probleme apparaige interrupteur legrand
toto26
Message par toto26 »
J'ai un problème pour appairer l'interrupteur legrand celiane LEG067726 sous domoticz Version: 4.10354 (beta), plugin zigate Version 4.0.7 (stable, firmware v3.0f :
2019-02-20 12:54:31.031 Status: (zigate) Started.
2019-02-20 12:54:31.346 Status: (zigate) Entering work loop.
2019-02-20 12:54:31.346 Status: (zigate) Initialized version 4.0.7, author 'zaraki673 pipiche38'
2019-02-20 12:54:31.348 Status: (zigate) onStart called - Zigate plugin V 4.0.7
2019-02-20 12:54:31.349 Status: (zigate) load PluginConf
2019-02-20 12:54:31.349 Status: (zigate) ZigateMode: ZigBee sendDelay: 0 reTransmit: 1 zTimeOut: 2
2019-02-20 12:54:31.349 Status: (zigate) logFORMAT: 0 logLQI: 0 allowRemoveZigateDevice: 0
2019-02-20 12:54:31.350 Status: (zigate) allowStoreDiscoveryFrames: 0 forceCreationDevice: 0 networkScan: 0 channel: ['0']
2019-02-20 12:54:31.358 Status: (zigate) load ListOfDevice
2019-02-20 12:54:31.363 Status: (zigate) Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigate/DeviceList-21.txt : 1
2019-02-20 12:54:31.364 Status: (zigate) Connection Name: Zigate, Transport: Serial, Address: /dev/serial/by-id/usb-Prolific_Technology_Inc._USB-Serial_Controller-if00-port0
2019-02-20 12:54:31.366 Status: (zigate) onConnect called
2019-02-20 12:54:31.366 Status: (zigate) ZigateConf - Setting UTC Time to : 1550663671
2019-02-20 12:54:31.367 Status: (zigate) Start network
2019-02-20 12:54:31.367 Status: (zigate) Zigate enter in discover mode for 254 Secs
2019-02-20 12:54:31.468 Status: (zigate) Major Version Num: 0003
2019-02-20 12:54:31.468 Status: (zigate) Installer Version Number: 030f
2019-02-20 12:54:31.570 Status: (zigate) Decode8015 : Number of devices recently active in Zigate = 0
2019-02-20 12:54:31.772 Status: (zigate) Decode8009 : Zigate addresses ieee: 00158d0001eda5ae , short addr: 0000
2019-02-20 12:54:31.772 Status: (zigate) Decode8009 - Network state UP, PANID: ece9 extPANID: 0x0d70cb9e494705be Channel: 11
2019-02-20 12:54:32.075 Status: (zigate) Permit Join is On
2019-02-20 12:54:41.391 (zigate) processListOfDevices - Device: 0ba9 is in Status = 'Left' for 15732HB
2019-02-20 12:54:41.486 (Oregon - Somfy - Chacon) Energy (Conso_electrique)
2019-02-20 12:54:41.391 Error: (zigate) 'onHeartbeat' failed 'TypeError':'not all arguments converted during string formatting'.
2019-02-20 12:54:41.391 Error: (zigate) ----> Line 294 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onHeartbeat
2019-02-20 12:54:41.391 Error: (zigate) ----> Line 243 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onHeartbeat
2019-02-20 12:54:41.391 Error: (zigate) ----> Line 227 in '/home/pi/domoticz/plugins/Domoticz-Zigate/z_heartbeat.py', function processListOfDevices
a l'aide !
Christophe
Re: probleme apparaige interrupteur legrand
Christophe,
J'ai corrigé le problème , qui ne devrait plus se manifester sur la version 4.0.8.
Par contre l'appairage des Devices Legrand Celiane est un peu particulier, je te laisse voir de ce coté https://faire-ca-soi-meme.fr/domotique/ ... mo-zigate/ pour plus d'information
toto26
Merci d'avoir regarder mon problème...
On dirait que l'appairage va un peu plus loin, mais je pense qu'il y a un problème de création du dispositif dans Domoticz...
2019-02-20 16:01:41.097 Status: (Zigate) [0] NEW OBJECT: d395 Ox8043 received Infos
2019-02-20 16:01:41.097 Status: (Zigate) [0] NEW OBJECT: d395 Trying to create Domoticz device(s)
2019-02-20 16:01:46.108 (Zigate) processNotinDBDevices - ready for creation: {'Stack Version': '64', 'ZDeviceID': '0202', 'Model': {}, 'Version': '3', 'Battery': {}, 'ReadAttributes': {'Ep': {'01': {'0000': {'0002': '00', '0004': '00', '0005': '89', '0001': '00', '0007': '00', '0010': '86', '0003': '00'}, '0001': {'0002': '86', '0004': '86', '0021': '86', '0020': '86', '0005': '86', '0001': '86', '0007': '86', '0006': '86', '0000': '86', '0003': '86'}}}}, 'Type': {}, 'NbEp': '1', 'RIA': '0', 'IEEE': '00047400009a2b35', 'Ep': {'01': {'0004': {}, '0005': {}, 'ClusterType': {}, '0102': {}, 'fc01': {}, '0019': {}, '0000': {}, '000f': {}, '0003': {}}}, 'Status': '8043', 'Heartbeat': '9', 'Stamp': {'Time': '2019-02-20 16:01:01', 'MsgType': '8102'}, 'HW Version': '1', 'RSSI': 171, 'MacCapa': '8e', 'ProfileID': '0104', 'SQN': {}, 'App Version': '0'}
2019-02-20 16:01:46.107 Status: (Zigate) [0] NEW OBJECT: d395 Ox8043 received Infos
2019-02-20 16:01:46.107 Status: (Zigate) [0] NEW OBJECT: d395 Trying to create Domoticz device(s)
et cela en boucle...
Christophe
j'viens de t'envoyer un MP
lboue
Message par lboue »
Peut-on savoir si cela fonctionne désormais ?
Cordialement,
lboue a écrit : 27 févr. 2019, 17:45 Bonjour,
Cordialement,
Je laisserais @toto26 commenter, mais a ma connaissance:
- Appairage ok
- On/Off ok
- Pour la partie Level Control et retour d'etat, c'est à tester ..
N'ayant pas de moteur de volet legrand, je ne peu pas avancer aussi vite que je voudrais
@lboue,
Pas de possibilité de commande de Level ( Lift) sur ce type de volet. Il semble que ce ne soit pas supporté
https://github.com/fairecasoimeme/ZiGate/issues/125
lboue
Message par lboue »
Pour infos l'application Legrand Home + Control à reçu une mise à jour 1.4.05 :
1.4.05 mars 2019
La fonctionnalité sur l’état des volants roulants a été enrichie. Vous pouvez à présent visualiser rapidement et facilement l’état de vos volets roulants (ouvert, fermé, entrouvert) dans votre App Home + Control. D’autres améliorations ont été apportées pour vous offrir la meilleure expérience possible.
Je ne sais pas si les modules seront mis à jour aussi.
Cordialement,
lboue a écrit : 05 mars 2019, 20:43 Pour infos l'application Legrand Home + Control à reçu une mise à jour 1.4.05 :
1.4.05 mars 2019
Cordialement,
C'est le problème potentiel avec Legrand. Sur la prise encastrée celian, la prise de base ne fait que On/Off alors que tous les clusters y sont. Il faut l'associer à leur passerelle faire un firmware upgrade et hop tu as la consommation ...
C'est de bonne guerre ... mais bon ... SI ils veulent rester dans un monde fermé ...
lboue
Message par lboue »
C'est sur c'est contraignant. Et je trouve que le prix a augmenté par rapport au lancement.
