[Resolu] Nouveau capteur de temperature
nico213111
Message par nico213111 »
Je viens d'acheter un nouveau capteur de température.
https://fr.aliexpress.com/item/10050120 ... pt=glo2fra
il est sur batterie
version domoticz 2026.2
version plugin 8.1.005 [8.553]
voici les information du fichier non optimiser :
{"Filename":"Excellux.json","Configuration":{"_comment":"","_version":"","_blakadder":"","_source":"","Ep":{"01":{"1000":"","0000":"","0003":"","ef00":"","0001":"","0402":"","0405":"","Type":"Temp+Hum/Voltage/Temp/Humi"}},"Type":"","ClusterToBind":null,"ConfigureReporting":{},"ReadAttributes":{"0000":[],"0402":[],"0001":[],"0405":[]},"Param":{},"GroupMembership":{}},"rawInfos":{"Version":"3","ZDeviceName":"","Status":"inDB","SQN":"05","Ep":{"01":{"1000":{},"0000":{"0004":"NTCHT01","0005":"Excellux","0000":3,"0001":1,"0007":3},"0003":{},"ef00":{},"0001":{},"0402":{},"0405":{},"ClusterType":{"8207":"Temp+Hum","8208":"Voltage","8209":"Temp","8210":"Humi"}}},"Heartbeat":"9300","RIA":"4","LQI":108,"Battery":{},"Model":"Excellux","ForceAckCommands":[],"MacCapa":"80","IEEE":"a4c138956afcdead","Type":"Voltage/Temp/Humi","ProfileID":"0104","ZDeviceID":"0302","App Version":1,"Attributes List":{},"DeviceType":"RFD","HW Version":"","LogicalType":"End Device","Manufacturer":"1141","Manufacturer Name":"NTCHT01","NbEp":"1","PowerSource":"Battery","ReadAttributes":{"Ep":{"01":{"0000":{"TimeStamp":1781366477,"iSQN":{"0004":"13","0000":"13","0001":"13","0005":"13","0007":"13","fffe":"13"},"Attributes":{},"ZigateRequest":{}},"0402":{"TimeStamp":1781366477,"iSQN":{"0000":"04","0001":"04","0002":"04","0003":"04","fffd":"04","fffe":"04"},"Attributes":{},"ZigateRequest":{}},"0001":{"TimeStamp":1781366477,"iSQN":{"0000":"05","0001":"05","0010":"05","0011":"05","0012":"05","0013":"05","0020":"06","0021":"06","0030":"06","0031":"06","0032":"06","0033":"06","0034":"07","0035":"07","0036":"07","0037":"07","0038":"07","0039":"07","003a":"08","003b":"08","003c":"08","003d":"08","003e":"08","fffd":"08","fffe":"09"},"Attributes":{},"ZigateRequest":{}},"0405":{"TimeStamp":1781366477,"iSQN":{"0000":"0a","0001":"0a","0002":"0a","0003":"0a","fffd":"0a","fffe":"0a"},"Attributes":{},"ZigateRequest":{}}}}},"ReceiveOnIdle":"Off","Stack Version":"","Stamp":{"time":1781367609.3897457,"Time":"2026-06-13 18:20:09","MsgType":"8100","LastSeen":1781367597},"ZCL Version":3,"Health":"Not seen last 24hours","Capability":["Reduced-Function Device","Standard security","NwkAddr should be allocated"],"_rawNodeDescriptor":"1141019401942a0000804a4002","Max Buffer Size":"4a","Max Rx":"0194","Max Tx":"0194","macapa":"80","bitfield":"4002","server_mask":"2a00","descriptor_capability":"00","Epv2":{"01":{"ProfileID":"0104","ZDeviceID":"0302","ClusterIn":{"1000":{},"0000":{},"0003":{},"ef00":{},"0001":{},"0402":{},"0405":{}},"ClusterOut":{"1000":{},"0003":{},"ef00":{}}}},"ConfigSource":"8043","RSSI":-33,"CertifiedDevice":false,"Log_UnknowDeviceFlag":1781391372.073092,"Bind":{"01":{"1000":{"Target":"0000","Stamp":1781366477,"Phase":"requested","Status":"","i_sqn":"07"},"0000":{"Target":"0000","Stamp":1781366477,"Phase":"requested","Status":"","i_sqn":"01"},"0003":{"Target":"0000","Stamp":1781366477,"Phase":"requested","Status":"","i_sqn":"02"},"ef00":{"Target":"0000","Stamp":1781366477,"Phase":"requested","Status":"","i_sqn":"03"},"0001":{"Target":"0000","Stamp":1781366477,"Phase":"requested","Status":"","i_sqn":"04"},"0402":{"Target":"0000","Stamp":1781366477,"Phase":"requested","Status":"","i_sqn":"05"},"0405":{"Target":"0000","Stamp":1781366477,"Phase":"requested","Status":"","i_sqn":"06"}}},"BindingTable":[{"Devices":[],"SQN":0,"Status":"","TimeStamp":1781366477,"Time":1781366477}],"ConfigureReporting":{"Ep":{"01":{"0001":{"TimeStamp":1781366477.1362677,"iSQN":{"0000":"01","0020":"01","0021":"01"},"Attributes":{},"ZigateRequest":{}},"0402":{"TimeStamp":1781366477.137054,"iSQN":{"0000":"02"},"Attributes":{},"ZigateRequest":{}},"0405":{"TimeStamp":1781366477.1375134,"iSQN":{"0000":"03"},"Attributes":{},"ZigateRequest":{}}}}},"ConsistencyCheck":"ok"}}
Merci d'avance pour le retour.
Dernière modification par Keros le 14 juin 2026, 20:56, modifié 1 fois.
Raison : Ajout des balises pour le code. Merci de lire la section Bien utiliser le forum
