Erreur fonction onstart dans le plugin
je cale sur ceci.
J'ai réinstallé domoticz à partir d'une sauvegarde incomplète après un plantage de carte SD (sic...)
sur ma précédente installation zigate fonctionnait très bien (version antérieure)
Toutes MAJ faites, python 3.5.3 domoticz 4.10717
cette fois , jai ce message dans le log à la relance du plugin:
2019-08-04 14:16:23.827 Status: (ZIGATE) Stop directive received.
2019-08-04 14:16:23.827 Status: (ZIGATE) Exiting work loop.
2019-08-04 14:16:23.839 Status: (ZIGATE) onStop called
2019-08-04 14:16:23.927 Status: (ZIGATE) Stopping threads.
2019-08-04 14:16:23.927 Status: (ZIGATE) Stopped.
2019-08-04 14:16:23.927 Status: (ZIGATE) Started.
2019-08-04 14:16:23.839 Error: (ZIGATE) 'onStop' failed 'AttributeError':''NoneType' object has no attribute 'pluginConf''.
2019-08-04 14:16:23.839 Error: (ZIGATE) ----> Line 790 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onStop
2019-08-04 14:16:23.839 Error: (ZIGATE) ----> Line 344 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onStop
2019-08-04 14:16:23.839 Error: (ZIGATE) ----> Line 119 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Modules/database.py', function WriteDeviceList
2019-08-04 14:16:24.290 (ZIGATE) Debug: 2
2019-08-04 14:16:24.287 Status: (ZIGATE) Entering work loop.
2019-08-04 14:16:24.288 Status: (ZIGATE) Initialized version 4.5, author 'zaraki673 pipiche38'
2019-08-04 14:16:24.290 Status: (ZIGATE) Zigate plugin stable-4.5.1 started
2019-08-04 14:16:24.290 Error: (ZIGATE) 'onStart' failed 'AttributeError':''NoneType' object has no attribute 'pluginConf''.
2019-08-04 14:16:24.290 Error: (ZIGATE) ----> Line 786 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onStart
2019-08-04 14:16:24.290 Error: (ZIGATE) ----> Line 200 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onStart
2019-08-04 14:16:24.290 Error: (ZIGATE) ----> Line 524 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Modules/tools.py', function loggingPlugin
qu'ai je fait de mal ???
merci à tous.
je cale sur ceci.
merci à tous.
Raspberry pi 3, RFXcom :idea: ,Zwave 8-) , Easysensors :oops: Zigbee et Zigate
Re: Erreur fonction onstart dans le plugin
Supprime les caches pythons
__ pycache __ qui sont dans le home du plugin ainsi que Modules et Classes
Si le problème persiste attachés le fichier de log, pas simplement les dernières lignes, car il faut le contexte
J'ai eu le même problème que j'ai résolu en passant le paramètre debug/verbose à la valeur 'aucun' dans la config du plug-in.
@pipiche, je pense qu'il y a un petit bug dans le code. La conf est utilisée avant d'être chargée par le programme en particulier pour vérifier le niveau des logs. Si j'ai le temps je crée un ticket sur github
Effectivement c’est corrigé sur la bêta.
Par contre aucun intérêt de mettre le mode Debug.
Désactives le Debug dans le menu de configuration du Plugin (Domoticz). Il doit etre à sa valeur par defaut: Nonemacaurele a écrit : 04 août 2019, 15:14 Bonjour
je cale sur ceci.
merci à tous.
C'est promis je ne l'utiliserai plus
Merci pour le boulot et la disponibilité.
pas de soucis
