[Fermé] Erreur installation sur Raspberry Pi OS Lite
padbol2002
Message par padbol2002 »
J'ai eu a noel une clé ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus
j'ai donc fait les commandes suivantes dans le répertoires du plugin :
git pull
j'obtient
pi@raspberrypi:~/domoticz/plugins/Domoticz-Zigbee $ git pull
hint: Pulling without specifying how to reconcile divergent branches is
hint: discouraged. You can squelch this message by running one of the following
hint: commands sometime before your next pull:
hint:
hint:   git config pull.rebase false  # merge (the default strategy)
hint:   git config pull.rebase true   # rebase
hint:   git config pull.ff only       # fast-forward only
hint:
hint: You can replace "git config" with "git config --global" to set a default
hint: preference for all repositories. You can also pass --rebase, --no-rebase,
hint: or --ff-only on the command line to override the configured default per
hint: invocation.
Updating 25df3399..83653834
error: Your local changes to the following files would be overwritten by merge:
        plugin.py
Please commit your changes or stash them before you merge.
Aborting
et :
Collecting cryptography
  Using cached cryptography-41.0.7.tar.gz (630 kB)
  .....(tout un paquet de ligne rouge)
  creating build/temp.linux-armv7l-cpython-39/src/c
    arm-linux-gnueabihf-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -ffile-prefix-map=/python3.9-3.9.2=.        -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -fPIC -DFFI_BUILDING=1 -DUSE__THREAD -DHAVE_SYNC_SYNCHRONIZE -I/usr/        include/ffi -I/usr/include/libffi -I/usr/include/python3.9 -c src/c/_cffi_backend.c -o build/temp.linux-armv7l-cpython-39/src/c/_cffi_backend        .o
    src/c/_cffi_backend.c:15:10: fatal error: ffi.h: No such file or directory
       15 | #include <ffi.h>
    compilation terminated.
    error: command '/usr/bin/arm-linux-gnueabihf-gcc' failed with exit code 1
    ERROR: Failed building wheel for cffi
  Failed to build cffi
  ERROR: Could not build wheels for cffi which use PEP 517 and cannot be installed directly
WARNING: Discarding https://files.pythonhosted.org/packages/ce/b3/13a12ea7edb068de0f62bac88a8ffd92cc2901881b391839851846b84a81/cryptography-4  1.0.7.tar.gz#sha256=13f93ce9bea8016c253b34afc6bd6a75993e5c40672ed5405a9c832f0d4a00bc (from https://pypi.org/simple/cryptography/) (requires-python:>=3.7). Command errored out with exit status 1:
/usr/bin/python3 /usr/lib/python3/dist-packages/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-qz1306jw/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i https://pypi.org/simple -'setuptools>=61.0.0' wheel 'cffi>=1.12; platform_python_implementation != '"'"'PyPy'"'"'' 'setuptools-rust>=0.11.4' Check the logs for full command output.
j'ai aussi installé rustc :
pi@raspberrypi:~/domoticz/plugins/Domoticz-Zigbee $ rustc --version
rustc 1.75.0 (82e1608df 2023-12-21)
et dans le log domoticz 2023.2 j'ai ceci :
Error: Zigbee: (Zigate) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/Domoticz-Zigbee/:/usr/lib/python39.zip:/usr/lib/python3.9:/usr/lib/python3.9/lib-dynload:/usr/local/lib/python3.9/dist-packages:/usr/lib/python3/dist-packages:/usr/lib/python3.9/dist-packages'.
2023-12-29 12:33:29.339 Error: Zigbee: Traceback (most recent call last):
2023-12-29 12:33:29.340 Error: Zigbee: File "/home/pi/domoticz/plugins/Domoticz-Zigbee/plugin.py", line 113, in <module>
2023-12-29 12:33:29.340 Error: Zigbee: from Classes.WebServer.WebServer import WebServer
2023-12-29 12:33:29.340 Error: Zigbee: File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Classes/WebServer/WebServer.py", line 55, in <module>
2023-12-29 12:33:29.340 Error: Zigbee: class WebServer(object):
2023-12-29 12:33:29.340 Error: Zigbee: File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Classes/WebServer/WebServer.py", line 86, in WebServer
2023-12-29 12:33:29.340 Error: Zigbee: from Classes.WebServer.rest_PluginUpgrade import (
2023-12-29 12:33:29.340 Error: Zigbee: File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Classes/WebServer/rest_PluginUpgrade.py", line 6, in <module>
2023-12-29 12:33:29.340 Error: Zigbee: import z4d_certified_devices
2023-12-29 12:33:29.340 Error: Zigbee: ModuleNotFoundError: No module named 'z4d_certified_devices'
merci pour vos éclaircissements
Dernière modification par Keros le 18 janv. 2024, 20:22, modifié 2 fois.
Raison : Sujet fermé car sans réponses
padbol2002
Re: Erreur au lancement et a la mise a jour
j'ai résolu mon pb de 1ere ligne rouge avec :
sudo apt install libffi-dev
mais j'en obtiens de nouvelles :
  This package requires Rust >=1.56.0.
  ERROR: Failed building wheel for cryptography
pourtant je l'ai (mal?) installé
Plusieurs choses:
1) tu dois voir fait un changement sur le fichier plugin.py, pour y remédier faire la commande suivante depuis le home du plugin
git reset --hard
git pull
2) essayes de faire la commande suivante ( --force ) va re-forcer l'installation
sudo python3 -m pip install -r requirements.txt --upgrade --force
padbol2002
merci pour ta réponse
pour les 2 premières commande pas de soucis.
la dernière idem ...
Capture d'écran 2023-12-29 140251.png (98.3 Kio) Consulté 557 fois
Pour info je viens de voir ceci avec le "sudo en difference"
pi@raspberrypi:~ $ rustc --version
pi@raspberrypi:~ $ sudo rustc --version
sudo: rustc: command not found
tu as installé une version mini de raspbian ?
Tu esbien sur un Bullseye ?
as tu essayé cela:
1.
sudo apt-get install build-essential libssl-dev libffi-dev python-dev
2.
sudo python3 -m pip install wheel --upgrade
3.
sudo python3 -m pip install cryptography==40.0.2 --upgrade`
4.
padbol2002
pi@raspberrypi:~ $ cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
NAME="Raspbian GNU/Linux"
VERSION_ID="11"
VERSION="11 (bullseye)"
VERSION_CODENAME=bullseye
pi@raspberrypi:~ $ uname -m
armv7l
Une version lite oui
padbol2002
Bloqué à la commande 3 :
pi@raspberrypi:~ $ sudo python3 -m pip install cryptography==40.0.2 --upgrade
Collecting cryptography==40.0.2
  Using cached cryptography-40.0.2.tar.gz (625 kB)
  Installing build dependencies ... done
  Getting requirements to build wheel ... done
    Preparing wheel metadata ... done
Collecting cffi>=1.12
  Using cached cffi-1.16.0-cp39-cp39-linux_armv7l.whl
Collecting pycparser
  Using cached pycparser-2.21-py2.py3-none-any.whl (118 kB)
Building wheels for collected packages: cryptography
  Building wheel for cryptography (PEP 517) ... error
  ERROR: Command errored out with exit status 1:
   command: /usr/bin/python3 /tmp/tmpf22y7q0i_in_process.py build_wheel /tmp/tmpmje96_m4
       cwd: /tmp/pip-install-ilz_9oi5/cryptography_bf39643005e044058b8a7b7a70a0f70b
  Complete output (248 lines):
  running bdist_wheel
  running build
  running build_py
  creating build
  creating build/lib.linux-armv7l-cpython-39
  creating build/lib.linux-armv7l-cpython-39/cryptography
  copying src/cryptography/__about__.py -> build/lib.linux-armv7l-cpython-39/cryptography
  copying src/cryptography/exceptions.py -> build/lib.linux-armv7l-cpython-39/cryptography
  copying src/cryptography/fernet.py -> build/lib.linux-armv7l-cpython-39/cryptography
  copying src/cryptography/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptography
  copying src/cryptography/utils.py -> build/lib.linux-armv7l-cpython-39/cryptography
  creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat
  copying src/cryptography/hazmat/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat
  copying src/cryptography/hazmat/_oid.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat
  creating build/lib.linux-armv7l-cpython-39/cryptography/x509
  copying src/cryptography/x509/oid.py -> build/lib.linux-armv7l-cpython-39/cryptography/x509
  copying src/cryptography/x509/extensions.py -> build/lib.linux-armv7l-cpython-39/cryptography/x509
  copying src/cryptography/x509/name.py -> build/lib.linux-armv7l-cpython-39/cryptography/x509
  copying src/cryptography/x509/ocsp.py -> build/lib.linux-armv7l-cpython-39/cryptography/x509
  copying src/cryptography/x509/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptography/x509
  copying src/cryptography/x509/base.py -> build/lib.linux-armv7l-cpython-39/cryptography/x509
  copying src/cryptography/x509/general_name.py -> build/lib.linux-armv7l-cpython-39/cryptography/x509
  copying src/cryptography/x509/certificate_transparency.py -> build/lib.linux-armv7l-cpython-39/cryptography/x509
  creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings
  copying src/cryptography/hazmat/bindings/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings
  creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends
  copying src/cryptography/hazmat/backends/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends
  creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/keywrap.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/hmac.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/cmac.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/constant_time.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/poly1305.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/hashes.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/_asymmetric.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/_serialization.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/_cipheralgorithm.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/padding.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
  creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/openssl
  copying src/cryptography/hazmat/bindings/openssl/_conditional.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/openssl
  copying src/cryptography/hazmat/bindings/openssl/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/openssl
  copying src/cryptography/hazmat/bindings/openssl/binding.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/openssl
  creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/ec.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/ed25519.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/hmac.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/cmac.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/x448.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/poly1305.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/aead.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/hashes.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/dsa.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/ed448.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/rsa.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/dh.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/decode_asn1.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/utils.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/backend.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/ciphers.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
  creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/twofactor
  copying src/cryptography/hazmat/primitives/twofactor/hotp.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/twofactor
  copying src/cryptography/hazmat/primitives/twofactor/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/twofactor
  copying src/cryptography/hazmat/primitives/twofactor/totp.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/twofactor
  creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/serialization
  copying src/cryptography/hazmat/primitives/serialization/pkcs7.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/serialization
  copying src/cryptography/hazmat/primitives/serialization/pkcs12.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/serialization
  copying src/cryptography/hazmat/primitives/serialization/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/serialization
  copying src/cryptography/hazmat/primitives/serialization/base.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/serialization
  copying src/cryptography/hazmat/primitives/serialization/ssh.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/serialization
  creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/kdf
  copying src/cryptography/hazmat/primitives/kdf/kbkdf.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/kdf
  copying src/cryptography/hazmat/primitives/kdf/pbkdf2.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/kdf
  copying src/cryptography/hazmat/primitives/kdf/scrypt.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/kdf
  copying src/cryptography/hazmat/primitives/kdf/concatkdf.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/kdf
  copying src/cryptography/hazmat/primitives/kdf/hkdf.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/kdf
  copying src/cryptography/hazmat/primitives/kdf/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/kdf
  copying src/cryptography/hazmat/primitives/kdf/x963kdf.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/kdf
  creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/ciphers
  copying src/cryptography/hazmat/primitives/ciphers/aead.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/ciphers
  copying src/cryptography/hazmat/primitives/ciphers/algorithms.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/ciphers
  copying src/cryptography/hazmat/primitives/ciphers/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/ciphers
  copying src/cryptography/hazmat/primitives/ciphers/base.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/ciphers
  copying src/cryptography/hazmat/primitives/ciphers/modes.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/ciphers
  creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/ec.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/types.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/ed25519.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/x25519.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/x448.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/dsa.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/ed448.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/rsa.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/dh.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/utils.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/padding.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
  running egg_info
  writing src/cryptography.egg-info/PKG-INFO
  writing dependency_links to src/cryptography.egg-info/dependency_links.txt
  writing requirements to src/cryptography.egg-info/requires.txt
  writing top-level names to src/cryptography.egg-info/top_level.txt
  reading manifest file 'src/cryptography.egg-info/SOURCES.txt'
  reading manifest template 'MANIFEST.in'
  no previously-included directories found matching 'docs/_build'
  warning: no previously-included files found matching 'vectors'
  warning: no previously-included files matching '*' found under directory 'vectors'
  warning: no previously-included files matching '*' found under directory '.github'
  warning: no previously-included files found matching 'release.py'
  warning: no previously-included files found matching '.readthedocs.yml'
  warning: no previously-included files found matching 'ci-constraints-requirements.txt'
  warning: no previously-included files found matching 'mypy.ini'
  adding license file 'LICENSE'
  adding license file 'LICENSE.APACHE'
  adding license file 'LICENSE.BSD'
  adding license file 'LICENSE.PSF'
  writing manifest file 'src/cryptography.egg-info/SOURCES.txt'
  /tmp/pip-build-env-r3dxjh07/overlay/lib/python3.9/site-packages/setuptools/command/build_py.py:207: _Warning: Package 'cryptography.hazmat.bindings._rust' is absent from the `packages` configuration.
          # Package would be ignored #
          Python recognizes 'cryptography.hazmat.bindings._rust' as an importable package[^1],
          but it is absent from setuptools' `packages` configuration.
          This leads to an ambiguous overall configuration. If you want to distribute this
          package, please make sure that 'cryptography.hazmat.bindings._rust' is explicitly added
          to the `packages` configuration field.
          Alternatively, you can also rely on setuptools' discovery methods
          (for example by using `find_namespace_packages(...)`/`find_namespace:`
          instead of `find_packages(...)`/`find:`).
          You can read more about "package discovery" on setuptools documentation page:
          - https://setuptools.pypa.io/en/latest/userguide/package_discovery.html
          If you don't want 'cryptography.hazmat.bindings._rust' to be distributed and are
          already explicitly excluding 'cryptography.hazmat.bindings._rust' via
          `find_namespace_packages(...)/find_namespace` or `find_packages(...)/find`,
          you can try to use `exclude_package_data`, or `include-package-data=False` in
          combination with a more fine grained `package-data` configuration.
          You can read more about "package data files" on setuptools documentation page:
          - https://setuptools.pypa.io/en/latest/userguide/datafiles.html
          [^1]: For Python, any directory (with suitable naming) can be imported,
                even if it does not contain any `.py` files.
                On the other hand, currently there is no concept of package data
                directory, all directories are treated like packages.
    check.warn(importable)
  /tmp/pip-build-env-r3dxjh07/overlay/lib/python3.9/site-packages/setuptools/command/build_py.py:207: _Warning: Package 'cryptography.hazmat.bindings._rust.openssl' is absent from the `packages` configuration.
          Python recognizes 'cryptography.hazmat.bindings._rust.openssl' as an importable package[^1],
          package, please make sure that 'cryptography.hazmat.bindings._rust.openssl' is explicitly added
          If you don't want 'cryptography.hazmat.bindings._rust.openssl' to be distributed and are
          already explicitly excluding 'cryptography.hazmat.bindings._rust.openssl' via
  copying src/cryptography/py.typed -> build/lib.linux-armv7l-cpython-39/cryptography
  creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust
  copying src/cryptography/hazmat/bindings/_rust/__init__.pyi -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust
  copying src/cryptography/hazmat/bindings/_rust/_openssl.pyi -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust
  copying src/cryptography/hazmat/bindings/_rust/asn1.pyi -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust
  copying src/cryptography/hazmat/bindings/_rust/ocsp.pyi -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust
  copying src/cryptography/hazmat/bindings/_rust/pkcs7.pyi -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust
  copying src/cryptography/hazmat/bindings/_rust/x509.pyi -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust
  creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust/openssl
  copying src/cryptography/hazmat/bindings/_rust/openssl/__init__.pyi -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust/openssl
  copying src/cryptography/hazmat/bindings/_rust/openssl/x25519.pyi -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust/openssl
  running build_ext
  running build_rust
  <string>:73: DeprecationWarning: pkg_resources is deprecated as an API. See https://setuptools.pypa.io/en/latest/pkg_resources.html
      =============================DEBUG ASSISTANCE=============================
      If you are seeing a compilation error please try the following steps to
      successfully install cryptography:
      1) Upgrade to the latest pip and try again. This will fix errors for most
         users. See: https://pip.pypa.io/en/stable/installing/#upgrading-pip
      2) Read https://cryptography.io/en/latest/installation/ for specific
         instructions for your platform.
      3) Check our frequently asked questions for more information:
         https://cryptography.io/en/latest/faq/
      4) Ensure you have a recent Rust toolchain installed:
         https://cryptography.io/en/latest/installation/#rust
      Python: 3.9.2
      platform: Linux-6.1.52-v7+-armv7l-with-glibc2.31
      pip: n/a
      setuptools: 69.0.3
      setuptools_rust: 1.8.1
      rustc: n/a
  error: can't find Rust compiler
  If you are using an outdated pip version, it is possible a prebuilt wheel is available for this package but pip is not able to install from it. Installing from the wheel would avoid the need for a Rust compiler.
  To update pip, run:
      pip install --upgrade pip
  and then retry package installation.
  If you did intend to build this package from source, try installing a Rust compiler from your system package manager and ensure it is on the PATH during installation. Alternatively, rustup (available at https://rustup.rs) is the recommended way to download and update the Rust compiler toolchain.
  This package requires Rust >=1.48.0.
Failed to build cryptography
ERROR: Could not build wheels for cryptography which use PEP 517 and cannot be installed directly
pi@raspberrypi:~ $
Voir avec google, mais je sais que la version lite présente le problème de son avantage elle est lite et il manque des paquets
Essaye sudo apt-get install rustc
