Mot de passe domoticz
PatriceN
Message par PatriceN »
Domoticz me demande mon mot de passe et évidemment je ne le connais pas.
En parcourant des forums, j'ai trouvé la commande ./domoticz -nowwpwd, mais les choses se compliquent à ce moment là, il semblerait que domoticz ne veuille pas démarrer dans ce mode alors qu'il semble démarrer en mode normal.
Des avis, conseils ?
Merci !
"pi@raspberrypi:~/domoticz $ sudo service domoticz.sh stop
pi@raspberrypi:~/domoticz $ ./domoticz -nowwwpwd
2019-02-26 08:18:25.922 Status: Domoticz V4.10456 (c)2012-2019 GizMoCuz
2019-02-26 08:18:25.922 Status: Build Hash: a0a439b3, Date: 2019-02-24 13:20:57
2019-02-26 08:18:25.923 Status: Startup Path: /home/pi/domoticz/
2019-02-26 08:18:25.924 Error: Error opening SQLite3 database: unable to open database file
terminate called without an active exception
2019-02-26 08:18:25.924 Error: Domoticz(pid:2542, tid:2542('domoticz')) received fatal signal 6 (Aborted)
2019-02-26 08:18:25.925 Error: siginfo address=0x9ee, address=0xffffffff
2019-02-26 08:18:29.102 Error: Thread 1 (Thread 0x76f89000 (LWP 2542)):
2019-02-26 08:18:29.102 Error: #0 0x76eb24cc in __waitpid (pid=2544, stat_loc=0x7ee3b560, options=0) at ../sysdeps/unix/sysv/linux/waitpid.c:29
2019-02-26 08:18:29.102 Error: #1 0x002c9860 in dumpstack_gdb(bool) ()
2019-02-26 08:18:29.102 Error: #2 0x002c9e4c in signal_handler(int, siginfo_t*, void*) ()
2019-02-26 08:18:29.102 Error: #3
2019-02-26 08:18:29.102 Error: #4 __GI_raise (sig=sig@entry=6) at ../sysdeps/unix/sysv/linux/raise.c:51
2019-02-26 08:18:29.102 Error: #5 0x76c5b824 in __GI_abort () at abort.c:89
2019-02-26 08:18:29.102 Error: #6 0x009fcf0c in __gnu_cxx::__verbose_terminate_handler() ()
2019-02-26 08:18:29.102 Error: #7 0x0095d78c in __cxxabiv1::__terminate(void (*)()) ()
2019-02-26 08:18:29.102 Error: #8 0x0095d800 in std::terminate() ()
2019-02-26 08:18:29.102 Error: #9 0x001e802c in main ()
Abandon
pi@raspberrypi:~/domoticz $ sudo service domoticz.sh start
pi@raspberrypi:~/domoticz $"
Re: Mot de passe domoticz
Re tente avec sudo ;)
