J'ai un problème avec cet interrupteur.
Configuration
Rasperry Pi3 B+
Dongle Sonoff E
Interrupteur Lever-Coucher Legrand ref. 6 000 84
PiOS debian 11
Domoticz 2023-2
version Zigbee for Domoticz (z4d) plugin stable7-7.1.007
0ptions debug plugin: Input-Cluster-ZclClusters-Legrand-ZclDecoder
L'inter est appairé correctement et les actions sur "lever" et "coucher" sont détectées dans les logs du plugin.
Par contre aucune action dans Domoticz; ni sur le widget ni dans les logs.
logs du plugin:
2023-12-19 13:51:09,423 INFO :b'Zigbee for Domoticz (z4d) plugin stable7-7.1.007 started'
2023-12-19 13:51:09,457 INFO :b'Plugin Database: DeviceList-3.txt'
2023-12-19 13:51:09,458 INFO :b'Pathname to z4d_certified_devices /usr/local/lib/python3.9/dist-packages/z4d_certified_devices/'
2023-12-19 13:51:09,459 INFO :b'Loading ZCL Cluster definitions'
2023-12-19 13:51:09,464 INFO :b' - ZCL Cluster 0000 - (V1) Basic loaded'
2023-12-19 13:51:09,466 INFO :b' - ZCL Cluster 0001 - (V1) Power loaded'
2023-12-19 13:51:09,468 INFO :b' - ZCL Cluster 0002 - (V1) Device Temperature Configuration loaded'
2023-12-19 13:51:09,470 INFO :b' - ZCL Cluster 0003 - (V1) Identify loaded'
2023-12-19 13:51:09,472 INFO :b' - ZCL Cluster 0004 - (V1) Groups loaded'
2023-12-19 13:51:09,474 INFO :b' - ZCL Cluster 0005 - (V1) Scenes loaded'
2023-12-19 13:51:09,476 INFO :b' - ZCL Cluster 0006 - (V1) On/Off loaded'
2023-12-19 13:51:09,477 INFO :b' - ZCL Cluster 0007 - (V1) On/Off Switch Configuration loaded'
2023-12-19 13:51:09,479 INFO :b' - ZCL Cluster 0008 - (V1) Level loaded'
2023-12-19 13:51:09,481 INFO :b' - ZCL Cluster 0009 - (V1) Alarms loaded'
2023-12-19 13:51:09,483 INFO :b' - ZCL Cluster 000a - (V1) Time loaded'
2023-12-19 13:51:09,488 INFO :b' - ZCL Cluster 000d - (V1) Analog Output loaded'
2023-12-19 13:51:09,490 INFO :b' - ZCL Cluster 000f - (V1) Binary Input loaded'
2023-12-19 13:51:09,492 INFO :b' - ZCL Cluster 0013 - (V1) Multistate Output loaded'
2023-12-19 13:51:09,493 INFO :b' - ZCL Cluster 0019 - (V1) OTA Upgrade loaded'
2023-12-19 13:51:09,495 INFO :b' - ZCL Cluster 0020 - (V1) Poll Control loaded'
2023-12-19 13:51:09,497 INFO :b' - ZCL Cluster 0102 - (V1) Window Covering loaded'
2023-12-19 13:51:09,499 INFO :b' - ZCL Cluster 0202 - (V1) Fan Control loaded'
2023-12-19 13:51:09,501 INFO :b' - ZCL Cluster 0204 - (V1) Thermostat User Interface Configuration loaded'
2023-12-19 13:51:09,504 INFO :b' - ZCL Cluster 0300 - (V1) Color Control loaded'
2023-12-19 13:51:09,506 INFO :b' - ZCL Cluster 0301 - (V1) Ballast Configuration loaded'
2023-12-19 13:51:09,508 INFO :b' - ZCL Cluster 0400 - (V1) Illuminance Level Sensing loaded'
2023-12-19 13:51:09,510 INFO :b' - ZCL Cluster 0402 - (V1) Temperature Measurement loaded'
2023-12-19 13:51:09,513 INFO :b' - ZCL Cluster 0403 - (V1) Pressure Measurement loaded'
2023-12-19 13:51:09,515 INFO :b' - ZCL Cluster 0405 - (V1) Relative Humidity Measurement loaded'
2023-12-19 13:51:09,517 INFO :b' - ZCL Cluster 0406 - (V1) Occupancy Sensing loaded'
2023-12-19 13:51:09,524 INFO :b' - ZCL Cluster 0700 - (V1) Price loaded'
2023-12-19 13:51:09,529 INFO :b' - ZCL Cluster 0702 - (V1) Metering (Smart Energy) loaded'
2023-12-19 13:51:09,531 INFO :b' - ZCL Cluster 0b01 - (V1) Meter Identification loaded'
2023-12-19 13:51:09,535 INFO :b' - ZCL Cluster 0b04 - (V1) Electrical Measurement loaded'
2023-12-19 13:51:09,538 INFO :b' - ZCL Cluster 0b05 - (V1) Diagnostics loaded'
2023-12-19 13:51:09,540 INFO :b' - ZCL Cluster e000 - (V1) Tuya E000 Private Cluster loaded'
2023-12-19 13:51:09,542 INFO :b' - ZCL Cluster e001 - (V1) Tuya E001 Private Cluster loaded'
2023-12-19 13:51:09,544 INFO :b' - ZCL Cluster e002 - (V1) Tuya E002 Private Cluster loaded'
2023-12-19 13:51:09,545 INFO :b' - ZCL Cluster fcc0 - (V1) LUMI Private Cluster loaded'
2023-12-19 13:51:09,548 INFO :b' - ZCL Cluster ff66 - (V1) Lixee Zlinky private cluster loaded'
2023-12-19 13:51:09,556 INFO :b'DeviceConf loaded - 16 confs loaded'
2023-12-19 13:51:09,564 INFO :b'Local-Device conf loaded - 19 confs loaded'
2023-12-19 13:51:10,493 INFO :b'Certified Devices loaded - 537 confs loaded'
2023-12-19 13:51:10,494 INFO :b'load ListOfDevice'
2023-12-19 13:51:10,500 INFO :b'1 Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigbee/Data/DeviceList-3.txt'
2023-12-19 13:51:10,506 INFO :b'Transport mode: ZigpyEZSP'
2023-12-19 13:51:12,808 INFO :b'Start Zigpy Transport on EZSP'
2023-12-19 13:51:12,809 DEBUG :Using selector: EpollSelector
2023-12-19 13:51:12,815 INFO :b'ZigpyTransport: thread_processing_and_sending Thread start.'
2023-12-19 13:51:12,817 INFO :b'Start Web Server connection'
2023-12-19 13:51:12,969 INFO :b'Web backend for Web User Interface started on port: 9440'
2023-12-19 13:51:13,328 INFO :b'Plugin looks to upgrade the Certified Device package'
2023-12-19 13:51:13,956 INFO :b'Started radio ezsp port: /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20230829140200-if00'
2023-12-19 13:51:15,314 INFO :b'Bellows Radio register default Ep'
2023-12-19 13:51:15,326 INFO :b"AppGeneric:initialize auto_form: True force_form: False Class: <class 'Classes.ZigpyTransport.AppBellows.App_bellows'>"
2023-12-19 13:51:15,865 INFO :b"EZSP Configuration {'device': {'path': '/dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20230829140200-if00', 'baudrate': 115200, 'flow_control': None}, 'network': {'channel': 11, 'update_id': 0, 'key_sequence_number': 0, 'tc_address': None, 'tc_link_key': 5a:69:67:42:65:65:41:6c:6c:69:61:6e:63:65:30:39, 'extended_pan_id': None, 'key': None, 'channels': <Channels.CHANNEL_25|CHANNEL_20|CHANNEL_15|CHANNEL_11: 34637824>, 'pan_id': None}, 'ezsp_config': {}, 'topology_scan_enabled': False, 'handle_unknown_devices': True, 'source_routing': False, 'backup_enabled': True, 'backup_period': 1, 'database_path': None, 'max_watchdog_failures': 4, 'additional_endpoints': [], 'ezsp_policies': {}, 'validate_network_settings': False, 'max_concurrent_requests': 8, 'watchdog_enabled': True, 'startup_energy_scan': True, 'topology_scan_skip_coordinator': False, 'topology_scan_period': 240, 'ota': {'ledvance_provider': False, 'salus_provider': False, 'ikea_provider': False, 'inovelli_provider': False, 'remote_providers': [], 'sonoff_provider': False, 'otau_directory': None, 'thirdreality_provider': False}}"
2023-12-19 13:51:15,866 INFO :b'Number of devices recently active in Coordinator = 0'
2023-12-19 13:51:15,895 INFO :b'EZSP Radio manufacturer: None'
2023-12-19 13:51:15,902 INFO :b'EZSP Radio board name: None'
2023-12-19 13:51:15,904 INFO :b'EmberZNet version: 6.10.3.0 build 297'
2023-12-19 13:51:15,904 INFO :b'bellows_extract_versioning_for_plugin Manuf: None Name: None Version: 6.10.3.0 build 297'
2023-12-19 13:51:15,905 INFO :b'Network settings'
2023-12-19 13:51:15,905 INFO :b' Device IEEE: e0:79:8d:ff:fe:9e:f5:a4'
2023-12-19 13:51:15,906 INFO :b' Device NWK: 0x0000'
2023-12-19 13:51:15,907 INFO :b' Network Update Id: 0x0001'
2023-12-19 13:51:15,908 INFO :b' PAN ID: 0x7A3C'
2023-12-19 13:51:15,909 INFO :b' Extended PAN ID: 46:56:0e:6f:3a:8e:f2:24'
2023-12-19 13:51:15,911 INFO :b' Channel: 11'
2023-12-19 13:51:15,917 INFO :b'Untested Zigbee adapter model. If this is a Sonoff USB Dongle E that is a known issue, otherwise please report to the Zigbee for Domoticz team'
2023-12-19 13:51:15,918 INFO :b'Installer Version Number: 6.10.3.0 build 297'
2023-12-19 13:51:15,922 INFO :b'Branch Version: ==> Unknown Silicon Labs <=='
2023-12-19 13:51:15,923 INFO :b'Zigbee Coordinator ieee: e0798dfffe9ef5a4 , short addr: 0000'
2023-12-19 13:51:15,924 INFO :b'Network state UP, PANID: 7a3c extPANID: 0x46560e6f3a8ef224 Channel: 11'
2023-12-19 13:51:27,193 INFO :b'Certified Device package upgrade results'
2023-12-19 13:51:27,194 INFO :b'Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple'
2023-12-19 13:51:27,194 INFO :b'Requirement already satisfied: z4d-certified-devices in /usr/local/lib/python3.9/dist-packages (2.164)'
2023-12-19 13:51:27,195 INFO :b'Collecting z4d-certified-devices'
2023-12-19 13:51:27,195 INFO :b' Using cached https://www.piwheels.org/simple/z4d-certified-devices/z4d_certified_devices-2.164-py3-none-any.whl (359 kB)'
2023-12-19 13:51:27,195 INFO :b' Using cached https://www.piwheels.org/simple/z4d-certified-devices/z4d_certified_devices-2.163-py3-none-any.whl (357 kB)'
2023-12-19 13:51:27,196 INFO :b''
2023-12-19 13:51:27,196 INFO :b'Domoticz Widgets usage is at 1.2 % (252 units free)'
2023-12-19 13:51:36,064 INFO :b'Request Disabling Accepting new Hardware'
2023-12-19 13:51:36,131 INFO :b"PERMIT-TO-JOIN: {'cmd': 'PERMIT-TO-JOIN', 'datas': {'Duration': 0, 'targetRouter': 'FFFC'}, 'NwkId': None, 'TimeStamp': 1702990296.0619507, 'ACKIsDisable': False, 'Sqn': None}"
2023-12-19 13:51:36,135 INFO :b'PERMIT-TO-JOIN: duration: 0 for Radio: ezsp for node: None'
2023-12-19 13:51:36,136 INFO :b'Calling self.app.permit(time_s=0, node=None )'
2023-12-19 13:51:36,164 INFO :b'returning from the self.app.permit(time_s=0, node=None )'
2023-12-19 13:51:41,078 INFO :b'Switch Blue Led On'
2023-12-19 13:51:41,083 INFO :b'coordinator set to Certification : 1/CE -> CE'
2023-12-19 13:51:43,058 INFO :b'ota_scan_folder Following Firmware have been loaded '
2023-12-19 13:51:43,060 INFO :b'Plugin with Zigpy, Coordinator Unknown Silicon Labs firmware 6.10.3.0 build 297 correctly initialized'
2023-12-19 15:35:15,856 INFO :b'Zigbee for Domoticz (z4d) plugin stable7-7.1.007 started'
2023-12-19 15:35:15,899 INFO :b'Plugin Database: DeviceList-3.txt'
2023-12-19 15:35:15,900 INFO :b'Pathname to z4d_certified_devices /usr/local/lib/python3.9/dist-packages/z4d_certified_devices/'
2023-12-19 15:35:15,901 INFO :b'Loading ZCL Cluster definitions'
2023-12-19 15:35:15,909 INFO :b' - ZCL Cluster 0000 - (V1) Basic loaded'
2023-12-19 15:35:15,912 INFO :b' - ZCL Cluster 0001 - (V1) Power loaded'
2023-12-19 15:35:15,915 INFO :b' - ZCL Cluster 0002 - (V1) Device Temperature Configuration loaded'
2023-12-19 15:35:15,918 INFO :b' - ZCL Cluster 0003 - (V1) Identify loaded'
2023-12-19 15:35:15,921 INFO :b' - ZCL Cluster 0004 - (V1) Groups loaded'
2023-12-19 15:35:15,923 INFO :b' - ZCL Cluster 0005 - (V1) Scenes loaded'
2023-12-19 15:35:15,926 INFO :b' - ZCL Cluster 0006 - (V1) On/Off loaded'
2023-12-19 15:35:15,929 INFO :b' - ZCL Cluster 0007 - (V1) On/Off Switch Configuration loaded'
2023-12-19 15:35:15,931 INFO :b' - ZCL Cluster 0008 - (V1) Level loaded'
2023-12-19 15:35:15,933 INFO :b' - ZCL Cluster 0009 - (V1) Alarms loaded'
2023-12-19 15:35:15,935 INFO :b' - ZCL Cluster 000a - (V1) Time loaded'
2023-12-19 15:35:15,937 INFO :b' - ZCL Cluster 000d - (V1) Analog Output loaded'
2023-12-19 15:35:15,939 INFO :b' - ZCL Cluster 000f - (V1) Binary Input loaded'
2023-12-19 15:35:15,941 INFO :b' - ZCL Cluster 0013 - (V1) Multistate Output loaded'
2023-12-19 15:35:15,943 INFO :b' - ZCL Cluster 0019 - (V1) OTA Upgrade loaded'
2023-12-19 15:35:15,946 INFO :b' - ZCL Cluster 0020 - (V1) Poll Control loaded'
2023-12-19 15:35:15,948 INFO :b' - ZCL Cluster 0102 - (V1) Window Covering loaded'
2023-12-19 15:35:15,950 INFO :b' - ZCL Cluster 0202 - (V1) Fan Control loaded'
2023-12-19 15:35:15,953 INFO :b' - ZCL Cluster 0204 - (V1) Thermostat User Interface Configuration loaded'
2023-12-19 15:35:15,955 INFO :b' - ZCL Cluster 0300 - (V1) Color Control loaded'
2023-12-19 15:35:15,959 INFO :b' - ZCL Cluster 0301 - (V1) Ballast Configuration loaded'
2023-12-19 15:35:15,961 INFO :b' - ZCL Cluster 0400 - (V1) Illuminance Level Sensing loaded'
2023-12-19 15:35:15,964 INFO :b' - ZCL Cluster 0402 - (V1) Temperature Measurement loaded'
2023-12-19 15:35:15,966 INFO :b' - ZCL Cluster 0403 - (V1) Pressure Measurement loaded'
2023-12-19 15:35:15,969 INFO :b' - ZCL Cluster 0405 - (V1) Relative Humidity Measurement loaded'
2023-12-19 15:35:15,971 INFO :b' - ZCL Cluster 0406 - (V1) Occupancy Sensing loaded'
2023-12-19 15:35:15,978 INFO :b' - ZCL Cluster 0700 - (V1) Price loaded'
2023-12-19 15:35:15,983 INFO :b' - ZCL Cluster 0702 - (V1) Metering (Smart Energy) loaded'
2023-12-19 15:35:15,986 INFO :b' - ZCL Cluster 0b01 - (V1) Meter Identification loaded'
2023-12-19 15:35:15,990 INFO :b' - ZCL Cluster 0b04 - (V1) Electrical Measurement loaded'
2023-12-19 15:35:15,993 INFO :b' - ZCL Cluster 0b05 - (V1) Diagnostics loaded'
2023-12-19 15:35:15,995 INFO :b' - ZCL Cluster e000 - (V1) Tuya E000 Private Cluster loaded'
2023-12-19 15:35:15,997 INFO :b' - ZCL Cluster e001 - (V1) Tuya E001 Private Cluster loaded'
2023-12-19 15:35:15,999 INFO :b' - ZCL Cluster e002 - (V1) Tuya E002 Private Cluster loaded'
2023-12-19 15:35:16,001 INFO :b' - ZCL Cluster fcc0 - (V1) LUMI Private Cluster loaded'
2023-12-19 15:35:16,005 INFO :b' - ZCL Cluster ff66 - (V1) Lixee Zlinky private cluster loaded'
2023-12-19 15:35:16,013 INFO :b'DeviceConf loaded - 16 confs loaded'
2023-12-19 15:35:16,024 INFO :b'Local-Device conf loaded - 19 confs loaded'
2023-12-19 15:35:17,127 INFO :b'Certified Devices loaded - 537 confs loaded'
2023-12-19 15:35:17,128 INFO :b'load ListOfDevice'
2023-12-19 15:35:17,135 INFO :b'1 Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigbee/Data/DeviceList-3.txt'
2023-12-19 15:35:17,142 INFO :b'Transport mode: ZigpyEZSP'
2023-12-19 15:35:19,520 INFO :b'Start Zigpy Transport on EZSP'
2023-12-19 15:35:19,522 DEBUG :Using selector: EpollSelector
2023-12-19 15:35:19,528 INFO :b'ZigpyTransport: thread_processing_and_sending Thread start.'
2023-12-19 15:35:19,530 INFO :b'Start Web Server connection'
2023-12-19 15:35:19,712 INFO :b'Web backend for Web User Interface started on port: 9440'
2023-12-19 15:35:20,114 INFO :b'Plugin looks to upgrade the Certified Device package'
2023-12-19 15:35:20,876 INFO :b'Started radio ezsp port: /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20230829140200-if00'
2023-12-19 15:35:22,269 INFO :b'Bellows Radio register default Ep'
2023-12-19 15:35:22,282 INFO :b"AppGeneric:initialize auto_form: True force_form: False Class: <class 'Classes.ZigpyTransport.AppBellows.App_bellows'>"
2023-12-19 15:35:22,865 INFO :b"EZSP Configuration {'device': {'path': '/dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20230829140200-if00', 'flow_control': None, 'baudrate': 115200}, 'network': {'channel': 11, 'channels': <Channels.CHANNEL_25|CHANNEL_20|CHANNEL_15|CHANNEL_11: 34637824>, 'key': None, 'tc_link_key': 5a:69:67:42:65:65:41:6c:6c:69:61:6e:63:65:30:39, 'key_sequence_number': 0, 'update_id': 0, 'pan_id': None, 'extended_pan_id': None, 'tc_address': None}, 'ezsp_config': {}, 'topology_scan_enabled': False, 'handle_unknown_devices': True, 'source_routing': False, 'backup_enabled': True, 'backup_period': 1, 'max_concurrent_requests': 8, 'startup_energy_scan': True, 'watchdog_enabled': True, 'additional_endpoints': [], 'ezsp_policies': {}, 'topology_scan_period': 240, 'validate_network_settings': False, 'ota': {'inovelli_provider': False, 'ikea_provider': False, 'remote_providers': [], 'ledvance_provider': False, 'otau_directory': None, 'salus_provider': False, 'sonoff_provider': False, 'thirdreality_provider': False}, 'topology_scan_skip_coordinator': False, 'max_watchdog_failures': 4, 'database_path': None}"
2023-12-19 15:35:22,868 INFO :b'Number of devices recently active in Coordinator = 0'
2023-12-19 15:35:22,905 INFO :b'EZSP Radio manufacturer: None'
2023-12-19 15:35:22,906 INFO :b'EZSP Radio board name: None'
2023-12-19 15:35:22,907 INFO :b'EmberZNet version: 6.10.3.0 build 297'
2023-12-19 15:35:22,909 INFO :b'bellows_extract_versioning_for_plugin Manuf: None Name: None Version: 6.10.3.0 build 297'
2023-12-19 15:35:22,911 INFO :b'Network settings'
2023-12-19 15:35:22,914 INFO :b' Device IEEE: e0:79:8d:ff:fe:9e:f5:a4'
2023-12-19 15:35:22,915 INFO :b' Device NWK: 0x0000'
2023-12-19 15:35:22,916 INFO :b' Network Update Id: 0x0001'
2023-12-19 15:35:22,917 INFO :b' PAN ID: 0x7A3C'
2023-12-19 15:35:22,917 INFO :b' Extended PAN ID: 46:56:0e:6f:3a:8e:f2:24'
2023-12-19 15:35:22,918 INFO :b' Channel: 11'
2023-12-19 15:35:22,921 INFO :b'Untested Zigbee adapter model. If this is a Sonoff USB Dongle E that is a known issue, otherwise please report to the Zigbee for Domoticz team'
2023-12-19 15:35:22,922 INFO :b'Installer Version Number: 6.10.3.0 build 297'
2023-12-19 15:35:22,923 INFO :b'Branch Version: ==> Unknown Silicon Labs <=='
2023-12-19 15:35:22,926 INFO :b'Zigbee Coordinator ieee: e0798dfffe9ef5a4 , short addr: 0000'
2023-12-19 15:35:22,926 INFO :b'Network state UP, PANID: 7a3c extPANID: 0x46560e6f3a8ef224 Channel: 11'
2023-12-19 15:35:34,567 INFO :b'Certified Device package upgrade results'
2023-12-19 15:35:34,568 INFO :b'Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple'
2023-12-19 15:35:34,568 INFO :b'Requirement already satisfied: z4d-certified-devices in /usr/local/lib/python3.9/dist-packages (2.164)'
2023-12-19 15:35:34,568 INFO :b'Collecting z4d-certified-devices'
2023-12-19 15:35:34,569 INFO :b' Using cached https://www.piwheels.org/simple/z4d-certified-devices/z4d_certified_devices-2.164-py3-none-any.whl (359 kB)'
2023-12-19 15:35:34,569 INFO :b' Using cached https://www.piwheels.org/simple/z4d-certified-devices/z4d_certified_devices-2.163-py3-none-any.whl (357 kB)'
2023-12-19 15:35:34,570 INFO :b''
2023-12-19 15:35:34,570 INFO :b'Domoticz Widgets usage is at 1.2 % (252 units free)'
2023-12-19 15:35:43,088 INFO :b'Request Disabling Accepting new Hardware'
2023-12-19 15:35:43,100 INFO :b"PERMIT-TO-JOIN: {'cmd': 'PERMIT-TO-JOIN', 'datas': {'Duration': 0, 'targetRouter': 'FFFC'}, 'NwkId': None, 'TimeStamp': 1702996543.0860734, 'ACKIsDisable': False, 'Sqn': None}"
2023-12-19 15:35:43,106 INFO :b'PERMIT-TO-JOIN: duration: 0 for Radio: ezsp for node: None'
2023-12-19 15:35:43,107 INFO :b'Calling self.app.permit(time_s=0, node=None )'
2023-12-19 15:35:43,135 INFO :b'returning from the self.app.permit(time_s=0, node=None )'
2023-12-19 15:35:48,104 INFO :b'Switch Blue Led On'
2023-12-19 15:35:48,110 INFO :b'coordinator set to Certification : 1/CE -> CE'
2023-12-19 15:35:55,702 INFO :b'ota_scan_folder Following Firmware have been loaded '
2023-12-19 15:35:55,704 INFO :b'Plugin with Zigpy, Coordinator Unknown Silicon Labs firmware 6.10.3.0 build 297 correctly initialized'
2023-12-19 15:36:23,571 INFO :b'Request Accepting new Hardware for 240 seconds '
2023-12-19 15:36:23,608 INFO :b"PERMIT-TO-JOIN: {'cmd': 'PERMIT-TO-JOIN', 'datas': {'Duration': 240, 'targetRouter': 'FFFC'}, 'NwkId': None, 'TimeStamp': 1702996583.5661561, 'ACKIsDisable': False, 'Sqn': None}"
2023-12-19 15:36:23,612 INFO :b'PERMIT-TO-JOIN: duration: 240 for Radio: ezsp for node: None'
2023-12-19 15:36:23,613 INFO :b'Calling self.app.permit(time_s=240, node=None )'
2023-12-19 15:36:23,645 INFO :b'returning from the self.app.permit(time_s=240, node=None )'
2023-12-19 15:37:30,964 INFO :b'--> Adding device 3d48 in self.DevicesInPairingMode'
2023-12-19 15:37:30,972 INFO :b"--> ['3d48']"
2023-12-19 15:37:30,974 INFO :b'[None] NEW OBJECT: 3d48 None'
2023-12-19 15:37:31,032 INFO :b'Decode0042 - 3d48/00 requested manuf code -responding with Manufacturer: 0000'
2023-12-19 15:37:31,561 INFO :b'Decode8046 - Match Descriptor response: SQN: 00 Status: 00 Nwkid: 3d48 Lenght: 00 List: '
2023-12-19 15:37:32,067 INFO :b'[-] NEW OBJECT: 3d48 Active Endpoint Response Ep: 01 LQI: 255'
2023-12-19 15:37:32,073 INFO :b'--> Not full scope'
2023-12-19 15:37:32,080 INFO :b'--> Build list of Attributes'
2023-12-19 15:37:32,086 INFO :b'--> ListOfEp with 0x0000: []'
2023-12-19 15:37:32,088 INFO :b"--> Build list Eps for Cluster Basic ['01']"
2023-12-19 15:37:32,089 INFO :b'Request Basic Manufacturer via Read Attribute request: 0004'
2023-12-19 15:37:32,095 INFO :b'Request Basic Model Name via Read Attribute request: 0005'
2023-12-19 15:37:32,099 INFO :b"EP: {'01': {}} Attributes: [4, 5]"
2023-12-19 15:37:32,109 INFO :b'[-] NEW OBJECT: 3d48 Request Simple Descriptor for Ep: 01'
2023-12-19 15:37:32,120 INFO :b'[-] NEW OBJECT: 3d48 Active Endpoint Response Ep: 01 LQI: 255'
2023-12-19 15:37:32,127 INFO :b'--> Not full scope'
2023-12-19 15:37:32,128 INFO :b'--> Build list of Attributes'
2023-12-19 15:37:32,129 INFO :b'--> ListOfEp with 0x0000: []'
2023-12-19 15:37:32,130 INFO :b"--> Build list Eps for Cluster Basic ['01']"
2023-12-19 15:37:32,131 INFO :b'Request Basic Manufacturer via Read Attribute request: 0004'
2023-12-19 15:37:32,132 INFO :b'Request Basic Model Name via Read Attribute request: 0005'
2023-12-19 15:37:32,132 INFO :b"EP: {'01': {}} Attributes: [4, 5]"
2023-12-19 15:37:32,659 INFO :b'[-] NEW OBJECT: 3d48 Simple Descriptor Response EP: 0x01 LQI: 255'
2023-12-19 15:37:32,666 INFO :b'[-] NEW OBJECT: 3d48 ProfileID 0104'
2023-12-19 15:37:32,668 INFO :b'[-] NEW OBJECT: 3d48 ZDeviceID 0006'
2023-12-19 15:37:32,669 INFO :b'[-] NEW OBJECT: 3d48 Application Version 0001'
2023-12-19 15:37:32,670 INFO :b'[-] NEW OBJECT: 3d48 Cluster IN Count: 05'
2023-12-19 15:37:32,672 INFO :b'[-] NEW OBJECT: 3d48 Cluster In 1: 0000 (Basic)'
2023-12-19 15:37:32,673 INFO :b'[-] NEW OBJECT: 3d48 Cluster In 2: 0003 (Identify)'
2023-12-19 15:37:32,674 INFO :b'[-] NEW OBJECT: 3d48 Cluster In 3: 000f (Binary Input (Basic))'
2023-12-19 15:37:32,676 INFO :b'[-] NEW OBJECT: 3d48 Cluster In 4: 0020 (Poll Control)'
2023-12-19 15:37:32,680 INFO :b'[-] NEW OBJECT: 3d48 Cluster In 5: 0001 (Power Configuration)'
2023-12-19 15:37:32,681 INFO :b'[-] NEW OBJECT: 3d48 Cluster OUT Count: 04'
2023-12-19 15:37:32,682 INFO :b'[-] NEW OBJECT: 3d48 Cluster Out 1: 0005 (Scenes)'
2023-12-19 15:37:32,683 INFO :b'[-] NEW OBJECT: 3d48 Cluster Out 2: 0003 (Identify)'
2023-12-19 15:37:32,684 INFO :b'[-] NEW OBJECT: 3d48 Cluster Out 3: 0000 (Basic)'
2023-12-19 15:37:32,684 INFO :b'[-] NEW OBJECT: 3d48 Cluster Out 4: 0019 (Over-the-Air Upgrade)'
2023-12-19 15:37:33,737 INFO :b'[-] NEW OBJECT: 3d48 Simple Descriptor Response EP: 0x01 LQI: 255'
2023-12-19 15:37:33,739 INFO :b'[-] NEW OBJECT: 3d48 ProfileID 0104'
2023-12-19 15:37:33,740 INFO :b'[-] NEW OBJECT: 3d48 ZDeviceID 0006'
2023-12-19 15:37:33,741 INFO :b'[-] NEW OBJECT: 3d48 Application Version 0001'
2023-12-19 15:37:33,742 INFO :b'[-] NEW OBJECT: 3d48 Cluster IN Count: 05'
2023-12-19 15:37:33,744 INFO :b'[-] NEW OBJECT: 3d48 Cluster In 1: 0000 (Basic)'
2023-12-19 15:37:33,745 INFO :b'[-] NEW OBJECT: 3d48 Cluster In 2: 0003 (Identify)'
2023-12-19 15:37:33,747 INFO :b'[-] NEW OBJECT: 3d48 Cluster In 3: 000f (Binary Input (Basic))'
2023-12-19 15:37:33,748 INFO :b'[-] NEW OBJECT: 3d48 Cluster In 4: 0020 (Poll Control)'
2023-12-19 15:37:33,749 INFO :b'[-] NEW OBJECT: 3d48 Cluster In 5: 0001 (Power Configuration)'
2023-12-19 15:37:33,750 INFO :b'[-] NEW OBJECT: 3d48 Cluster OUT Count: 04'
2023-12-19 15:37:33,751 INFO :b'[-] NEW OBJECT: 3d48 Cluster Out 1: 0005 (Scenes)'
2023-12-19 15:37:33,752 INFO :b'[-] NEW OBJECT: 3d48 Cluster Out 2: 0003 (Identify)'
2023-12-19 15:37:33,753 INFO :b'[-] NEW OBJECT: 3d48 Cluster Out 3: 0000 (Basic)'
2023-12-19 15:37:33,754 INFO :b'[-] NEW OBJECT: 3d48 Cluster Out 4: 0019 (Over-the-Air Upgrade)'
2023-12-19 15:37:34,082 INFO :b'[0] NEW OBJECT: 3d48 Model Name: Remote switch Wake up Sleep'
2023-12-19 15:37:34,106 INFO :b'[0] NEW OBJECT: 3d48 Manufacturer Name: Legrand'
2023-12-19 15:42:22,740 INFO :b'zigbee_receive_message - MsgType: 8002, Data: 00000000130000023d4802000000483dd27e7a000074040080, LQI: 236'
2023-12-19 15:42:26,253 INFO :b'zigbee_receive_message - MsgType: 8002, Data: 00000000130000023d4802000000483dd27e7a000074040080, LQI: 255'
2023-12-19 15:43:08,956 INFO :b'zigbee_receive_message - MsgType: 8002, Data: 00000000130000023d4802000000483dd27e7a000074040080, LQI: 255'
2023-12-19 15:44:15,231 INFO :b'zigbee_receive_message - MsgType: 8002, Data: 00000000130000023d4802000000483dd27e7a000074040080, LQI: 255'
2023-12-19 15:44:20,267 INFO :b'zigbee_receive_message - MsgType: 8002, Data: 00000000130000023d4802000000483dd27e7a000074040080, LQI: 255'
Merci d'avance
Jihem
