Error: Webserver: File '/BasicDeviceDescription.xml': No such file or directory (2)
ciberyan
Message par ciberyan »
Bonjour à tous
Merci de ce forum ou je trouve plein de solutions à mes problemes mais là, je ne vois pas
J'ai cette erreur 2 fois par jour, quelqu'un sait il ce que cela veut dire ??
Merci de votre aide
Doudy
Re: Error: Webserver: File '/BasicDeviceDescription.xml': No such file or directory (2)
Message par Doudy »
J'ai le même soucis mais je ne trouve pas de solution !
Merci de m'éclairer un peu.
2017-08-30 01:43:59.429 Error: Webserver: File '/BasicDeviceDescription.xml': No such file or directory (2)
2017-08-30 01:53:15.584 Error: Webserver: File '/BasicDeviceDescription.xml': No such file or directory (2)
2017-08-30 03:08:46.595 Error: Webserver: File '/BasicDeviceDescription.xml': No such file or directory (2)
2017-08-30 03:32:37.645 Error: Webserver: File '/BasicDeviceDescription.xml': No such file or directory (2)
2017-08-30 04:04:54.212 Error: Webserver: File '/BasicDeviceDescription.xml': No such file or directory (2)
2017-08-30 04:27:44.375 Error: Webserver: File '/BasicDeviceDescription.xml': No such file or directory (2)
2017-08-30 04:40:17.818 Error: Webserver: File '/BasicDeviceDescription.xml': No such file or directory (2)
2017-08-30 05:05:09.732 Error: Webserver: File '/BasicDeviceDescription.xml': No such file or directory (2)
2017-08-30 05:23:22.737 Error: Webserver: File '/BasicDeviceDescription.xml': No such file or directory (2)
2017-08-30 05:44:51.945 Error: Webserver: File '/BasicDeviceDescription.xml': No such file or directory (2)
2017-08-30 05:57:40.318 Error: Webserver: File '/BasicDeviceDescription.xml': No such file or directory (2)
2017-08-30 06:10:07.285 Error: Webserver: File '/BasicDeviceDescription.xml': No such file or directory (2)
2017-08-30 06:20:02.778 Error: Webserver: File '/BasicDeviceDescription.xml': No such file or directory (2)
2017-08-30 06:53:30.018 Error: Webserver: File '/BasicDeviceDescription.xml': No such file or directory (2)
2017-08-30 07:37:25.230 Error: Webserver: File '/BasicDeviceDescription.xml': No such file or directory (2)
2017-08-30 08:56:32.223 Error: Webserver: File '/BasicDeviceDescription.xml': No such file or directory (2)
DumpDos
Message par DumpDos »
Tu as ouvert un accès vers l'extèrieur sur ton DZ ?
Si oui essaye de passer sur un autre port, le 443 par exemple (HTTPS).
Sinon, il s'agit d'un problème interne...
Raspberry Pi 2 - Domoticz bêta- Custom Page - RfxTrx433E - MySensors - Z-Stick Gen 5
6 x DIO 54795 - 4 x DIO 54781 - 2 x Home Confort ECR-100 - 4 X THGR122NX - 1 X OWL Micro+
2 X RGB - 3D - 2 X Switch - 1 X Ir Rx-Tx
1 X Fibaro FGMS-001
Doudy
Message par Doudy »
DumpDos a écrit :Bonjour,
Pas ouvert de port
Qu'est ce tu entends par " Problème interne" ?
Lorsque je fais un dmesg | grep -e "RFX\|tty"
J'obtiens ceci :
Je ne comprends pas.
D'un côté
ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnected from ttyUSB0
et ensuite
usb 1-1.4.2: FTDI USB Serial Device converter now attached to ttyUSB0
Connecté ou pas connecté ?
:shock: :oops:
DumpDos
D'accord,
J'avais des messages d'erreur très similaires lorsque mon port était ouvert au publique, mais ton problème ne semble pas venir d'ici.
Je pense ici que le problème vient :
  • Soit du réseau local, un dispositif qui chercherai à contacter ton serveur domoticz. J'ai eu le problème avec un Bridge Phillips Hue
  • Soit un problème interne à domoticz... Mais lequel ? Ça, je n'en ai pas la moindre idée.. :?
Es-tu allé faire un tour sur le forum officiel ?
Déconnecté je pense.
De mon coté avec mon RFX, j’obtiens ceci :
1 X Fibaro FGMS-001
