plantage domoticz quand je débranche un module prise !
alexbi
Message par alexbi »
Multiple errors received in the last 5 minutes:
2016-12-03 17:20:39.646 Error: OpenZWave: Node has failed (or is not alive), Switch command not sent! (NodeID: 18, 0x12)
2016-12-03 17:20:39.766 Error: OpenZWave: Node has failed (or is not alive), Switch command not sent! (NodeID: 18, 0x12)
2016-12-03 17:20:39.847 Error: OpenZWave: Node has failed (or is not alive), Switch command not sent! (NodeID: 18, 0x12)
2016-12-03 17:20:41.450 Error: OpenZWave: Node has failed (or is not alive), Switch command not sent! (NodeID: 18, 0x12)
2016-12-03 17:20:41.571 Error: OpenZWave: Node has failed (or is not alive), Switch command not sent! (NodeID: 18, 0x12)
2016-12-03 17:20:41.652 Error: OpenZWave: Node has failed (or is not alive), Switch command not sent! (NodeID: 18, 0x12)
2016-12-03 17:20:43.255 Error: OpenZWave: Node has failed (or is not alive), Switch command not sent! (NodeID: 18, 0x12)
2016-12-03 17:20:43.336 Error: OpenZWave: Node has failed (or is not alive), Switch command not sent! (NodeID: 18, 0x12)
2016-12-03 17:20:43.418 Error: OpenZWave: Node has failed (or is not alive), Switch command not sent! (NodeID: 18, 0x12)
2016-12-03 17:20:44.821 Error: OpenZWave: Node has failed (or is not alive), Switch command not sent! (NodeID: 18, 0x12)
2016-12-03 17:20:44.902 Error: OpenZWave: Node has failed (or is not alive), Switch command not sent! (NodeID: 18, 0x12)
2016-12-03 17:20:45.022 Error: OpenZWave: Node has failed (or is not alive), Switch command not sent! (NodeID: 18, 0x12)
2016-12-03 17:20:45.103 Error: OpenZWave: Node has failed (or is not alive), Switch command not sent! (NodeID: 18, 0x12)
2016-12-03 17:20:45.184 Error: OpenZWave: Node has failed (or is not alive), Switch command not sent! (NodeID: 18, 0x12)
2016-12-03 17:20:45.266 Error: OpenZWave: Node has failed (or is not alive), Switch command not sent! (NodeID: 18, 0x12)
2016-12-03 17:20:45.387 Error: OpenZWave: Node has failed (or is not alive), Switch command not sent! (NodeID: 18, 0x12)
2016-12-03 17:20:50.120 Error: OpenZWave: Node has failed (or is not alive), Switch command not sent! (NodeID: 18, 0x12)
2016-12-03 17:20:50.241 Error: OpenZWave: Node has failed (or is not alive), Switch command not sent! (NodeID: 18, 0x12)
2016-12-03 17:20:50.321 Error: OpenZWave: Node has failed (or is not alive), Switch command not sent! (NodeID: 18, 0x12)
2016-12-03 17:20:50.402 Error: OpenZWave: Node has failed (or is not alive), Switch command not sent! (NodeID: 18, 0x12)
2016-12-03 17:20:50.483 Error: OpenZWave: Node has failed (or is not alive), Switch command not sent! (NodeID: 18, 0x12)
2016-12-03 17:20:50.604 Error: OpenZWave: Node has failed (or is not alive), Switch command not sent! (NodeID: 18, 0x12)
2016-12-03 17:20:54.130 Error: OpenZWave: Node has failed (or is not alive), Switch command not sent! (NodeID: 18, 0x12)
2016-12-03 17:21:00.139 Error: OpenZWave: Node has failed (or is not alive), Switch command not sent! (NodeID: 18, 0x12)
2016-12-03 17:21:00.220 Error: OpenZWave: Node has failed (or is not alive), Switch command not sent! (NodeID: 18, 0x12)
de ce que j'ai compris :
j'ai debranché une prise Everspring AN157 Plug-in Appliance Module
je l'utilise dans un script LUA qui s'active lorsqu'il y a dans ma cuisine du mouvement ou luminosité supérieur a xxx. J'ai débranché la prise j'ai quitté mon domicile et lorsque je suis revenue chez moi domoticz avait planté et j'avais les messages d'erreur plus haut.
le plantage semble due au faite que domoticz cherche a activé ma prise mais vu qu'elle est debranché il n'y arrive pas.
mon chauffage electrique est géré par domoticz !!! vous avez une idée pour résoudre ce problème avant que ma femme ne me tombe dessus ???
merci pour votre aide
alexbi
Re: plantage domoticz quand je débranche un module prise !
pas d'idées ? :?
