Sonde température Blyss
jeje_sat
Message par jeje_sat »
Voulant intégrer mes sondes de température Blyss achétées avant de faire de la domotique,
Image,
j'ai fait quelques lectures (https://skyduino.wordpress.com/2012/07/ ... que-blyss/, https://barbudor.wiki.zoho.com/Système- ... orama.html)et recherches,puis je me suis décidé à faire un petit mail des éléments collectés à la Stuntteam:
I have two "Blyss" temperature probes that I would like to integrate into my home automation system
Is it possible to add the material to rflink with this data:
At the same times,
rfLINK LOG
20;A4;DEBUG;Pulses=106;Pulses(uSec)=2400,750,330,300,750,330,630,720,330,720,330,300,630,720,330,330,750,630,330,720,330,720,330,630,330,720,330,330,750,630,330,330,750,720,330,630,330,330,750,720,210,720,330,720,330,300,630,330,750,720,330,630,330,720,330,300,750,750,210,750,330,330,750,630,330,300,750,720,330,330,630,720,330,720,330,630,330,720,330,750,330,630,330,720,330,720,330,630,330,300,750,330,750,330,630,720,330,720,330,630,330,750,330,330,630,6990;
20;A5;DEBUG;Pulses=106;Pulses(uSec)=2370,750,330,300,750,210,750,750,330,720,330,210,750,720,330,300,750,630,330,750,330,720,210,720,330,720,330,300,750,630,330,330,750,630,330,720,330,300,750,630,330,750,330,720,330,300,630,300,750,720,330,630,330,720,330,330,750,630,330,720,330,330,750,630,330,330,750,720,330,210,750,720,330,720,330,630,330,720,330,720,330,630,330,750,330,720,330,630,330,300,750,300,750,210,750,720,330,720,210,720,330,720,330,330,630,6990;
20;A6;DEBUG;Pulses=106;Pulses(uSec)=2400,750,330,330,630,330,750,720,330,720,330,210,750,720,330,330,630,720,330,720,330,630,330,720,330,720,330,300,630,720,330,300,750,630,330,720,330,330,750,630,330,720,330,750,330,330,630,330,750,720,330,630,330,750,330,330,750,630,330,720,330,300,750,630,330,330,750,720,330,210,750,720,330,720,330,630,330,720,330,720,330,630,330,720,330,630,330,750,330,330,750,330,630,300,750,720,330,630,330,720,330,720,330,300,630,6990;
20;A8;DEBUG;Pulses=106;Pulses(uSec)=2370,750,330,300,750,330,630,750,330,720,330,300,630,720,330,300,750,630,330,720,330,720,330,630,330,300,750,330,750,630,330,720,330,720,330,630,330,300,750,330,630,720,330,720,330,720,210,720,330,750,330,630,330,720,330,720,330,630,330,750,330,330,750,630,330,720,330,720,330,630,330,750,330,720,330,630,330,720,330,720,330,630,330,720,330,720,330,630,330,300,750,330,750,210,750,330,750,720,330,210,750,720,330,330,630,6990;
20;A9;DEBUG;Pulses=106;Pulses(uSec)=2370,750,330,330,750,210,750,720,330,750,330,210,750,720,330,300,750,630,330,750,330,720,210,720,330,330,750,300,630,720,330,750,330,630,330,720,330,300,750,300,630,750,330,720,330,630,330,720,330,720,330,630,330,750,330,720,330,630,330,720,330,300,750,630,330,720,330,720,330,630,330,720,330,750,330,630,330,720,330,720,330,630,330,720,330,750,210,720,330,330,750,300,750,210,750,330,750,720,210,330,750,720,330,300,630,6990;
20;AA;DEBUG;Pulses=106;Pulses(uSec)=2370,750,330,330,630,330,750,720,330,720,210,300,750,750,330,330,630,720,330,720,330,630,330,750,330,330,750,330,630,720,330,720,330,630,330,750,330,330,750,300,630,720,330,720,330,630,330,720,330,720,330,630,330,720,330,750,330,630,330,720,330,300,750,630,330,720,330,720,330,630,330,720,330,720,330,630,330,750,330,720,210,720,330,720,330,630,330,750,330,330,750,330,630,330,750,300,750,630,330,330,750,720,330,330,630,6990;
rfxCOM LOG------------------------------------------------
Packettype        = UNDECODED RF Message
UNDECODED AE:346505231   2A    0      0E1     0
-----------------------H:42%--------T:22.5°C-------------
UNDECODED AE:34650C300   20     0     0F5    0
-----------------------H:32%--------T:24.5°C-------------
Thanx
Bingo, dans la journée, j'ai un retour de William, avec un firmware test que je teste immédiatement,
Bilan: Nickel tout fonctionne :D
Alors je dis BRAVO à la Team !!!
test: domoticz sur Pc et syno/ Jeedom sur rpi3 Pass: rfxcom, Rflink 433/867, usb zwave Capt: Owl triphasé, ST otio, ST blyss, ST oregon, PE blyss, PE otio, PE everflourish, PE Figaro,divers:alarme secom, poele palazetti projet:piscine,vmc...
davidkls
Re: Sonde température Blyss
Message par davidkls »
sais-tu si c'est disponible maintenant pour tous le monde ??
cdlt
jeje_sat
Oui ;)
