Plugins Python
ziaziung
Plugins Python
Message par ziaziung »
Bonjour à tous.
J'ai installé deux plugins Python : Domoticz-TUYA-Plugin et PluginDomoticzFreebox.
Je vois bien les repertoires :
pi@raspberrypi:~/domoticz/plugins $ ls
AwoxSMP  Domoticz-TUYA-Plugin  examples  PluginDomoticzFreebox
dans chaque repertoire les fichiers sont executables :
pi@raspberrypi:~/domoticz/plugins/Domoticz-TUYA-Plugin $ ls -al
total 44
drwxr-xr-x 4 pi pi  4096 mai    3 15:29 .
drwxr-xr-x 6 pi pi  4096 mai    3 18:34 ..
-rwxr-xr-x 1 pi pi    81 mai    3 15:29 fakeDomoticz.py
drwxr-xr-x 8 pi pi  4096 mai    3 15:29 .git
-rwxr-xr-x 1 pi pi 16775 mai    3 15:29 plugin.py
-rw-r--r-- 1 pi pi  3068 mai    3 15:29 README.md
drwxr-xr-x 2 pi pi  4096 mai    3 15:29 tools
pi@raspberrypi:~/domoticz/plugins/PluginDomoticzFreebox $ ls -al
total 56
drwxr-xr-x 3 pi pi  4096 mai    3 18:34 .
-rwxr-xr-x 1 pi pi 10772 mai    3 18:34 freebox.py
drwxr-xr-x 8 pi pi  4096 mai    3 18:34 .git
-rw-r--r-- 1 pi pi  1157 mai    3 18:34 .gitignore
-rwxr-xr-x 1 pi pi 16425 mai    3 18:34 plugin.py
-rw-r--r-- 1 pi pi  5235 mai    3 18:34 README.md
Une fois redémarré le raspi je ne vois rien dans les logs!!!!
    Tout
    Statut
    Erreur
	Filtre: X
2021-05-03 18:40:40.954 Status: Domoticz V4.10761 (c)2012-2019 GizMoCuz
2021-05-03 18:40:40.957 Status: Build Hash: ca1256bf, Date: 2019-05-15 16:24:19
2021-05-03 18:40:40.966 Status: Startup Path: /home/pi/domoticz/
2021-05-03 18:40:42.215 Sunrise: 06:39:00 SunSet: 20:59:00
2021-05-03 18:40:42.215 Day length: 14:20:00 Sun at south: 13:49:00
2021-05-03 18:40:42.215 Civil twilight start: 06:06:00 Civil twilight end: 21:31:00
2021-05-03 18:40:42.215 Nautical twilight start: 05:26:00 Nautical twilight end: 22:11:00
2021-05-03 18:40:42.215 Astronomical twilight start: 04:41:00 Astronomical twilight end: 22:57:00
2021-05-03 18:40:43.684 Active notification Subsystems: email, http, pushbullet, telegram (4/13)
2021-05-03 18:40:43.843 Starting shared server on: :::6144
2021-05-03 18:40:43.533 Status: PluginSystem: Started, Python version '3.4.2'.
2021-05-03 18:40:43.720 Status: WebServer(HTTP) started on address: :: with port 8080
2021-05-03 18:40:43.811 Status: WebServer(SSL) started on address: :: with port 443
2021-05-03 18:40:43.857 Status: TCPServer: shared server started...
2021-05-03 18:40:43.857 Status: RxQueue: queue worker started...
2021-05-03 18:40:45.863 Status: Hardware Monitor: Started
2021-05-03 18:40:45.950 Status: AppLamp: Worker Started...
2021-05-03 18:40:45.952 Status: EventSystem: reset all events...
2021-05-03 18:40:45.954 Status: Darksky: Started...
2021-05-03 18:40:45.954 Status: RFXCOM: Worker started...
2021-05-03 18:40:45.954 Status: Wunderground: Worker started...
2021-05-03 18:40:46.000 Status: EventSystem: reset all device statuses...
2021-05-03 18:40:46.357 Status: PluginSystem: Entering work loop.
2021-05-03 18:40:46.508 Status: Python EventSystem: Initalizing event module.
2021-05-03 18:40:46.511 Status: EventSystem: Queue thread started...
2021-05-03 18:40:46.511 Status: EventSystem: Started
2021-05-03 18:40:46.960 Status: RFXCOM: Using serial port: /dev/ttyUSB0
2021-05-03 18:40:47.537
2021-05-03 18:40:47.198 Status: AppLamp: Bridge found!...
On dirait que Python ne vois rien de ces plugins!
Une idée?
Raspi B+ et 2. RfxcomE. Volets Somfy. Sondes de température "AliExpress". Domoticz version 4.10761
Re: Plugins Python
Tu les as ajoutés dans 'Matériel' ?
ziaziung
Re: Plugins Python
Heu...... ;) non. Merci.
C'est fait.
Par contre voila ce que j'obtiens dans le log :
2021-05-03 20:57:07.941 Error: (tuya) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/Domoticz-TUYA-Plugin/:/usr/lib/python3.4/:/usr/lib/python3.4/plat-arm-linux-gnueabihf:/usr/lib/python3.4/lib-dynload:/usr/local/lib/python3.4/dist-packages:/usr/lib/python3/dist-packages:/usr/lib/python3.4/dist-packages:/usr/lib/dist-python'.
2021-05-03 20:57:07.941 Error: (TuyaPlug) Module Import failed, exception: 'SyntaxError'
2021-05-03 20:57:07.941 Error: (TuyaPlug) Import detail: File: /usr/local/lib/python3.4/dist-packages/tuyaha/tuyaapi.py, Line: 69, offset: 87
2021-05-03 20:57:07.941 Error: (TuyaPlug) Error Line ' f"Discovery interval below {MIN_DISCOVERY_INTERVAL} seconds is invalid"
2021-05-03 20:57:07.941 '
Une idée?
Re: Plugins Python
La première ligne d'erreur indique un problème de librairie avec python 3.4. Est-ce que tu as python 3.4 d'installer ?
ziaziung
Re: Plugins Python
En fait je m'y perd. En verifiant ma version de Python, voila ce que je trouve :
pi@raspberrypi:~ $ python -V
Python 2.7.9
pi@raspberrypi:~ $ python3 -V
Python 3.4.2
pi@raspberrypi:~ $
J'aurai deux Pythons dans ma fraise :roll: !!!? A priori ce n'est pas un problème.
Re: Plugins Python
une version 2 et une version 3, c'est normal.
Tu as bien fait cette manip ?
sudo pip3 install tuyaha requests
ziaziung
Re: Plugins Python
Oui, oui.
J'ai l'impression que cela s'est bien passé.
Thorgal
Re: Plugins Python
Message par Thorgal »
C'est la ou j'ai un doute
Or justement le plugin a son propre repertoire avec la lib tuyaha, peut etre une version speciale cf https://github.com/guino/tuyaha
ziaziung
Re: Plugins Python
Merci pour l'aide.
Je vais retenter l'installation via git dans le repertoire plugin de domoticz de tuyaha après avoir viré les autres repertoires contenant les autres plugin tuya et redémarré.
Je vous donne le résultat.
Le résultat :
* avec le plugin "Guino" mon identifiant et mot de passe sont reconnus. Le plugin Tuya démarre (je le vois dans les logs). Et après c'est le drame : domoticz me dit que je n'est p;lus de matériel, plus de dispositif plus d'interrupteur. Puis Domoticz ne fait plus rien : planté!
* avec le plugin "Xenomes" : Domoticz ne plante pas mais le plugin ne demarre pas (les logs sont ceux que j'ai donné plus haut).
Au final, j'ai restauré un backup récent.
