J'ai du faire une reinstall du pi et j'ai suivi la page : https://easydomoticz.com/domotique-comm ... ux-debian/
tout est ok, juste la partie connexion ssh qui merde :
As of the November 2016 release, Raspbian has the SSH server disabled by default. You will have to enable it manually. This is done using raspi-config:
Enter sudo raspi-config in the terminal, first select Interfacing options, then navigate to ssh, press Enter and select Enable or disable ssh server.
For headless setup, SSH can be enabled by placing a file named 'ssh', without any extension, onto the boot partition of the SD card.
