RFLink et relais 433Mhz AG-C101
flatsix33
Message par flatsix33 »
j'ai acheté sur ebay ce relais chinois 433 Mhz pour commander une électrovanne d'arrosage.
Ce relais peut fonctionner de différentes manières;
soit avec les 2 boutons, ON pour actionner le relais et OFF pour l'éteindre, soit avec le seul bouton OFF une impulsion pour activer une autre pour désactiver et enfin de manière impulsionnelle avec le bouton OFF.
Le fonctionnement avec la télécommande livrée, donne dans RFLink Loader les fichiers DEBUG suivants pour le fonctionnement avec les 2 boutons:
appuie sur ON:
20;B8;DEBUG;Pulses=44;Pulses(uSec)=840,90,780,60,210,600,210,600,240,600,210,600,780,90,750,90,750,90,750,90,180,630,210,630,180,630,210,630,210,630,750,90,720,120,180,630,180,660,720,120,150,660,180,6990;
20;B9;DEBUG;Pulses=50;Pulses(uSec)=750,120,180,630,210,630,720,120,720,120,180,660,180,660,180,660,180,630,720,120,720,120,720,120,690,150,180,660,180,660,180,660,180,660,180,660,690,150,690,150,150,660,180,660,690,150,150,660,180,6990;
20;BA;Eurodomest;ID=06787c;SWITCH=06;CMD=ALLON;
20;BB;DEBUG;Pulses=50;Pulses(uSec)=810,120,210,630,180,630,720,120,720,120,180,630,180,630,180,660,180,660,720,120,720,120,690,150,690,150,180,660,180,660,180,660,180,660,180,660,690,150,690,150,180,660,180,660,690,150,180,660,180,6990;
appuie sur OFF:
20;7D;DEBUG;Pulses=52;Pulses(uSec)=30,360,780,30,240,570,240,570,780,60,780,60,240,600,240,600,240,600,210,600,750,90,750,90,720,90,720,120,180,630,210,630,210,630,210,630,210,630,720,120,720,120,180,630,180,630,180,630,720,120,180,6990;
20;7E;DEBUG;Pulses=50;Pulses(uSec)=750,120,180,600,180,600,660,120,660,120,180,600,180,630,180,660,180,660,690,150,690,150,690,150,690,150,180,660,180,660,180,660,180,660,180,660,690,150,690,150,150,660,180,660,180,660,690,150,150,6990;
20;7F;Eurodomest;ID=06787c;SWITCH=07;CMD=ALLOFF;
20;80;DEBUG;Pulses=50;Pulses(uSec)=780,120,180,630,180,660,720,120,690,120,180,660,180,660,180,660,180,660,690,150,690,150,690,150,690,150,180,660,180,660,180,660,180,660,180,660,690,150,690,150,150,660,150,660,150,660,690,150,150,6990;
20;81;DEBUG;Pulses=48;Pulses(uSec)=750,120,180,600,180,600,660,120,660,120,150,630,150,630,180,660,180,660,690,150,690,150,690,150,690,150,180,660,180,660,180,660,150,660,150,660,690,150,690,150,150,660,150,660,150,660,240,6990;
Jusque là pas de souci, mais lorsque j'utilise dans RFLink Loader l'envoi des commandes suivantes:
10;Eurodomest;06787c;06;ALLON;
10;Eurodomest;06787c;07;ALLOFF;
seule la commande ALLON active le relais, la commande ALLOFF reste sans effet (par ailleurs, quelque soit les différents fonctionnements avec 1 ou 2 boutons, seule la commande On est réactive)
J'utilise RFLink Gateway Ver:1.1, Rev:46, Build:0c avec Domoticz sous PI 1
Les interrupteurs sont bien reconnus dans Domoticz.
Cependant dans un premier temps je voudrais faire fonctionner ce relais avec RFLink Loader avant de l'intégrer à Domoticz.
Si quelqu'un a une idée je suis preneur, j'en perds mon chinois...
