Dans le /tmp/domoticz.txt, il n'y a plus aucune ligne concernant le plugin Zigate. Même pas un message d'erreur.
Tous les autres plugins démarrent.
2023-03-01 12:02:50.280 Status: Domoticz V2022.2 (c)2012-2022 GizMoCuz
2023-03-01 12:02:50.280 Status: Build Hash: eea9db734, Date: 2022-11-05 13:05:35
2023-03-01 12:02:50.280 Status: Startup Path: /home/pi/domoticz/
2023-03-01 12:02:50.315 Sunrise: 07:33:00 SunSet: 18:34:00
2023-03-01 12:02:50.315 Day length: 11:01:00 Sun at south: 13:03:00
2023-03-01 12:02:50.315 Civil twilight start: 07:01:00 Civil twilight end: 19:05:00
2023-03-01 12:02:50.315 Nautical twilight start: 06:25:00 Nautical twilight end: 19:42:00
2023-03-01 12:02:50.315 Astronomical twilight start: 05:48:00 Astronomical twilight end: 20:18:00
2023-03-01 12:02:50.421 Status: PluginSystem: Started, Python version '3.7.3', 6 plugin definitions loaded.
2023-03-01 12:02:50.431 Active notification Subsystems: email, lms (2/13)
2023-03-01 12:02:50.442 Status: WebServer(SSL) started on address: :: with port 8443
2023-03-01 12:02:50.446 Status: Camera: settings (re)loaded
2023-03-01 12:02:50.447 Starting shared server on: :::6144
2023-03-01 12:02:50.447 Status: TCPServer: shared server started...
2023-03-01 12:02:50.448 Status: RxQueue: queue worker started...
2023-03-01 12:02:52.448 Status: AEON: ZWave: This hardware type is Deprecated! Please move to MQTT Auto Discovery and ZWave JS UI
2023-03-01 12:02:52.449 Status: SqueezeBox Server DS: Worker started...
2023-03-01 12:02:52.449 Status: Météo: Started...
2023-03-01 12:02:52.450 Status: Linky: Entering work loop.
2023-03-01 12:02:52.450 Linky: Worker thread started.
2023-03-01 12:02:52.450 Status: Linky: Started.
2023-03-01 12:02:52.450 Status: SqueezeBox Server DS: 3 player-switch(es) found.
2023-03-01 12:02:52.450 Status: IKEA GW: Entering work loop.
2023-03-01 12:02:52.451 Status: IKEA GW: Started.
2023-03-01 12:02:52.465 Status: SqueezeBox Server DS: No playlists found.
2023-03-01 12:02:52.478 Status: RPI: System: Raspberry Pi
2023-03-01 12:02:52.499 Status: RPI: Hardware Monitor: Started (OStype Raspberry Pi Linux)
2023-03-01 12:02:52.499 Status: OWM: Using specified location (City xxx)!
2023-03-01 12:02:52.836 Status: OWM: City (xxx)-> Lat/Long = xx.x,xx.x
2023-03-01 12:02:52.839 Status: OWM: Started
2023-03-01 12:02:52.841 Status: SmartLife: Entering work loop.
2023-03-01 12:02:52.841 Status: SmartLife: Started.
2023-03-01 12:02:52.843 Status: iDetect: Entering work loop.
2023-03-01 12:02:52.843 Status: iDetect: Started.
2023-03-01 12:02:52.844 Status: NotificationSystem: thread started...
2023-03-01 12:02:52.844 Status: EventSystem: reset all events...
2023-03-01 12:02:52.846 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/AngleBSO.lua
2023-03-01 12:02:52.847 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/OuvertureJour.lua
2023-03-01 12:02:52.847 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/FermetureSoir.lua
2023-03-01 12:02:52.847 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/Presence.lua
2023-03-01 12:02:52.847 Status: EventSystem: reset all device statuses...
2023-03-01 12:02:52.949 Status: AEON: using config in: /home/pi/domoticz/Config/
2023-03-01 12:02:52.995 Status: AEON: Starting...
2023-03-01 12:02:52.995 Status: AEON: Version: 1.6-1911-gc6a420ef
2023-03-01 12:02:53.146 Status: Linky: Initialized version 2.4.5, author 'Barberousse'
2023-03-01 12:02:53.162 Linky: Heures creuses désactivées
2023-03-01 12:02:53.168 Linky: Consommation à montrer sur le tableau de bord mis à value_day / peak_day
2023-03-01 12:02:53.170 Linky: Nombre de jours à récupérer pour la vue par heures mis à 4
2023-03-01 12:02:53.173 Linky: Nombre de jours à récupérer pour les autres vues mis à 366
2023-03-01 12:02:53.179 Linky: Nombre de jours à récupérer pour le calcul du pic mis à 1
2023-03-01 12:02:53.181 Linky: Debug mis à 0
2023-03-01 12:02:53.314 Linky: Cache chargé depuis le disque
2023-03-01 12:02:53.317 Linky: Si vous ne voyez pas assez de données dans la vue par heures, augmentez le paramètre Log des capteurs qui se trouve dans Ré
glages / Paramètres / Historique des logs
2023-03-01 12:02:53.318 Status: PluginSystem: 5 plugins started.
2023-03-01 12:02:53.475 Status: SqueezeBox Server DS: 1 connected player(s) found.
2023-03-01 12:02:53.575 Status: iDetect: Initialized version 2.1, author 'ESCape'
2023-03-01 12:02:53.604 Status: IKEA GW: Initialized version 0.10.7, author 'moroen'
2023-03-01 12:02:54.992 Status: Python EventSystem: Initializing event module.
2023-03-01 12:02:54.993 Status: EventSystem: Started
2023-03-01 12:02:54.993 Status: EventSystem: Queue thread started...
2023-03-01 12:02:55.027 Status: AEON: A DNS Error Occurred
2023-03-01 12:02:55.027 Status: AEON: ManufacturerSpecificDB Ready
2023-03-01 12:02:55.286 Status: AEON: Driver Ready
2023-03-01 12:02:55.288 AEON: Value_Added: Node: 4 (0x04), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1, Index: 0
2023-03-01 12:02:55.289 AEON: Value_Added: Node: 4 (0x04), CommandClass: SENSOR MULTILEVEL, Label: Power, Instance: 1, Index: 4
2023-03-01 12:02:55.289 AEON: Value_Added: Node: 4 (0x04), CommandClass: METER, Label: Electric - kWh, Instance: 1, Index: 0
2023-03-01 12:02:55.289 AEON: Value_Added: Node: 4 (0x04), CommandClass: METER, Label: Electric - W, Instance: 1, Index: 2
2023-03-01 12:02:55.289 AEON: Value_Added: Node: 4 (0x04), CommandClass: METER, Label: Exporting, Instance: 1, Index: 256
2023-03-01 12:02:55.291 AEON: Value_Added: Node: 7 (0x07), CommandClass: SENSOR BINARY, Label: Sensor, Instance: 1, Index: 0
2023-03-01 12:02:55.292 AEON: Value_Added: Node: 7 (0x07), CommandClass: BATTERY, Label: Battery Level, Instance: 1, Index: 0
2023-03-01 12:02:55.293 AEON: Value_Added: Node: 7 (0x07), CommandClass: SENSOR ALARM, Label: General, Instance: 1, Index: 0
2023-03-01 12:02:55.293 AEON: Value_Added: Node: 7 (0x07), CommandClass: SENSOR ALARM, Label: Flood, Instance: 1, Index: 5
2023-03-01 12:02:55.297 AEON: Value_Added: Node: 10 (0x0a), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1, Index: 0
2023-03-01 12:02:55.298 AEON: Value_Added: Node: 11 (0x0b), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1, Index: 0
2023-03-01 12:02:55.299 Status: AEON: Value_Added: Warning: OpenZWave returned ValueLabel "Unknown" on Node: 11 (0x0b), CommandClass: SENSOR MULTILEVEL, L
abel: Unknown, Instance: 1, Index: 0
2023-03-01 12:02:55.299 AEON: Value_Added: Node: 11 (0x0b), CommandClass: SENSOR MULTILEVEL, Label: Unknown, Instance: 1, Index: 0
2023-03-01 12:02:55.299 Status: AEON: Value_Added: Unhandled Label: Unknown, Unit: , Node: 11 (0x0b), CommandClass: SENSOR MULTILEVEL, Label: Unknown, Ins
tance: 1, Index: 0
2023-03-01 12:02:55.299 AEON: Value_Added: Node: 11 (0x0b), CommandClass: SENSOR MULTILEVEL, Label: Power, Instance: 1, Index: 4
2023-03-01 12:02:55.299 AEON: Value_Added: Node: 11 (0x0b), CommandClass: SENSOR MULTILEVEL, Label: Velocity, Instance: 1, Index: 6
2023-03-01 12:02:55.299 AEON: Value_Added: Node: 11 (0x0b), CommandClass: SENSOR MULTILEVEL, Label: Formaldehyde CH20 Level, Instance: 1, Index: 36
2023-03-01 12:02:55.299 Status: AEON: Value_Added: Unhandled Label: Formaldehyde CH20 Level, Unit: mol/m3, Node: 11 (0x0b), CommandClass: SENSOR MULTILEVE
2023-03-01 12:02:55.299 AEON: Value_Added: Node: 11 (0x0b), CommandClass: METER, Label: Electric - kWh, Instance: 1, Index: 0
2023-03-01 12:02:55.299 AEON: Value_Added: Node: 11 (0x0b), CommandClass: METER, Label: Electric - W, Instance: 1, Index: 2
2023-03-01 12:02:55.299 AEON: Value_Added: Node: 11 (0x0b), CommandClass: METER, Label: Exporting, Instance: 1, Index: 256
2023-03-01 12:02:55.301 AEON: Value_Added: Node: 15 (0x0f), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1, Index: 0
2023-03-01 12:02:55.301 Status: AEON: Value_Added: Warning: OpenZWave returned ValueLabel "Unknown" on Node: 15 (0x0f), CommandClass: SENSOR MULTILEVEL, L
2023-03-01 12:02:55.301 AEON: Value_Added: Node: 15 (0x0f), CommandClass: SENSOR MULTILEVEL, Label: Unknown, Instance: 1, Index: 0
2023-03-01 12:02:55.301 Status: AEON: Value_Added: Unhandled Label: Unknown, Unit: , Node: 15 (0x0f), CommandClass: SENSOR MULTILEVEL, Label: Unknown, Ins
tance: 1, Index: 0
2023-03-01 12:02:55.302 AEON: Value_Added: Node: 15 (0x0f), CommandClass: SENSOR MULTILEVEL, Label: Power, Instance: 1, Index: 4
2023-03-01 12:02:55.302 AEON: Value_Added: Node: 15 (0x0f), CommandClass: SENSOR MULTILEVEL, Label: Distance, Instance: 1, Index: 20
2023-03-01 12:02:55.302 Status: AEON: Value_Added: Unhandled Label: Distance, Unit: m, Node: 15 (0x0f), CommandClass: SENSOR MULTILEVEL, Label: Distance,
2023-03-01 12:02:55.302 AEON: Value_Added: Node: 15 (0x0f), CommandClass: METER, Label: Electric - kWh, Instance: 1, Index: 0
2023-03-01 12:02:55.302 AEON: Value_Added: Node: 15 (0x0f), CommandClass: METER, Label: Electric - W, Instance: 1, Index: 2
2023-03-01 12:02:55.302 AEON: Value_Added: Node: 15 (0x0f), CommandClass: METER, Label: Exporting, Instance: 1, Index: 256
2023-03-01 12:02:55.303 AEON: Value_Added: Node: 17 (0x11), CommandClass: SWITCH BINARY, Label: Instance 1: Switch, Instance: 1, Index: 0
2023-03-01 12:02:55.304 AEON: Value_Added: Node: 17 (0x11), CommandClass: SWITCH BINARY, Label: Instance 2: Switch, Instance: 2, Index: 0
2023-03-01 12:02:55.304 AEON: Value_Added: Node: 17 (0x11), CommandClass: SWITCH BINARY, Label: Instance 3: Switch, Instance: 3, Index: 0
2023-03-01 12:02:55.307 AEON: Value_Added: Node: 18 (0x12), CommandClass: SWITCH BINARY, Label: Instance 1: Switch, Instance: 1, Index: 0
2023-03-01 12:02:55.316 AEON: Value_Added: Node: 19 (0x13), CommandClass: SENSOR BINARY, Label: Sensor, Instance: 1, Index: 0
2023-03-01 12:02:55.317 AEON: Value_Added: Node: 19 (0x13), CommandClass: SENSOR MULTILEVEL, Label: Air Temperature, Instance: 1, Index: 1
2023-03-01 12:02:55.317 AEON: Value_Added: Node: 19 (0x13), CommandClass: ALARM, Label: Smoke Alarm, Instance: 1, Index: 1
2023-03-01 12:02:55.318 AEON: Value_Added: Node: 19 (0x13), CommandClass: ALARM, Label: Heat, Instance: 1, Index: 4
2023-03-01 12:02:55.318 AEON: Value_Added: Node: 19 (0x13), CommandClass: ALARM, Label: Home Security, Instance: 1, Index: 7
2023-03-01 12:02:55.319 AEON: Value_Added: Node: 19 (0x13), CommandClass: ALARM, Label: Power Management, Instance: 1, Index: 8
2023-03-01 12:02:55.319 AEON: Value_Added: Node: 19 (0x13), CommandClass: ALARM, Label: System, Instance: 1, Index: 9
2023-03-01 12:02:55.320 AEON: Value_Added: Node: 19 (0x13), CommandClass: ALARM, Label: Previous Event Cleared, Instance: 1, Index: 256
2023-03-01 12:02:55.320 Status: AEON: SendSwitchIfNotExists: Device '19.instance.1.index.256.commandClasses.113' (Previous Event Cleared) with DeviceID '0
0001300' matches '19.instance.1.index.0.commandClasses.48' (Sensor). Domoticz will use the Dimmer (and hide the Switch).
2023-03-01 12:02:55.321 AEON: Value_Added: Node: 19 (0x13), CommandClass: BATTERY, Label: Battery Level, Instance: 1, Index: 0
2023-03-01 12:02:55.321 AEON: Value_Added: Node: 19 (0x13), CommandClass: SENSOR ALARM, Label: General, Instance: 1, Index: 0
2023-03-01 12:02:55.322 AEON: Value_Added: Node: 19 (0x13), CommandClass: SENSOR ALARM, Label: Smoke, Instance: 1, Index: 1
2023-03-01 12:02:55.322 Status: AEON: SendSwitchIfNotExists: Device '19.instance.1.index.1.commandClasses.156' (Smoke) with DeviceID '00001329' matches '1
9.instance.1.index.1.commandClasses.113' (Smoke Alarm). Domoticz will use the Dimmer (and hide the Switch).
2023-03-01 12:02:55.323 AEON: Value_Added: Node: 19 (0x13), CommandClass: SENSOR ALARM, Label: Heat, Instance: 1, Index: 4
2023-03-01 12:02:55.323 Status: AEON: SendSwitchIfNotExists: Device '19.instance.1.index.4.commandClasses.156' (Heat) with DeviceID '0000132C' matches '19
.instance.1.index.4.commandClasses.113' (Heat). Domoticz will use the Dimmer (and hide the Switch).
2023-03-01 12:02:55.324 AEON: Value_Added: Node: 24 (0x18), CommandClass: SENSOR MULTILEVEL, Label: Air Temperature, Instance: 1, Index: 1
2023-03-01 12:02:55.325 AEON: Value_Added: Node: 24 (0x18), CommandClass: BATTERY, Label: Battery Level, Instance: 1, Index: 0
2023-03-01 12:02:55.328 AEON: Value_Added: Node: 24 (0x18), CommandClass: SENSOR ALARM, Label: General, Instance: 1, Index: 0
2023-03-01 12:02:55.329 AEON: Value_Added: Node: 24 (0x18), CommandClass: SENSOR ALARM, Label: Smoke, Instance: 1, Index: 1
2023-03-01 12:02:55.329 AEON: Value_Added: Node: 24 (0x18), CommandClass: SENSOR ALARM, Label: Heat, Instance: 1, Index: 4
2023-03-01 12:02:55.330 AEON: Value_Added: Node: 30 (0x1e), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1, Index: 0
2023-03-01 12:02:55.331 AEON: Value_Added: Node: 30 (0x1e), CommandClass: ALARM, Label: Power Management, Instance: 1, Index: 8
2023-03-01 12:02:55.331 AEON: Value_Added: Node: 30 (0x1e), CommandClass: ALARM, Label: Previous Event Cleared, Instance: 1, Index: 256
2023-03-01 12:02:55.333 AEON: Value_Added: Node: 33 (0x21), CommandClass: SCENE ACTIVATION, Label: Scene, Instance: 1, Index: 0
2023-03-01 12:02:55.333 AEON: Value_Added: Node: 33 (0x21), CommandClass: SCENE ACTIVATION, Label: Duration, Instance: 1, Index: 1
2023-03-01 12:02:55.333 AEON: Value_Added: Node: 33 (0x21), CommandClass: SENSOR BINARY, Label: Sensor, Instance: 1, Index: 0
2023-03-01 12:02:55.334 AEON: Value_Added: Node: 33 (0x21), CommandClass: SENSOR BINARY, Label: Sensor, Instance: 2, Index: 0
2023-03-01 12:02:55.335 AEON: Value_Added: Node: 33 (0x21), CommandClass: SENSOR MULTILEVEL, Label: Air Temperature, Instance: 1, Index: 1
2023-03-01 12:02:55.335 AEON: Value_Added: Node: 33 (0x21), CommandClass: BATTERY, Label: Battery Level, Instance: 1, Index: 0
2023-03-01 12:02:55.336 AEON: Value_Added: Node: 37 (0x25), CommandClass: SCENE ACTIVATION, Label: Scene, Instance: 1, Index: 0
2023-03-01 12:02:55.336 AEON: Value_Added: Node: 37 (0x25), CommandClass: SCENE ACTIVATION, Label: Duration, Instance: 1, Index: 1
2023-03-01 12:02:55.337 AEON: Value_Added: Node: 37 (0x25), CommandClass: SENSOR BINARY, Label: Sensor, Instance: 2, Index: 0
2023-03-01 12:02:55.338 AEON: Value_Added: Node: 37 (0x25), CommandClass: SENSOR MULTILEVEL, Label: Air Temperature, Instance: 1, Index: 1
2023-03-01 12:02:55.338 AEON: Value_Added: Node: 37 (0x25), CommandClass: BATTERY, Label: Battery Level, Instance: 1, Index: 0
2023-03-01 12:02:55.339 AEON: Value_Added: Node: 38 (0x26), CommandClass: SENSOR BINARY, Label: Sensor, Instance: 1, Index: 0
2023-03-01 12:02:55.340 AEON: Value_Added: Node: 38 (0x26), CommandClass: SENSOR MULTILEVEL, Label: Air Temperature, Instance: 1, Index: 1
2023-03-01 12:02:55.340 AEON: Value_Added: Node: 38 (0x26), CommandClass: SENSOR MULTILEVEL, Label: Illuminance, Instance: 1, Index: 3
2023-03-01 12:02:55.341 AEON: Value_Added: Node: 38 (0x26), CommandClass: BATTERY, Label: Battery Level, Instance: 1, Index: 0
2023-03-01 12:02:55.341 AEON: Value_Added: Node: 38 (0x26), CommandClass: SENSOR ALARM, Label: General, Instance: 1, Index: 0
2023-03-01 12:02:55.343 AEON: Value_Added: Node: 41 (0x29), CommandClass: SENSOR BINARY, Label: Sensor, Instance: 1, Index: 0
2023-03-01 12:02:55.344 AEON: Value_Added: Node: 41 (0x29), CommandClass: SENSOR MULTILEVEL, Label: Air Temperature, Instance: 1, Index: 1
2023-03-01 12:02:55.345 AEON: Value_Added: Node: 41 (0x29), CommandClass: ALARM, Label: Smoke Alarm, Instance: 1, Index: 1
2023-03-01 12:02:55.345 AEON: Value_Added: Node: 41 (0x29), CommandClass: ALARM, Label: Heat, Instance: 1, Index: 4
2023-03-01 12:02:55.346 AEON: Value_Added: Node: 41 (0x29), CommandClass: ALARM, Label: Home Security, Instance: 1, Index: 7
2023-03-01 12:02:55.346 AEON: Value_Added: Node: 41 (0x29), CommandClass: ALARM, Label: Power Management, Instance: 1, Index: 8
2023-03-01 12:02:55.347 AEON: Value_Added: Node: 41 (0x29), CommandClass: ALARM, Label: System, Instance: 1, Index: 9
2023-03-01 12:02:55.347 AEON: Value_Added: Node: 41 (0x29), CommandClass: ALARM, Label: Previous Event Cleared, Instance: 1, Index: 256
2023-03-01 12:02:55.348 Status: AEON: SendSwitchIfNotExists: Device '41.instance.1.index.256.commandClasses.113' (Previous Event Cleared) with DeviceID '0
0002900' matches '41.instance.1.index.0.commandClasses.48' (Sensor). Domoticz will use the Dimmer (and hide the Switch).
2023-03-01 12:02:55.348 AEON: Value_Added: Node: 41 (0x29), CommandClass: BATTERY, Label: Battery Level, Instance: 1, Index: 0
2023-03-01 12:02:55.348 AEON: Value_Added: Node: 41 (0x29), CommandClass: SENSOR ALARM, Label: General, Instance: 1, Index: 0
2023-03-01 12:02:55.349 AEON: Value_Added: Node: 41 (0x29), CommandClass: SENSOR ALARM, Label: Smoke, Instance: 1, Index: 1
2023-03-01 12:02:55.350 Status: AEON: SendSwitchIfNotExists: Device '41.instance.1.index.1.commandClasses.156' (Smoke) with DeviceID '00002929' matches '4
1.instance.1.index.1.commandClasses.113' (Smoke Alarm). Domoticz will use the Dimmer (and hide the Switch).
2023-03-01 12:02:55.350 AEON: Value_Added: Node: 41 (0x29), CommandClass: SENSOR ALARM, Label: Heat, Instance: 1, Index: 4
2023-03-01 12:02:55.350 Status: AEON: SendSwitchIfNotExists: Device '41.instance.1.index.4.commandClasses.156' (Heat) with DeviceID '0000292C' matches '41
2023-03-01 12:02:55.351 AEON: Value_Added: Node: 44 (0x2c), CommandClass: SENSOR BINARY, Label: Sensor, Instance: 1, Index: 0
2023-03-01 12:02:55.352 AEON: Value_Added: Node: 44 (0x2c), CommandClass: SENSOR MULTILEVEL, Label: Air Temperature, Instance: 1, Index: 1
2023-03-01 12:02:55.352 AEON: Value_Added: Node: 44 (0x2c), CommandClass: ALARM, Label: Smoke Alarm, Instance: 1, Index: 1
2023-03-01 12:02:55.353 AEON: Value_Added: Node: 44 (0x2c), CommandClass: ALARM, Label: Heat, Instance: 1, Index: 4
2023-03-01 12:02:55.354 AEON: Value_Added: Node: 44 (0x2c), CommandClass: ALARM, Label: Home Security, Instance: 1, Index: 7
2023-03-01 12:02:55.354 AEON: Value_Added: Node: 44 (0x2c), CommandClass: ALARM, Label: Power Management, Instance: 1, Index: 8
2023-03-01 12:02:55.355 AEON: Value_Added: Node: 44 (0x2c), CommandClass: ALARM, Label: System, Instance: 1, Index: 9
2023-03-01 12:02:55.355 AEON: Value_Added: Node: 44 (0x2c), CommandClass: ALARM, Label: Previous Event Cleared, Instance: 1, Index: 256
2023-03-01 12:02:55.356 Status: AEON: SendSwitchIfNotExists: Device '44.instance.1.index.256.commandClasses.113' (Previous Event Cleared) with DeviceID '0
0002C00' matches '44.instance.1.index.0.commandClasses.48' (Sensor). Domoticz will use the Dimmer (and hide the Switch).
2023-03-01 12:02:55.356 AEON: Value_Added: Node: 44 (0x2c), CommandClass: BATTERY, Label: Battery Level, Instance: 1, Index: 0
2023-03-01 12:02:55.357 AEON: Value_Added: Node: 44 (0x2c), CommandClass: SENSOR ALARM, Label: General, Instance: 1, Index: 0
2023-03-01 12:02:55.357 AEON: Value_Added: Node: 44 (0x2c), CommandClass: SENSOR ALARM, Label: Smoke, Instance: 1, Index: 1
2023-03-01 12:02:55.358 Status: AEON: SendSwitchIfNotExists: Device '44.instance.1.index.1.commandClasses.156' (Smoke) with DeviceID '00002C29' matches '4
4.instance.1.index.1.commandClasses.113' (Smoke Alarm). Domoticz will use the Dimmer (and hide the Switch).
2023-03-01 12:02:55.358 AEON: Value_Added: Node: 44 (0x2c), CommandClass: SENSOR ALARM, Label: Heat, Instance: 1, Index: 4
2023-03-01 12:02:55.358 Status: AEON: SendSwitchIfNotExists: Device '44.instance.1.index.4.commandClasses.156' (Heat) with DeviceID '00002C2C' matches '44
2023-03-01 12:02:55.359 AEON: Value_Added: Node: 45 (0x2d), CommandClass: SENSOR BINARY, Label: Sensor, Instance: 1, Index: 0
2023-03-01 12:02:55.359 AEON: Value_Added: Node: 45 (0x2d), CommandClass: SENSOR MULTILEVEL, Label: Air Temperature, Instance: 1, Index: 1
2023-03-01 12:02:55.360 AEON: Value_Added: Node: 45 (0x2d), CommandClass: ALARM, Label: Smoke Alarm, Instance: 1, Index: 1
2023-03-01 12:02:55.361 AEON: Value_Added: Node: 45 (0x2d), CommandClass: ALARM, Label: Heat, Instance: 1, Index: 4
2023-03-01 12:02:55.361 AEON: Value_Added: Node: 45 (0x2d), CommandClass: ALARM, Label: Home Security, Instance: 1, Index: 7
2023-03-01 12:02:55.361 AEON: Value_Added: Node: 45 (0x2d), CommandClass: ALARM, Label: Power Management, Instance: 1, Index: 8
2023-03-01 12:02:55.362 AEON: Value_Added: Node: 45 (0x2d), CommandClass: ALARM, Label: System, Instance: 1, Index: 9
2023-03-01 12:02:55.362 AEON: Value_Added: Node: 45 (0x2d), CommandClass: ALARM, Label: Previous Event Cleared, Instance: 1, Index: 256
2023-03-01 12:02:55.362 Status: AEON: SendSwitchIfNotExists: Device '45.instance.1.index.256.commandClasses.113' (Previous Event Cleared) with DeviceID '0
0002D00' matches '45.instance.1.index.0.commandClasses.48' (Sensor). Domoticz will use the Dimmer (and hide the Switch).
2023-03-01 12:02:55.363 AEON: Value_Added: Node: 45 (0x2d), CommandClass: BATTERY, Label: Battery Level, Instance: 1, Index: 0
2023-03-01 12:02:55.363 AEON: Value_Added: Node: 45 (0x2d), CommandClass: SENSOR ALARM, Label: General, Instance: 1, Index: 0
2023-03-01 12:02:55.364 AEON: Value_Added: Node: 45 (0x2d), CommandClass: SENSOR ALARM, Label: Smoke, Instance: 1, Index: 1
2023-03-01 12:02:55.364 Status: AEON: SendSwitchIfNotExists: Device '45.instance.1.index.1.commandClasses.156' (Smoke) with DeviceID '00002D29' matches '4
5.instance.1.index.1.commandClasses.113' (Smoke Alarm). Domoticz will use the Dimmer (and hide the Switch).
2023-03-01 12:02:55.364 AEON: Value_Added: Node: 45 (0x2d), CommandClass: SENSOR ALARM, Label: Heat, Instance: 1, Index: 4
2023-03-01 12:02:55.364 Status: AEON: SendSwitchIfNotExists: Device '45.instance.1.index.4.commandClasses.156' (Heat) with DeviceID '00002D2C' matches '45
2023-03-01 12:02:55.364 Status: AEON: New Node added. HomeID: 21826952, NodeID: 20 (0x14)
2023-03-01 12:02:55.365 Status: AEON: New Node added. HomeID: 21826952, NodeID: 21 (0x15)
2023-03-01 12:02:55.365 Status: AEON: New Node added. HomeID: 21826952, NodeID: 23 (0x17)
2023-03-01 12:02:55.365 Status: AEON: New Node added. HomeID: 21826952, NodeID: 25 (0x19)
2023-03-01 12:02:55.365 Status: AEON: New Node added. HomeID: 21826952, NodeID: 26 (0x1a)
2023-03-01 12:02:55.366 Status: AEON: New Node added. HomeID: 21826952, NodeID: 28 (0x1c)
2023-03-01 12:02:55.366 Status: AEON: New Node added. HomeID: 21826952, NodeID: 29 (0x1d)
2023-03-01 12:02:55.366 Status: AEON: New Node added. HomeID: 21826952, NodeID: 32 (0x20)
2023-03-01 12:02:55.366 Status: AEON: New Node added. HomeID: 21826952, NodeID: 34 (0x22)
2023-03-01 12:02:55.366 Status: AEON: New Node added. HomeID: 21826952, NodeID: 35 (0x23)
2023-03-01 12:02:55.367 Status: AEON: New Node added. HomeID: 21826952, NodeID: 42 (0x2a)
2023-03-01 12:02:55.367 Status: AEON: New Node added. HomeID: 21826952, NodeID: 43 (0x2b)
2023-03-01 12:02:56.121 Status: SmartLife: Initialized version 1.0.14, author 'Wagner Oliveira contributed Xenomes'
2023-03-01 12:02:57.094 Status: iDetect: Starting tracker:local pinger, user:irrelevant, class:ping_tracker and poll interval:30
2023-03-01 12:02:57.118 Status: iDetect: Starting tracker:192.168.x.x, user:pi, class:ssh_autodetect and poll interval:120
2023-03-01 12:03:00.671 Status: dzVents: !Info: Lux: 72/540 Vent: 6.9/12/25 Journée: true
2023-03-01 12:03:00.672 Status: dzVents: !Info: index 1 : Store-Cuisine
2023-03-01 12:03:00.674 Status: dzVents: !Info: (Store-Cuisine Level 0 LastLevel 0 Orientation 70 LastOrientation 80)
2023-03-01 12:03:00.675 Status: dzVents: !Info: Ouverture Store-Cuisine-Orientation orientation 70 +10 (Store-Cuisine Level 0 LastLevel 0 Orientation 70 L
astOrientation 80)
2023-03-01 12:03:00.675 Status: dzVents: !Info: index 2 : Store-Bureau
2023-03-01 12:03:00.675 Status: dzVents: !Info: (Store-Bureau Level 0 LastLevel 0 Orientation 70 LastOrientation 80)
2023-03-01 12:03:00.675 Status: dzVents: !Info: Ouverture Store-Bureau-Orientation orientation 70 +10 (Store-Bureau Level 0 LastLevel 0 Orientation 70 Las
tOrientation 80)
2023-03-01 12:03:00.675 Status: dzVents: !Info: index 3 : Store-Caverne
2023-03-01 12:03:00.675 Status: dzVents: !Info: (Store-Caverne Level 0 LastLevel 0 Orientation 70 LastOrientation 80)
2023-03-01 12:03:00.675 Status: dzVents: !Info: Ouverture Store-Caverne-Orientation orientation 70 +10 (Store-Caverne Level 0 LastLevel 0 Orientation 70 L
astOrientation 80)
2023-03-01 12:03:01.129 Status: AEON: Received timeout notification from HomeID: 21826952, NodeID: 15 (0x0f)
2023-03-01 12:03:01.893 Status: AEON: Received Node Dead notification from HomeID: 21826952, NodeID: 10 (0x0a)
2023-03-01 12:03:01.900 AEON: Light/Switch (Inter fil0A)
2023-03-01 12:03:01.987 AEON: Temp (Temp df18 bureau)
2023-03-01 12:03:02.097 Status: Linky: Récupération des données avec l'historique court
2023-03-01 12:03:02.140 Status: Linky: Traitement pour le point de livraisonxxx
2023-03-01 12:03:03.308 AEON: Usage (W p04)
2023-03-01 12:03:03.323 AEON: General/kWh (kWh p04 VMC)
2023-03-01 12:03:03.460 AEON: General/kWh (kWh p04 VMC)
2023-03-01 12:03:03.718 AEON: Usage (Unknown)
2023-03-01 12:03:03.727 AEON: General/kWh (kWh p04 VMC)
2023-03-01 12:03:03.852 AEON: Usage (W p0B)
2023-03-01 12:03:03.873 AEON: General/kWh (kWh p0B)
2023-03-01 12:03:03.994 AEON: General/kWh (kWh p0B)
2023-03-01 12:03:04.016 AEON: Usage (Unknown)
2023-03-01 12:03:04.029 AEON: General/kWh (kWh p0B)
2023-03-01 12:03:04.996 Status: Linky: Prochaine récupération complète de l'historique : 2023-05-12
2023-03-01 12:03:04.999 Status: Linky: Prochaine connexion : 2023-03-02 08:06:02
2023-03-01 12:03:07.016 Status: AEON: Received timeout notification from HomeID: 21826952, NodeID: 15 (0x0f)
2023-03-01 12:03:10.020 Status: AEON: Received timeout notification from HomeID: 21826952, NodeID: 15 (0x0f)
2023-03-01 12:03:13.021 Status: AEON: Received timeout notification from HomeID: 21826952, NodeID: 15 (0x0f)
2023-03-01 12:03:16.023 Status: AEON: Received timeout notification from HomeID: 21826952, NodeID: 15 (0x0f)
2023-03-01 12:03:19.025 Status: AEON: Received timeout notification from HomeID: 21826952, NodeID: 15 (0x0f)
2023-03-01 12:03:19.944 Status: AEON: Alarm received (Power Management: Power Applied), NodeID: 30 (0x1e)
2023-03-01 12:03:19.948 AEON: General/Alarm (Alarm Type: Power Management 8 (0x08))
2023-03-01 12:03:19.951 AEON: Light/Switch (Power Management)
2023-03-01 12:03:20.552 Status: AEON: Awake Nodes queried
2023-03-01 12:03:41.519 AEON: Temp (Temp df18 bureau)
2023-03-01 12:06:00.221 Status: dzVents: !Info: Lux: 72/540 Vent: 6.9/12/25 Journée: true
2023-03-01 12:06:00.222 Status: dzVents: !Info: index 1 : Store-Cuisine
2023-03-01 12:06:00.222 Status: dzVents: !Info: (Store-Cuisine Level 0 LastLevel 0 Orientation 70 LastOrientation 80)
2023-03-01 12:06:00.222 Status: dzVents: !Info: Ouverture Store-Cuisine-Orientation orientation 70 +10 (Store-Cuisine Level 0 LastLevel 0 Orientation 70 L
astOrientation 80)
2023-03-01 12:06:00.222 Status: dzVents: !Info: index 2 : Store-Bureau
2023-03-01 12:06:00.222 Status: dzVents: !Info: (Store-Bureau Level 0 LastLevel 0 Orientation 70 LastOrientation 80)
2023-03-01 12:06:00.222 Status: dzVents: !Info: Ouverture Store-Bureau-Orientation orientation 70 +10 (Store-Bureau Level 0 LastLevel 0 Orientation 70 Las
tOrientation 80)
2023-03-01 12:06:00.222 Status: dzVents: !Info: index 3 : Store-Caverne
2023-03-01 12:06:00.222 Status: dzVents: !Info: (Store-Caverne Level 0 LastLevel 0 Orientation 70 LastOrientation 80)
2023-03-01 12:06:00.222 Status: dzVents: !Info: Ouverture Store-Caverne-Orientation orientation 70 +10 (Store-Caverne Level 0 LastLevel 0 Orientation 70 L
astOrientation 80)
2023-03-01 12:07:08.381 AEON: Temp (Temp df21 cabanon)
2023-03-01 12:07:27.439 AEON: Temp (Temp df21 cabanon)
2023-03-01 12:09:00.209 Status: dzVents: !Info: Lux: 72/540 Vent: 7.0/12/25 Journée: true
2023-03-01 12:09:00.209 Status: dzVents: !Info: index 1 : Store-Cuisine
2023-03-01 12:09:00.209 Status: dzVents: !Info: (Store-Cuisine Level 0 LastLevel 0 Orientation 70 LastOrientation 80)
2023-03-01 12:09:00.209 Status: dzVents: !Info: Ouverture Store-Cuisine-Orientation orientation 70 +10 (Store-Cuisine Level 0 LastLevel 0 Orientation 70 L
astOrientation 80)
2023-03-01 12:09:00.209 Status: dzVents: !Info: index 2 : Store-Bureau
2023-03-01 12:09:00.209 Status: dzVents: !Info: (Store-Bureau Level 0 LastLevel 0 Orientation 70 LastOrientation 80)
2023-03-01 12:09:00.210 Status: dzVents: !Info: Ouverture Store-Bureau-Orientation orientation 70 +10 (Store-Bureau Level 0 LastLevel 0 Orientation 70 Las
tOrientation 80)
2023-03-01 12:09:00.210 Status: dzVents: !Info: index 3 : Store-Caverne
2023-03-01 12:09:00.210 Status: dzVents: !Info: (Store-Caverne Level 0 LastLevel 0 Orientation 70 LastOrientation 80)
2023-03-01 12:09:00.210 Status: dzVents: !Info: Ouverture Store-Caverne-Orientation orientation 70 +10 (Store-Caverne Level 0 LastLevel 0 Orientation 70 L
astOrientation 80)
2023-03-01 12:09:14.638 Status: AEON: Received timeout notification from HomeID: 21826952, NodeID: 45 (0x2d)
2023-03-01 12:09:14.693 AEON: Temp (Temp df2d Etage)
2023-03-01 12:09:14.794 AEON: Light/Switch (General)
2023-03-01 12:09:14.839 AEON: Light/Switch (Smoke df2d Etage)
2023-03-01 12:09:14.891 AEON: Light/Switch (Heat df2d Etage)
2023-03-01 12:12:00.249 Status: dzVents: !Info: Lux: 72/540 Vent: 7.0/12/25 Journée: true
2023-03-01 12:12:00.249 Status: dzVents: !Info: index 1 : Store-Cuisine
2023-03-01 12:12:00.249 Status: dzVents: !Info: (Store-Cuisine Level 0 LastLevel 0 Orientation 70 LastOrientation 80)
2023-03-01 12:12:00.249 Status: dzVents: !Info: Ouverture Store-Cuisine-Orientation orientation 70 +10 (Store-Cuisine Level 0 LastLevel 0 Orientation 70 L
astOrientation 80)
2023-03-01 12:12:00.249 Status: dzVents: !Info: index 2 : Store-Bureau
2023-03-01 12:12:00.249 Status: dzVents: !Info: (Store-Bureau Level 0 LastLevel 0 Orientation 70 LastOrientation 80)
2023-03-01 12:12:00.249 Status: dzVents: !Info: Ouverture Store-Bureau-Orientation orientation 70 +10 (Store-Bureau Level 0 LastLevel 0 Orientation 70 Las
tOrientation 80)
2023-03-01 12:12:00.249 Status: dzVents: !Info: index 3 : Store-Caverne
2023-03-01 12:12:00.249 Status: dzVents: !Info: (Store-Caverne Level 0 LastLevel 0 Orientation 70 LastOrientation 80)
2023-03-01 12:12:00.249 Status: dzVents: !Info: Ouverture Store-Caverne-Orientation orientation 70 +10 (Store-Caverne Level 0 LastLevel 0 Orientation 70 L
astOrientation 80)
2023-03-01 12:15:00.356 Status: dzVents: !Info: Lux: 72/540 Vent: 7.0/12/25 Journée: true
2023-03-01 12:15:00.356 Status: dzVents: !Info: index 1 : Store-Cuisine
2023-03-01 12:15:00.356 Status: dzVents: !Info: (Store-Cuisine Level 0 LastLevel 0 Orientation 70 LastOrientation 80)
2023-03-01 12:15:00.356 Status: dzVents: !Info: Ouverture Store-Cuisine-Orientation orientation 70 +10 (Store-Cuisine Level 0 LastLevel 0 Orientation 70 L
astOrientation 80)
2023-03-01 12:15:00.356 Status: dzVents: !Info: index 2 : Store-Bureau
2023-03-01 12:15:00.356 Status: dzVents: !Info: (Store-Bureau Level 0 LastLevel 0 Orientation 70 LastOrientation 80)
