[RESOLU] Xiaomi vaccum
ebretteville
Message par ebretteville »
Voilà après avoir suivi le tuto suivant et les liens inclus: https://github.com/mrin/domoticz-mirobot-plugin + https://github.com/rytilahti/python-miio et là
Je n'arrive toujours pas à déclencher ou voir mon aspirateur.
Voilà les logs:
 2017-10-03 08:59:28.501 New sensors allowed for 5 minutes...
2017-10-03 08:59:29.870 Error: (nono) Response mirobo-wrapper exception:
2017-10-03 08:59:29.870 CConnection_connect, connect request from 'onHeartbeat' ignored. Plugin is stopping.
2017-10-03 08:59:31.462 RFLink: 20;39;Alecto V4;ID=5a9a;TEMP=00b9;HUM=80;
2017-10-03 08:59:31.630 (RFLink) Temp + Humidity (Escalier Cave)
2017-10-03 08:59:45.513 RFLink: 20;3A;Alecto V4;ID=5ae9;TEMP=00c7;HUM=72;
2017-10-03 08:59:45.680 (RFLink) Temp + Humidity (Etage)
2017-10-03 08:59:52.621 Error: (nono) Response mirobo-wrapper exception:
2017-10-03 08:59:52.621 CConnection_connect, connect request from 'onHeartbeat' ignored. Plugin is stopping.
2017-10-03 08:59:52.621 Error: PluginSystem: Exception processing message.
2017-10-03 08:59:52.622 Error: PluginSystem: Exception processing message.
2017-10-03 08:59:52.622 CConnection_connect, connect request from 'onHeartbeat' ignored. Plugin is stopping.
2017-10-03 09:00:01.379 Starting automatic database backup procedure...
2017-10-03 09:00:06.463 RFLink: 20;3B;Alecto V4;ID=5a9a;TEMP=00b9;HUM=80;
2017-10-03 09:00:16.103 Error: (nono) Response mirobo-wrapper exception:
2017-10-03 09:00:16.103 CConnection_connect, connect request from 'onHeartbeat' ignored. Plugin is stopping.
2017-10-03 09:00:20.516 RFLink: 20;3C;Alecto V4;ID=5ae9;TEMP=00c7;HUM=72;
2017-10-03 09:00:25.983 Ending automatic database backup procedure...
2017-10-03 09:00:25.995 Error: EventSystem: in YeeLIght Desk: [string "--Temp Blanc Lamp Bureau yeelight..."]:7: attempt to index global 'devicechanged' (a nil value)
2017-10-03 09:00:26.221 (RFLink) Temp + Humidity (Escalier Cave)
2017-10-03 09:00:26.385 (RFLink) Temp + Humidity (Etage)
2017-10-03 09:00:38.798 Error: (nono) Response mirobo-wrapper exception:
2017-10-03 09:00:38.799 Error: PluginSystem: Exception processing message.
2017-10-03 09:00:38.799 (onHeartbeat) Failed to connect to IKEA tradfri COAP-adapter! Status: 111 Description: Connection refused
2017-10-03 09:00:38.799 CConnection_connect, connect request from 'onHeartbeat' ignored. Plugin is stopping.
2017-10-03 09:00:38.800 CConnection_connect, connect request from 'onHeartbeat' ignored. Plugin is stopping.
2017-10-03 09:00:41.465 RFLink: 20;3D;Alecto V4;ID=5a9a;TEMP=00b9;HUM=80;
2017-10-03 09:00:41.654 (RFLink) Temp + Humidity (Escalier Cave)
Le retour de la commande ssh suivante:
Last login: Tue Oct 3 08:18:55 2017 from 185.189.113.40
pi@domoticz-tours:~ $ mirobo
You have to give ip and token!
Et pourtant token et ip sont spécifiés pour moi cf capture d'écran:
Ma compagne a baptisé le xiaomi vacuum nono d'où les interrupteurs...
Merci à vous
Dernière modification par ebretteville le 03 oct. 2017, 19:55, modifié 1 fois.
Re: Xiaomi vaccum
Ok on va reprendre depuis le debut :
Pour que cela fonctionne chez moi :
J'ai installer cette librairie : https://github.com/rytilahti/python-miio
apt-get install libffi-dev libssl-dev
pip3 install python-miio
pip3 install -U pip setuptools
Ensuite pour tester sans passer par Domoticz il faut "enregistrer des variables pour mirobo"
export MIROBO_IP=ipdetonrobotaspi
export MIROBO_TOKEN=tokenquetuasrecuperer de ton application
Une fois fait test avec la commande
mirobo
Elle doit te donner quelque chose comme cela :
nico@maison:~$ mirobo
State: Cleaning
Battery: 97 %
Fanspeed: 90 %
Cleaning since: 0:04:53
Cleaned area: 7.275 m²
ebretteville
Re: Xiaomi vaccum
Eh ben en fait mon token doit pas être le bon...:
Usage: mirobo [OPTIONS] COMMAND [ARGS]...
Error: Invalid value for "--token": Token length != 32 chars: 96
Re: Xiaomi vaccum
ebretteville a écrit :Eh ben en fait mon token doit pas être le bon...:
Chez moi le token fait 32 caracteres
ebretteville
Re: Xiaomi vaccum
Ben oui, pourtant je l'ai pris avec la méthode de lecture de la base de donnée sqlite sur ipad et appli mihome, je vais voir dans mon token sui fait 96 si il n'y a pas 3 chapines de caractères qui se répètent...
ebretteville
Re: Xiaomi vaccum
J'ai pourtant utilisé ce tuto (dernier point, iOS non jailbreaké): https://github.com/jghaanstra/com.xiaom ... bot_new.md
Qui m'a donné ce token.
Bizarre...
Re: Xiaomi vaccum
ebretteville a écrit :J'ai pourtant utilisé ce tuto (dernier point, iOS non jailbreaké): https://github.com/jghaanstra/com.xiaom ... bot_new.md
Bizarre...
Justement sur le tuto que tu donnes il y a bien ecrit que le token doit faire 32 caracteres...perso je ne fais pas de query bidule machin , je navigue direct dans la base sql avec sql browser
base sql robot.PNG (88.62 Kio) Consulté 10729 fois
ebretteville
Re: Xiaomi vaccum
Je viens de voir aussi le coup du 32 que j'avais du lire mais je tenterai sans le query truc ;-)
EN revanche le fichier est à lamaison, je testerai ce soir, en ts cas, merci pour l'aide. To be continued tonight ;-)
Trax
Re: Xiaomi vaccum
Message par Trax »
J'ai eu le meme probleme ( 96 char ), je suis tombé sur un post qui m'a aider :
https://www.jeedom.com/forum/viewtopic. ... 20#p514930
c'est sur jeedom mais bon la technique est la même.
ebretteville
[RESOLU] Re: Xiaomi vaccum
Trax a écrit :J'ai eu le meme probleme ( 96 char ), je suis tombé sur un post qui m'a aider :
MERCI A TOI Trax, cela a fonctionné! Je ne sais comment te remercier!
Merci à toi aussi deennoo de ne pas avoir lâché et pris ma demande d'aide.
Je marques le sujet résolu.
