pas d interface web
psytgc
pas d interface web
Message par psytgc »
suite à une coupure de courant et/ou retrait inopinée de la carte sd
domoticz démarre, mais pas d'interface web, j'ai ce message d'erreur.
c'est lié à python
message d erreur :  ./domoticz
2025-01-02 22:48:20.418  Status: Domoticz V2024.7 (c)2012-2024 GizMoCuz
2025-01-02 22:48:20.418  Status: Build Hash: b317cfab1, Date: 2024-07-13 16:59:31
2025-01-02 22:48:20.418  Status: Startup Path: /home/orangepi/domoticz/
2025-01-02 22:48:20.571  Sunrise: 08:52:00 SunSet: 17:27:00
2025-01-02 22:48:20.571  Day length: 08:35:00 Sun at south: 13:10:00
2025-01-02 22:48:20.571  Civil twilight start: 08:17:00 Civil twilight end: 18:03:00
2025-01-02 22:48:20.571  Nautical twilight start: 07:38:00 Nautical twilight end: 18:41:00
2025-01-02 22:48:20.571  Astronomical twilight start: 07:01:00 Astronomical twilight end: 19:18:00
2025-01-02 22:48:20.643  Status: PluginSystem: Started, Python version '3.9.2', 3 plugin definitions loaded.
2025-01-02 22:48:20.657  Active notification Subsystems: (0/13)
2025-01-02 22:48:20.660  Status: WebServer(HTTP) started on address: :: with port 8080
2025-01-02 22:48:20.667  Status: WebServer(SSL) startup failed on address :: with port: 443: bind: Permission denied [system:13 at /usr/local/include/boost/asio/detail/reactive_socket_service.hpp:161 in function 'bind'], trying ::
2025-01-02 22:48:20.671  Status: WebServer(SSL) startup failed on address :: with port: 443: bind: Permission denied [system:13 at /usr/local/include/boost/asio/detail/reactive_socket_service.hpp:161 in function 'bind'], trying 0.0.0.0
2025-01-02 22:48:20.674  Error: WebServer(SSL) startup failed on address 0.0.0.0 with port: 443: bind: Permission denied [system:13 at /usr/local/include/boost/asio/detail/reactive_socket_service.hpp:161 in function 'bind']
2025-01-02 22:48:20.674  Error: WebServer(SSL) check privileges for opening ports below 1024
2025-01-02 22:48:20.675  Status: Camera: settings (re)loaded
2025-01-02 22:48:20.676  Starting shared server on: :::6144
2025-01-02 22:48:20.677  Status: TCPServer: shared server started...
2025-01-02 22:48:20.679  Status: RxQueue: queue worker started...
2025-01-02 22:48:22.679  Status: zigbee: Entering work loop.
2025-01-02 22:48:22.679  zigbee: Worker thread started.
2025-01-02 22:48:22.679  Status: zigbee: Started.
2025-01-02 22:48:22.680  Status: Heos: Worker started...
2025-01-02 22:48:22.681  Status: Heos: 1 players found.
2025-01-02 22:48:22.683  Status: Heos: Connected to: 192.168.44.23:1255
2025-01-02 22:48:22.685  Status: Xiaomi: XiaomiGateway (ID=15): Delaying worker startup...
2025-01-02 22:48:23.683  Status: to HA: Connecting to 192.168.44.169:1883
2025-01-02 22:48:23.685  Status: Mqtt: Connecting to 192.168.44.169:1883
2025-01-02 22:48:23.685  Status: Heos: 1 players found.
2025-01-02 22:48:23.885  Status: to HA: Connected to: 192.168.44.169:1883
2025-01-02 22:48:23.886  Status: Mqtt: Connected to: 192.168.44.169:1883
2025-01-02 22:48:24.696  Status: zigbee: Initialized version 7.1, author 'pipiche38'
Fatal Python error: Segmentation fault
Current thread 0x0000ffffa57f9f70 (most recent call first):
<no Python frame>
2025-01-02 22:48:24.696  Error: Domoticz(pid:2337, tid:2349('zigbee')) received fatal signal 11 (Segmentation fault)
2025-01-02 22:48:24.697  Error: siginfo address=0x3e800000921, address=0xffff90061378
2025-01-02 22:48:24.730  Error: Failed to start gdb, will use backtrace() for printing stack frame
2025-01-02 22:48:24.738  Error: #0  ./domoticz :  + 0x32c3dc [0xaaaabb5ec3dc]
2025-01-02 22:48:24.738  Error: #1  ./domoticz : signal_handler(int, siginfo_t*, void*) + 0x250 [0xaaaabb5ece70]
2025-01-02 22:48:24.738  Error: #2  linux-vdso.so.1 : __kernel_rt_sigreturn + 0 [0xffffb133278c]
2025-01-02 22:48:24.738  Error: #3  /lib/aarch64-linux-gnu/libpthread.so.0 : raise + 0xdc [0xffffb0d677dc]
2025-01-02 22:48:24.738  Error: #4  linux-vdso.so.1 : __kernel_rt_sigreturn + 0 [0xffffb133278c]
2025-01-02 22:48:24.738  Error: #5  /lib/aarch64-linux-gnu/libpython3.9.so : PyDict_GetItem + 0x10 [0xffffafb087e0]
2025-01-02 22:48:24.738  Error: #6  ./domoticz : Plugins::CPlugin::onDeviceModified(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, int) + 0x174 [0xaaaabb9e97bc]
2025-01-02 22:48:24.738  Error: #7  ./domoticz : Plugins::onDeviceModifiedCallback::ProcessLocked(Plugins::CPlugin*) + 0x48 [0xaaaabb9f8ec0]
2025-01-02 22:48:24.738  Error: #8  ./domoticz : Plugins::CPluginMessageBase::Process(Plugins::CPlugin*) + 0x3c [0xaaaabb568154]
2025-01-02 22:48:24.738  Error: #9  ./domoticz : Plugins::CPlugin::Do_Work() + 0x3c4 [0xaaaabb9f6524]
2025-01-02 22:48:24.738  Error: #10 ./domoticz :  + 0x9dbc0c [0xaaaabbc9bc0c]
2025-01-02 22:48:24.738  Error: #11 /lib/aarch64-linux-gnu/libpthread.so.0 :  + 0x7648 [0xffffb0d5b648]
2025-01-02 22:48:24.738  Error: #12 /lib/aarch64-linux-gnu/libc.so.6 :  + 0xd1c9c [0xffffb0bb3c9c]
Erreur de segmentation
Je suis sur un orangepi zero2 (bullseye) avec la dernière version domoticz, j'accède bien en ssh à ma carte sd et j'ai vérifié les updates.
Merci de vos retours
Re: pas d interface web
Fais une image de la carte maintenant pour revenir à cet état au cas où.
Il est possible qu'il y ait un lien avec le plugin zigbee que tu as. Essaye de le désactiver avant le démarrage via la base de donnée de DomoticZ (fait une copie de sauvegarde de la base avant toute modification).
lost
Message par lost »
Avant cela, il y a des erreurs (pb de droits pour un port < 1024) au bind du port 443, pour le https. Pas forcément lié mais probable que domoticz ne soit d'ordinaire pas lancé avec un compte utilisateur simple mais sous root?
Possible que cela enchaîne d'autres pb ensuite avec des dépendances installées en root.
Essaie de lancer domoticz à la main avec et sans un sudo en préfixe.
psytgc
Je n'ai pas réussi à faire une image de ma carte sd sur mac.
je vais essayer sur Windows ce soir, pour la base de données et les backup j'en ai de novembre, mais je vais essayer de prendre les derniers.
Je n'arrive pas à allumer domoticz sans sudo.
Je ne sais pas comment désactiver un plugin en SSH, car je n'ai pas accès à l'interface web ?
Merci pour vos retours
Et Bonne Année aussi
Chrominator
Message par Chrominator »
Si j'avais cette erreur, j'essaierais de mettre à jour le plugin zigbee4domoticz.
https://zigbeefordomoticz.github.io/wiki/fr-fr/Plugin_Mise-a-jour.html#mettre-%C3%A0-jour-le-plugin
Capture d'écran 2025-01-03 145305.png (18.37 Kio) Consulté 1355 fois
RFXtrx433 USB Ver Pro1/1043
Rtl433 RTL-SDR receiver
RFLink Gateway
Zigbee SLZB-06
psytgc
bonsoir
J'ai réussi le backup de la sd
j'ai récup le domoticz db
j'ai essayé la mise à jour du plugin Zigbee mais c'est idem
La j'essaye de mettre un domoticz tout neuf sur une autre rpi en espérant pouvoir récupérer les données de celui planté.
Essaye de désactiver le plugin via une modification dans la base de données de DomoticZ.
