LUA:Probleme variation aleatoire lampe HUE
MisterT
Message par MisterT »
Salut
Je rencontre un probleme par rapport a mon script lua concernant le changement toutes les 5 minutes de la couleur de ma lampe hue go. Le script fonctionnait parfaitement mais depuis 1 semaine je n'ai plus de variation de couleur et je ne comprends pas. L'info renvoyée dans les logs de domoticz est:
2018-09-06 22:05:00.158 Status: EventSystem: Fetching url http://1xx.xxx.x.xx:xxxx/json.htm?type=command&param=setcolbrightnessvalue&idx=215&hue=45525&brightness=128&iswhite=false...
2018-09-06 22:05:00.158 Status: EventSystem: Script event triggered: /home/pi/domoticz/scripts/lua/script_time_hue.lua
2018-09-06 22:05:00.382 Status: setcolbrightnessvalue: ID: d7, bri: 100, color: '{m: 3, RGB: ff0000, CWWW: 0000, CT: 0}'
La valeur hue varie bien, la valeur brightness aussi mais la valeur setcolbrightnessvalue est toujours la mème :
mon script ci dessous
-- script_time_variation_hue.lua
t1 = os.date("*t")
print(t1) -- Initialise le seed
math.randomseed(os.time())
huename = "Lampe ambiance"
    minutesnow = t1.min + t1.hour * 60
   -- test for t1 > sunset
  if (minutesnow > timeofday['SunsetInMinutes']) then
        if (t1.min%5 == 0 and (otherdevices['Playstation 4 Etat'] == 'On' or otherdevices['Freebox player Etat'] == 'On')) then
          local brightness = math.random(128, 255)
          iswhite = "false"
          local hue = math.random(1, 65535)
          idx = otherdevices_idx[huename] -- name lamp
          url = 'http://192.168.1.37:8085/json.htm?type=command&param=setcolbrightnessvalue&idx=' .. idx .. '&hue=' .. hue .. '&brightness=' .. brightness ..'&iswhite=' .. iswhite
          commandArray['OpenURL']= url
       elseif (otherdevices['Playstation 4 Etat'] == 'On' or otherdevices['Freebox player Etat'] == 'On') then
         commandArray['le salon'] = 'Off'
         commandArray['Lampe ambiance'] = 'On'
  if (otherdevices['Television Etat'] == 'Off') then
        commandArray['Lampe ambiance'] = 'Off'
  if (otherdevices['HTPC Etat'] == 'On' and otherdevices['Kodi Salon'] == 'Paused') then
  if (otherdevices['HTPC Etat'] == 'On') then
mon pont hue est bien paramétré dans matériel et je peux modifier via l'interrupteur la couleur de la lampe. J'ai redémarré le pont et reinit usine mais rien
Avez vous une idée?
Avez vous
