Plus de liaison avec mes Sonoff POW R2 sous tasmotta 12.5.0 depuis la mise a jour de Domoticz 2023.2
- Fait une installation complète de mon Raspberry pi 3B+
PRETTY_NAME="Debian GNU/Linux 12 (bookworm)"
NAME="Debian GNU/Linux"
VERSION_ID="12"
VERSION="12 (bookworm)"
VERSION_CODENAME=bookworm
ID=debian
HOME_URL="https://www.debian.org/"
SUPPORT_URL="https://www.debian.org/support"
BUG_REPORT_URL="https://bugs.debian.org/"
- Réinstaller Domoticz
Version: 2023.2
Build Hash: 19efd039c
Compile Date: 2023-07-21 17:23:44
dzVents Version: 3.1.8
Python Version: 3.11.2 (main, Mar 13 2023, 12:18:29) [GCC 12.2.0]
Active User: Herve
- Réinstaller MQTT par se site (https://randomnerdtutorials.com/how-to- ... pberry-pi/)
Avec la commande mosquitto -v
1697890708: mosquitto version 2.0.11 starting
1697890708: Using default config.
1697890708: Starting in local only mode. Connections will only be possible from clients running on this machine.
1697890708: Create a configuration file which defines a listener to allow remote access.
1697890708: For more details see https://mosquitto.org/documentation/aut ... n-methods/
1697890708: Opening ipv4 listen socket on port 1883.
1697890708: Error: Address already in use
1697890708: Opening ipv6 listen socket on port 1883.
Avec la commande sudo systemctl status mosquitto
● mosquitto.service - Mosquitto MQTT Broker
Loaded: loaded (/lib/systemd/system/mosquitto.service; enabled; preset: enabled)
Active: active (running) since Fri 2023-10-20 19:53:29 CEST; 18h ago
Docs: man:mosquitto.conf(5)
man:mosquitto(8)
Process: 728 ExecStartPre=/bin/mkdir -m 740 -p /var/log/mosquitto (code=exited, status=0/SUCCESS)
Process: 731 ExecStartPre=/bin/chown mosquitto /var/log/mosquitto (code=exited, status=0/SUCCESS)
Process: 732 ExecStartPre=/bin/mkdir -m 740 -p /run/mosquitto (code=exited, status=0/SUCCESS)
Process: 733 ExecStartPre=/bin/chown mosquitto /run/mosquitto (code=exited, status=0/SUCCESS)
Main PID: 734 (mosquitto)
Tasks: 1 (limit: 758)
CPU: 337ms
CGroup: /system.slice/mosquitto.service
└─734 /usr/sbin/mosquitto -c /etc/mosquitto/mosquitto.conf
Oct 20 19:53:26 raspberrypi systemd[1]: Starting mosquitto.service - Mosquitto MQTT Broker...
Oct 20 19:53:29 raspberrypi systemd[1]: Started mosquitto.service - Mosquitto MQTT Broker.
Tous semble correct je ne vois pas se qui ne marche pas, besoin d'aide merci
La liaison mosquitto avec domoticz ne fonctionne plus
Re: La liaison mosquitto avec domoticz ne fonctionne plus
1697890708: Error: Address already in useTu as modifié le fichier mosquitto.conf ?
As tu regardé ce sujet au titre étonnamment très similaire ?
Re: Résolue La liaison mosquitto avec domoticz ne fonctionne plus
Merci pour l'aide en faite j'ai remis la clé wifi ainsi que le mot de passe Mosquitto dans mes sonoff POW R2 et tous et rentrer dans l'ordre ( mdp wifi et Mqtt non pas changer !!!)
Je ne sais pas ou marquer résolue
