Suite à mon poste viewtopic.php?f=28&t=10813 j'ai mis hier à jour le plugin de la 4.7 à la dernière 4.11.0.11
Hier soir domoticz crash, pas de bol passons (bien que ça n'arrive jamais)
Cependant aujourd'hui paf même chose j'arrive chez moi plus rien ne fonctionne en domotique, je regarde et domoticz est encore en stop sur mon synology.
les logs des deux crash (j'ai la version wifi)
2020-12-09 22:43:05.403 Status: (Zigate) Plugin Restart command : http://monuser:xxx@127.0.0.1:8080/json.htm?type=command¶m=updatehardware&htype=94&idx=19&name=Zigate&address=192.168.31.60&port=9999&serialport=null&Mode1=Wifi&Mode2=&Mode3=False&Mode4=9440&Mode5=&Mode6=0&extra=Zigate&enabled=true&datatimeout=0
2020-12-09 22:43:05.481 Status: (Zigate) Stop directive received.
2020-12-09 22:43:05.481 Status: (Zigate) Exiting work loop.
2020-12-09 22:43:05.569 Status: (Zigate) onDisconnect called
2020-12-09 22:43:05.569 (Zigate) onDisconnect - Closing Name: 'Zigate Server Connection', Transport: 'TCP/IP', Protocol: 'HTTP', Address: '', Port: '9440', Baud: -1, Connected: False, Parent: 'None'
2020-12-09 22:43:05.569 Status: (Zigate) onStop called
2020-12-09 22:43:05.569 Status: (Zigate) Connection close: Name: 'Zigate', Transport: 'TCP/IP', Protocol: 'None ', Address: '192.168.31.60', Port: '9999', Baud: -1, Connected: False, Parent: 'None'
2020-12-09 22:43:05.569 Error: CConnection_disconnect, disconnection request from 'Zigate' ignored. Transport does not exist.
2020-12-09 22:43:05.584 Status: (Zigate) Statistics on message
2020-12-09 22:43:05.584 Status: (Zigate) ZiGate reacting time
2020-12-09 22:43:05.584 Status: (Zigate) Max : 0 sec
2020-12-09 22:43:05.584 Status: (Zigate) Average : 0 sec
2020-12-09 22:43:05.584 Status: (Zigate) ZiGate processing time on Rx
2020-12-09 22:43:05.585 Status: (Zigate) Average : 0 sec
2020-12-09 22:43:05.585 Status: (Zigate) Sent:
2020-12-09 22:43:05.585 Status: (Zigate) TX commands : 138
2020-12-09 22:43:05.585 Status: (Zigate) Max Load (Queue) : 6
2020-12-09 22:43:05.585 Status: (Zigate) TX failed : 0 (0.0%)
2020-12-09 22:43:05.585 Status: (Zigate) TX timeout : 30 (21.74%)
2020-12-09 22:43:05.585 Status: (Zigate) TX data timeout : 0 (0.0%)
2020-12-09 22:43:05.585 Status: (Zigate) TX reTransmit : 0 (0.0%)
2020-12-09 22:43:05.585 Status: (Zigate) TX APS Failure : 8 (5.8%)
2020-12-09 22:43:05.585 Status: (Zigate) TX APS Ack : 52 (37.68%)
2020-12-09 22:43:05.585 Status: (Zigate) TX APS Nck : 55 (39.86%)
2020-12-09 22:43:05.585 Status: (Zigate) Received:
2020-12-09 22:43:05.585 Status: (Zigate) RX frame : 894
2020-12-09 22:43:05.585 Status: (Zigate) RX crc errors : 0 (0.0%)
2020-12-09 22:43:05.585 Status: (Zigate) RX lentgh errors : 0 (0.0%)
2020-12-09 22:43:05.585 Status: (Zigate) RX clusters : 608
2020-12-09 22:43:05.585 Status: (Zigate) RX clusters KO : 0
2020-12-09 22:43:05.585 Status: (Zigate) Operating time : 2 Hours 45 Mins 1 Secs
2020-12-09 22:43:05.940 Error: Domoticz(pid:10827, tid:10832('PluginMgr')) received fatal signal 11 (Segmentation fault)
2020-12-09 22:43:05.940 Error: siginfo address=0x2a4b, address=0x7f830e76c089
2020-12-09 22:43:06.052 Error: Failed to start gdb, will use backtrace() for printing stack frame
2020-12-09 22:43:06.063 Error: #0 /usr/local/domoticz/bin/domoticz() [0x6e0660]
2020-12-09 22:43:06.126 Error: #1 /usr/local/domoticz/bin/domoticz : signal_handler(int, siginfo_t*, void*) + 0x295 [0x6e13d5]
2020-12-09 22:43:06.126 Error: #2 /lib/libpthread.so.0 : + 0x101c0 [0x7f830e76c1c0]
2020-12-09 22:43:06.126 Error: #3 /lib/libpthread.so.0 : raise + 0x29 [0x7f830e76c089]
2020-12-09 22:43:06.126 Error: #4 /lib/libpthread.so.0 : + 0x101c0 [0x7f830e76c1c0]
2020-12-09 22:43:06.126 Error: #5 /usr/local/lib/libpython3.8.so : + 0xccf77 [0x7f830c637f77]
2020-12-09 22:43:06.126 Error: #6 /usr/local/domoticz/bin/domoticz : Plugins::CPlugin::Stop() + 0xd7 [0xa39c17]
2020-12-09 22:43:06.126 Error: #7 /usr/local/domoticz/bin/domoticz : Plugins::onStopCallback::ProcessLocked() + 0x2b [0xa3c99b]
2020-12-09 22:43:06.126 Error: #8 /usr/local/domoticz/bin/domoticz : Plugins::CPluginMessageBase::Process() + 0x33 [0x66d683]
2020-12-09 22:43:06.126 Error: #9 /usr/local/domoticz/bin/domoticz : Plugins::CPluginSystem::Do_Work() + 0x319 [0xa3d9e9]
2020-12-09 22:43:06.126 Error: #10 /usr/local/domoticz/bin/domoticz : execute_native_thread_routine + 0x30 [0xd662fc]
2020-12-09 22:43:06.126 Error: #11 /lib/libpthread.so.0 : + 0x72c4 [0x7f830e7632c4]
2020-12-09 22:43:06.126 Error: #12 /lib/libc.so.6 : clone + 0x6d [0x7f830d6f310d]
2020-12-10 14:27:00.230 (Meteo) Temp + Humidity + Baro (THB)
2020-12-10 14:27:00.235 (Meteo) Wind (Vent)
2020-12-10 14:27:00.236 (Meteo) UV (UV Index)
2020-12-10 14:27:00.239 (Meteo) Rain (Rain)
2020-12-10 14:27:00.240 (Meteo) General/Visibility (Unknown)
2020-12-10 14:27:00.240 (Meteo) General/Custom Sensor (Ozone Sensor)
2020-12-10 14:27:00.241 (Meteo) General/Percentage (Cloud Cover)
2020-12-10 14:27:00.294 InfluxLink: value Temperature,idx=177,name=THB value=2.7
2020-12-10 14:27:00.294 InfluxLink: value Direction,idx=178,name=Vent value=141.0
2020-12-10 14:27:00.294 InfluxLink: value Speed,idx=178,name=Vent value=5.0
2020-12-10 14:27:14.614 Status: Incoming connection from: 192.168.31.71
2020-12-10 14:27:20.615 Status: EventSystem: Opening a URL after 0.2 seconds...
2020-12-10 14:27:20.935 InfluxLink: value Usage-current,idx=150,name=EDF-Smart-Meter value=250.0
2020-12-10 14:27:23.075 Status: Incoming connection from: 192.168.31.72
2020-12-10 14:27:23.512 InfluxLink: value Temperature,idx=175,name=Tmp_72_salon value=19.1
2020-12-10 14:28:20.694 Status: EventSystem: Opening a URL after 0.2 seconds...
2020-12-10 14:28:21.128 InfluxLink: value Usage-current,idx=150,name=EDF-Smart-Meter value=230.0
2020-12-10 14:29:03.228 InfluxLink: value Temperature,idx=209,name=Rika-Stove-Tmp value=653.0
2020-12-10 14:29:14.579 Status: Incoming connection from: 192.168.31.71
2020-12-10 14:29:20.617 Status: EventSystem: Opening a URL after 0.2 seconds...
2020-12-10 14:29:25.036 (Zigate) pingZigate - WARNING: Ping sent but no response yet from Zigate. Status: Sent - Ping: 5 sec
2020-12-10 14:29:30.050 (Zigate) pingZigate - WARNING: Ping sent but no response yet from Zigate. Status: Sent - Ping: 10 sec
2020-12-10 14:29:35.062 (Zigate) pingZigate - WARNING: Ping sent but no response yet from Zigate. Status: Sent - Ping: 15 sec
2020-12-10 14:29:38.803 Error: Broadlink hardware (7) thread seems to have ended unexpectedly
2020-12-10 14:29:40.057 (Zigate) pingZigate - WARNING: Ping sent but no response yet from Zigate. Status: Sent - Ping: 20 sec
2020-12-10 14:29:45.019 (Zigate) pingZigate - WARNING: Ping sent but no response yet from Zigate. Status: Sent - Ping: 25 sec
2020-12-10 14:29:50.030 (Zigate) pingZigate - WARNING: Ping sent but no response yet from Zigate. Status: Sent - Ping: 30 sec
2020-12-10 14:29:52.805 Error: Broadlink hardware (7) thread seems to have ended unexpectedly
2020-12-10 14:29:55.060 (Zigate) pingZigate - WARNING: Ping sent but no response yet from Zigate. Status: Sent - Ping: 35 sec
2020-12-10 14:30:00.055 (Zigate) pingZigate - WARNING: Ping sent but no response yet from Zigate. Status: Sent - Ping: 40 sec
2020-12-10 14:30:05.036 (Zigate) pingZigate - WARNING: Ping sent but no response yet from Zigate. Status: Sent - Ping: 45 sec
2020-12-10 14:30:10.048 (Zigate) pingZigate - WARNING: Ping sent but no response yet from Zigate. Status: Sent - Ping: 50 sec
2020-12-10 14:30:13.742 Status: Incoming connection from: 192.168.31.71
2020-12-10 14:30:14.579 Status: Incoming connection from: 192.168.31.71
2020-12-10 14:30:15.025 (Zigate) pingZigate - WARNING: Ping sent but no response yet from Zigate. Status: Sent - Ping: 55 sec
2020-12-10 14:30:20.037 (Zigate) pingZigate - WARNING: Ping sent but no response yet from Zigate. Status: Sent - Ping: 60 sec
2020-12-10 14:30:20.037 Error: (Zigate) pingZigate - no Heartbeat with Zigate, try to reConnect
2020-12-10 14:30:20.050 Status: (Zigate) Plugin Restart command : http://userchangé:pwchangé@127.0.0.1:8080/json.htm?type=command¶m=updatehardware&htype=94&idx=19&name=Zigate&address=192.168.31.60&port=9999&serialport=null&Mode1=Wifi&Mode2=&Mode3=False&Mode4=9440&Mode5=&Mode6=0&extra=Zigate&enabled=true&datatimeout=0
2020-12-10 14:30:20.084 Status: (Zigate) Stop directive received.
2020-12-10 14:30:20.084 Status: (Zigate) Exiting work loop.
2020-12-10 14:30:20.158 Status: (Zigate) onDisconnect called
2020-12-10 14:30:20.158 (Zigate) onDisconnect - Closing Name: 'Zigate Server Connection', Transport: 'TCP/IP', Protocol: 'HTTP', Address: '', Port: '9440', Baud: -1, Connected: False, Parent: 'None'
2020-12-10 14:30:20.158 Status: (Zigate) onStop called
2020-12-10 14:30:20.158 Status: (Zigate) Connection close: Name: 'Zigate', Transport: 'TCP/IP', Protocol: 'None ', Address: '192.168.31.60', Port: '9999', Baud: -1, Connected: False, Parent: 'None'
2020-12-10 14:30:20.158 Error: CConnection_disconnect, disconnection request from 'Zigate' ignored. Transport does not exist.
2020-12-10 14:30:20.173 Status: (Zigate) Statistics on message
2020-12-10 14:30:20.173 Status: (Zigate) ZiGate reacting time
2020-12-10 14:30:20.173 Status: (Zigate) Max : 0 sec
2020-12-10 14:30:20.173 Status: (Zigate) Average : 0 sec
2020-12-10 14:30:20.173 Status: (Zigate) ZiGate processing time on Rx
2020-12-10 14:30:20.174 Status: (Zigate) Max : 0 sec
2020-12-10 14:30:20.174 Status: (Zigate) Average : 0 sec
2020-12-10 14:30:20.174 Status: (Zigate) Sent:
2020-12-10 14:30:20.174 Status: (Zigate) TX commands : 91
2020-12-10 14:30:20.174 Status: (Zigate) Max Load (Queue) : 5
2020-12-10 14:30:20.174 Status: (Zigate) TX failed : 0 (0.0%)
2020-12-10 14:30:20.174 Status: (Zigate) TX timeout : 6 (6.59%)
2020-12-10 14:30:20.174 Status: (Zigate) TX data timeout : 0 (0.0%)
2020-12-10 14:30:20.174 Status: (Zigate) TX reTransmit : 0 (0.0%)
2020-12-10 14:30:20.174 Status: (Zigate) TX APS Failure : 23 (25.27%)
2020-12-10 14:30:20.174 Status: (Zigate) TX APS Ack : 51 (56.04%)
2020-12-10 14:30:20.174 Status: (Zigate) TX APS Nck : 53 (58.24%)
2020-12-10 14:30:20.174 Status: (Zigate) Received:
2020-12-10 14:30:20.174 Status: (Zigate) RX frame : 1653
2020-12-10 14:30:20.174 Status: (Zigate) RX crc errors : 0 (0.0%)
2020-12-10 14:30:20.174 Status: (Zigate) RX lentgh errors : 0 (0.0%)
2020-12-10 14:30:20.174 Status: (Zigate) RX clusters : 1266
2020-12-10 14:30:20.174 Status: (Zigate) RX clusters KO : 0
2020-12-10 14:30:20.174 Status: (Zigate) Operating time : 6 Hours 3 Mins 55 Secs
2020-12-10 14:30:20.340 Error: Domoticz(pid:8899, tid:8904('PluginMgr')) received fatal signal 11 (Segmentation fault)
2020-12-10 14:30:20.340 Error: siginfo address=0x22c3, address=0x7fd6c0a44089
2020-12-10 14:30:20.427 Error: Failed to start gdb, will use backtrace() for printing stack frame
2020-12-10 14:30:20.429 Error: #0 /usr/local/domoticz/bin/domoticz() [0x6e0660]
2020-12-10 14:30:20.429 Error: #1 /usr/local/domoticz/bin/domoticz : signal_handler(int, siginfo_t*, void*) + 0x295 [0x6e13d5]
2020-12-10 14:30:20.429 Error: #2 /lib/libpthread.so.0 : + 0x101c0 [0x7fd6c0a441c0]
2020-12-10 14:30:20.429 Error: #3 /lib/libpthread.so.0 : raise + 0x29 [0x7fd6c0a44089]
2020-12-10 14:30:20.429 Error: #4 /lib/libpthread.so.0 : + 0x101c0 [0x7fd6c0a441c0]
2020-12-10 14:30:20.429 Error: #5 /usr/local/lib/libpython3.8.so : + 0xccf77 [0x7fd6be90ff77]
2020-12-10 14:30:20.429 Error: #6 /usr/local/domoticz/bin/domoticz : Plugins::CPlugin::Stop() + 0xd7 [0xa39c17]
2020-12-10 14:30:20.429 Error: #7 /usr/local/domoticz/bin/domoticz : Plugins::onStopCallback::ProcessLocked() + 0x2b [0xa3c99b]
2020-12-10 14:30:20.429 Error: #8 /usr/local/domoticz/bin/domoticz : Plugins::CPluginMessageBase::Process() + 0x33 [0x66d683]
2020-12-10 14:30:20.429 Error: #9 /usr/local/domoticz/bin/domoticz : Plugins::CPluginSystem::Do_Work() + 0x319 [0xa3d9e9]
2020-12-10 14:30:20.429 Error: #10 /usr/local/domoticz/bin/domoticz : execute_native_thread_routine + 0x30 [0xd662fc]
2020-12-10 14:30:20.429 Error: #11 /lib/libpthread.so.0 : + 0x72c4 [0x7fd6c0a3b2c4]
2020-12-10 14:30:20.429 Error: #12 /lib/libc.so.6 : clone + 0x6d [0x7fd6bf9cb10d]
Pour moi il y a deux problèmes :
1/ Le plugin ne voit plus la zigate pendant 1mn (y a-t-il moyen de voir l'uptime de la zigate qqpart? je doute d'un problème réseau)
2/ Si j'essaye de faire "update" sur un hardware dans domoticz, ce dernier crash (peu importe le plugin)
Edit : en regardant viewtopic.php?t=9616 j'ai constaté que j'avais également 2 PluginConf-19.json et PluginConf-14.json (ancien hardware, je viens de le delete mais normalement il ne rentre pas en compte)
je vais laisser tourner et si ça replante j'essayerai en rajoutant "internetAccess": 0, (sauf indication contraire)
Edit2: En fait dans mes hardware, si le plugin Zigate est enabled, dès que je fais un update sur n'importe quel autre hardware ça fait crash domoticz. Si le plugin Zigate est disabled aucun soucis pour update les autres...
