je viens d'avoir un plantage de domoticz. Plus de devices, obligé de redémarrer le service.
Dans les logs j'ai :
2017-10-22 17:01:54.350 (RFXCom) Temp + Humidity (Bureau)
2017-10-22 17:01:59.273 (RFXCom) Temp + Humidity (S.d.Bain)
2017-10-22 17:02:00.148 Error: Domoticz received fatal signal 6 !...
2017-10-22 17:02:00.149 (RFXCom) Temp + Humidity (Ch.)
2017-10-22 17:02:00.266 Error: /home/pi/domoticz/domoticz() [0x1cdc48]
2017-10-22 17:02:00.266 Error: /home/pi/domoticz/domoticz(_Z14signal_handleri+0x58) [0x1cdd00]
2017-10-22 17:02:00.266 Error: /lib/arm-linux-gnueabihf/libc.so.6(__default_sa_restorer_v2+0) [0x76add180]
2017-10-22 17:02:00.266 Error: /lib/arm-linux-gnueabihf/libc.so.6(gsignal+0x38) [0x76adbf70]
2017-10-15 16:48:00.117 Error: Domoticz received fatal signal 6 !...
2017-10-15 16:48:00.188 Error: /home/pi/domoticz/domoticz() [0x1cdc48]
2017-10-15 16:48:00.188 Error: /home/pi/domoticz/domoticz(_Z14signal_handleri+0x58) [0x1cdd00]
2017-10-15 16:48:00.188 Error: /lib/arm-linux-gnueabihf/libc.so.6(__default_sa_restorer_v2+0) [0x76a9d180]
2017-10-15 16:48:00.188 Error: /lib/arm-linux-gnueabihf/libc.so.6(gsignal+0x38) [0x76a9bf70]Les codes erreurs n'étant pas vraiment explicite
Je vous remercie.
Version: 3.8153
Build Hash: 494fff7
Compile Date: 2017-07-30 12:19:41
Rasbian Pixel.
séquence démarrage domoticz:
2017-10-15 19:21:18.995 1Wire: Added Device: 28-000008506620
2017-10-15 19:21:18.995 1Wire: Added Device: 28-00000850a760
2017-10-15 19:21:18.995 1Wire: Added Device: 28-00000850f1c7
2017-10-15 19:21:18.995 1Wire: Added Device: 28-00000850df7f
2017-10-15 19:21:22.588 GPIO: This hardware is deprecated. Please transfer to the new SysFS hardware type!
2017-10-15 19:21:22.600 (Tele-info) Teleinfo device uses serial port: /dev/ttyUSB0 at 1200 bauds
2017-10-15 19:21:22.604 (Tele-info) CRC checks will be performed on incoming data
2017-10-15 19:21:22.605 DarkSky: Started...
2017-10-15 19:21:22.605 EventSystem: reset all events...
2017-10-15 19:21:22.607 EventSystem: reset all device statuses...
2017-10-15 19:21:22.611 PluginSystem: Entering work loop.
2017-10-15 19:21:22.793 (Tele-info) Teleinfo CRC check mode set to 1
2017-10-15 19:21:23.009 Python EventSystem: Module not found - Trying to initialize.
2017-10-15 19:21:23.011 Python EventSystem: Initalizing event module.
2017-10-15 19:21:23.012 EventSystem: Started
2017-10-15 19:21:23.624 RFXCOM: Using serial port: /dev/ttyUSB1
2017-10-15 19:21:24.277 subtype = Interface Response
Sequence nbr = 2
response on cmnd = Get Status
Transceiver type = 433.92MHz
Firmware version = 1009
Firmware type = Ext
Hardware version = 1.3
Undec off
X10 enabled
ARC enabled
AC enabled
HomeEasy EU enabled
Meiantech/Atlantic disabled
Oregon Scientific enabled
ATI/Cartelectronic disabled
Visonic disabled
Mertik disabled
AD disabled
Hideki enabled
La Crosse enabled
FS20/Legrand disabled
ProGuard disabled
BlindsT0 disabled
BlindsT1 disabled
AE disabled
RUBiCSON enabled
FineOffset disabled
Lighting4 enabled
Conrad RSL disabled
ByronSX disabled
IMAGINTRONIX disabled
KEELOQ disabled
Home Confort disabled
