Suite a un passage a BullsEye sur mon PI, mon instance de domoticz ne tourne plus. Je suppose un soucis au niveau de python. Bref normalement docker est la pour cela.
Du coup je viens de monter un container avec :
https://github.com/linuxserver/docker-domoticz
Du coup bien sur tout se lance bien mais La Zigate ne connais plus mes devices.
J ai pourtant copy past l'ancien folder Plugin dans le nouveau.
Du coup qu'ai je oublié de faire a votre avis?
Avez vous deja une image avec le plugin installé et les port configurés?
Mes logs :
2021-11-16 14:38:16.502 Error: ZiGate: (ZiGate) Cannot access path: /opt/domoticz/plugins/Domoticz-Zigate/Conf/PluginConf-09.json
2021-11-16 14:38:16.503 Error: ZiGate: (ZiGate) Cannot access path: /opt/domoticz/plugins/Domoticz-Zigate/
2021-11-16 14:38:16.503 Error: ZiGate: (ZiGate) Cannot access path: /opt/domoticz/plugins/Domoticz-Zigate/Data/
2021-11-16 14:38:16.503 Error: ZiGate: (ZiGate) Cannot access path: /opt/domoticz/plugins/Domoticz-Zigate/Conf/
2021-11-16 14:38:16.503 Error: ZiGate: (ZiGate) Cannot access path: /opt/domoticz/plugins/Domoticz-Zigate/OTAFirmware/
2021-11-16 14:38:16.503 Error: ZiGate: (ZiGate) Cannot access path: /opt/domoticz/plugins/Domoticz-Zigate/Reports/
2021-11-16 14:38:16.504 Error: ZiGate: (ZiGate) Cannot access path: /opt/domoticz/plugins/Domoticz-Zigate/www/
2021-11-16 14:38:16.504 Error: ZiGate: (ZiGate) Cannot access path: /opt/domoticz/plugins/Domoticz-Zigate/Logs/
2021-11-16 14:38:16.557 Error: ZiGate: (ZiGate) checkListOfDevice2Devices - W_radiateur_chambre_amis - 00158d0002166ba4 not found in Plugin Database
2021-11-16 14:38:16.558 Error: ZiGate: (ZiGate) checkListOfDevice2Devices - temp_cuisine - 00158d0002310205 not found in Plugin Database
2021-11-16 14:38:16.558 Error: ZiGate: (ZiGate) checkListOfDevice2Devices - temp_sdb_bas - 00158d0002310318 not found in Plugin Database
2021-11-16 14:38:16.558 Error: ZiGate: (ZiGate) checkListOfDevice2Devices - temp_chambre_amis - 00158d0002310322 not found in Plugin Database
2021-11-16 14:38:16.559 Error: ZiGate: (ZiGate) checkListOfDevice2Devices - plug-mosaic - 00124b0023592cd3 not found in Plugin Database
2021-11-16 14:38:16.560 Error: ZiGate: (ZiGate) checkListOfDevice2Devices - Pompe_a_Eau - 7cb03eaa00afbcd6 not found in Plugin Database
2021-11-16 14:38:16.561 Error: ZiGate: (ZiGate) checkListOfDevice2Devices - temp_bureau - 00158d0002389139 not found in Plugin Database
