N'ayant pas trop de nouvelle coté Zigate, j'ai essayé de tout reprendre a zéro, notamment car j'avais envie de tester les différentes options pour désactiver le BT des Raspberry, que j'ai pu trouver ici :
https://www.framboise314.fr/le-port-ser ... as-simple/
Cependant, cette fois je fais face à un nouveau souci. Une fois tout installé et configuré, dés que j'ajoute un hardware "zigate plugin", alors l'interface web crash. Le seul moyen que j'ai de retrouver un domoticz fonctionnel est d'effacer la domoticz.db
Extrait des logs :
2022-03-07 22:01:35.886 Status: EventSystem: Started
2022-03-07 22:01:38.077 Status: myZigate: Initialized version 5.1, author 'zaraki673 pipiche38'
2022-03-07 22:01:38.086 myZigate: ZiGate plugin started!
2022-03-07 22:01:38.093 myZigate: load PluginConf
2022-03-07 22:01:38.097 myZigate: is_domoticz_db_available: Fashion: True , Major: 2022, Minor: 1
2022-03-07 22:01:38.097 myZigate: is_domoticz_db_available: True
2022-03-07 22:01:38.099 myZigate: /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/PluginConf-02.json timestamp is 1646685554.9938745
2022-03-07 22:01:38.099 myZigate: Dz PluginConf is older than Json Dz: 0 Json: 1646685554.9938745
2022-03-07 22:01:38.101 myZigate: is_domoticz_db_available: Fashion: True , Major: 2022, Minor: 1
2022-03-07 22:01:38.101 myZigate: is_domoticz_db_available: True
2022-03-07 22:01:38.105 Status: myZigate: filename set to /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/PluginConf-02.json
2022-03-07 22:01:38.105 Status: myZigate: pluginHome set to /home/pi/domoticz/plugins/Domoticz-Zigate/
2022-03-07 22:01:38.105 Status: myZigate: homedirectory set to /home/pi/domoticz/plugins/Domoticz-Zigate/
2022-03-07 22:01:38.106 Status: myZigate: pluginData set to /home/pi/domoticz/plugins/Domoticz-Zigate/Data/
2022-03-07 22:01:38.106 Status: myZigate: pluginConfig set to /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/
2022-03-07 22:01:38.106 Status: myZigate: pluginOTAFirmware set to /home/pi/domoticz/plugins/Domoticz-Zigate/OTAFirmware/
2022-03-07 22:01:38.106 Status: myZigate: pluginReports set to /home/pi/domoticz/plugins/Domoticz-Zigate/Reports/
2022-03-07 22:01:38.107 Status: myZigate: pluginWWW set to /home/pi/domoticz/plugins/Domoticz-Zigate/www/
2022-03-07 22:01:38.107 Status: myZigate: pluginLogs set to /home/pi/domoticz/plugins/Domoticz-Zigate/Logs/
2022-03-07 22:01:38.108 myZigate: Starting LoggingManagement thread
2022-03-07 22:01:38.109 myZigate: start_logging_thread
2022-03-07 22:01:38.111 myZigate: logging_thread - listening
2022-03-07 22:01:38.113 Status: myZigate: Log history not found, no error logged
2022-03-07 22:01:38.131 Status: myZigate: Zigate plugin stable5-5.1.018 started
2022-03-07 22:01:38.223 Error: Domoticz(pid:1862, tid:1880('myZigate')) received fatal signal 11 (Segmentation fault)
2022-03-07 22:01:38.224 Error: siginfo address=0x746, address=0xb6a30b20
2022-03-07 22:01:49.175 Error: Did not find stack frame for thread (LWP 1880)), printing full gdb output:
2022-03-07 22:01:49.175 Error: > gdb: warning: Couldn't determine a path for the index cache directory.
2022-03-07 22:01:49.176 Error: > [New LWP 1863]
2022-03-07 22:01:49.176 Error: > [New LWP 1869]
2022-03-07 22:01:49.176 Error: > [New LWP 1870]
S'en suis une long list d'erreur (groupe de message par Thread).
Dont :
2022-03-07 22:01:49.190 Error: >
2022-03-07 22:01:49.190 Error: > Thread 14 (Thread 0xaeefb200 (LWP 1880) "myZigate"):
2022-03-07 22:01:49.190 Error: > #0 0xb68ab4d4 in __GI___wait4 (pid=1886, stat_loc=0xb0f29d08, options=0, usage=0x0) at ../sysdeps/unix/sysv/linux/wait4.c:27
2022-03-07 22:01:49.190 Error: > #1 0x0029121c in dumpstack_gdb(bool) ()
2022-03-07 22:01:49.191 Error: > #2 0x002917e8 in signal_handler(int, siginfo_t*, void*) ()
2022-03-07 22:01:49.191 Error: > #3 <signal handler called>
2022-03-07 22:01:49.191 Error: > #4 raise (sig=11) at ../sysdeps/unix/sysv/linux/raise.c:50
2022-03-07 22:01:49.191 Error: > #5 <signal handler called>
2022-03-07 22:01:49.191 Error: > #6 0x00000014 in ?? ()
2022-03-07 22:01:49.191 Error: > #7 0xb591d47c in _PyEval_EvalFrameDefault () from /lib/arm-linux-gnueabihf/libpython3.9.so
2022-03-07 22:01:49.191 Error: > #8 0xac2a89b0 in ?? ()
2022-03-07 22:01:49.192 Error: > Backtrace stopped: previous frame identical to this frame (corrupt stack?)
2022-03-07 22:01:49.192 Error: > Thread 13 (Thread 0xaf6fc200 (LWP 1879) "MainWorkerRxMsg"):
Je n'ai pourtant pas l'impression d'avoir fait différemment de la 1ere fois, 1ere fois ou je n'avais pas rencontré ces soucis.
(Seul différence, j'ai résinstallé Rasbian, et c'est donc une version plus récente de l'OS).
D'avance merci pour votre aide !
