J'ai une sonde OWON THS 317 qui est reconnu par zigbee2mqtt mais pas de device découvert par le plugin MQTT Auto Discovery Client Gateway with LAN interface.
Comment l'installer dans domoticz ?
Ci dessous les entrées pour cette sonde du serveur mosquitto
mosquitto_sub -h localhost -t "homeassistant/sensor/0x3c6a2cfffed2455b/battery/config"
{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0x3c6a2cfffed2455b"],"manufacturer":"OWON","model":"Temperature sensor (THS317-ET)","name":"Sonde wired 01"},"device_class":"battery","enabled_by_default":true,"entity_category":"diagnostic","json_attributes_topic":"zigbee2mqtt/Sonde wired 01","name":"Sonde wired 01 battery","state_class":"measurement","state_topic":"zigbee2mqtt/Sonde wired 01","unique_id":"0x3c6a2cfffed2455b_battery_zigbee2mqtt","unit_of_measurement":"%","value_template":"{{ value_json.battery }}"}
mosquitto_sub -h localhost -t "homeassistant/sensor/0x3c6a2cfffed2455b/temperature/config"
{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0x3c6a2cfffed2455b"],"manufacturer":"OWON","model":"Temperature sensor (THS317-ET)","name":"Sonde wired 01"}, "device_class":"temperature","enabled_by_default":true,"json_attributes_topic":"zigbee2mqtt/Sonde wired 01","name":"Sonde wired 01 temperature","state_class":"measurement","state_topic":"zigbee2mqtt/Son de wired 01","unique_id":"0x3c6a2cfffed2455b_temperature_zigbee2mqtt","unit_of_measurement":"°C","value_template":"{{ value_json.temperature }}"}
mosquitto_sub -h localhost -t "homeassistant/sensor/0x3c6a2cfffed2455b/linkquality/config"
{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0x3c6a2cfffed2455b"],"manufacturer":"OWON","model":"Temperature sensor (THS317-ET)","name":"Sonde wired 01"},"enabled_by_default":false,"entity_category":"diagnostic","icon":"mdi:signal","json_attributes_topic":"zigbee2mqtt/Sonde wired 01","name":"Sonde wired 01 linkquality","state_class":"measurement","state_topic":"zigbee2mqtt/Sonde wired 01","unique_id":"0x3c6a2cfffed2455b_linkquality_zigbee2mqtt","unit_of_measurement":"lqi","value_template":"{{ value_json.linkquality }}"}
