[Résolu] Réinstallation
mysterevince
Message par mysterevince »
J'ai été amené à réinstaller mon raspberry.
J'ai refait la manipulation pour l'installation et ai restauré ma configuration sous domoticz et homebridge.
Tout fonctionne sauf Zigbeefordomoticz (ne se lance pas sur ip:9440)
Voici le log ci dessous.
Qu'en pensez-vous ?
2023-11-10 12:51:54.319 ZigBeeForDomoticZ: Installing plugin custom page /home/vcahen/domoticz/www/templates/ZigBeeForDomoticZ.html
2023-11-10 12:51:54.326 ZigBeeForDomoticZ: Starting LoggingManagement thread
2023-11-10 12:51:54.326 ZigBeeForDomoticZ: zigpy_login_mode(30)
2023-11-10 12:51:54.329 ZigBeeForDomoticZ: start_logging_thread
2023-11-10 12:51:54.330 ZigBeeForDomoticZ: logging_thread - listening
2023-11-10 12:53:22.478 Zwave: Light/Switch (Porte entrée)
2023-11-10 12:53:27.904 Zwave: Light/Switch (Porte entrée)
2023-11-10 12:53:55.110 ZigBeeForDomoticZ: URL INFOS {'type': 'command', 'param': 'updatehardware', 'htype': '94', 'idx': 10, 'name': 'ZigBeeForDomoticZ', 'address': '0.0.0.0', 'port': '9999', 'serialport': '/dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20221202180749-if00', 'Mode1': 'ZigpyEZSP', 'Mode2': 'USB', 'Mode3': 'False', 'Mode4': '9440', 'Mode5': 'http://127.0.0.1:8080', 'Mode6': '2', 'extra': 'Zigate', 'enabled': 'true', 'datatimeout': '0', 'loglevel': 7}
2023-11-10 12:53:55.190 ZigBeeForDomoticZ: onStop()
2023-11-10 12:53:55.202 ZigBeeForDomoticZ: logging_thread - ended
2023-11-10 12:53:55.212 ZigBeeForDomoticZ: Logging Thread shutdown
2023-11-10 12:53:55.212 ZigBeeForDomoticZ: onStop called (6) Close Logging Management
2023-11-10 12:53:55.591 ZigBeeForDomoticZ: Worker thread started.
2023-11-10 12:53:59.366 ZigBeeForDomoticZ: load PluginConf
2023-11-10 12:53:59.368 ZigBeeForDomoticZ: Loading PluginConf - from Domoticz sqlite Db
2023-11-10 12:53:59.369 ZigBeeForDomoticZ: /home/vcahen/domoticz/plugins/Domoticz-Zigbee/Conf/PluginConf-10.json timestamp is 1699560358.1342182
2023-11-10 12:53:59.369 ZigBeeForDomoticZ: Dz PluginConf is older than Json Dz: 0 Json: 1699560358.1342182
2023-11-10 12:53:59.372 ZigBeeForDomoticZ: Installing plugin custom page /home/vcahen/domoticz/www/templates/ZigBeeForDomoticZ.html
2023-11-10 12:53:59.379 ZigBeeForDomoticZ: Starting LoggingManagement thread
2023-11-10 12:53:59.379 ZigBeeForDomoticZ: zigpy_login_mode(30)
2023-11-10 12:53:59.382 ZigBeeForDomoticZ: start_logging_thread
2023-11-10 12:53:59.383 ZigBeeForDomoticZ: logging_thread - listening
2023-11-10 12:55:10.673 Zwave: Light/Switch (Lampe Salon)
2023-11-10 12:55:11.410 Zwave: Usage (Unknown)
2023-11-10 12:55:11.413 Zwave: General/kWh (kWh Meter)
2023-11-10 12:55:16.420 Zwave: Usage (Unknown)
2023-11-10 12:55:16.423 Zwave: General/kWh (kWh Meter)
2023-11-10 12:55:53.971 Zwave: Thermostat (Radiateur)
2023-11-10 12:55:54.010 Zwave: Temp (Air Temperature)
2023-11-10 12:56:00.081 ZigBeeForDomoticZ: URL INFOS {'type': 'command', 'param': 'updatehardware', 'htype': '94', 'idx': 10, 'name': 'ZigBeeForDomoticZ', 'address': '0.0.0.0', 'port': '9999', 'serialport': '/dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20221202180749-if00', 'Mode1': 'ZigpyEZSP', 'Mode2': 'USB', 'Mode3': 'False', 'Mode4': '9440', 'Mode5': 'http://127.0.0.1:8080', 'Mode6': '2', 'extra': 'Zigate', 'enabled': 'true', 'datatimeout': '0', 'loglevel': 7}
2023-11-10 12:56:00.162 ZigBeeForDomoticZ: onStop()
2023-11-10 12:56:00.172 ZigBeeForDomoticZ: logging_thread - ended
2023-11-10 12:56:00.183 ZigBeeForDomoticZ: Logging Thread shutdown
2023-11-10 12:56:00.184 ZigBeeForDomoticZ: onStop called (6) Close Logging Management
2023-11-10 12:56:00.563 ZigBeeForDomoticZ: Worker thread started.
2023-11-10 12:56:04.349 ZigBeeForDomoticZ: load PluginConf
2023-11-10 12:56:04.351 ZigBeeForDomoticZ: Loading PluginConf - from Domoticz sqlite Db
2023-11-10 12:56:04.352 ZigBeeForDomoticZ: /home/vcahen/domoticz/plugins/Domoticz-Zigbee/Conf/PluginConf-10.json timestamp is 1699560358.1342182
2023-11-10 12:56:04.352 ZigBeeForDomoticZ: Dz PluginConf is older than Json Dz: 0 Json: 1699560358.1342182
2023-11-10 12:56:04.356 ZigBeeForDomoticZ: Installing plugin custom page /home/vcahen/domoticz/www/templates/ZigBeeForDomoticZ.html
2023-11-10 12:56:04.356 ZigBeeForDomoticZ: Starting LoggingManagement thread
2023-11-10 12:56:04.356 ZigBeeForDomoticZ: zigpy_login_mode(30)
2023-11-10 12:56:04.360 ZigBeeForDomoticZ: start_logging_thread
2023-11-10 12:56:04.360 ZigBeeForDomoticZ: logging_thread - listening
2023-11-10 12:56:05.538 Error: ZigBeeForDomoticZ: File "/usr/local/lib/python3.9/dist-packages/zigpy/config/validators.py", line 9, in <module>
2023-11-10 12:56:05.538 Error: ZigBeeForDomoticZ: import zigpy.zdo.types as zdo_t
2023-11-10 12:56:05.538 Error: ZigBeeForDomoticZ: File "/usr/local/lib/python3.9/dist-packages/zigpy/zdo/__init__.py", line 10, in <module>
2023-11-10 12:56:05.538 Error: ZigBeeForDomoticZ: import zigpy.util
2023-11-10 12:56:05.538 Error: ZigBeeForDomoticZ: File "/usr/local/lib/python3.9/dist-packages/zigpy/util.py", line 15, in <module>
2023-11-10 12:56:05.538 Error: ZigBeeForDomoticZ: from cryptography.hazmat.primitives.ciphers import Cipher
2023-11-10 12:56:05.538 Error: ZigBeeForDomoticZ: File "/usr/local/lib/python3.9/dist-packages/cryptography/hazmat/primitives/ciphers/__init__.py", line 11, in <module>
2023-11-10 12:56:05.538 Error: ZigBeeForDomoticZ: from cryptography.hazmat.primitives.ciphers.base import (
2023-11-10 12:56:05.538 Error: ZigBeeForDomoticZ: File "/usr/local/lib/python3.9/dist-packages/cryptography/hazmat/primitives/ciphers/base.py", line 10, in <module>
2023-11-10 12:56:05.538 Error: ZigBeeForDomoticZ: from cryptography.exceptions import (
2023-11-10 12:56:05.538 Error: ZigBeeForDomoticZ: File "/usr/local/lib/python3.9/dist-packages/cryptography/exceptions.py", line 9, in <module>
2023-11-10 12:56:05.538 Error: ZigBeeForDomoticZ: from cryptography.hazmat.bindings._rust import exceptions as rust_exceptions
2023-11-10 12:56:05.538 Error: ZigBeeForDomoticZ: ImportError: PyO3 modules may only be initialized once per interpreter process
2023-11-10 12:57:14.057 Error: ZigBeeForDomoticZ: [ 70] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2023-11-10 12:57:24.085 Error: ZigBeeForDomoticZ: [ 80] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2023-11-10 12:57:34.063 Error: ZigBeeForDomoticZ: [ 90] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2023-11-10 12:57:44.094 Error: ZigBeeForDomoticZ: [100] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2023-11-10 12:57:54.072 Error: ZigBeeForDomoticZ: [110] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2023-11-10 12:58:04.055 Error: ZigBeeForDomoticZ: [120] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2023-11-10 12:58:05.069 ZigBeeForDomoticZ: URL INFOS {'type': 'command', 'param': 'updatehardware', 'htype': '94', 'idx': 10, 'name': 'ZigBeeForDomoticZ', 'address': '0.0.0.0', 'port': '9999', 'serialport': '/dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20221202180749-if00', 'Mode1': 'ZigpyEZSP', 'Mode2': 'USB', 'Mode3': 'False', 'Mode4': '9440', 'Mode5': 'http://127.0.0.1:8080', 'Mode6': '2', 'extra': 'Zigate', 'enabled': 'true', 'datatimeout': '0', 'loglevel': 7}
2023-11-10 12:58:05.162 ZigBeeForDomoticZ: onStop()
2023-11-10 12:58:05.169 ZigBeeForDomoticZ: logging_thread - ended
2023-11-10 12:58:05.177 ZigBeeForDomoticZ: Logging Thread shutdown
2023-11-10 12:58:05.178 ZigBeeForDomoticZ: onStop called (6) Close Logging Management
2023-11-10 12:58:05.563 ZigBeeForDomoticZ: Worker thread started.
2023-11-10 12:58:09.329 ZigBeeForDomoticZ: load PluginConf
2023-11-10 12:58:09.332 ZigBeeForDomoticZ: Loading PluginConf - from Domoticz sqlite Db
2023-11-10 12:58:09.332 ZigBeeForDomoticZ: /home/vcahen/domoticz/plugins/Domoticz-Zigbee/Conf/PluginConf-10.json timestamp is 1699560358.1342182
2023-11-10 12:58:09.332 ZigBeeForDomoticZ: Dz PluginConf is older than Json Dz: 0 Json: 1699560358.1342182
2023-11-10 12:58:09.336 ZigBeeForDomoticZ: Installing plugin custom page /home/vcahen/domoticz/www/templates/ZigBeeForDomoticZ.html
2023-11-10 12:58:09.342 ZigBeeForDomoticZ: Starting LoggingManagement thread
2023-11-10 12:58:09.343 ZigBeeForDomoticZ: zigpy_login_mode(30)
2023-11-10 12:58:09.346 ZigBeeForDomoticZ: start_logging_thread
2023-11-10 12:58:09.346 ZigBeeForDomoticZ: logging_thread - listening
2023-11-10 12:58:10.177 Error: ZigBeeForDomoticZ: checkListOfDevice2Devices - Lampe salle à manger - 9035eafffe095c52 not found in Plugin Database
2023-11-10 12:58:10.187 Error: ZigBeeForDomoticZ: checkListOfDevice2Devices - ZigBeeForDomoticZ - ZBMINIL2_Voltage-9035eafffe095c52-01 - 9035eafffe095c52 not found in Plugin Database
2023-11-10 12:58:10.517 Error: ZigBeeForDomoticZ: Call to function 'onStart' failed, exception details:
2023-11-10 12:58:10.524 Error: ZigBeeForDomoticZ: Traceback (most recent call last):
2023-11-10 12:58:10.524 Error: ZigBeeForDomoticZ: File "/home/vcahen/domoticz/plugins/Domoticz-Zigbee/plugin.py", line 1563, in onStart
2023-11-10 12:58:10.524 Error: ZigBeeForDomoticZ: _plugin.onStart()
2023-11-10 12:58:10.524 Error: ZigBeeForDomoticZ: File "/home/vcahen/domoticz/plugins/Domoticz-Zigbee/plugin.py", line 631, in onStart
2023-11-10 12:58:10.524 Error: ZigBeeForDomoticZ: from zigpy.config import (CONF_DEVICE, CONF_DEVICE_PATH,
2023-11-10 12:58:10.524 Error: ZigBeeForDomoticZ: File "/usr/local/lib/python3.9/dist-packages/zigpy/config/__init__.py", line 34, in <module>
2023-11-10 12:58:10.524 Error: ZigBeeForDomoticZ: from zigpy.config.validators import (
2023-11-10 12:58:10.524 Error: ZigBeeForDomoticZ: File "/usr/local/lib/python3.9/dist-packages/zigpy/config/validators.py", line 9, in <module>
2023-11-10 12:58:10.524 Error: ZigBeeForDomoticZ: import zigpy.zdo.types as zdo_t
2023-11-10 12:58:10.524 Error: ZigBeeForDomoticZ: File "/usr/local/lib/python3.9/dist-packages/zigpy/zdo/__init__.py", line 10, in <module>
2023-11-10 12:58:10.524 Error: ZigBeeForDomoticZ: import zigpy.util
2023-11-10 12:58:10.524 Error: ZigBeeForDomoticZ: File "/usr/local/lib/python3.9/dist-packages/zigpy/util.py", line 15, in <module>
2023-11-10 12:58:10.524 Error: ZigBeeForDomoticZ: from cryptography.hazmat.primitives.ciphers import Cipher
2023-11-10 12:58:10.524 Error: ZigBeeForDomoticZ: File "/usr/local/lib/python3.9/dist-packages/cryptography/hazmat/primitives/ciphers/__init__.py", line 11, in <module>
2023-11-10 12:58:10.524 Error: ZigBeeForDomoticZ: from cryptography.hazmat.primitives.ciphers.base import (
2023-11-10 12:58:10.524 Error: ZigBeeForDomoticZ: File "/usr/local/lib/python3.9/dist-packages/cryptography/hazmat/primitives/ciphers/base.py", line 10, in <module>
2023-11-10 12:58:10.524 Error: ZigBeeForDomoticZ: from cryptography.exceptions import (
2023-11-10 12:58:10.524 Error: ZigBeeForDomoticZ: File "/usr/local/lib/python3.9/dist-packages/cryptography/exceptions.py", line 9, in <module>
2023-11-10 12:58:10.524 Error: ZigBeeForDomoticZ: from cryptography.hazmat.bindings._rust import exceptions as rust_exceptions
2023-11-10 12:58:10.524 Error: ZigBeeForDomoticZ: ImportError: PyO3 modules may only be initialized once per interpreter process
2023-11-10 12:59:19.097 Error: ZigBeeForDomoticZ: [ 70] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2023-11-10 12:59:29.081 Error: ZigBeeForDomoticZ: [ 80] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2023-11-10 12:59:39.063 Error: ZigBeeForDomoticZ: [ 90] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2023-11-10 12:59:49.099 Error: ZigBeeForDomoticZ: [100] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2023-11-10 12:59:59.083 Error: ZigBeeForDomoticZ: [110] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2023-11-10 13:00:09.058 Error: ZigBeeForDomoticZ: [120] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2023-11-10 13:00:10.071 ZigBeeForDomoticZ: URL INFOS {'type': 'command', 'param': 'updatehardware', 'htype': '94', 'idx': 10, 'name': 'ZigBeeForDomoticZ', 'address': '0.0.0.0', 'port': '9999', 'serialport': '/dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20221202180749-if00', 'Mode1': 'ZigpyEZSP', 'Mode2': 'USB', 'Mode3': 'False', 'Mode4': '9440', 'Mode5': 'http://127.0.0.1:8080', 'Mode6': '2', 'extra': 'Zigate', 'enabled': 'true', 'datatimeout': '0', 'loglevel': 7}
2023-11-10 13:00:10.154 ZigBeeForDomoticZ: onStop()
2023-11-10 13:00:10.163 ZigBeeForDomoticZ: logging_thread - ended
2023-11-10 13:00:10.175 ZigBeeForDomoticZ: Logging Thread shutdown
2023-11-10 13:00:10.176 ZigBeeForDomoticZ: onStop called (6) Close Logging Management
2023-11-10 13:00:10.555 ZigBeeForDomoticZ: Worker thread started.
2023-11-10 13:00:14.314 ZigBeeForDomoticZ: load PluginConf
2023-11-10 13:00:14.316 ZigBeeForDomoticZ: Loading PluginConf - from Domoticz sqlite Db
2023-11-10 13:00:14.317 ZigBeeForDomoticZ: /home/vcahen/domoticz/plugins/Domoticz-Zigbee/Conf/PluginConf-10.json timestamp is 1699560358.1342182
2023-11-10 13:00:14.317 ZigBeeForDomoticZ: Dz PluginConf is older than Json Dz: 0 Json: 1699560358.1342182
2023-11-10 13:00:14.320 ZigBeeForDomoticZ: Installing plugin custom page /home/vcahen/domoticz/www/templates/ZigBeeForDomoticZ.html
2023-11-10 13:00:14.327 ZigBeeForDomoticZ: Starting LoggingManagement thread
2023-11-10 13:00:14.327 ZigBeeForDomoticZ: zigpy_login_mode(30)
2023-11-10 13:00:14.331 ZigBeeForDomoticZ: start_logging_thread
2023-11-10 13:00:14.331 ZigBeeForDomoticZ: logging_thread - listening
2023-11-10 13:00:14.402 Status: ZigBeeForDomoticZ: - ZCL Cluster 0008 - (V1) Level loaded
2023-11-10 13:00:14.404 Status: ZigBeeForDomoticZ: - ZCL Cluster 0009 - (V1) Alarms loaded
2023-11-10 13:00:14.406 Status: ZigBeeForDomoticZ: - ZCL Cluster 000a - (V1) Time loaded
2023-11-10 13:00:14.407 Status: ZigBeeForDomoticZ: - ZCL Cluster 000d - (V1) Analog Output loaded
2023-11-10 13:00:14.409 Status: ZigBeeForDomoticZ: - ZCL Cluster 000f - (V1) Binary Input loaded
2023-11-10 13:00:14.411 Status: ZigBeeForDomoticZ: - ZCL Cluster 0013 - (V1) Multistate Output loaded
2023-11-10 13:00:14.413 Status: ZigBeeForDomoticZ: - ZCL Cluster 0019 - (V1) OTA Upgrade loaded
2023-11-10 13:00:14.415 Status: ZigBeeForDomoticZ: - ZCL Cluster 0020 - (V1) Poll Control loaded
2023-11-10 13:00:14.417 Status: ZigBeeForDomoticZ: - ZCL Cluster 0102 - (V1) Window Covering loaded
2023-11-10 13:00:14.418 Status: ZigBeeForDomoticZ: - ZCL Cluster 0202 - (V1) Fan Control loaded
2023-11-10 13:00:14.420 Status: ZigBeeForDomoticZ: - ZCL Cluster 0204 - (V1) Thermostat User Interface Configuration loaded
2023-11-10 13:00:14.422 Status: ZigBeeForDomoticZ: - ZCL Cluster 0300 - (V1) Color Control loaded
2023-11-10 13:00:14.424 Status: ZigBeeForDomoticZ: - ZCL Cluster 0301 - (V1) Ballast Configuration loaded
2023-11-10 13:00:14.426 Status: ZigBeeForDomoticZ: - ZCL Cluster 0400 - (V1) Illuminance Level Sensing loaded
2023-11-10 13:00:14.428 Status: ZigBeeForDomoticZ: - ZCL Cluster 0402 - (V1) Temperature Measurement loaded
2023-11-10 13:00:14.430 Status: ZigBeeForDomoticZ: - ZCL Cluster 0403 - (V1) Pressure Measurement loaded
2023-11-10 13:00:14.432 Status: ZigBeeForDomoticZ: - ZCL Cluster 0405 - (V1) Relative Humidity Measurement loaded
2023-11-10 13:00:14.434 Status: ZigBeeForDomoticZ: - ZCL Cluster 0406 - (V1) Occupancy Sensing loaded
2023-11-10 13:00:14.440 Status: ZigBeeForDomoticZ: - ZCL Cluster 0700 - (V1) Price loaded
2023-11-10 13:00:14.443 Status: ZigBeeForDomoticZ: - ZCL Cluster 0702 - (V1) Metering (Smart Energy) loaded
2023-11-10 13:00:14.446 Status: ZigBeeForDomoticZ: - ZCL Cluster 0b01 - (V1) Meter Identification loaded
2023-11-10 13:00:14.449 Status: ZigBeeForDomoticZ: - ZCL Cluster 0b04 - (V1) Electrical Measurement loaded
2023-11-10 13:00:14.451 Status: ZigBeeForDomoticZ: - ZCL Cluster 0b05 - (V1) Diagnostics loaded
2023-11-10 13:00:14.453 Status: ZigBeeForDomoticZ: - ZCL Cluster e000 - (V1) Tuya E000 Private Cluster loaded
2023-11-10 13:00:14.455 Status: ZigBeeForDomoticZ: - ZCL Cluster e001 - (V1) Tuya E001 Private Cluster loaded
2023-11-10 13:00:14.457 Status: ZigBeeForDomoticZ: - ZCL Cluster e002 - (V1) Tuya E002 Private Cluster loaded
2023-11-10 13:00:14.459 Status: ZigBeeForDomoticZ: - ZCL Cluster fcc0 - (V1) LUMI Private Cluster loaded
2023-11-10 13:00:14.461 Status: ZigBeeForDomoticZ: - ZCL Cluster ff66 - (V1) Lixee Zlinky private cluster loaded
2023-11-10 13:00:14.469 Status: ZigBeeForDomoticZ: DeviceConf loaded - 16 confs loaded
2023-11-10 13:00:14.478 Status: ZigBeeForDomoticZ: Local-Device conf loaded - 21 confs loaded
2023-11-10 13:00:15.140 Status: ZigBeeForDomoticZ: Certified Devices loaded - 530 confs loaded
2023-11-10 13:00:15.142 Status: ZigBeeForDomoticZ: load ListOfDevice
2023-11-10 13:00:15.144 Status: ZigBeeForDomoticZ: 0 Entries loaded from /home/vcahen/domoticz/plugins/Domoticz-Zigbee/Data/DeviceList-10.txt
2023-11-10 13:00:15.173 Status: ZigBeeForDomoticZ: Transport mode: ZigpyEZSP
2023-11-10 13:00:15.151 Error: ZigBeeForDomoticZ: checkListOfDevice2Devices - Lampe salle à manger - 9035eafffe095c52 not found in Plugin Database
2023-11-10 13:00:15.161 Error: ZigBeeForDomoticZ: checkListOfDevice2Devices - ZigBeeForDomoticZ - ZBMINIL2_Voltage-9035eafffe095c52-01 - 9035eafffe095c52 not found in Plugin Database
2023-11-10 13:00:15.492 Error: ZigBeeForDomoticZ: Call to function 'onStart' failed, exception details:
2023-11-10 13:00:15.499 Error: ZigBeeForDomoticZ: Traceback (most recent call last):
2023-11-10 13:00:15.499 Error: ZigBeeForDomoticZ: File "/home/vcahen/domoticz/plugins/Domoticz-Zigbee/plugin.py", line 1563, in onStart
2023-11-10 13:00:15.499 Error: ZigBeeForDomoticZ: _plugin.onStart()
2023-11-10 13:00:15.499 Error: ZigBeeForDomoticZ: File "/home/vcahen/domoticz/plugins/Domoticz-Zigbee/plugin.py", line 631, in onStart
2023-11-10 13:00:15.499 Error: ZigBeeForDomoticZ: from zigpy.config import (CONF_DEVICE, CONF_DEVICE_PATH,
2023-11-10 13:00:15.499 Error: ZigBeeForDomoticZ: File "/usr/local/lib/python3.9/dist-packages/zigpy/config/__init__.py", line 34, in <module>
2023-11-10 13:00:15.499 Error: ZigBeeForDomoticZ: from zigpy.config.validators import (
2023-11-10 13:00:15.499 Error: ZigBeeForDomoticZ: File "/usr/local/lib/python3.9/dist-packages/zigpy/config/validators.py", line 9, in <module>
2023-11-10 13:00:15.499 Error: ZigBeeForDomoticZ: import zigpy.zdo.types as zdo_t
2023-11-10 13:00:15.499 Error: ZigBeeForDomoticZ: File "/usr/local/lib/python3.9/dist-packages/zigpy/zdo/__init__.py", line 10, in <module>
2023-11-10 13:00:15.499 Error: ZigBeeForDomoticZ: import zigpy.util
2023-11-10 13:00:15.499 Error: ZigBeeForDomoticZ: File "/usr/local/lib/python3.9/dist-packages/zigpy/util.py", line 15, in <module>
2023-11-10 13:00:15.499 Error: ZigBeeForDomoticZ: from cryptography.hazmat.primitives.ciphers import Cipher
2023-11-10 13:00:15.499 Error: ZigBeeForDomoticZ: File "/usr/local/lib/python3.9/dist-packages/cryptography/hazmat/primitives/ciphers/__init__.py", line 11, in <module>
2023-11-10 13:00:15.499 Error: ZigBeeForDomoticZ: from cryptography.hazmat.primitives.ciphers.base import (
2023-11-10 13:00:15.499 Error: ZigBeeForDomoticZ: File "/usr/local/lib/python3.9/dist-packages/cryptography/hazmat/primitives/ciphers/base.py", line 10, in <module>
2023-11-10 13:00:15.499 Error: ZigBeeForDomoticZ: from cryptography.exceptions import (
2023-11-10 13:00:15.499 Error: ZigBeeForDomoticZ: File "/usr/local/lib/python3.9/dist-packages/cryptography/exceptions.py", line 9, in <module>
2023-11-10 13:00:15.499 Error: ZigBeeForDomoticZ: from cryptography.hazmat.bindings._rust import exceptions as rust_exceptions
2023-11-10 13:00:15.499 Error: ZigBeeForDomoticZ: ImportError: PyO3 modules may only be initialized once per interpreter process
2023-11-10 13:00:21.856 Zwave: Usage (Unknown)
2023-11-10 13:00:21.867 Zwave: General/kWh (kWh Meter)
2023-11-10 13:00:22.181 Zwave: Light/Switch (Lumière cuisine)
2023-11-10 13:00:22.597 Zwave: Usage (Unknown)
2023-11-10 13:00:22.605 Zwave: General/kWh (kWh Meter)
2023-11-10 13:00:27.517 Zwave: Usage (Unknown)
2023-11-10 13:00:27.522 Zwave: General/kWh (kWh Meter)
2023-11-10 13:00:46.906 Zwave: Thermostat (Radiateur)
2023-11-10 13:00:46.943 Zwave: Temp (Air Temperature)
2023-11-10 13:01:24.069 Error: ZigBeeForDomoticZ: [ 70] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2023-11-10 13:01:34.104 Error: ZigBeeForDomoticZ: [ 80] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2023-11-10 13:01:44.085 Error: ZigBeeForDomoticZ: [ 90] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2023-11-10 13:01:54.062 Error: ZigBeeForDomoticZ: [100] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2023-11-10 13:02:04.095 Error: ZigBeeForDomoticZ: [110] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2023-11-10 13:02:14.077 Error: ZigBeeForDomoticZ: [120] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2023-11-10 13:02:15.091 ZigBeeForDomoticZ: URL INFOS {'type': 'command', 'param': 'updatehardware', 'htype': '94', 'idx': 10, 'name': 'ZigBeeForDomoticZ', 'address': '0.0.0.0', 'port': '9999', 'serialport': '/dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20221202180749-if00', 'Mode1': 'ZigpyEZSP', 'Mode2': 'USB', 'Mode3': 'False', 'Mode4': '9440', 'Mode5': 'http://127.0.0.1:8080', 'Mode6': '2', 'extra': 'Zigate', 'enabled': 'true', 'datatimeout': '0', 'loglevel': 7}
2023-11-10 13:02:15.175 ZigBeeForDomoticZ: onStop()
2023-11-10 13:02:15.189 ZigBeeForDomoticZ: logging_thread - ended
2023-11-10 13:02:15.203 ZigBeeForDomoticZ: Logging Thread shutdown
2023-11-10 13:02:15.203 ZigBeeForDomoticZ: onStop called (6) Close Logging Management
2023-11-10 13:02:15.576 ZigBeeForDomoticZ: Worker thread started.
2023-11-10 13:02:15.093 Status: ZigBeeForDomoticZ: Plugin Restart command : http://127.0.0.1:8080/json.htm?type=command&param=updatehardware&htype=94&idx=10&name=ZigBeeForDomoticZ&address=0.0.0.0&port=9999&serialport=%2Fdev%2Fserial%2Fby-id%2Fusb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20221202180749-if00&Mode1=ZigpyEZSP&Mode2=USB&Mode3=False&Mode4=9440&Mode5=http%3A%2F%2F127.0.0.1%3A8080&Mode6=2&extra=Zigate&enabled=true&datatimeout=0&loglevel=7
2023-11-10 13:02:15.175 Status: ZigBeeForDomoticZ: Stop directive received.
2023-11-10 13:02:15.522 Status: ZigBeeForDomoticZ: Exiting work loop.
2023-11-10 13:02:15.575 Status: ZigBeeForDomoticZ: Stopping threads.
2023-11-10 13:02:15.575 Status: ZigBeeForDomoticZ: Stopped.
2023-11-10 13:02:15.576 Status: ZigBeeForDomoticZ: Entering work loop.
2023-11-10 13:02:15.576 Status: ZigBeeForDomoticZ: Started.
2023-11-10 13:02:17.573 Status: ZigBeeForDomoticZ: Initialized version 7.1, author 'pipiche38'
2023-11-10 13:02:17.578 Status: ZigBeeForDomoticZ: Zigbee for Domoticz plugin starting
2023-11-10 13:02:17.578 Status: ZigBeeForDomoticZ: Z4D plugin requires python3 3.8 or above and you are running 3.9
2023-11-10 13:02:17.578 Status: ZigBeeForDomoticZ: Checking Python modules /home/vcahen/domoticz/plugins/Domoticz-Zigbee/requirements.txt
2023-11-10 13:02:19.331 ZigBeeForDomoticZ: load PluginConf
2023-11-10 13:02:19.333 ZigBeeForDomoticZ: Loading PluginConf - from Domoticz sqlite Db
2023-11-10 13:02:19.334 ZigBeeForDomoticZ: /home/vcahen/domoticz/plugins/Domoticz-Zigbee/Conf/PluginConf-10.json timestamp is 1699560358.1342182
2023-11-10 13:02:19.334 ZigBeeForDomoticZ: Dz PluginConf is older than Json Dz: 0 Json: 1699560358.1342182
2023-11-10 13:02:19.338 ZigBeeForDomoticZ: Installing plugin custom page /home/vcahen/domoticz/www/templates/ZigBeeForDomoticZ.html
2023-11-10 13:02:19.345 ZigBeeForDomoticZ: Starting LoggingManagement thread
2023-11-10 13:02:19.345 ZigBeeForDomoticZ: zigpy_login_mode(30)
2023-11-10 13:02:19.348 ZigBeeForDomoticZ: start_logging_thread
2023-11-10 13:02:19.349 ZigBeeForDomoticZ: logging_thread - listening
2023-11-10 13:02:19.337 Status: ZigBeeForDomoticZ: filename set to /home/vcahen/domoticz/plugins/Domoticz-Zigbee/Conf/PluginConf-10.json
2023-11-10 13:02:19.337 Status: ZigBeeForDomoticZ: pluginHome set to /home/vcahen/domoticz/plugins/Domoticz-Zigbee
2023-11-10 13:02:19.337 Status: ZigBeeForDomoticZ: homedirectory set to /home/vcahen/domoticz/plugins/Domoticz-Zigbee
2023-11-10 13:02:19.337 Status: ZigBeeForDomoticZ: pluginData set to /home/vcahen/domoticz/plugins/Domoticz-Zigbee/Data
2023-11-10 13:02:19.337 Status: ZigBeeForDomoticZ: pluginConfig set to /home/vcahen/domoticz/plugins/Domoticz-Zigbee/Conf
2023-11-10 13:02:19.337 Status: ZigBeeForDomoticZ: pluginOTAFirmware set to /home/vcahen/domoticz/plugins/Domoticz-Zigbee/OTAFirmware
2023-11-10 13:02:19.337 Status: ZigBeeForDomoticZ: pluginReports set to /home/vcahen/domoticz/plugins/Domoticz-Zigbee/Reports
2023-11-10 13:02:19.337 Status: ZigBeeForDomoticZ: pluginWWW set to /home/vcahen/domoticz/plugins/Domoticz-Zigbee/www
2023-11-10 13:02:19.337 Status: ZigBeeForDomoticZ: pluginLogs set to /home/vcahen/domoticz/plugins/Domoticz-Zigbee/Logs
2023-11-10 13:02:19.337 Status: ZigBeeForDomoticZ: expJsonDatabase set to 0
2023-11-10 13:02:19.349 Status: ZigBeeForDomoticZ: Please watch plugin log into /home/vcahen/domoticz/plugins/Domoticz-Zigbee/Logs/PluginZigbee_10.log
2023-11-10 13:02:19.365 Status: ZigBeeForDomoticZ: Zigbee for Domoticz (z4d) plugin stable7-7.1.004 started
2023-11-10 13:02:19.399 Status: ZigBeeForDomoticZ: Loading ZCL Cluster definitions
2023-11-10 13:02:19.405 Status: ZigBeeForDomoticZ: - ZCL Cluster 0000 - (V1) Basic loaded
2023-11-10 13:02:19.407 Status: ZigBeeForDomoticZ: - ZCL Cluster 0001 - (V1) Power loaded
2023-11-10 13:02:19.409 Status: ZigBeeForDomoticZ: - ZCL Cluster 0002 - (V1) Device Temperature Configuration loaded
2023-11-10 13:02:19.410 Status: ZigBeeForDomoticZ: - ZCL Cluster 0003 - (V1) Identify loaded
2023-11-10 13:02:19.412 Status: ZigBeeForDomoticZ: - ZCL Cluster 0004 - (V1) Groups loaded
2023-11-10 13:02:19.414 Status: ZigBeeForDomoticZ: - ZCL Cluster 0005 - (V1) Scenes loaded
2023-11-10 13:02:19.416 Status: ZigBeeForDomoticZ: - ZCL Cluster 0006 - (V1) On/Off loaded
2023-11-10 13:02:19.418 Status: ZigBeeForDomoticZ: - ZCL Cluster 0007 - (V1) On/Off Switch Configuration loaded
2023-11-10 13:02:19.419 Status: ZigBeeForDomoticZ: - ZCL Cluster 0008 - (V1) Level loaded
2023-11-10 13:02:19.421 Status: ZigBeeForDomoticZ: - ZCL Cluster 0009 - (V1) Alarms loaded
2023-11-10 13:02:19.423 Status: ZigBeeForDomoticZ: - ZCL Cluster 000a - (V1) Time loaded
2023-11-10 13:02:19.425 Status: ZigBeeForDomoticZ: - ZCL Cluster 000d - (V1) Analog Output loaded
2023-11-10 13:02:19.427 Status: ZigBeeForDomoticZ: - ZCL Cluster 000f - (V1) Binary Input loaded
2023-11-10 13:02:19.428 Status: ZigBeeForDomoticZ: - ZCL Cluster 0013 - (V1) Multistate Output loaded
2023-11-10 13:02:19.430 Status: ZigBeeForDomoticZ: - ZCL Cluster 0019 - (V1) OTA Upgrade loaded
2023-11-10 13:02:19.432 Status: ZigBeeForDomoticZ: - ZCL Cluster 0020 - (V1) Poll Control loaded
2023-11-10 13:02:19.434 Status: ZigBeeForDomoticZ: - ZCL Cluster 0102 - (V1) Window Covering loaded
2023-11-10 13:02:19.436 Status: ZigBeeForDomoticZ: - ZCL Cluster 0202 - (V1) Fan Control loaded
2023-11-10 13:02:19.438 Status: ZigBeeForDomoticZ: - ZCL Cluster 0204 - (V1) Thermostat User Interface Configuration loaded
2023-11-10 13:02:19.440 Status: ZigBeeForDomoticZ: - ZCL Cluster 0300 - (V1) Color Control loaded
2023-11-10 13:02:19.442 Status: ZigBeeForDomoticZ: - ZCL Cluster 0301 - (V1) Ballast Configuration loaded
2023-11-10 13:02:19.444 Status: ZigBeeForDomoticZ: - ZCL Cluster 0400 - (V1) Illuminance Level Sensing loaded
2023-11-10 13:02:19.446 Status: ZigBeeForDomoticZ: - ZCL Cluster 0402 - (V1) Temperature Measurement loaded
2023-11-10 13:02:19.448 Status: ZigBeeForDomoticZ: - ZCL Cluster 0403 - (V1) Pressure Measurement loaded
2023-11-10 13:02:19.450 Status: ZigBeeForDomoticZ: - ZCL Cluster 0405 - (V1) Relative Humidity Measurement loaded
2023-11-10 13:02:19.452 Status: ZigBeeForDomoticZ: - ZCL Cluster 0406 - (V1) Occupancy Sensing loaded
2023-11-10 13:02:19.458 Status: ZigBeeForDomoticZ: - ZCL Cluster 0700 - (V1) Price loaded
2023-11-10 13:02:19.461 Status: ZigBeeForDomoticZ: - ZCL Cluster 0702 - (V1) Metering (Smart Energy) loaded
2023-11-10 13:02:19.464 Status: ZigBeeForDomoticZ: - ZCL Cluster 0b01 - (V1) Meter Identification loaded
2023-11-10 13:02:19.467 Status: ZigBeeForDomoticZ: - ZCL Cluster 0b04 - (V1) Electrical Measurement loaded
2023-11-10 13:02:19.469 Status: ZigBeeForDomoticZ: - ZCL Cluster 0b05 - (V1) Diagnostics loaded
2023-11-10 13:02:19.471 Status: ZigBeeForDomoticZ: - ZCL Cluster e000 - (V1) Tuya E000 Private Cluster loaded
2023-11-10 13:02:19.473 Status: ZigBeeForDomoticZ: - ZCL Cluster e001 - (V1) Tuya E001 Private Cluster loaded
2023-11-10 13:02:19.474 Status: ZigBeeForDomoticZ: - ZCL Cluster e002 - (V1) Tuya E002 Private Cluster loaded
2023-11-10 13:02:19.476 Status: ZigBeeForDomoticZ: - ZCL Cluster fcc0 - (V1) LUMI Private Cluster loaded
2023-11-10 13:02:19.479 Status: ZigBeeForDomoticZ: - ZCL Cluster ff66 - (V1) Lixee Zlinky private cluster loaded
2023-11-10 13:02:19.486 Status: ZigBeeForDomoticZ: DeviceConf loaded - 16 confs loaded
2023-11-10 13:02:19.496 Status: ZigBeeForDomoticZ: Local-Device conf loaded - 21 confs loaded
2023-11-10 13:02:20.160 Status: ZigBeeForDomoticZ: Certified Devices loaded - 530 confs loaded
2023-11-10 13:02:20.161 Status: ZigBeeForDomoticZ: load ListOfDevice
2023-11-10 13:02:20.163 Status: ZigBeeForDomoticZ: 0 Entries loaded from /home/vcahen/domoticz/plugins/Domoticz-Zigbee/Data/DeviceList-10.txt
2023-11-10 13:02:20.190 Status: ZigBeeForDomoticZ: Transport mode: ZigpyEZSP
2023-11-10 13:02:20.169 Error: ZigBeeForDomoticZ: checkListOfDevice2Devices - Lampe salle à manger - 9035eafffe095c52 not found in Plugin Database
2023-11-10 13:02:20.178 Error: ZigBeeForDomoticZ: checkListOfDevice2Devices - ZigBeeForDomoticZ - ZBMINIL2_Voltage-9035eafffe095c52-01 - 9035eafffe095c52 not found in Plugin Database
2023-11-10 13:02:20.511 Error: ZigBeeForDomoticZ: Call to function 'onStart' failed, exception details:
2023-11-10 13:02:20.518 Error: ZigBeeForDomoticZ: Traceback (most recent call last):
2023-11-10 13:02:20.518 Error: ZigBeeForDomoticZ: File "/home/vcahen/domoticz/plugins/Domoticz-Zigbee/plugin.py", line 1563, in onStart
2023-11-10 13:02:20.518 Error: ZigBeeForDomoticZ: _plugin.onStart()
2023-11-10 13:02:20.518 Error: ZigBeeForDomoticZ: File "/home/vcahen/domoticz/plugins/Domoticz-Zigbee/plugin.py", line 631, in onStart
2023-11-10 13:02:20.518 Error: ZigBeeForDomoticZ: from zigpy.config import (CONF_DEVICE, CONF_DEVICE_PATH,
2023-11-10 13:02:20.518 Error: ZigBeeForDomoticZ: File "/usr/local/lib/python3.9/dist-packages/zigpy/config/__init__.py", line 34, in <module>
2023-11-10 13:02:20.518 Error: ZigBeeForDomoticZ: from zigpy.config.validators import (
2023-11-10 13:02:20.518 Error: ZigBeeForDomoticZ: File "/usr/local/lib/python3.9/dist-packages/zigpy/config/validators.py", line 9, in <module>
2023-11-10 13:02:20.518 Error: ZigBeeForDomoticZ: import zigpy.zdo.types as zdo_t
2023-11-10 13:02:20.518 Error: ZigBeeForDomoticZ: File "/usr/local/lib/python3.9/dist-packages/zigpy/zdo/__init__.py", line 10, in <module>
2023-11-10 13:02:20.518 Error: ZigBeeForDomoticZ: import zigpy.util
2023-11-10 13:02:20.519 Error: ZigBeeForDomoticZ: File "/usr/local/lib/python3.9/dist-packages/zigpy/util.py", line 15, in <module>
2023-11-10 13:02:20.519 Error: ZigBeeForDomoticZ: from cryptography.hazmat.primitives.ciphers import Cipher
2023-11-10 13:02:20.519 Error: ZigBeeForDomoticZ: File "/usr/local/lib/python3.9/dist-packages/cryptography/hazmat/primitives/ciphers/__init__.py", line 11, in <module>
2023-11-10 13:02:20.519 Error: ZigBeeForDomoticZ: from cryptography.hazmat.primitives.ciphers.base import (
2023-11-10 13:02:20.519 Error: ZigBeeForDomoticZ: File "/usr/local/lib/python3.9/dist-packages/cryptography/hazmat/primitives/ciphers/base.py", line 10, in <module>
2023-11-10 13:02:20.519 Error: ZigBeeForDomoticZ: from cryptography.exceptions import (
2023-11-10 13:02:20.519 Error: ZigBeeForDomoticZ: File "/usr/local/lib/python3.9/dist-packages/cryptography/exceptions.py", line 9, in <module>
2023-11-10 13:02:20.519 Error: ZigBeeForDomoticZ: from cryptography.hazmat.bindings._rust import exceptions as rust_exceptions
2023-11-10 13:02:20.519 Error: ZigBeeForDomoticZ: ImportError: PyO3 modules may only be initialized once per interpreter process
2023-11-10 13:03:05.066 Zwave: General/kWh (kWh Meter)
2023-11-10 13:03:29.059 Error: ZigBeeForDomoticZ: [ 70] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
Dernière modification par mysterevince le 19 nov. 2023, 16:28, modifié 2 fois.
Re: Réinstallation
alors une simple recherche sur la FAQ du plugin aurais donné la réponse : https://zigbeefordomoticz.github.io/wik ... er-process
et une recherche google pointe sur ce post là https://www.domoticz.com/forum/viewtopi ... 16#p303598
mysterevince
Re: Réinstallation
Merci, j'avais essayé, mais depuis le répertoire plugin, sans succès.
Ca fonctionne à présent.
Merci encore.
Re: Réinstallation
