J'ai installé domoticz via les sources (github).
Quelles procédures utiliser pour la mise à jour ?
Interface web ?
./updaterelease ?
Ou via les sources ("git pull" & "make")?
Merci.
Envoyé de mon SM-N9005 en utilisant Tapatalk
Installation via sources
jackslayter
Re: Installation via sources
http://www.domoticz.com/wiki/Install.txt#Upgrading
Upgrading
To Update to a newer version:
stop the application (control-c), or stop the startup script (see below) with /etc/init.d/domoticz.sh stop
Execute
start domoticzCode : Tout sélectionner
cd /home/pi/domoticz (or where you installed domoticz) git pull make
If you have installed the Unix startup script (see below), you can also update with the provided script:
./updatedomo
