En checkant ce soir pourquoi mes scenarios à base d objet zigbee ne ce sont pas lancés je suis tombé sur des log étrange.
Plus aucun devices dans le plusin
Voici les logs apres restart
2023-07-06 21:45:40.529 Status: ZiGate: Initialized version 6.3, author 'pipiche38'
2023-07-06 21:45:40.612 Status: ZiGate: Zigbee for Domoticz plugin started!
2023-07-06 21:45:40.613 Status: ZiGate: Python3 requires 3.8 or above and you are running 3.9
2023-07-06 21:45:40.614 Status: ZiGate: Checking Python modules /opt/domoticz/userdata/plugins/Domoticz-Zigbee/requirements.txt
2023-07-06 21:45:44.024 Status: ZiGate: Checking Python modules /opt/domoticz/userdata/plugins/Domoticz-Zigbee/requirements.txt
2023-07-06 21:45:44.468 ZiGate: load PluginConf
2023-07-06 21:45:44.473 ZiGate: Loading PluginConf - from Domoticz sqlite Db
2023-07-06 21:45:44.474 ZiGate: /opt/domoticz/userdata/plugins/Domoticz-Zigbee/Conf/PluginConf-09.json timestamp is 1686485731.8825412
2023-07-06 21:45:44.475 ZiGate: Dz PluginConf is older than Json Dz: 0 Json: 1686485731.8825412
2023-07-06 21:45:44.510 Status: ZiGate: PluginAnalytics set to 1
2023-07-06 21:45:44.511 Status: ZiGate: blueLedOnOff set to 0
2023-07-06 21:45:44.511 Status: ZiGate: channel set to 11
2023-07-06 21:45:44.511 Status: ZiGate: filename set to /opt/domoticz/userdata/plugins/Domoticz-Zigbee/Conf/PluginConf-09.json
2023-07-06 21:45:44.511 Status: ZiGate: pluginHome set to /opt/domoticz/userdata/plugins/Domoticz-Zigbee/
2023-07-06 21:45:44.511 Status: ZiGate: homedirectory set to /opt/domoticz/userdata/plugins/Domoticz-Zigbee/
2023-07-06 21:45:44.511 Status: ZiGate: pluginData set to /opt/domoticz/userdata/plugins/Domoticz-Zigbee/Data/
2023-07-06 21:45:44.511 Status: ZiGate: pluginConfig set to /opt/domoticz/userdata/plugins/Domoticz-Zigbee/Conf/
2023-07-06 21:45:44.512 Status: ZiGate: pluginOTAFirmware set to /opt/domoticz/userdata/plugins/Domoticz-Zigbee/OTAFirmware/
2023-07-06 21:45:44.512 Status: ZiGate: pluginReports set to /opt/domoticz/userdata/plugins/Domoticz-Zigbee/Reports/
2023-07-06 21:45:44.512 Status: ZiGate: pluginWWW set to /opt/domoticz/userdata/plugins/Domoticz-Zigbee/www/
2023-07-06 21:45:44.512 Status: ZiGate: pluginLogs set to /opt/domoticz/userdata/plugins/Domoticz-Zigbee/Logs/
2023-07-06 21:45:44.512 Status: ZiGate: logThreadName set to 1
2023-07-06 21:45:44.512 Status: ZiGate: ZiGateReactTime set to 1
2023-07-06 21:45:44.513 Status: ZiGate: EnableLedIfOn set to 0
2023-07-06 21:45:44.513 Status: ZiGate: EnableReleaseButton set to 1
2023-07-06 21:45:44.514 ZiGate: Installing plugin custom page /opt/domoticz/www/templates/ZiGate.html
2023-07-06 21:45:44.521 ZiGate: Starting LoggingManagement thread
2023-07-06 21:45:44.528 ZiGate: start_logging_thread
2023-07-06 21:45:44.531 ZiGate: logging_thread - listening
2023-07-06 21:45:44.532 Status: ZiGate: Please watch plugin log into /opt/domoticz/userdata/plugins/Domoticz-Zigbee/Logs//PluginZigbee_09.log
2023-07-06 21:45:44.573 Status: ZiGate: Zigbee for Domoticz (z4d) plugin stable6-6.3.013 started
2023-07-06 21:45:44.610 Status: [WebServer] Deprecated RType (hardware) for API request. Handled via fallback (gethardware), please use correct API Command! (127.0.0.1)
2023-07-06 21:45:44.613 Status: [web:8080] Incoming connection from: 127.0.0.1
2023-07-06 21:45:44.632 Status: [WebServer] Deprecated RType (hardware) for API request. Handled via fallback (gethardware), please use correct API Command! (127.0.0.1)
2023-07-06 21:45:44.684 Status: ZiGate: DeviceConf loaded - 17 confs loaded
2023-07-06 21:45:46.525 Status: ZiGate: DeviceConf loaded - 440 confs loaded
2023-07-06 21:45:46.530 Status: ZiGate: load ListOfDevice
2023-07-06 21:45:46.563 Status: ZiGate: 1 Entries loaded from /opt/domoticz/userdata/plugins/Domoticz-Zigbee/Data/DeviceList-9.txt
2023-07-06 21:45:46.593 Error: ZiGate: checkListOfDevice2Devices - W_radiateur_chambre_amis - 00158d0002166ba4 not found in Plugin Database
2023-07-06 21:45:46.661 Error: ZiGate: checkListOfDevice2Devices - temp_cuisine - 00158d0002310205 not found in Plugin Database
2023-07-06 21:45:49.335 Error: ZiGate: checkListOfDevice2Devices - EDF outside - 3c6a2cfffed212dd not found in Plugin Database
2023-07-06 21:45:49.375 Error: ZiGate: checkListOfDevice2Devices - EDF-Exterieur - 3c6a2cfffed212dd not found in Plugin Database
2023-07-06 21:45:49.426 Error: ZiGate: checkListOfDevice2Devices - ZiGate - PC321_Voltage-3c6a2cfffed212dd-f3 - 3c6a2cfffed212dd not found in Plugin Database
2023-07-06 21:45:49.467 Error: ZiGate: checkListOfDevice2Devices - ZiGate - PC321_Ampere-3c6a2cfffed212dd-f3 - 3c6a2cfffed212dd not found in Plugin Database
2023-07-06 21:45:49.508 Status: ZiGate: Transport mode: USB
2023-07-06 21:45:49.513 Status: ZiGate: ZigateTransport: Serial Connection open: Serial<id=0x7f679ef2b0, open=True>(port='/dev/ttyUSB-ZIGATE', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=None, xonxoff=False, rtscts=False, dsrdtr=False)
2023-07-06 21:45:49.519 Status: ZiGate: ZigateTransport: writer_thread Thread start.
2023-07-06 21:45:49.522 Status: ZiGate: ZigateTransport: thread_processing_and_sending Thread start.
2023-07-06 21:45:49.526 Status: ZiGate: Start Web Server connection
2023-07-06 21:45:49.534 Status: ZiGate: Web backend for Web User Interface started on port: 9440
2023-07-06 21:45:49.537 Status: ZiGate: Domoticz Widgets usage is at 25.1 % (191 units free)
2023-07-06 21:45:56.158 ZiGate: Zigate command round trip 0x8000 Max: 99 ms with an of average: 99 ms
2023-07-06 21:45:56.160 ZiGate: Zigate Thread Serial Read Max: 3 ms with an of average: 3 ms
2023-07-06 21:45:56.164 ZiGate: Zigate receive message processing time Max: 1 ms with an of average: 1 ms
2023-07-06 21:45:56.174 ZiGate: Zigate receive message processing time Max: 2 ms with an of average: 1 ms
2023-07-06 21:45:56.178 Status: ZiGate: ==> Transport Mode switch to full mode
2023-07-06 21:45:56.189 Status: ZiGate: ZiGate Classic PDM (OptiPDM)
2023-07-06 21:45:56.194 Status: ZiGate: Installer Version Number: 0320
2023-07-06 21:45:56.199 Status: ZiGate: Branch Version: ==> Production <==
2023-07-06 21:45:57.067 ZiGate: Zigate receive message processing time Max: 5 ms with an of average: 2 ms
2023-07-06 21:45:57.090 ZiGate: Zigate receive message processing time Max: 19 ms with an of average: 4 ms
2023-07-06 21:46:04.460 Status: [WebServer] Deprecated RType (devices) for API request. Handled via fallback (getdevices), please use correct API Command! (192.168.2.6)
2023-07-06 21:46:06.208 ZiGate: Zigate command round trip 0x8000 Max: 106 ms with an of average: 102 ms
2023-07-06 21:46:06.293 ZiGate: Zigate receive message processing time Max: 81 ms with an of average: 6 ms
2023-07-06 21:46:06.299 Status: ZiGate: Zigbee Coordinator ieee: 00158d0001b22f0a , short addr: 0000
2023-07-06 21:46:06.304 Status: ZiGate: Network state UP, PANID: 5c2a extPANID: 0x564fbaf9e54f509d Channel: 11
2023-07-06 21:46:11.106 Status: ZiGate: Request Disabling Accepting new Hardware
2023-07-06 21:46:11.652 Status: ZiGate: Accepting new Hardware: Disable (Off)
2023-07-06 21:46:11.758 Status: ZiGate: Number of devices recently active in Coordinator = 10
2023-07-06 21:46:11.760 Status: ZiGate: [00] DevID: 00 Network addr: 0c91 IEEE: 00158d00023101f1 LQI: 099 power: 00 not found in plugin database!
2023-07-06 21:46:11.762 Status: ZiGate: [01] DevID: 01 Network addr: 55de IEEE: 04cf8cdf3c78c104 LQI: 109 power: 01 not found in plugin database!
2023-07-06 21:46:11.765 Status: ZiGate: [02] DevID: 14 Network addr: 34f7 IEEE: 00158d00022f4120 LQI: 140 power: 01 not found in plugin database!
2023-07-06 21:46:11.768 Status: ZiGate: [03] DevID: 15 Network addr: 00ea IEEE: 7cb03eaa00afbcd6 LQI: 093 power: 01 not found in plugin database!
2023-07-06 21:46:11.771 Status: ZiGate: [04] DevID: 16 Network addr: 5a7f IEEE: 5c0272fffed6822d LQI: 135 power: 01 not found in plugin database!
2023-07-06 21:46:11.773 Status: ZiGate: [05] DevID: 17 Network addr: 3350 IEEE: 60a423fffe94f54e LQI: 144 power: 01 not found in plugin database!
2023-07-06 21:46:11.775 Status: ZiGate: [06] DevID: 18 Network addr: aeab IEEE: 00124b0023592cd3 LQI: 130 power: 01 not found in plugin database!
2023-07-06 21:46:11.789 Status: ZiGate: [07] DevID: 19 Network addr: 6a56 IEEE: 3c6a2cfffed212dd LQI: 198 power: 01 not found in plugin database!
2023-07-06 21:46:11.792 Status: ZiGate: [08] DevID: 1a Network addr: 5130 IEEE: 7cb03eaa0a0a2774 LQI: 084 power: 01 not found in plugin database!
2023-07-06 21:46:11.794 Status: ZiGate: [09] DevID: 1b Network addr: 649f IEEE: 540f57fffe74c5ed LQI: 094 power: 01 not found in plugin database!
2023-07-06 21:46:17.129 Status: ZiGate: coordinator set to Certification : 1/CE -> CE
2023-07-06 21:46:17.357 ZiGate: Zigate command round trip 0x8000 Max: 125 ms with an of average: 95 ms
2023-07-06 21:46:17.361 ZiGate: Zigate Thread Serial Read Max: 4 ms with an of average: 0 ms
2023-07-06 21:46:17.382 Status: ZiGate: TxPower Attenuation: 0 dBm
Je me suis toujours dis qu un jour je devrait tout refaire propre mais je comprends pas quand même.
Je n 'ai rien changé, le system était up hier (du moins les scenario était bon ) et j ai cela depuis ce matin 6h20, date a laquel j ai recu la derniere info du capteur de consommation electrique
Pour les details
Version de DomoticZ : 023.1 (build 15369)
Système sur lequel tourne DomoticZ avec le plugin : RPI3B+
Modèle de ZiGate : V1
Version de ZiGate : USB
Marque de l’équipement : tous
