suite à la perte de l'interface web, ma domotique ne schedulait plus rien
2022-12-25 00:24:31.751 Status: WebServer(HTTP) startup failed on address :: with port: 8080: bind: Address already in use [system:98], trying ::
2022-12-25 00:24:31.754 Status: WebServer(HTTP) startup failed on address :: with port: 8080: bind: Address already in use [system:98], trying 0.0.0.0
2022-12-25 00:24:31.760 Error: WebServer(HTTP) startup failed on address 0.0.0.0 with port: 8080: bind: Address already in use [system:98]
2022-12-25 00:24:31.760 Error: WebServer(HTTP) check if no other application is using port: 8080
2022-12-25 00:24:31.793 Status: WebServer(SSL) startup failed on address :: with port: 443: bind: Address already in use [system:98], trying ::
2022-12-25 00:24:31.799 Status: WebServer(SSL) startup failed on address :: with port: 443: bind: Address already in use [system:98], trying 0.0.0.0
2022-12-25 00:24:31.806 Error: WebServer(SSL) startup failed on address 0.0.0.0 with port: 443: bind: Address already in use [system:98]
2022-12-25 00:24:31.806 Error: WebServer(SSL) check privileges for opening ports below 1024
2022-12-25 00:24:31.806 Error: Domoticz(pid:8800, tid:8800('domoticz')) received fatal signal 6 (Aborted)
2022-12-25 00:24:31.806 Error: siginfo address=0x2260, address=0xffffffff
2022-12-25 00:24:40.419 Error: Thread 1 (Thread 0x75ef5040 (LWP 8800)):
2022-12-25 00:24:40.419 Error: #0 __waitpid (options=0, stat_loc=0x7efe0020, pid=8808) at ../sysdeps/unix/sysv/linux/waitpid.c:30
2022-12-25 00:24:40.419 Error: #1 __waitpid (pid=8808, stat_loc=0x7efe0020, options=0) at ../sysdeps/unix/sysv/linux/waitpid.c:25
2022-12-25 00:24:40.419 Error: #2 0x00279814 in dumpstack_gdb(bool) ()
2022-12-25 00:24:40.419 Error: #3 0x00279de0 in signal_handler(int, siginfo_t*, void*) ()
2022-12-25 00:24:40.419 Error: #4 <signal handler called>
2022-12-25 00:24:40.419 Error: #5 __GI_raise (sig=sig@entry=6) at ../sysdeps/unix/sysv/linux/raise.c:50
2022-12-25 00:24:40.419 Error: #6 0x76891230 in __GI_abort () at abort.c:79
2022-12-25 00:24:40.420 Error: #7 0x008d8fa8 in __gnu_cxx::__verbose_terminate_handler() ()
2022-12-25 00:24:40.420 Error: #8 0x0083c59c in __cxxabiv1::__terminate(void (*)()) ()
2022-12-25 00:24:40.420 Error: #9 0x0083c610 in std::terminate() ()
2022-12-25 00:24:40.420 Error: #10 0x001a21e0 in main ()
[New LWP 8801]
[New LWP 8804]
[New LWP 8805]
[New LWP 8807]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/arm-linux-gnueabihf/libthread_db.so.1".
30 ../sysdeps/unix/sysv/linux/waitpid.c: Aucun fichier ou dossier de ce type.
Id Target Id Frame
* 1 Thread 0x75ef5040 (LWP 8800) "domoticz" __waitpid (options=0, stat_loc=0x7efe0020, pid=8808) at ../sysdeps/unix/sysv/linux/waitpid.c:30
2 Thread 0x75a1c200 (LWP 8801) "Watchdog" __GI___nanosleep (remaining=0x75a1bbb0, requested_time=0x75a1bbb0) at ../sysdeps/unix/sysv/linux/nanosleep.c:28
3 Thread 0x7521b200 (LWP 8804) "SQLHelper" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
4 Thread 0x74a1a200 (LWP 8805) "PluginMgr" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
5 Thread 0x73bef200 (LWP 8807) "InfluxPush" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
Thread 5 (Thread 0x73bef200 (LWP 8807)):
#0 syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
#1 0x0088cff4 in std::__atomic_futex_unsigned_base::_M_futex_wait_until(unsigned int*, unsigned int, bool, std::chrono::duration<long long, std::ratio<1ll, 1ll> >, std::chrono::duration<long long, std::ratio<1ll, 1000000000ll> >) ()
#2 0x00372824 in CInfluxPush::Do_Work() ()
#3 0x008af584 in execute_native_thread_routine ()
#4 0x76a9d494 in start_thread (arg=0x73bef200) at pthread_create.c:486
#5 0x76950dd8 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
Backtrace stopped: previous frame identical to this frame (corrupt stack?)
Thread 4 (Thread 0x74a1a200 (LWP 8805)):
#2 0x00653190 in Plugins::CPluginSystem::Do_Work() ()
#4 0x76a9d494 in start_thread (arg=0x74a1a200) at pthread_create.c:486
Thread 3 (Thread 0x7521b200 (LWP 8804)):
#2 0x0028f710 in CSQLHelper::Do_Work() ()
#4 0x76a9d494 in start_thread (arg=0x7521b200) at pthread_create.c:486
Thread 2 (Thread 0x75a1c200 (LWP 8801)):
#0 __GI___nanosleep (remaining=0x75a1bbb0, requested_time=0x75a1bbb0) at ../sysdeps/unix/sysv/linux/nanosleep.c:28
#1 __GI___nanosleep (requested_time=0x75a1bbb0, remaining=0x75a1bbb0) at ../sysdeps/unix/sysv/linux/nanosleep.c:25
#2 0x0021069c in sleep_milliseconds(long) ()
#3 0x00279f7c in Do_Watchdog_Work() ()
#4 0x008af584 in execute_native_thread_routine ()
#5 0x76a9d494 in start_thread (arg=0x75a1c200) at pthread_create.c:486
#6 0x76950dd8 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
Main thread:
[Inferior 1 (process 8800) detached]
à 00H45 j’arrête le service domoticz pour les sauvegarde mais en effet le serveur apache était en vrac, ce qui a fait planter les sauvegardes même l'appel de sauvegarde de Base de données par curl -s http://192.XXX.X.X:XXX/backupdatabase.php a bien planté mais erreur mal remontée par le NAS
Bienvenue interface de backup de la domotique
26 Dec 00:45:02 tournesol (root):
Debut : 26-12-2022 00:45:02
Jour traite : 26
999 Param1 : Sauvegarde Database Y/N - Y
999 Param2 : Jour Database - 0
999 Param3 : Sauvegarde Directory Y/N - Y
999 Param4 : Jour Directory - 0
999 Param5 : Sauvegarde SD Y/N - Y
999 Param6 : Jour SD - 01
Sauvegarde database Domoticz-Duree:0:02:15-Satut:KO
Erreur valeur : 2
Fin : 26-12-2022 00:47:17
Duree : 0:02:15
