Check here: http://www.nemcon.nl/blog2/
R46: (10/03/2017)
- New Device: Applidom DM82 motion sensor
- New Device: OWL Intuition PV / CM180i
- New Device: WH2A temperature sensors
- New Device: WH1285 TX (WH-5) Temp & Humidity sensor
- New Device: ABB lightswitch type 3299a-11900 (a.k.a. TX Tango) (Receive only!)
- New Device: Velleman VM130T Motor control
- New Device: HRC 101 Motor control
- New Device: AC512-02 AC to RF projection screen trigger
- New Device: 2 new Dooya protocol flavors
- New Device: D-YA / Diya Motor control
- New Device: Konx doorbell model 602 (Receive only!)
- New Device: Doorman doorbell (Receive only!)
- New Device: Acurite 3in1 3N1TXR / 3N1TXC (Thanks: JR)
- New Device: Byron BY532E (Receive only!)
- New Device: Stagnoli remotes
- New Device: Blyss temperature sensors (Ref.630467) (Thanks: JD)
- New Device: Grundig QH-831A 2010525 & Quhwa QH-831A doorbell
- New Device: 868mhz: Woonveilig security sensors
- New Device: 868mhz: Egardia security sensors
- New Device: 868mhz: Alecto WS3900
- New Device: Yale HSA3000/6000 alarm system sensors
- New Device: Sartano 50080 (Harald Nyborg 2794) switch set
- New Device: Astrell 85 portal motorization system
- New Device: Philips AJ7010/12
- New Feature: Learn RF device signals that use a standard EV1527/PT2262 protocol
- Fixed: Some small eeprom handling issues
- Fixed: Improved AI protocol priority handling
- Fixed: various CC2500 issues, make sure pin 6 is wired to ground to use CC2500!
- Fixed: Tightened Warema EWFS detection
- Fixed: RTSlongTX command
- Fixed: ON/OFF vs UP/DOWN command handling
- Fixed: UPM Esic extended packet detection and increased sanity checks on data
- Fixed: Optimized Novatys timing
- Fixed: AlectoV3 Humidity value validation
- Fixed: FineOffset vs Alecto improved differentiation, Note: device ID's have changed for WS1100
- Fixed: Alecto WS-1100 humidity
- Fixed: AlectoV4 Some packets contained an invalid temperature
- Fixed: Globaltronics GT-WT-02 negative temperature/channel number mixup
- Fixed: Globaltronics GT-WT-02 now always reporting a humidity
- Fixed: Tristate send, removed debug message and fixed a timing bug
- Fixed: WS7000 rain reporting
- Fixed: Added additional Brel protocol variant
- Fixed: LightwaveRF turned MOOD commands into regular switch commands so any home automation software can use them
- Fixed: Improved Friedland doorbell signal detection
- Fixed: Acurite 5in1 corrected wind speed, wind direction and rainfall values (Thanks: Xztraz.)
- Fixed: Improved AcuRite 00592TXR detection
- Fixed: Tunex zero humidity value
- Fixed: Improved Home Confort transmit routine and added up/down support (Thanks: Geert)
- Fixed: Battery detection in Prologue protocol
- Fixed: Added channel number to device ID for THGR810
- Fixed: Added channel number support to Warema devices
- Fixed: Improved UPM ESIC protocol detection
- Fixed: Improved SA33 detection
- Fixed: Gaposa protocol timing
- Added: battery status on various Alecto/Maplin devices (Thanks: Ad)
- Added: Hardware & Software configuration via i/o pins:
pin 6 to ground for: CC2500 enable
pin 7 to ground for: disable internal pull-up on RF data in
pin 12 to ground for: reset of EEPROM settings
New RFLink firmware (R46) now available!
Re: New RFLink firmware (R46) now available!
Good news! Thank you very much for your improvements.
I test it asap !
Envoyé de mon SM-G900F en utilisant Tapatalk
I test it asap !
Maitre: Raspberry 2 + Touchscreen (interface DIY en cours) + Domoticz + RFLink 433MHz
Esclave: Volets roulants SOMFY / VMC (à venir) / Lumière extérieur auto (à venir)
Nice as always !
Thanks.
Thanks.
