1 modelle repeter avec plus de communication et un autre modelle non optimisé
nico213111
Message par nico213111 »
J'ai des repeters zigbee qui été reconnue comme optimisé en TS0001.
Il s'emblerait que depuis la dernière mise à jour (7.1.023 6.483), il ne communique plus avec la cle sonoff zigbee.
voici les information du fichier
{"Filename":"TS0001.json","Configuration":{"_comment":"","_version":"","_blakadder":"","_source":"","Ep":{"01":{"0000":"","0004":"","0005":"","0006":"","0019":"","e000":"","e001":"","Type":"Switch"}},"Type":"","ClusterToBind":["0019","0006"],"ConfigureReporting":{"0006":{"0000":{"Change":{},"DataType":{},"MaxInterval":{},"MinInterval":{},"TimeOut":"0000"}}},"ReadAttributes":{"0019":[],"0006":["0000","4001","4002"],"0000":["0000","0001","0002","0003","0004","0005","0007"]},"Param":{},"GroupMembership":{}},"rawInfos":{"Version":"3","ZDeviceName":"repeter - piscine","Status":"inDB","SQN":"43","Ep":{"01":{"0000":{"0004":"_TZ3000_n0lphcok","0005":"TS0001","0000":3,"0001":100,"0002":1,"0003":2,"0007":1},"0004":{},"0005":{},"0006":{"4001":0,"4002":0,"0000":"01"},"0019":{},"e000":{},"Type":"Switch","e001":{"d010":0,"d030":2},"ClusterType":{"6762":"Switch"}}},"Heartbeat":"385","RIA":"1","LQI":152,"Battery":{},"Model":"TS0001","ForceAckCommands":[],"MacCapa":"8e","IEEE":"70b3d52b600c074d","Type":"Switch","ProfileID":"0104","ZDeviceID":"0100","App Version":100,"Attributes List":{},"DeviceType":"FFD","HW Version":2,"Last Cmds":[["01","","9551","0104 - 0006","10010203403002"],["01","","9551","0000 - 0021","014d070c602bd5b3700106000384d4c6feff8d79e001"],["02","","9551","0104 - 0006","1002060000001001002c01"],["02","","9551","0000 - 0021","024d070c602bd5b3700106000384d4c6feff8d79e001"],["03","","9551","0104 - 0006","1003060000001001002c01"]],"LogicalType":"Router","Manufacturer":"1002","Manufacturer Name":"_TZ3000_n0lphcok","NbEp":"1","PowerSource":"Main","ReadAttributes":{"Ep":{"01":{"0019":{"TimeStamp":1760783347,"iSQN":{"0000":"1d","0001":"1d","0002":"1d","0003":"1e","0004":"1e","0005":"1e","0006":"1f","0007":"1f","0008":"1f","0009":"20","000a":"20","fffd":"20","fffe":"21"},"Attributes":{},"ZigateRequest":{}},"0006":{"TimeStamp":1761820395,"iSQN":{"4001":"22","4002":"22","4003":"27","0000":"28"},"Attributes":{"4001":"00","4002":"00","4003":"86","0000":"00"},"ZigateRequest":{}},"0000":{"TimeStamp":1761821928,"iSQN":{"0000":"23","0001":"23","0002":"23","0003":"24","0004":"24","0005":"24","0007":"25"},"Attributes":{"0000":"00","0001":"00","0002":"00","0003":"00","0004":"00","0005":"00","0007":"00"},"ZigateRequest":{}}}}},"ReceiveOnIdle":"On","Stack Version":1,"Stamp":{"time":1761821928.2474444,"Time":"2025-10-30 11:58:48","MsgType":"8102","LastSeen":1761821928,"LastPing":1757583540},"ZCL Version":3,"Health":"Not Reachable","descriptor_capability":"00","BindingTable":{"SQN":0,"Status":"Success","TimeStamp":1760783350.6850047,"BindingTableSize":2,"Devices":[{"70b3d52b600c074d":{"sourceEp":"01","Cluster":"0006","targetIEEE":"e0798dfffec6d484","targetNickName":"Zigbee Coordinator","targetEp":"01"}},{"70b3d52b600c074d":{"sourceEp":"01","Cluster":"0019","targetIEEE":"e0798dfffec6d484","targetNickName":"Zigbee Coordinator","targetEp":"01"}}]},"Epv2":{"01":{"ProfileID":"0104","ZDeviceID":"0100","ClusterIn":{"0000":{},"0006":{},"0003":{},"0004":{},"0005":{},"e001":{}},"ClusterOut":{"000a":{}}}},"Max Buffer Size":"6c","RSSI":-57,"Max Rx":"0000","ConfigSource":"DeviceConf","macapa":"8e","Param":{"PowerOnAfterOffOn":2},"ConfigureReporting":{"Ep":{"01":{"0006":{"TimeStamp":1760783347.5978665,"iSQN":{"0000":"03"},"Attributes":{"0000":"01"},"ZigateRequest":{}}}}},"Bind":{"01":{"0019":{"Target":"0000","Stamp":1760783349,"Phase":"binded","Status":"00","i_sqn":"1c"},"0006":{"Target":"0000","Stamp":1761822019,"Phase":"requested","Status":"","i_sqn":"02"}}},"Max Tx":"0000","Tuya":{},"Capability":["Full-Function Device","Main Powered","Receiver during Idle","Standard security","NwkAddr should be allocated"],"_rawNodeDescriptor":"1234000000002c00008e6c4001","CertifiedDevice":true,"bitfield":"4001","WriteAttributes":{"Ep":{"01":{"0000":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0004":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0005":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0006":{"TimeStamp":1761821294,"iSQN":{"4003":"01"},"Attributes":{"4003":"00"},"ZigateRequest":{"4003":{"Status":"requested","DataType":"30","EPin":"01","EPout":"01","manuf_id":"0000","manuf_spec":"00","data":"02","ackIsDisabled":false}}},"0019":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"e000":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"e001":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}}}}},"ReadConfigureReporting":{"Ep":{"01":{"0006":{"0000":{"TimeStamp":1761820638.2397249,"Status":"8b"}}}},"TimeStamp":1761820638.2397108},"server_mask":"2c00","CheckParam":false,"ConsistencyCheck":"ok","ErrorManagement":0,"RollingLQI":[152,152,152],"ZCLSQN":"03","ZDPSQN":"02"}}
de plus je viens d'essayer d'installer un nouveau modelle de repeter et celui-ci est reconnu mais non optimisé.
voici les informations :
{"Filename":"CK-BL702-ROUTER-01(7018).json","Configuration":{"_comment":"","_version":"","_blakadder":"","_source":"","Ep":{"01":{"0000":"","0003":"","e002":"","ef00":"","ee00":"","e000":"","000a":"","0019":"","Type":{}}},"Type":"","ClusterToBind":[],"ConfigureReporting":{},"ReadAttributes":{"0000":["0004","0000","0001","0005","0007"]},"Param":{},"GroupMembership":{}},"rawInfos":{"Version":"3","ZDeviceName":"","Status":"UNKNOW","SQN":"a0","Ep":{"01":{"0000":{},"0003":{},"e002":{},"ef00":{},"ee00":{},"e000":{},"000a":{},"0019":{}}},"Heartbeat":"146","RIA":"4","LQI":255,"Battery":{},"Model":"CK-BL702-ROUTER-01(7018)","ForceAckCommands":[],"MacCapa":"8e","IEEE":"a4c1380f778f8cb1","Type":{},"ProfileID":"0104","ZDeviceID":"0051","App Version":162,"Attributes List":{},"DeviceType":"FFD","HW Version":"","Last Cmds":[["03","","0907","0000 - 0006","030709040101000500"],["04","","0907","0000 - 0005","040709"],["None","","0907","0104 - 0000","10010004000000010005000700feff"],["None","","0907","0104 - 0000","10020004000500"],["05","","0907","0000 - 0004","05070901"],["06","","0907","0000 - 0002","060709"],["07","","0907","0000 - 0002","070709"],["None","","0907","0104 - 000a","189e0107000023560f9630"],["None","","0907","0104 - 000a","189f0107000023560f9630"],["None","","0907","0104 - 000a","18a00107000023570f9630"]],"LogicalType":"Router","Manufacturer":"","Manufacturer Name":"HOBEIAN","NbEp":"1","PowerSource":"Main","ReadAttributes":{"Ep":{"01":{"0000":{"TimeStamp":1761821884,"iSQN":{"0000":"01","0001":"01","0007":"01","fffe":"01","0004":"02","0005":"02"},"Attributes":{"0004":"00","0000":"00","0001":"00","0005":"00","0007":"00","fffe":"86"},"ZigateRequest":{}}}}},"ReceiveOnIdle":"","Stack Version":"","Stamp":{"time":1761821895.1996243,"Time":"2025-10-30 11:58:15","MsgType":"8011","LastSeen":1761821873},"ZCL Version":3,"Health":"Live","Capability":["Full-Function Device","Main Powered","Receiver during Idle","Standard security","NwkAddr should be allocated"],"ZDPSQN":"07","ErrorManagement":0,"PairingInProgress":true,"RSSI":-23,"RollingRSSI":[-24,-24,-24,-23,-23,-23,-23,-23],"RollingLQI":[255,255,255,255,255,255,255,255,255,255],"SQN_000a":"a0","Epv2":{"01":{"ProfileID":"0104","ZDeviceID":"0051","ClusterIn":{"0000":{},"0003":{},"e002":{},"ef00":{},"ee00":{},"e000":{}},"ClusterOut":{"000a":{},"0019":{}}}},"ZCLSQN":"02","ReqEpv2":{"01":1761821884.2095222},"ZDeviceVersion":"0001","ConfigSource":"8043"}}
export.7z
(1.88 Mio) Téléchargé 45 fois
Dernière modification par Keros le 30 oct. 2025, 12:38, modifié 1 fois.
Raison : Ajout des balsies
Re: 1 modelle repeter avec plus de communication et un autre modelle non optimisé
Merci de nous donner les informations demandées dans [A lire avant de poster] Guide pour bien formuler une demande
nico213111
Version de DomoticZ Version: 2025.2 (build 16839)
Version de Python utilisée par DomoticZ (dans Configuration / A propos) Python Version: 3.11.2 (main, Apr 28 2025, 14:11:48) [GCC 12.2.0]
Système sur lequel tourne DomoticZ avec le plugin : armbian
Modèle de coordinateur : Sonoff, s
Version de coordinateur : USB,
Version du firmware : Firmware: UNK - 6.10.3.0 build 297
Version du plugin 7.1.023 [6.484]
Branche du plugin : stable7
Marque de l’équipement sans marque
Modèle de l’équipement
Lien permettant de le commander
Description du fonctionnement attendu, versus comportement observé
nico213111
pour le repeter TS0001 il semble refonctionner après plusieurs manipulations.
Mais ce n'est pas la première fois que j'ai une perte de connection continue malgrés un redémarage de mes devices
errors.json
(146.16 Kio) Téléchargé 45 fois
pas certain de comprendre ce que tu entends pas 'plus de communication' ? une fois qu'il y a eu appairage, si tu veux constater communication ou pas, il faut voir cela avec un sniffer.
Pour ce qui est du fait que ce ne sont pas des modèles optimisés, cela est indépendant de la version du plugin. Donc je suis surpris que tu indiques qu'ils étaient optimisés avant !
je les ai intégré avec la version [6.486] de la base des objets.
nico213111
Désoler pour la réponse tardive
Quand je mentionne ne communique plus, je veux dire que sur la home page du plugin les 3 repeters installé ne passe jamais en mode vivant.
Bon pour l'instant, tout est revenu dans l'ordre. pour les premiers repeter TS0001.
Ce matin j'ai mis a jour le plugin en version 7.1.024 [6.486] et j'ai essayé de testé d'intégrer les nouveaux repeter pour testé les modifications que tu as apporté.
Quand j'e vais dans appairage et que je clique sur le bouton bleu appairer la fenêtre s'ouvre mais le mode appairage en arrière plan en haut a droite ne semble pas s'activer et il ne trouve pas le device.
si j'active le mode appairage manuellement en haut a droite puis clique sur appairer le bouton bleu, le device et reconnu mais aucun rapport n'apparait dans la fenêtre suite à l'appairage.
De plus le device est reconnu comme optimiser mais avec la possibilité d'être supprimé comme si il ne crée pas de devices dans domoticz (peut etre c'est normal pour ce modelé de repeter).
Pour info le TS0001 lui crait un switch dans domoticz( ce switch ne sert a rien).
nico213111 a écrit : 01 nov. 2025, 08:12 Quand j'e vais dans appairage et que je clique sur le bouton bleu appairer la fenêtre s'ouvre mais le mode appairage en arrière plan en haut a droite ne semble pas s'activer et il ne trouve pas le device.
C'est normal. L'ouverture de la fenêtre ne change pas les autres éléments du WebUI.
Ce qu'il nous faut, ce sont les logs de DomoticZ et du plugin lorsque tu tentes l'appairage. C'est ça qu'il faut regarder.
Redonne-nous un export json de tes devices.
