es que quelqu'un a un tuto pour faire un vpn via openvpn sur RPi qui a marché pour lui car j'ai pris 15 tuto sur le net et ils ne marchent pas alors que dans les log il n'y a aucune erreurs, je pense que mon problème vient du route.
serveur (rpi):
local 192.168.10.50
#mode server
dev tun
proto udp
port 1194
ca /etc/openvpn/easy-rsa/keys/ca.crt
cert /etc/openvpn/easy-rsa/keys/server.crt
key /etc/openvpn/easy-rsa/keys/server.key
dh /etc/openvpn/easy-rsa/keys/dh1024.pem
cipher AES-128-CBC # algorithme de chiffrement
tls-auth /etc/openvpn/easy-rsa/keys/ta.key 0 # 0 pour le serveur
server 10.8.0.0 255.255.255.0
ifconfig 10.8.0.1 10.8.0.2
push "route 10.8.0.1 255.255.255.255"
push "route 10.8.0.0 255.255.255.0"
push "route 192.168.10.50 255.255.255.0"
push "redirect-gateway def1"
#set the dns servers
#push "dhcp-option DNS 8.8.8.8"
#push "dhcp-option DNS 8.8.4.4"
push "dhcp-option DNS 192.168.10.1"
user nobody
group nogroup
#chroot /etc/openvpn/jail # chroot de openvpn
persist-key
persist-tun
status /var/log/openvpn-status.log
verb 3
mute 20
client-to-client
log-append /var/log/openvpn.log
comp-lzo
duplicate-cn
keepalive 10 120Code : Tout sélectionner
Fri Jun 12 11:45:29 2015 OpenVPN 2.2.1 arm-linux-gnueabihf [SSL] [LZO2] [EPOLL] [PKCS11] [eurephia] [MH] [PF_INET6] [IPv6 payload 20110424-2 (2.2RC2)] built$
Fri Jun 12 11:45:29 2015 NOTE: your local LAN uses the extremely common subnet address 192.168.0.x or 192.168.1.x. Be aware that this might create routing $
Fri Jun 12 11:45:29 2015 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Fri Jun 12 11:45:29 2015 Diffie-Hellman initialized with 1024 bit key
Fri Jun 12 11:45:29 2015 Control Channel Authentication: using '/etc/openvpn/easy-rsa/keys/ta.key' as a OpenVPN static key file
Fri Jun 12 11:45:29 2015 Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Fri Jun 12 11:45:29 2015 Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Fri Jun 12 11:45:30 2015 TLS-Auth MTU parms [ L:18 D:14 EF:8 EB:15 ET:0 EL:250 ]
Fri Jun 12 11:45:30 2015 Socket Buffers: R=[163840->131072] S=[163840->131072]
Fri Jun 12 11:45:30 2015 ROUTE default_gateway=192.168.10.1
Fri Jun 12 11:45:30 2015 TUN/TAP device tun0 opened
Fri Jun 12 11:45:30 2015 TUN/TAP TX queue length set to 100
Fri Jun 12 11:45:30 2015 do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
Fri Jun 12 11:45:30 2015 /sbin/ifconfig tun0 10.8.0.1 pointopoint 10.8.0.2 mtu 1500
Fri Jun 12 11:45:30 2015 /sbin/route add -net 10.8.0.0 netmask 255.255.255.0 gw 10.8.0.2
Fri Jun 12 11:45:30 2015 Data Channel MTU parms [ L:18 D:14 EF:8 EB:15 ET:0 EL:250 AF:13/1 ]
Fri Jun 12 11:45:30 2015 GID set to nogroup
Fri Jun 12 11:45:30 2015 UID set to nobody
Fri Jun 12 11:45:30 2015 UDPv4 link local (bound): [AF_INET]192.168.10.50:1194
Fri Jun 12 11:45:30 2015 UDPv4 link remote: [undef]
Fri Jun 12 11:45:30 2015 MULTI: multi_init called, r=256 v=256
Fri Jun 12 11:45:30 2015 IFCONFIG POOL: base=10.8.0.4 size=62, ipv6=0
Fri Jun 12 11:45:30 2015 Initialization Sequence CompletedCode : Tout sélectionner
#!/bin/sh
#iptables -t nat -A POSTROUTING -s 10.8.0.0/24 -o eth0 -j SNAT --to-source 192.168.10.50
IPT="/sbin/iptables"
# Flush old rules, old custom tables
$IPT --flush
$IPT --delete-chain
# Set default policies for all three default chains
$IPT -P INPUT DROP
$IPT -P FORWARD DROP
$IPT -P OUTPUT DROP
# Enable free use of loopback interfaces
$IPT -A INPUT -i lo -j ACCEPT
$IPT -A OUTPUT -o lo -j ACCEPT
# Accept inbound TCP packets
$IPT -A INPUT -m state --state ESTABLISHED,RELATED -j ACCEPT
# Accept inbound UDP packets for OPENVPN
$IPT -A INPUT -p udp --dport 1194 -j ACCEPT
# Accept all trafic from LAN
$IPT -A INPUT -p udp -s 192.168.1.0/24 -j ACCEPT
$IPT -A INPUT -p tcp -s 192.168.1.0/24 -j ACCEPT
# Accept all trafic from VPN
$IPT -A INPUT -p udp -s 10.8.0.0/24 -j ACCEPT
$IPT -A INPUT -p tcp -s 10.8.0.0/24 -j ACCEPT
#Autoriser toutes les sorties
$IPT -A OUTPUT -p tcp -j ACCEPT
$IPT -A OUTPUT -p udp -j ACCEPT
#Accept openvpn connections
$IPT -t nat -A INPUT -i eth0 -p udp -m udp --dport 1194 -j ACCEPT
# Allow TUN interface connections to OpenVPN server
$IPT -A INPUT -i tun+ -j ACCEPT
$IPT -A FORWARD -m state --state RELATED,ESTABLISHED -j ACCEPT
$IPT -A FORWARD -s 10.8.0.0/24 -j ACCEPT
$IPT -A FORWARD -j REJECT
$IPT -t nat -A POSTROUTING -s 10.8.0.0/24 -o eth0 -j MASQUERADE
echo 1 > /proc/sys/net/ipv4/ip_forwardCode : Tout sélectionner
client
dev tun
proto udp
remote REMOTE 1194
resolv-retry infinite
nobind
persist-key
persist-tun
mute-replay-warnings
ns-cert-type server
key-direction 1
ca "C:\\Program Files\\OpenVPN\\config\\ca.crt"
cert "C:\\Program Files\\OpenVPN\\config\\client.crt"
key "C:\\Program Files\\OpenVPN\\config\\client.key"
tls-auth "C:\\Program Files\\OpenVPN\\config\\ta.key" 1 #1 pour le client
cipher AES-128-CBC
comp-lzo
verb 3
mute 20Code : Tout sélectionner
Fri Jun 12 13:01:33 2015 OpenVPN 2.3.6 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [PKCS11] [IPv6] built on Mar 4 2015
Fri Jun 12 13:01:33 2015 library versions: OpenSSL 1.0.1l 15 Jan 2015, LZO 2.08
Fri Jun 12 13:01:33 2015 MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:25340
Fri Jun 12 13:01:33 2015 Need hold release from management interface, waiting...
Fri Jun 12 13:01:33 2015 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:25340
Fri Jun 12 13:01:33 2015 MANAGEMENT: CMD 'state on'
Fri Jun 12 13:01:33 2015 MANAGEMENT: CMD 'log all on'
Fri Jun 12 13:01:33 2015 MANAGEMENT: CMD 'hold off'
Fri Jun 12 13:01:33 2015 MANAGEMENT: CMD 'hold release'
Fri Jun 12 13:01:34 2015 Control Channel Authentication: using 'C:\Program Files\OpenVPN\config\ta.key' as a OpenVPN static key file
Fri Jun 12 13:01:34 2015 Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Fri Jun 12 13:01:34 2015 Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Fri Jun 12 13:01:34 2015 Socket Buffers: R=[8192->8192] S=[8192->8192]
Fri Jun 12 13:01:34 2015 MANAGEMENT: >STATE:14341894,RESOLVE,,,
Fri Jun 12 13:01:34 2015 UDPv4 link local: [undef]
Fri Jun 12 13:01:34 2015 UDPv4 link remote: [AF_INET]REMOTE:1194
Fri Jun 12 13:01:34 2015 MANAGEMENT: >STATE:14341894,WAIT,,,
Fri Jun 12 13:02:34 2015 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Jun 12 13:02:34 2015 TLS Error: TLS handshake failed
Fri Jun 12 13:02:34 2015 SIGUSR1[soft,tls-error] received, process restarting
Fri Jun 12 13:02:34 2015 MANAGEMENT: >STATE:14341894,RECONNECTING,tls-error,,
Fri Jun 12 13:02:34 2015 Restart pause, 2 second(s)
Fri Jun 12 13:02:36 2015 Socket Buffers: R=[8192->8192] S=[8192->8192]
Fri Jun 12 13:02:36 2015 MANAGEMENT: >STATE:14341894,RESOLVE,,,
Fri Jun 12 13:02:36 2015 UDPv4 link local: [undef]
Fri Jun 12 13:02:36 2015 UDPv4 link remote: [AF_INET]REMOTE:1194
Fri Jun 12 13:02:36 2015 MANAGEMENT: >STATE:1434107456,WAIT,,,je sais pas pour ca ne marche pas ??????
