Merci, j'ai été voir et j'ai les fichiers suivants:
PluginZigbee_02.log
PluginZigbee_02.log.2022-12-07
PluginZigbee_02.log.2022-12-08
PluginZigbee_log_error_history.json
Dans
PluginZigbee_02.log
j'ai :
2022-12-09 00:00:03,492 INFO : [ MainThread 21570] onDisconnect - Closing Name: 'Zigate Server Connection', Transport: 'TCP/IP', Protocol: 'HTTP', Address: '', Port: '9440', Baud: -1, Timeout: 0, Connected: False, Parent: 'None'
2022-12-09 00:00:03,497 INFO : [ MainThread 21570] onStop called
2022-12-09 00:00:03,498 INFO : [ MainThread 21570] onStop calling (1) domoticzDb DeviceStatus closed
2022-12-09 00:00:03,499 INFO : [ MainThread 21570] onStop calling (3) Transport off
2022-12-09 00:00:03,499 INFO : [ MainThread 21570] Shuting down co-routine
2022-12-09 00:00:03,501 INFO : [ZigpyForwarder_2 21606] ZigpyTransport: thread_processing_and_sending Thread stop.
2022-12-09 00:00:03,544 INFO : [ ZigpyCom_2 21605] worker_loop: Exiting Worker loop. Semaphore : 7
2022-12-09 00:00:03,546 INFO : [ ZigpyCom_2 21605] worker_loop: Semaphore[00:12:4b:00:25:8d:4a:55]
2022-12-09 00:00:03,547 INFO : [ ZigpyCom_2 21605] worker_loop: Semaphore[a4:c1:38:e4:96:8b:d5:e6]
2022-12-09 00:00:03,548 INFO : [ ZigpyCom_2 21605] worker_loop: Semaphore[a4:c1:38:b1:25:ed:0f:86]
2022-12-09 00:00:03,548 INFO : [ ZigpyCom_2 21605] worker_loop: Semaphore[a4:c1:38:28:49:72:38:21]
2022-12-09 00:00:03,555 INFO : [ ZigpyCom_2 21605] worker_loop: Semaphore[a4:c1:38:df:02:22:d1:6e]
2022-12-09 00:00:03,557 INFO : [ ZigpyCom_2 21605] worker_loop: Semaphore[00:12:4b:00:24:c2:e9:78]
2022-12-09 00:00:03,558 INFO : [ ZigpyCom_2 21605] worker_loop: Semaphore[a4:c1:38:23:35:6c:4e:06]
2022-12-09 00:00:18,656 INFO : [ ZigpyCom_2 21605] Coordinator backup is available: /home/pi/domoticz/plugins/Domoticz-Zigbee/Data//Coordinator-02.backup
2022-12-09 00:00:20,700 INFO : [ MainThread 21570] onStop calling (4) WebServer off
2022-12-09 00:00:20,702 INFO : [ MainThread 21570] onStop called (4) WebServer off
2022-12-09 00:00:20,709 INFO : [ MainThread 21570] onStop calling (5) Plugin Database saved
2022-12-09 00:00:20,999 INFO : [ MainThread 21570] onStop called (5) Plugin Database saved
2022-12-09 00:00:21,002 INFO : [ MainThread 21570] onStop calling (6) Close Logging Management
2022-12-09 00:00:31,643 INFO : [ MainThread 22056] Zigbee for Domoticz (z4d) plugin stable6-6.3.007 started
2022-12-09 00:00:31,681 ERROR : [ MainThread] domoticz_request - wrong URL toget access to Domoticz JSON/API: http://192.168.1.101:8080/json.htm?type=hardware
2022-12-09 00:00:31,703 ERROR : [ MainThread] domoticz_request - wrong URL toget access to Domoticz JSON/API: http://192.168.1.101:8080/json.htm?type=hardware
2022-12-09 00:00:31,737 INFO : [ MainThread 22056] Plugin Database: DeviceList-2.txt
2022-12-09 00:00:31,739 INFO : [ MainThread 22056] DeviceConf loaded - 22 confs loaded
2022-12-09 00:00:32,258 INFO : [ MainThread 22056] DeviceConf loaded - 369 confs loaded
2022-12-09 00:00:32,259 INFO : [ MainThread 22056] load ListOfDevice
2022-12-09 00:00:32,833 INFO : [ MainThread 22056] 18 Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigbee/Data/DeviceList-2.txt
2022-12-09 00:00:32,967 INFO : [ MainThread 22056] Transport mode: ZigpyZNP
2022-12-09 00:00:36,654 DEBUG :Using selector: EpollSelector
2022-12-09 00:00:36,657 INFO : [ MainThread 22056] Start Zigpy Transport on ZNP
2022-12-09 00:00:36,698 INFO : [ MainThread 22056] ZigpyTransport __init__
2022-12-09 00:00:36,707 INFO : [ ZigpyCom_2 22082] Starting radio znp port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c4e39f672f1aec11b0b37fe5f01c6278-if00-port0
2022-12-09 00:00:36,712 INFO : [ZigpyForwarder_2 22083] ZigpyTransport: thread_processing_and_sending Thread start.
2022-12-09 00:00:36,714 INFO : [ MainThread 22056] Start Web Server connection
2022-12-09 00:00:36,801 INFO : [ MainThread 22056] Web backend for Web User Interface started on port: 9440
2022-12-09 00:00:36,803 INFO : [ MainThread 22056] Domoticz Widgets usage is at 9.0 % (232 units free)
2022-12-09 00:00:37,599 INFO : [ ZigpyCom_2 22082] Started radio znp port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c4e39f672f1aec11b0b37fe5f01c6278-if00-port0
2022-12-09 00:00:45,995 INFO : [ ZigpyCom_2 22082] ZNP Radio register default Ep
2022-12-09 00:00:46,020 INFO : [ ZigpyCom_2 22082] ZNP Radio register any additional/specific Ep
2022-12-09 00:00:46,244 INFO : [ ZigpyCom_2 22082] device_initialized (0x0000 00:12:4b:00:25:8d:4a:55)
2022-12-09 00:00:46,248 INFO : [ ZigpyCom_2 22082] ZNP Configuration {'device': {'path': '/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c4e39f672f1aec11b0b37fe5f01c6278-if00-port0', 'flow_control': None, 'baudrate': 1>
2022-12-09 00:01:00,739 INFO : [ZigpyForwarder_2 22083] Number of devices recently active in Zigate = 19
2022-12-09 00:01:00,746 INFO : [ZigpyForwarder_2 22083] [00] DevID: 00 Network addr: 152d IEEE: a4c138c083df2759 LQI: 000 power: ff not found in plugin database!
2022-12-09 00:01:00,757 INFO : [ZigpyForwarder_2 22083] [01] DevID: 00 Network addr: d454 IEEE: a4c138c1cb0f56be LQI: 000 power: ff Model: TS0001 ( Radiateur salle )
2022-12-09 00:01:00,771 INFO : [ZigpyForwarder_2 22083] [02] DevID: 00 Network addr: a4c1 IEEE: 38c083df2759152d LQI: 000 power: ff not found in plugin database!
2022-12-09 00:01:00,779 INFO : [ZigpyForwarder_2 22083] [03] DevID: 00 Network addr: 0f56 IEEE: a4c1389a0a6b6848 LQI: 000 power: ff Model: TS0001 ( Radiateur couloir )
2022-12-09 00:01:00,790 INFO : [ZigpyForwarder_2 22083] [04] DevID: 00 Network addr: 6782 IEEE: a4c1382849723821 LQI: 000 power: ff Model: TS0001 ( Radiateur cuisine )
2022-12-09 00:01:00,792 INFO : [ZigpyForwarder_2 22083] [05] DevID: 00 Network addr: 37b7 IEEE: a4c1388816198824 LQI: 000 power: ff Model: TS0001 ( Radiateur entrée )
2022-12-09 00:01:00,794 INFO : [ZigpyForwarder_2 22083] [06] DevID: 00 Network addr: bc40 IEEE: a4c1387cbd3ec273 LQI: 000 power: ff Model: TS0001 ( Radiateur chambre sohan )
2022-12-09 00:01:00,796 INFO : [ZigpyForwarder_2 22083] [07] DevID: 00 Network addr: 92d6 IEEE: a4c1384671b4d883 LQI: 000 power: ff Model: TS0001 ( Radiateur chambre parents )
2022-12-09 00:01:00,798 INFO : [ZigpyForwarder_2 22083] [08] DevID: 00 Network addr: 397f IEEE: a4c1385db0285afe LQI: 000 power: ff Model: TS0001 ( Radiateur salle eau )
2022-12-09 00:01:00,805 INFO : [ZigpyForwarder_2 22083] [09] DevID: 00 Network addr: fae8 IEEE: a4c138b125ed0f86 LQI: 000 power: ff Model: TS0601-_TZE200_nklqjk62 ( Porte de garage )
2022-12-09 00:01:00,812 INFO : [ZigpyForwarder_2 22083] [10] DevID: 00 Network addr: 1adf IEEE: 00124b0024c2e978 LQI: 000 power: ff Model: 01MINIZB ( Chauffe eau )
2022-12-09 00:01:00,819 INFO : [ ZigpyCom_2 22082] ZNP Radio manufacturer: Texas Instruments
2022-12-09 00:01:00,827 INFO : [ ZigpyCom_2 22082] ZNP Radio board model: CC1352/CC2652, Z-Stack 3.30+ (build 20210708)
2022-12-09 00:01:00,834 INFO : [ ZigpyCom_2 22082] ZNP Radio version: 3.3
2022-12-09 00:01:00,839 INFO : [ ZigpyCom_2 22082] Network settings
2022-12-09 00:01:00,842 INFO : [ ZigpyCom_2 22082] Channel: 15
Et dans
{"LastLog": 63, "59": {"LastLog": 0, "StartTime": 1670615131, "FirmwareVersion": "0708", "FirmwareMajorVersion": "21", "PluginVersion": ["stable6-6.3.007"], "0": {"Time": 1670615183, "Module": "Input", "nwkid": "None", "PluginHealth": "Ready", "message": "Decode 8041 - Receive an IEEE: a4c138c083df2759 with a NwkId: 152d, seems not known by the plugin", "PermitToJoin": {"Duration": 0, "Starttime": 1670615171}, "Thread": "ZigpyForwarder_2"}}, "60": {"LastLog": 0, "StartTime": 1670615431, "FirmwareVersion": "0708", "FirmwareMajorVersion": "21", "PluginVersion": ["stable6-6.3.007"], "0": {"Time": 1670615483, "Module": "Input", "nwkid": "None", "PluginHealth": "Ready", "message": "Decode 8041 - Receive an IEEE: a4c138c083df2759 with a NwkId: 152d, seems not known by the plugin", "PermitToJoin": {"Duration": 0, "Starttime": 1670615471}, "Thread": "ZigpyForwarder_2"}}, "61": {"LastLog": 4, "StartTime": 1670616631, "FirmwareVersion": "0708", "FirmwareMajorVersion": "21", "PluginVersion": ["stable6-6.3.007"], "0": {"Time": 1670616685, "Module": "Input", "nwkid": "None", "PluginHealth": "Ready", "message": "Decode 8041 - Receive an IEEE: a4c138c083df2759 with a NwkId: 152d, seems not known by the plugin", "PermitToJoin": {"Duration": 0, "Starttime": 1670616670}, "Thread": "ZigpyForwarder_2"}, "1": {"Time": 1670616688, "Module": "Input", "nwkid": "None", "PluginHealth": "Ready", "message": "Decode 8041 - Receive an IEEE: a4c138c083df2759 with a NwkId: 152d, seems not known by the plugin", "PermitToJoin": {"Duration": 0, "Starttime": 1670616670}, "Thread": "ZigpyForwarder_2"}, "2": {"Time": 1670616795, "Module": "Input", "nwkid": "None", "PluginHealth": "Ready", "message": "Decode 8041 - Receive an IEEE: a4c138e0409d7976 with a NwkId: 7ebf, seems not known by the plugin", "PermitToJoin": {"Duration": 0, "Starttime": 1670616670}, "Thread": "ZigpyForwarder_2"}, "3": {"Time": 1670616798, "Module": "Input", "nwkid": "None", "PluginHealth": "Ready", "message": "Decode 8041 - Receive an IEEE: a4c138e0409d7976 with a NwkId: 7ebf, seems not known by the plugin", "PermitToJoin": {"Duration": 0, "Starttime": 1670616670}, "Thread": "ZigpyForwarder_2"}, "4": {"Time": 1670616801, "Module": "Input", "nwkid": "None", "PluginHealth": "Ready", "message": "Decode 8041 - Receive an IEEE: a4c138e0409d7976 with a NwkId: 7ebf, seems not known by the plugin", "PermitToJoin": {"Duration": 0, "Starttime": 1670616670}, "Thread": "ZigpyForwarder_2"}}, "62": {"LastLog": 0, "StartTime": 1670617231, "FirmwareVersion": "0708", "FirmwareMajorVersion": "21", "PluginVersion": ["stable6-6.3.007"], "0": {"Time": 1670617284, "Module": "Input", "nwkid": "None", "PluginHealth": "Ready", "message": "Decode 8041 - Receive an IEEE: a4c138c083df2759 with a NwkId: 152d, seems not known by the plugin", "PermitToJoin": {"Duration": 0, "Starttime": 1670617271}, "Thread": "ZigpyForwarder_2"}}, "63": {"LastLog": 0, "StartTime": 1670617531, "FirmwareVersion": "0708", "FirmwareMajorVersion": "21", "PluginVersion": ["stable6-6.3.007"], "0": {"Time": 1670617582, "Module": "Input", "nwkid": "None", "PluginHealth": "Ready", "message": "Decode 8041 - Receive an IEEE: a4c138c083df2759 with a NwkId: 152d, seems not known by the plugin", "PermitToJoin": {"Duration": 0, "Starttime": 1670617783}, "Thread": "ZigpyForwarder_2"}}}
Je dois reconnaitre ne pas tout comprendre...
