Panne du système
JPJCB66
Panne du système
Message par JPJCB66 »
Bonsoir à toutes et tous,
Depuis qq jours j'ai tout essayé en vain. Et comme je ne suis pas un cador j'appelle au secours.
Tous les onglets de Domoticz fonctionnent et ouvrent les pages concernées.
Mais tous mes contacteurs et températures ont la barre rouge en haut à part deux ou trois interrupt. qui renvoient "Error sending switch command, check device/hardware(idx=xx) !
J'ai donc checké, tout semble normal.
Le log :
2025-04-28 21:20:24.212 Status: User: admin (IP: 192.168.1.27) initiated a switch command (3/Switch Pompe Piscine/Off)
2025-04-28 21:39:51.039 Status: Aeotec: Closed
2025-04-28 21:39:53.046 Status: Aeotec: ZWave: This hardware type is Deprecated! Please try to move to MQTT Auto Discovery and ZWave JS UI
2025-04-28 21:39:53.546 Status: Aeotec: using config in: /home/pi/domoticz/Config/
2025-04-28 21:39:53.554 Status: Aeotec: Starting...
2025-04-28 21:39:53.554 Status: Aeotec: Version: 1.6-1967-g5550fa34
2025-04-28 21:39:53.584 Status: Aeotec: A DNS Error Occurred
2025-04-28 21:39:53.585 Status: Aeotec: ManufacturerSpecificDB Ready
2025-04-28 21:40:05.861 Status: Aeotec: Driver Ready
2025-04-28 21:40:05.912 Status: Aeotec: New Node added. HomeID: 4167047645, NodeID: 67 (0x43)
2025-04-28 21:40:05.913 Status: Aeotec: New Node added. HomeID: 4167047645, NodeID: 68 (0x44)
2025-04-28 21:40:05.913 Status: Aeotec: New Node added. HomeID: 4167047645, NodeID: 69 (0x45)
2025-04-28 21:40:05.914 Status: Aeotec: New Node added. HomeID: 4167047645, NodeID: 73 (0x49)
2025-04-28 21:40:09.065 Status: Aeotec: Received timeout notification from HomeID: 4167047645, NodeID: 48 (0x30)
2025-04-28 21:40:12.139 Status: Aeotec: Received timeout notification from HomeID: 4167047645, NodeID: 53 (0x35)
2025-04-28 21:40:15.141 Status: Aeotec: Received timeout notification from HomeID: 4167047645, NodeID: 58 (0x3a)
2025-04-28 21:40:23.987 Status: Aeotec: Received timeout notification from HomeID: 4167047645, NodeID: 82 (0x52)
2025-04-28 21:40:27.075 Status: Aeotec: Received timeout notification from HomeID: 4167047645, NodeID: 30 (0x1e)
2025-04-28 21:40:40.190 Status: Aeotec: Received timeout notification from HomeID: 4167047645, NodeID: 64 (0x40)
2025-04-28 21:40:43.204 Status: Aeotec: Received timeout notification from HomeID: 4167047645, NodeID: 71 (0x47)
2025-04-28 21:40:46.658 Status: Aeotec: Received timeout notification from HomeID: 4167047645, NodeID: 52 (0x34)
2025-04-28 21:41:31.434 Status: Aeotec: Received timeout notification from HomeID: 4167047645, NodeID: 80 (0x50)
2025-04-28 21:42:03.047 Status: Aeotec: Received timeout notification from HomeID: 4167047645, NodeID: 58 (0x3a)
2025-04-28 21:42:06.052 Status: Aeotec: Received timeout notification from HomeID: 4167047645, NodeID: 58 (0x3a)
2025-04-28 21:42:09.054 Status: Aeotec: Received timeout notification from HomeID: 4167047645, NodeID: 58 (0x3a)
2025-04-28 21:42:12.057 Status: Aeotec: Received timeout notification from HomeID: 4167047645, NodeID: 64 (0x40)
2025-04-28 21:42:15.061 Status: Aeotec: Received timeout notification from HomeID: 4167047645, NodeID: 64 (0x40)
2025-04-28 21:42:18.063 Status: Aeotec: Received timeout notification from HomeID: 4167047645, NodeID: 71 (0x47)
2025-04-28 21:42:18.235 Status: Aeotec: Alarm received (System: Clear), NodeID: 71 (0x47)
2025-04-28 21:42:21.339 Status: Aeotec: Received timeout notification from HomeID: 4167047645, NodeID: 77 (0x4d)
2025-04-28 21:42:21.537 Status: Aeotec: Alarm received (System: Clear), NodeID: 77 (0x4d)
2025-04-28 21:42:22.213 Status: Aeotec: Awake Nodes queried
Quelqu'un peut-m'aider ?
Merci !
JP
Dernière modification par Keros le 29 avr. 2025, 12:30, modifié 1 fois.
Raison : Ajout des balises pour les logs
Contrôleur Z-Stick Gen5, piloté par Domoticz 2022.1 sur Raspberry 2B v1.1 (2015)
5 FGS212/221/222, 1xFGS224, 1 Qubino relay, 4x FGS001, 12 DS18B20 temp sensor, 3x Everspring SM103 Door/Window sensor. 9x capt. 18B20.
Re: Panne du système
Sujet déplacé dans la section Zwave.
