je viens d'installer Zigbee2mqtt mais impossible de le lancer. Voici les traces que j'obtiens lors du lancement :
npm start
Mon matériel est un sonoff zigbee 3.0 usb dongle que j'ai flashé avec la procédure décrite dans ce tuto vidéo : https://www.youtube.com/watch?v=iCE5Z43EKpk> zigbee2mqtt@1.24.0 start /opt/zigbee2mqtt
> node index.js
Zigbee2MQTT:info 2022-03-11 07:27:38: Logging to console and directory: '/opt/zigbee2mqtt/data/log/2022-03-11.07-27-36' filename: log.txt
Zigbee2MQTT:info 2022-03-11 07:27:38: Starting Zigbee2MQTT version 1.24.0 (commit #7a2ddf24)
Zigbee2MQTT:info 2022-03-11 07:27:38: Starting zigbee-herdsman (0.14.20)
Zigbee2MQTT:error 2022-03-11 07:28:43: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2022-03-11 07:28:43: Failed to start zigbee
Zigbee2MQTT:error 2022-03-11 07:28:43: Check https://www.zigbee2mqtt.io/guide/instal ... start.html for possible solutions
Zigbee2MQTT:error 2022-03-11 07:28:43: Exiting...
Zigbee2MQTT:error 2022-03-11 07:28:44: Error: network commissioning timed out - most likely network with the same panId or extendedPanId already exists nearby
at ZnpAdapterManager.beginCommissioning (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:347:23)
at ZnpAdapterManager.start (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:92:17)
at Controller.start (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/src/controller/controller.ts:123:29)
at Zigbee.start (/opt/zigbee2mqtt/lib/zigbee.ts:58:27)
at Controller.start (/opt/zigbee2mqtt/lib/controller.ts27)
at start (/opt/zigbee2mqtt/index.js:101:5)
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! zigbee2mqtt@1.24.0 start: `node index.js`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the zigbee2mqtt@1.24.0 start script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! A complete log of this run can be found in:
npm ERR! /home/zeus/.npm/_logs/2022-03-11T06_28_44_169Z-debug.log
Voici le fichier de conf :
# Home Assistant integration (MQTT discovery)
homeassistant: false
# allow new devices to join
permit_join: true
# MQTT settings
mqtt:
# MQTT base topic for zigbee2mqtt MQTT messages
base_topic: zigbee2mqtt
# MQTT server URL
server: 'mqtt://192.168.1.100:1883'
# MQTT server authentication, uncomment if required:
#user:
#password:
# Serial settings
serial:
# Location of CC2531 USB sniffer
port: /dev/ttyUSB0
