[Bash] Récupérer les informations de consommation des sites de la lyonnaise des eaux
atlantis007
Message par atlantis007 »
bonjour j ai un petit souci avec un script qui peut me permettre de récupéré les données de mon compteur d eau
le script vient de se site http://domotique.web2diz.net/?p=166
# This script will get the data from SDEI/SOGEST website and insert into domoticz.db
# Site    : http://domotique.web2diz.net/
# Detail  : http://domotique.web2diz.net/?p=131
# List of working provider : http://domotique.web2diz.net/?p=320
# Source  : https://github.com/Sirus10/domoticz/blob/master/updateConsoEau.sh
# License : CC BY-SA 4.0
#  Usage:
#  ./updateConsoEau.sh [year] [month]
#  PART 0 Common variables
# Temp set global C local
LC_ALL=C
# Date setup (if not set = today)
if [ "$1" != '' ] && [ "$2" != '' ] && [[ "$1" == +([0-9]) ]] && [[ "$2" == +([0-9]) ]]
then
  dateY=$1
  dateM=$2
  dateY=`date "+%Y"`
  dateM=`date "+%m"`
fi
# SQL Files setup for temporary and final file
workingDIR=/home/pi/EAU
sqlfinalfile=$workingDIR/only_new_generated.$dateY-$dateM.sql
sqlpreviousfile=$workingDIR/previous.generated.$dateY-$dateM.sql
sqltmpfile=$workingDIR/temps.generated.$dateY-$dateM.sql
# SDEI PERSONAL CODE ( see http://domotique.web2diz.net/?p=137)
SDEI_CODE=[b]xxxxxxxx[/b]              # put your code here      ex:  SDEI_CODE=PLOLKIKU
SDEI_EMAIL=[b]xxxxxxx [/b]            # put your email here     ex:  SDEI_EMAIL=toto@tata.com
SDEI_PASSWD=[b]xxxxxxxxxx[/b]            # put your password here  ex:  SDEI_PASSWD=totolabrico42
# Set your provider comment/uncomment if needed (default = SDEI)
PROVIDER=SDEI
#PROVIDER=SOGEST
#PROVIDER=SENART
# Your virtual device ID in domoticz (see step2 here http://domotique.web2diz.net/?p=138 )
devicerowid=[b]xxxxxxx[/b]            #  put your devices idx here   ex : devicerowid=123
# Database file setup
dbfile=/home/pi/domoticz/domoticz.db
#  PART 1 get the data
echo -e "\n - PART 1 Get the data from website for $dateY-$dateM"
if [[ $PROVIDER == 'SDEI' ]]
then
	loginpage="https://www.lyonnaise-des-eaux.fr/mon-compte-en-ligne/connexion/validation"
	datapage="https://www.lyonnaise-des-eaux.fr/mon-compte-en-ligne/statJData/$dateY/$dateM/$SDEI_CODE"
elif [[ $PROVIDER == 'SOGEST' ]]
then
	loginpage="https://www.sogest.info/mon-compte-en-ligne/connexion/validation"
	datapage="https://www.sogest.info/mon-compte-en-ligne/statJData/$dateY/$dateM/$SDEI_CODE"
elif [[ $PROVIDER == 'SENART' ]]
then
loginpage="https://www.eauxdesenart.com/mon-compte-en-ligne/connexion/validation"
datapage="https://www.eauxdesenart.com/mon-compte-en-ligne/statJData/$dateY/$dateM/$SDEI_CODE"
fi
export_file=$workingDIR/$dateY-$dateM.dat
# This first cmd will allow to connect to the site and get the cookiefile
curl -s $loginpage -c $workingDIR/cookiefile -d "input_mail=$SDEI_EMAIL&input_password=$SDEI_PASSWD" > /dev/null
# This second cmd will download the data
curl -s $datapage -b $workingDIR/cookiefile > $export_file
echo -e "\n $export_file  generated "
# Remove cookiefiles
rm $workingDIR/cookiefile
#  PART 2 set the file to be usable
echo -e "\n - PART 2 Update .dat file  "
sed -e 's/\\//g' $export_file > file1
sed -e 's/\],\[/\n/g' file1 > file2
sed -e 's/\[\[/\n/g' file2 > file3
sed -e 's/\"//g' file3  |grep -v ",0,0" |grep -e '^$' -v |grep -v ERR  > $export_file
rm file1 file2 file3
echo -e "\n $export_file  Updated "
#  PART 3 Generate SQL
echo -e "\n - PART 3 Generate SQL"
# create the previous file is does not exits
if [ ! -f "$sqlpreviousfile" ] ; then touch $sqlpreviousfile ; fi
IFS=,
while read date val val2 ; do
#### DATE ####
 dd=`echo $date |awk -F/ '{print $1}'`
 mm=`echo $date |awk -F/ '{print $2}'`
 yy=`echo $date |awk -F/ '{print $3}'`
 hh=`date +%H:%M:%S`
#### VAL1  ####
val1=$(( $val * 100))
if [[ $val -eq 0 ]];
then
          float val1=$((100 * ($val2-$prevVal2)))
fi
prevVal2=$val2
### Generation  ###
echo  "DELETE FROM \`Meter_Calendar\` WHERE devicerowid=$devicerowid and date = '$yy-$mm-$dd'; INSERT INTO \`Meter_Calendar\` VALUES ('$devicerowid'," \'$val1\', \'$val2\', \'$yy-$mm-$dd\' ");" >> $sqltmpfile
done < $export_file
# GENERATE SQL FOR UPDATE DEVICE STATUS
DEVICESTATUS1="update DeviceStatus set lastupdate = '$yy-$mm-$dd $hh' where id = $devicerowid;"
###  prepare  and compare fromm previous run  ####
comm -3 $sqltmpfile $sqlpreviousfile > $sqlfinalfile
cat $sqlfinalfile
echo $DEVICESTATUS1
mv $sqltmpfile $sqlpreviousfile
#  PART 4 Update the db
#exit
echo -e "\n - PART 4 Update the db  "
if [ -s $sqlfinalfile ]
then
   echo -e "\nFile size is NOT zero ->  DB update needed"
   echo " Stoping Domoticz ! "
   sudo /etc/init.d/domoticz.sh stop
   echo " Domoticz stopped"
        echo Update DB START
        echo Update Values
        sudo cat $sqlfinalfile |sqlite3  $dbfile
        echo Update Status
        sudo echo $DEVICESTATUS1 |sqlite3  $dbfile
        echo Update DB END
    echo " Starting Domoticz !"
    sudo /etc/init.d/domoticz.sh start
    echo " Domoticz started "
   echo -e "\nFile size is zero -> DB update NOT needed"
fi
echo -e "\n ### END ###\n"
voici le message d erreur
/home/pi/EAU/updateConsoEau.sh: line 128: 0.306 * 100: syntax error: invalid arithmetic operator (error token is ".306 * 100")
comm: /home/pi/EAU/temps.generated.2015-09.sql: No such file or directory
update DeviceStatus set lastupdate = '2015-09-01 20:50:03' where id = 888;
mv: cannot stat `/home/pi/EAU/temps.generated.2015-09.sql': No such file or directory
 ### END ###
si quelqu'un une solution a mon problème :idea: je récupère bien les data sur le site de la lyonnaise des eau que c est la génération :? du sql qui va pas
merci d avence
Re: Récupérer les informations de consommation des sites de la lyonnaise des eaux
