[Résolu] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
ebretteville
Message par ebretteville »
J'ai réinstallé le plugin v6. Le firmware est le 3.21.
Tous les tests avec TestGUI (https://zigate.fr/documentation/tester- ... /?seq_no=2) fonctionne jusqu'à l'inclusion.
Les logs domoticz:
2022-04-02 22:06:35.247 ZiGateV6: Worker thread started.
2022-04-02 22:06:35.247 Status: ZiGateV6: Entering work loop.
2022-04-02 22:06:35.247 Status: ZiGateV6: Started.
2022-04-02 22:06:37.052 Status: Python EventSystem: Initializing event module.
2022-04-02 22:06:38.821 ZiGateV6: Zigbee for Domoticz plugin started!
2022-04-02 22:06:38.847 ZiGateV6: load PluginConf
2022-04-02 22:06:38.851 ZiGateV6: is_domoticz_db_available: Fashion: True , Major: 2022, Minor: 1
2022-04-02 22:06:38.851 ZiGateV6: is_domoticz_db_available: True
2022-04-02 22:06:38.852 ZiGateV6: /home/pi/domoticz/plugins/Domoticz-Zigbee/Conf/PluginConf-49.json timestamp is 1648927519.5731952
2022-04-02 22:06:38.852 ZiGateV6: Dz PluginConf is older than Json Dz: 0 Json: 1648927519.5731952
2022-04-02 22:06:38.854 ZiGateV6: is_domoticz_db_available: Fashion: True , Major: 2022, Minor: 1
2022-04-02 22:06:38.854 ZiGateV6: is_domoticz_db_available: True
2022-04-02 22:06:38.857 ZiGateV6: Starting LoggingManagement thread
2022-04-02 22:06:38.858 ZiGateV6: start_logging_thread
2022-04-02 22:06:38.860 ZiGateV6: logging_thread - listening
2022-04-02 22:06:38.815 Status: ZiGateV6: Initialized version 6.1, author 'pipiche38'
2022-04-02 22:06:38.856 Status: ZiGateV6: PluginAnalytics set to 1
2022-04-02 22:06:38.856 Status: ZiGateV6: Lang set to fr-FR
2022-04-02 22:06:38.856 Status: ZiGateV6: filename set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Conf/PluginConf-49.json
2022-04-02 22:06:38.856 Status: ZiGateV6: pluginHome set to /home/pi/domoticz/plugins/Domoticz-Zigbee/
2022-04-02 22:06:38.856 Status: ZiGateV6: homedirectory set to /home/pi/domoticz/plugins/Domoticz-Zigbee/
2022-04-02 22:06:38.856 Status: ZiGateV6: pluginData set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Data/
2022-04-02 22:06:38.857 Status: ZiGateV6: pluginConfig set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Conf/
2022-04-02 22:06:38.857 Status: ZiGateV6: pluginOTAFirmware set to /home/pi/domoticz/plugins/Domoticz-Zigbee/OTAFirmware/
2022-04-02 22:06:38.857 Status: ZiGateV6: pluginReports set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Reports/
2022-04-02 22:06:38.857 Status: ZiGateV6: pluginWWW set to /home/pi/domoticz/plugins/Domoticz-Zigbee/www/
2022-04-02 22:06:38.857 Status: ZiGateV6: pluginLogs set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Logs/
2022-04-02 22:06:38.860 Status: ZiGateV6: Please watch plugin log into /home/pi/domoticz/plugins/Domoticz-Zigbee/Logs//PluginZigbee_49.log
2022-04-02 22:06:38.880 Status: ZiGateV6: Zigate plugin stable6-6.1.001 started
2022-04-02 22:06:38.954 Status: ZiGateV6: DeviceConf loaded - 23 confs loaded
2022-04-02 22:06:38.924 Error: ZiGateV6: Device creation failed, Domoticz settings prevent accepting new devices.
2022-04-02 22:06:38.924 Error: ZiGateV6: createAdminWidget - Fail to create Zigate Status 49. ID: -1, Name: 'Zigate Status 49', nValue: 0, sValue: ''
2022-04-02 22:06:38.924 Error: ZiGateV6: createNotificationWidget - Fail to create Zigate Notifications 49. ID: -1, Name: 'Zigate Notifications 49', nValue: 0, sValue: ''
2022-04-02 22:06:39.834 ZiGateV6: is_domoticz_db_available: Fashion: True , Major: 2022, Minor: 1
2022-04-02 22:06:39.834 ZiGateV6: is_domoticz_db_available: True
2022-04-02 22:06:39.843 ZiGateV6: is_domoticz_db_available: Fashion: True , Major: 2022, Minor: 1
2022-04-02 22:06:39.843 ZiGateV6: is_domoticz_db_available: True
2022-04-02 22:06:39.837 Status: ZiGateV6: DeviceConf loaded - 331 confs loaded
2022-04-02 22:06:39.838 Status: ZiGateV6: load ListOfDevice
2022-04-02 22:06:39.846 Status: ZiGateV6: 0 Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigbee/Data/DeviceList-49.txt
2022-04-02 22:06:39.849 Status: ZiGateV6: Transport mode: USB
2022-04-02 22:06:40.502 Status: ZiGateV6: ZigateTransport: Serial Connection open: Serial<id=0x606afcd0, open=True>(port='/dev/ttyUSB0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=None, xonxoff=False, rtscts=False, dsrdtr=False)
2022-04-02 22:06:40.512 Status: ZiGateV6: ZigateTransport: writer_thread Thread start.
2022-04-02 22:06:40.514 Status: ZiGateV6: ZigateTransport: thread_processing_and_sending Thread start.
2022-04-02 22:06:40.539 Status: ZiGateV6: Start Web Server connection
2022-04-02 22:06:40.570 Status: ZiGateV6: Web backend for Web User Interface started on port: 9440
2022-04-02 22:07:53.069 Error: ZiGateV6: [ 61] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-04-02 22:07:53.099 Error: ZiGateV6: [ ] Stop the plugin and check the Coordinator connectivity.
2022-04-02 22:07:54.071 Error: ZiGateV6: [ 62] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-04-02 22:07:54.105 Error: ZiGateV6: [ ] Stop the plugin and check the Coordinator connectivity.
2022-04-02 22:07:55.074 Error: ZiGateV6: [ 63] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
pi@domoticz-tours:~ $ dmesg | grep tty
[    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 rootwait
[    0.001130] printk: console [tty1] enabled
[    3.085943] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 114, base_baud = 0) is a PL011 rev2
[    3.125713] printk: console [ttyAMA0] enabled
[    4.591322]     kgdboc=ttyAMA0,115200
[    7.044344] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    9.347728] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
[    9.350644] cdc_acm 1-1.5:1.0: ttyACM1: USB ACM device
[    9.607584] usb 1-1.2.4: pl2303 converter now attached to ttyUSB0
[   33.814647] pl2303 ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
[   34.401615] pl2303 ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
pi@domoticz-tours:~ $ ls -l /dev/ttyUSB0
crw-rw---- 1 root dialout 188, 0 avril  2 22:21 /dev/ttyUSB0
pi@domoticz-tours:~ $ ls -l /dev/serial/by-id/*
lrwxrwxrwx 1 root root 13 avril  2 22:06 /dev/serial/by-id/usb-0658_0200-if00 -> ../../ttyACM1
lrwxrwxrwx 1 root root 13 avril  2 22:06 /dev/serial/by-id/usb-Arduino__www.arduino.cc__0042_55639313133351F08022-if00 -> ../../ttyACM0
lrwxrwxrwx 1 root root 13 avril  2 22:06 /dev/serial/by-id/usb-Prolific_Technology_Inc._USB-Serial_Controller-if00-port0 -> ../../ttyUSB0
Merci de votre aide
Dernière modification par ebretteville le 05 avr. 2022, 19:49, modifié 1 fois.
ebretteville
Re: I have hard time to get Coordinator Version. Mostlikly there is a communication issue
J'ai les 2 devices des gestions (j'avais oublié de mettre en mode autoriser les nouveaux périphériques). En revanche tjrs les erreurs de communications:
 2022-04-02 22:25:13.031 Status: ZiGate: Initialized version 6.1, author 'pipiche38'
2022-04-02 22:25:13.038 Status: ZiGate: PluginAnalytics set to 1
2022-04-02 22:25:13.038 Status: ZiGate: Lang set to fr-FR
2022-04-02 22:25:13.038 Status: ZiGate: filename set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Conf/PluginConf-49.json
2022-04-02 22:25:13.038 Status: ZiGate: pluginHome set to /home/pi/domoticz/plugins/Domoticz-Zigbee/
2022-04-02 22:25:13.038 Status: ZiGate: homedirectory set to /home/pi/domoticz/plugins/Domoticz-Zigbee/
2022-04-02 22:25:13.038 Status: ZiGate: pluginData set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Data/
2022-04-02 22:25:13.038 Status: ZiGate: pluginConfig set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Conf/
2022-04-02 22:25:13.038 Status: ZiGate: pluginOTAFirmware set to /home/pi/domoticz/plugins/Domoticz-Zigbee/OTAFirmware/
2022-04-02 22:25:13.038 Status: ZiGate: pluginReports set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Reports/
2022-04-02 22:25:13.038 Status: ZiGate: pluginWWW set to /home/pi/domoticz/plugins/Domoticz-Zigbee/www/
2022-04-02 22:25:13.038 Status: ZiGate: pluginLogs set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Logs/
2022-04-02 22:25:13.040 Status: ZiGate: Please watch plugin log into /home/pi/domoticz/plugins/Domoticz-Zigbee/Logs//PluginZigbee_49.log
2022-04-02 22:25:13.050 Status: ZiGate: Zigate plugin stable6-6.1.001 started
2022-04-02 22:25:13.099 Status: ZiGate: DeviceConf loaded - 23 confs loaded
2022-04-02 22:25:13.343 Status: ZiGate: DeviceConf loaded - 331 confs loaded
2022-04-02 22:25:13.344 Status: ZiGate: load ListOfDevice
2022-04-02 22:25:13.349 Status: ZiGate: 0 Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigbee/Data/DeviceList-49.txt
2022-04-02 22:25:13.350 Status: ZiGate: Transport mode: USB
2022-04-02 22:25:13.907 Status: ZiGate: ZigateTransport: Serial Connection open: Serial<id=0x6cf7e9d0, open=True>(port='/dev/ttyUSB0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=None, xonxoff=False, rtscts=False, dsrdtr=False)
2022-04-02 22:25:13.912 Status: ZiGate: ZigateTransport: writer_thread Thread start.
2022-04-02 22:25:13.914 Status: ZiGate: ZigateTransport: thread_processing_and_sending Thread start.
2022-04-02 22:25:13.916 Status: ZiGate: Start Web Server connection
2022-04-02 22:25:13.941 Status: ZiGate: Web backend for Web User Interface started on port: 9440
2022-04-02 22:26:13.093 Error: ZiGate: [ 61] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-04-02 22:26:13.139 Error: ZiGate: [ ] Stop the plugin and check the Coordinator connectivity.
2022-04-02 22:26:14.095 Error: ZiGate: [ 62] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-04-02 22:26:14.131 Error: ZiGate: [ ] Stop the plugin and check the Coordinator connectivity.
2022-04-02 22:26:15.097 Error: ZiGate: [ 63] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
As-tu vérifier dans le menu Hardware que
Le Coordinator Model est bien Zigate ou Zigate+ ?
Est-ce une nouvelle installation ? Ou un passage depuis la version 5 ?
As-tu bien suivi toutes les etapes de l'installation telle que decrite ?
Peux-tu regarder les Logs dans /home/pi/domoticz/plugins/Domoticz-Zigbee/Logs//PluginZigbee_49.log
ebretteville
1. Ou la vérification. Dans domoticz ZiGate est bien sélectionné
2. Nouvelle installation, le passage de la v5 a la v6 c'est pas bien passé. Je n'avais pas de dispositifs.
3. Oui ttes les étapes ont été suivies.
4. le fichier de logs est en PJ
Archive.zip
(92.36 Kio) Téléchargé 94 fois
Dernière modification par Keros le 03 avr. 2022, 00:19, modifié 1 fois.
peux-tu faire les commandes suivantes dans le home du plugin
cd domoticz/plugins/Domoticz-Zigbee
touch Domoticz.log
python3 plugin.py
ls -l
Il s'agit d'une premiere installation , dans ce cas as-tu bien activé le parametre
Initialize Coordinator: True
Screenshot 2022-04-02 at 23.49.19.png (60.21 Kio) Consulté 2475 fois
ebretteville
Oui paramètre a true.
pi@domoticz-tours:~/domoticz/plugins/Domoticz-Zigbee $ touch Domoticz.log
pi@domoticz-tours:~/domoticz/plugins/Domoticz-Zigbee $ python3 plugin.py
  File "plugin.py", line 72, in <module>
    import Domoticz
ModuleNotFoundError: No module named 'Domoticz'
Envoyé de mon ZTE A2322G en utilisant Tapatalk
Étrange.
As tu access au webUI sur le port 9440 ?
Si oui il faut que tu ailles dans le menu Tools>Debug
Que tu actives les paramètres
DebugInputs
DebugPlugin
DebugTransport
Tu relances le plug-in et tu partages les logs
ebretteville
1. Oui j'ai bien accès au webUI
2. C'est activé.
Les logs sont en PJ
Archive.zip
(466.54 Kio) Téléchargé 78 fois
Dernière modification par Keros le 03 avr. 2022, 10:35, modifié 1 fois.
Peut-etre une piste, par assure-toi de bien activer les paramètres
debugInput
debugZigateCmd
debugPlugin
debugTransport
debugTransportSerial
