) ----> Line 203 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Modules/domoTools.py', function UpdateDevice_v2
certe il y a bug dans le plugin, mais l'erreur est liée à une inconsistence . Peut-etre qu'un simple restart du plugin devrait remettre les choses en place ..
SpaWnOL
pipiche a écrit : 08 déc. 2020, 22:20 certe il y a bug dans le plugin, mais l'erreur est liée à une inconsistence . Peut-etre qu'un simple restart du plugin devrait remettre les choses en place ..
C'est ce que je viens de faire.. tjs la meme :'(
