[Résolu] Crash Domoticz depuis quelques jours
adv
Message par adv »
Salut la communauté :D
Depuis quelques jours mon Domoticz plante, le service passe en "active (exited)" au lieu de "active (running)".
Ce soir j'ai activé l’écriture des logs et patatrac il a planté encore une fois, juste après un événement relatif au téléinfo.
2017-04-13 21:38:52.556  (Teleinfo) General/kWh (Teleinfo kWh Heures Creuses)
2017-04-13 21:38:52.559  (Teleinfo) General/kWh (Teleinfo kWh Heures Pleines)
2017-04-13 21:38:52.561  (Teleinfo) P1 Smart Meter (EDF)
2017-04-13 21:38:52.579  (Teleinfo) Current (Teleinfo Courant)
2017-04-13 21:38:52.581  (Teleinfo) General/Percentage (Teleinfo Pourcentage de Charge)
2017-04-13 21:38:52.983  (RFXcom) Temp + Humidity (Garage)
2017-04-13 21:38:54.934  Hardware Monitor: Fetching data (System sensors)
2017-04-13 21:39:00.445  LUA: Lancement du check a 21h39
2017-04-13 21:39:06.938  (RFXcom) Temp (Congelateur)
2017-04-13 21:39:24.988  Hardware Monitor: Fetching data (System sensors)
2017-04-13 21:39:24.978  (RFXcom) Temp + Humidity (Exterieur)
2017-04-13 21:39:31.984  (RFXcom) Temp + Humidity (Garage)
2017-04-13 21:39:47.938  (RFXcom) Temp (Congelateur)
2017-04-13 21:39:55.056  Hardware Monitor: Fetching data (System sensors)
2017-04-13 21:40:00.392  Error: Teleinfo hardware (4) nothing received for more than 1 Minute!....
2017-04-13 21:40:00.484  LUA: Lancement du check a 21h40
2017-04-13 21:40:00.842  (Teleinfo) General/kWh (Teleinfo kWh Heures Creuses)
2017-04-13 21:40:00.846  (Teleinfo) General/kWh (Teleinfo kWh Heures Pleines)
2017-04-13 21:40:01.393  Error: Restarting: Teleinfo
2017-04-13 21:40:01.536  (Teleinfo) Teleinfo device uses serial port: /dev/ttyUSB1 at 1200 bauds
2017-04-13 21:40:01.540  (Teleinfo) CRC checks will be performed on incoming data
2017-04-13 21:40:03.538  Error: Domoticz received fatal signal 11 !...
2017-04-13 21:40:03.543  Error:   /home/pi/domoticz/domoticz() [0x1c2798]
2017-04-13 21:40:03.543  Error:   /home/pi/domoticz/domoticz(_Z14signal_handleri+0x58) [0x1c2850]
2017-04-13 21:40:03.543  Error:   /lib/arm-linux-gnueabihf/libc.so.6(__default_sa_restorer_v2+0) [0x76a50180]
Je sais pas si vous avez remarqué mais faut dire que y'a l'air d'y avoir eu pas mal d'évolutions au niveau Téléinfo récemment (rendez vous dans dispositif pour vous en rendre compte !).
Allez je suis les log encore quelques jours il est encore trop tôt pour conclure ;)
Idem chez vous ?!
Est ce que le développeur du module logiciel "Téléinfo" (franco-français) habite sur ce forum ?
Bonne soirée à tous. :)
EDIT: je suis en beta 7320 après la rédaction de ce post, j'étais en 7310 avant...
EDIT2: j'ai aussi remarqué qu'après le redémarrage de domoticz (update ou redémarrage manuel) la conso instantanée apparaît en double un court moment... huummm (screenshot joint), je crois que je vais repasser en stable moi... :lol:
double conso instantanée.png (16.56 Kio) Consulté 3180 fois
Dernière modification par adv le 18 avr. 2017, 15:05, modifié 1 fois.
adv
Re: Crash Domoticz depuis quelques jours
Message par adv »
Salut ! ;)
Bon baaaaa plus de plantage depuis plusieurs jours, plus d’erreurs bizarroïdes dans les LOGs.
J'ai désactivé le "Délai d'attente des données" que j'avais positionné à 1 minutes pour redémarrer le port USB en cas de perte de comm avec mon module téléinfo :mrgreen:
J'ai quand même posté le bug de double affichage -> https://github.com/domoticz/domoticz/issues/1470
Bonne journée à tous (et aux autres aussi ^^)
