[Résolu] Apparreil non optimisé
Puce49
Message par Puce49 »
Bonjour, Appareil Sonoff Capteur porte Rohs ZB-DS01 ayant déjà fonctionné. En changeant de pile, impossible de réappairer cet appareil (Non optimisé) avec message :
{"Nom de fichier » :"DS01.json »,"Configuration » :{"_comment » :" »,"_version » :" »,"_blakadder » : » :" »,"_source » :" »,"ep » :{"01 » :{"0000 » :" »,"0001 » :" »,"0003 » :" »,"0500 » :" »,"type » :"door"}},"type » :" »,"ClusterToBind » :[],"ConfigureReporting » :{},"ReadAttributes » :{"0000 » :["0004 »,"0005"],"0500 » :["0010 »,"0000 »,"0001 »,"0001 »,"0002"]},"Param » :{},"GroupMembership » :{}},"rawInfos » :{"Version » :"3 »,"ZDeviceName » :" »,"Status » :"8043 »,"SQN » :"03 »,"Heartbeat » :"100 »,"RIA » :"5 »,"LQI » :142,"Battery » :{} ,"Model » :"DS01 »,"ForceAckCommands » :
[],"MacCapa » :"80 »,"IEEE » :"00124b002514ce8a »,"Type » :" »,"ProfileID » :"0104 »,"ZDeviceID » :"0402 »,"Version de l’application » :" »,"Liste des attributs » :{},"DeviceType » :"RFD »,"HW Version » :" »,"Last Cmds » :[[39,"02 »,"587b »,"0100 »,"0101050000000010010010"],[40,"02 »,"587b »,"0100 »,"010105000000000003000000010002"],[46,"02 »,"587b »,"0110 »,"01010500000000000010010F000158d0005d2a90e"],[47,"02 »,"587b »,"0100 »,"01010000000000000200040005"],[48,"02 »,"587b »,"0100 »,"0101050000000010010010"],[ « Aucun »,"02 »,"587b »,"0100 »,"01010000000000000200040005"],["Aucun »,"02 »,"587b »,"0110 »,"01010500000000000010010F000158d0005d2a90e"]],"LogicalType » :"Périphérique final »,"Fabricant » :"0000 »,"Nom du fabricant » :"eWeLink »,"NbEp » :"1 »,"PowerSource » :"Batterie »,"ReadAttributes » :{"Ep » :{"01 » :{"0000 » :{"TimeStamp » :1714643469,"iSQN » :{},"Attributes » :{"0004 » :"00 »,"0005 » :"00"},"ZigateRequest » :{}},"0500 » :{"TimeStamp » :1714643469,"iSQN » :{},"Attributes » :{"0010 » :"00 »,"0000 » :"00 », » 0001 » :"00 »,"0002 » :"00"},"ZigateRequest » :{}}}}},"ReceiveOnIdle » :"Off »,"Version de la pile » :" »,"Stamp » :{"time » :1714643928.3313837,"Time » :"2024-05-02 11 :58 :48 »,"MsgType » :"8401 »,"LastSeen » :1714643928},"ZCL Version » :" »,"Health » :"Live »,"Capability » :["Périphérique à fonction réduite »,"Sécurité standard »,"NwkAddr doit être alloué"],"ZDPSQN » :"01 »,"IAS » :{"Auto-Enrollment » :{"Status » :"Enrolled »,"Ep » :{"01 » :{"Status » :"Enrolled »,"ZoneId » :"00"}}},"01 » :{"EnrolledStatus » :1, » ZoneType » :21,"ZoneTypeName » :"contact »,"ZoneStatus » :{"alarm1 » :0,"alarm2 » :0,"tamper » :0,"battery » :0,"Support Reporting » :0,"Restaurer les rapports » :0,"trouble » :0,"acmain » :0,"test » :0,"battdef » :0,"doorbell » :0,"GlobalInfos » :"0 ; 0; 0; 0; 0; 0; 0; 0; 0; 0; 0 »,"TimeStamp » :1714643459}}},"Bind » :{"01 » :{"0500 » :{"Target » :"0000 »,"Stamp » :1714643460,"Phase » :"binded »,"Status » :"00 »,"i_sqn » :42}}},"RollingLQI » :[147,147,147,148,147,147,147,147,142],"IASBattery » :100,"PairingInProgress » :true,"Param » :{"Disabled » :0},"CheckParam » :true,"Epv2 » :{"01 » :{"ProfileID » :"0104 »,"ZDeviceID » :"0402 »,"ClusterIn » :{"0000 » :{},"0003 » :{},"0500 » :{},"0001 » :{}},"ClusterOut » :{"0003 » :{}}}},"ReqEpv2 » :{"01 » :1714643457.556829}, » ZDeviceVersion » :"0000 »,"ConfigSource » :"DeviceConf »,"_rawNodeDescriptor » :"000000a0000a0000000080504002 »,"Taille maximale de la mémoire tampon » :"50 »,"Max Rx » :"00a0 »,"Max Tx » :"00a0 »,"macapa » :"80 »,"bitfield » :"4002 »,"server_mask » :"0000 »,"descriptor_capability » :"00 »,"WriteAttributes » :{"ep » :{"01 » :{"0500 » :{"TimeStamp » :0,"iSQN » :{},"Attributes » :{},"ZigateRequest » :{}}}}},"ep » :{"01 » :{"0000 » :{"0004 » :"eWeLink »,"0005 » :"DS01"},"0001 » :{},"0003 » :{},"0500 » :{"0002 » :"alarm1 : 1, alarm2 : 0, tamper : 0, batterie : 0, Rapport de support : 0, Rapport de restauration : 0, trouble : 0, acmain : 0, test : 0, battdef : 0 »,"0010 » :"00158d0005d2a90e »,"0000 » :"01 »,"0001 » :"0015"},"Type » :"Porte"}}}}
Plusieurs essais réalisés, en vain. Peut être simplement HS? Merci pour votre aide (Débutant)
Dernière modification par Keros le 03 mai 2024, 10:22, modifié 3 fois.
Raison : Ajout les balises pour les logs. Merci de lire la section Bien utiliser le forum
Puce49
Re: Appairage
re-bonjour,
La situation s'est dégardée après mes différents essais :
Mise à jour Raspberry, du Pluging, redémarrage général,
Je ne peux plus appairer mon capteur de porte. une erreur apparait dans le log domoticz au moment du lancement de la procédure d'appairage mais ne sais pas l'interpréter :
2024-05-02 15:33:25.270 Error: Zigate-Module: Something wrong on Device 3f7b 00124b002514ce8a pairing process. (aborting)
2024-05-02 15:33:25.324 Error: Zigate-Module: forwarder_thread - Error while receiving a ZiGate command
2024-05-02 15:33:25.332 Error: Zigate-Module: 'forwarder_thread' failed ''3f7b''
2024-05-02 15:33:25.341 Error: Zigate-Module: ----> Line 35 in '/home/puce49/domoticz/plugins/Domoticz-Zigbee/Classes/ZigateTransport/forwarderThread.py', function forwarder_thread
2024-05-02 15:33:25.350 Error: Zigate-Module: ----> Line 50 in '/home/puce49/domoticz/plugins/Domoticz-Zigbee/Classes/ZigateTransport/instrumentation.py', function f_out
2024-05-02 15:33:25.358 Error: Zigate-Module: ----> Line 59 in '/home/puce49/domoticz/plugins/Domoticz-Zigbee/Classes/ZigateTransport/forwarderThread.py', function forward_message
2024-05-02 15:33:25.367 Error: Zigate-Module: ----> Line 758 in '/home/puce49/domoticz/plugins/Domoticz-Zigbee/plugin.py', function processFrame
2024-05-02 15:33:25.374 Error: Zigate-Module: ----> Line 158 in '/home/puce49/domoticz/plugins/Domoticz-Zigbee/Modules/input.py', function zigbee_receive_message
2024-05-02 15:33:25.381 Error: Zigate-Module: ----> Line 165 in '/home/puce49/domoticz/plugins/Domoticz-Zigbee/Modules/input.py', function _decode_message
2024-05-02 15:33:25.389 Error: Zigate-Module: ----> Line 79 in '/home/puce49/domoticz/plugins/Domoticz-Zigbee/Z4D_decoders/z4d_decoder_IAS.py', function Decode8401
2024-05-02 15:33:25.397 Error: Zigate-Module: handle_error_in_thread
J'avais un autre capteur de même type en stock mais c'est pareil, je n'ose plus trop toucher ne peur de tout casser mon alarme.
Merci de m'éclairer sur le sujet, je ne comprends pas tout sur le débbogage. Pour info, je travaille sur un rasp Pi 3+
Dernière modification par Keros le 03 mai 2024, 10:22, modifié 1 fois.
Modération
Pour info, il y a une section dédiée au plugin ZigBeeForDomoticZ sur le forum, je viens d'y déplacer ton sujet.
Nous avons regroupé dans le sujet [A lire avant de poster] Guide pour bien formuler une demande une première liste d’informations qui nous sont utiles pour commencer à analyser les demandes. En complétant tes informations, nous pourrons t’apporter plus rapidement des réponses pertinentes. Merci.
Puce49
Re: [Résolu] Apparreil non optimisé
J'ai repris la procédure d'appairage ce matin sans avoir arrêter quoique ce soit, tout semble être rentré dans l'ordre . rien compris. Désolé du dérangement. Bon Journée.
