Problème lors de la programmation en python via domoticz même, le script en python donné par domoticz ne fonctionne pas et donne ces messages d'erreurs :
2022-03-08 15:18:17.522 Status: EventSystem: reset all events...
2022-03-08 15:18:17.538 Error: Pyhton Event System: Failed to parse parameters: string expected.
2022-03-08 15:18:17.538 Error: EventSystem: Failed to execute python event script "Original"
2022-03-08 15:18:17.538 Error: EventSystem: Traceback (most recent call last):
2022-03-08 15:18:17.538 Error: EventSystem: File "C:\Program Files (x86)\Domoticz\scripts\python\domoticz.py", line 41, in <module>
2022-03-08 15:18:17.538 Error: EventSystem: Devices
2022-03-08 15:18:17.538 Error: EventSystem: NameError: name 'Devices' is not defined
2022-03-08 15:18:17.538 Error: EventSystem: During handling of the above exception, another exception occurred:
2022-03-08 15:18:17.538 Error: EventSystem: TypeError: function takes exactly 1 argument (2 given)
2022-03-08 15:18:17.538 Error: EventSystem: The above exception was the direct cause of the following exception:
2022-03-08 15:18:17.538 Error: EventSystem: File "<string>", line 63, in <module>
2022-03-08 15:18:17.538 Error: EventSystem: File "C:\Program Files (x86)\Domoticz\scripts\python\domoticz.py", line 44, in <module>
2022-03-08 15:18:17.538 Error: EventSystem: domoticz_.Log(1, "Devices was not created by Domoticz C++ code")
2022-03-08 15:18:17.538 Error: EventSystem: SystemError: <built-in function Log> returned a result with an error set Code : Tout sélectionner
import domoticz
import random
print ("This will only show up in the shell where you start domoticz");
domoticz.log("Hi Domoticz!")
domoticz.log("The device that got changed is: ", changed_device_name)
# changed_device.name is the same string
for name, device in domoticz.devices.items():
domoticz.log("device", name, "is", "on" if device.is_on() else "off")
if device.is_off():
domoticz.log("could turn it on in 3 seconds")
#device.on(after=3)
for name, value in user_variables.items():
domoticz.log("var", name, "has value", value)Code : Tout sélectionner
Helper module for python+domoticz
Every script_device_*.py script has the following variables
* changed_device: the current device that changed (object of Device)
* changed_device_name: name of current device (same as changed_device.name)
* is_daytime: boolean, true when it is is daytime
* is_nighttime: same for the night
* sunrise_in_minutes: integer
* sunset_in_minutes: integer
* user_variables: dictionary from string to value
For more advanced project, you may want to use modules.
say you have a file heating.py
You can do
import heating
heating.check_heating()
But heating has a different scope, and won't have access to these variables.
By importing this module, you can have access to them in a standard way
import domoticz
domoticz.changed_device
And you also have access to more:
* same as in the device scripts (changed_device ... user_variables)
* devices: dictionary from string to Device
#try:
import DomoticzEvents as domoticz_ #
#except:
# pass
import reloader
import datetime
import re
# Enable plugins to do:
# from Domoticz import Devices, Images, Parameters, Settings
try:
Devices #(Ligne 41)
except NameError:
Devices = {}
domoticz_.Log(1, "Devices was not created by Domoticz C++ code") #(Ligne 44)
try:
Images
except NameError:
Images = {}
domoticz_.Log(1, "Images was not created by Domoticz C++ code")
try:
Parameters
except NameError:
Parameters = {}
domoticz_.Log(1, "Parameters was not created by Domoticz C++ code")
try:
Settings
except NameError:
Settings = {}
domoticz_.Log(1, "Settings was not created by Domoticz C++ code")
#def _log(type, text): # 'virtual' function, will be modified to call
# pass
def log(*args):
domoticz_.Log(0, " ".join([str(k) for k in args]))
def error(*args):
domoticz_.Log(1, " ".join([str(k) for k in args]))
reloader.auto_reload(__name__)
# this will be filled in by the c++ part
devices = {}
device = None
testing = False
commands = []
event_system = None # will be filled in by domoticz
def command(name, action, file):
if testing:
commands.append((name, action))
else:
event_system.command(name, action, file)
def process_commands():
for name, action in commands:
device = devices[name]
if action == "On":
device.n_value = 1
print ("\tsetting %s On" % name)
elif action == "Off":
device.n_value = 0
else:
print ("unknown command", name, action)
del commands[:]
class Device(object):
def __init__(self, id, name, type, sub_type, switch_type, n_value, n_value_string, s_value, last_update):
devices[name] = self
self.id = id
self.name = name
self.type = type
self.sub_type = sub_type
self.switch_type = switch_type
self.n_value = n_value
self.n_value_string = n_value_string
self.s_value = s_value
self.last_update_string = last_update
# from http://stackoverflow.com/questions/127803/how-to-parse-iso-formatted-date-in-python
if self.last_update_string:
try:
self.last_update = datetime.datetime(*map(int, re.split('[^\d]', self.last_update_string)[:]))
if str(self.last_update_string) != str(self.last_update):
log("Error parsing date:", self.last_update_string, " parsed as", str(self.last_update))
except:
log("Exception while parsing date:", self.last_update_string)
else:
self.last_update = None
def __str__(self):
return "Device(%s, %s, %s, %s)" % (self.id, self.name, self.n_value, self.s_value)
def __repr__(self):
def last_update_was_ago(self, **kwargs):
"""Arguments can be: days[, seconds[, microseconds[, milliseconds[, minutes[, hours[, weeks]"""
return self.last_update + datetime.deltatime(**kwargs) < datetime.datetime.now()
def is_on(self):
return self.n_value == 1
def is_off(self):
return self.n_value == 0
def on(self, after=None, reflect=False):
if self.is_off() or after is not None:
self._command("On" , after=after)
if reflect:
self.n_value = 1
def off(self, after=None, reflect=False):
if self.is_on() or after is not None:
self._command("Off" , after=after)
if reflect:
self.n_value = 0
def _command(self, action, after=None):
if after is not None:
command(self.name, "%s AFTER %d" % (action, after), __file__)
else:
command(self.name, action, __file__)
