Plugin Zigbee2mqtt se deconnect, reconnect régulièrement. (50mn)
Plugins DeConz et ZigBee2MQTT
Jempi57
Message par Jempi57 »
Toutes les 50 minutes.
2023-06-17 01:36:49.571 Zigbee2MQTT: Zigbee2mqtt bridge is offline
2023-06-17 01:37:09.360 Zigbee2MQTT: Zigbee2mqtt bridge is online
2023-06-17 01:37:09.615 Zigbee2MQTT: Received available devices list from bridge
2023-06-17 01:37:09.754 Zigbee2MQTT: Received available devices groups from bridge
2023-06-17 01:37:09.806 Zigbee2MQTT: Joining new devices is disabled on the zigbee bridge
2023-06-17 02:26:49.135 Zigbee2MQTT: Zigbee2mqtt bridge is offline
2023-06-17 02:27:08.975 Zigbee2MQTT: Zigbee2mqtt bridge is online
2023-06-17 02:27:09.230 Zigbee2MQTT: Received available devices list from bridge
2023-06-17 02:27:09.394 Zigbee2MQTT: Received available devices groups from bridge
2023-06-17 02:27:09.496 Zigbee2MQTT: Joining new devices is disabled on the zigbee bridge
2023-06-17 03:16:52.282 Zigbee2MQTT: Zigbee2mqtt bridge is offline
2023-06-17 03:17:12.173 Zigbee2MQTT: Zigbee2mqtt bridge is online
2023-06-17 03:17:12.429 Zigbee2MQTT: Received available devices list from bridge
2023-06-17 03:17:12.570 Zigbee2MQTT: Received available devices groups from bridge
2023-06-17 03:17:12.722 Zigbee2MQTT: Joining new devices is disabled on the zigbee bridge
2023-06-17 04:06:53.598 Zigbee2MQTT: Zigbee2mqtt bridge is offline
2023-06-17 04:07:13.587 Zigbee2MQTT: Zigbee2mqtt bridge is online
2023-06-17 04:07:13.892 Zigbee2MQTT: Received available devices list from bridge
2023-06-17 04:07:14.012 Zigbee2MQTT: Received available devices groups from bridge
2023-06-17 04:07:14.065 Zigbee2MQTT: Joining new devices is disabled on the zigbee bridge
2023-06-17 04:56:52.631 Zigbee2MQTT: Zigbee2mqtt bridge is offline
2023-06-17 04:57:12.372 Zigbee2MQTT: Zigbee2mqtt bridge is online
2023-06-17 04:57:12.627 Zigbee2MQTT: Received available devices list from bridge
2023-06-17 04:57:12.769 Zigbee2MQTT: Received available devices groups from bridge
2023-06-17 04:57:12.872 Zigbee2MQTT: Joining new devices is disabled on the zigbee bridge
2023-06-17 05:46:52.954 Zigbee2MQTT: Zigbee2mqtt bridge is offline
2023-06-17 05:47:12.894 Zigbee2MQTT: Zigbee2mqtt bridge is online
2023-06-17 05:47:13.149 Zigbee2MQTT: Received available devices list from bridge
2023-06-17 05:47:13.281 Zigbee2MQTT: Received available devices groups from bridge
2023-06-17 05:47:13.383 Zigbee2MQTT: Joining new devices is disabled on the zigbee bridge
2023-06-17 06:36:54.011 Zigbee2MQTT: Zigbee2mqtt bridge is offline
2023-06-17 06:37:13.952 Zigbee2MQTT: Zigbee2mqtt bridge is online
2023-06-17 06:37:14.208 Zigbee2MQTT: Received available devices list from bridge
2023-06-17 06:37:14.336 Zigbee2MQTT: Received available devices groups from bridge
2023-06-17 06:37:14.438 Zigbee2MQTT: Joining new devices is disabled on the zigbee bridge
Qui, quoi, pourquoi ?
Modération
Sujet déplacé dans la section ZigBee.
Il serait intéressant de nous partager quelques infos sur ton système.
Jempi57
Re: Plugin Zigbee2mqtt se deconnect, reconnect régulièrement. (50mn)
Disparu.... Bref domoticz et Zigbee2mqtt n'est ps vraiment une histoire d'amour.
J'ai laissé tomber l'intégration, je n'utilise plus que le portail Z2M, "http://@-du-pi:8081"
Je récupère les données avec le plugin "MQTT Auto Discovery Client Gataway with LAN Interface"
